REVISION T
DO NOT
SCALE FROM
THIS PRINT
3.600
CC09X-01-XX
DESIGNED & DIMENSIONED
IN MILLIMETERS
ALL DIMENSIONS ARE REFERENCES
LEAD STYLE
-01
CARRIER SPECIFICATIONS
"A"
PLATING
-T: BRIGHT ACID TIN (FOR EXISTING CUSTOMER ONLY)
-GF: 3μ" FLASH SELECTIVE IN CONTACT AREA,
3μ" GOLD ON TAIL
SUPPLIED
-R: REEL
-M: MINI REEL
"A"
4.35
"H" MAX
(TAB LENGTH)
(SEE TABLE 1, SHT 2)
7.11
"B"
9.01
"B"
"G" MAX
(VESTIGE ALLOWANCE)
2.76
3.81
1.80
FIG 1
1.600±0.020
CC09X-01-XX WITH CARRIER SHOWN
3.600
0.95
1.42 REF
0.05x45
0.05x45
NOTES:
1. PLATED C-309 PARTS TO BE PULLED, PLATING OPTION CONFIRMED, POSITIONED AS SHOWN
ON SAMTEC REEL WITH VIEWPORTS, LABELED CC09R WITH APPROPRIATE PLATING CALLOUT
AND LABEL PLACED AS SHOWN.
2. MAXIMUM No OF SPLICES PER REEL:
-R: 2
-M: 1
3. SPLICES ARE NOT TO BE CONNECTED.
4. NUMBER OF SPLICES TO BE MARKED ON EACH REEL.
5. REELED PARTS TO BE INTERLEAVED WITH PAPER BETWEEN EACH LAYER OF PARTS.
6. ALLOWABLE INTERLEAF SPLICES PER REEL:
-R: 3
-M: 1
7. SECURELY CONNECT INTERLEAF SPLICE.
8. OUTER WRAP SHALL RECEIVE PROTECTIVE REEL BAND SEE TABLE 2.
9. DUE TO PLATING REQUIREMENTS CONTACT SAMPLES MAY BE REMOVED INTERMITTINGLY
FROM THE CARRIER RESULTING IN SMALL GAPS BUT DOES NOT AFFECT FINAL COUNT.
10. QTY PER REEL:
-R: 25,000 +300/-0 PCS
-M: 1,000 - 5,000 +300/-0 PCS
1.21 REF
0.80 REF
R0.13 REF
SECTION "B"-"B"
SECTION "A"-"A"
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN MILLIMETERS.
TOLERANCES ARE:
DECIMALS
MATERIAL:
ANGLES
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
PHOS BRONZE
THICKNESS: 0.100
F:\dwg\sw\exisprod\compnt\contact\CC09X-01-XX.SLDDRW
SHEET SCALE: 19:1
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail: info@SAMTEC.com
code: 55322
DESCRIPTION:
1.00 MM PITCH S1SX CONTACT
DWG. NO.
CC09X-01-XX
BY: SHERRY W 11/3/2011
SHEET 1 OF 2
REVISION T
"C"
"A"
"B"
SCALE 20 : 1
WIRE CRIMP
FIG 2
RECOMMENDED PROCESSING
INSULATION STRIP LENGTH
CARRIER
TO BE ON LABEL SIDE
UNWINDING DIRECTION
REEL (SEE TABLE 2)
"D" 0.25
(OUTSIDE DIAMETER)
"F"±0.062
5.50 REF
LABEL DOWN,
LOGO DOWN
FIG 3
REEL SPECIFICATIONS
"E" 0.25
(HUB DIAMETER)
PROPRIETARY NOTE
SHEET SCALE: 6:1
PHONE: 812-944-6733
FAX: 812-948-5047
code: 55322
DESCRIPTION:
DWG. NO.
CC09X-01-XX
SHEET 2 OF 2
很抱歉,暂时无法提供与“CC09R-01-GF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.08962
- 50+1.06618
- 150+1.05063
- 500+1.03497
