F-215
FLE–110–01–G–DV
FLE–120–01–G–DV
FLE–150–01–G–DV
(1,27 mm) .050"
FLE SERIES
COST EFFECTIVE RELIABLE SOCKET
SPECIFICATIONS
For complete specifications and
recommended PCB layouts
see www.samtec.com?FLE
Insulator Material:
Black Liquid
Crystal Polymer
Contact Material:
Phosphor Bronze
Plating:
Au over 50µ" (1,27 µm) Ni
Current Rating:
2 A per pin
(6 adjacent pins powered)
Operating Temp Range:
-55°C to +125°C
Contact Resistance:
15mΩ
Insertion Depth:
(1,83 mm) .072" to
(4,37 mm) .172" or
pass-through
Insertion Force:
(Single contact only)
1.5 oz (0,42 N)
Normal Force:
100 grams (0,98 N)
Withdrawal Force:
1.5 oz (0,42 N)
Max Cycles:
100+
RoHS Compliant:
Yes
Ideal for
pass-through
applications
Tiger Beam™
contact
Mates with:
FTSH, FTS, FW,
FFMD, FMTP
Surface
Mount
Available with optional
Pick & Place pads
(1,27 mm) .050"
micro pitch
FLE
1
NO. PINS
PER ROW
PLATING
OPTION
01
DV
OPTIONS
Processing:
–A
Lead-Free Solderable:
Yes
SMT Lead Coplanarity:
(0,10 mm) .004" max
–G
02 thru 50
= 10µ" (0,25 µm) Gold
= Alignment Pin
(Metal or plastic at
Samtec discretion)
(3 positions minimum)
RECOGNITIONS
–K
For complete scope
of recognitions see
www.samtec.com/quality
= (4,25 mm) .167" DIA
Polyimide film
Pick & Place Pad
(5 positions minimum)
(6,35)
.250
x
(4,17)
.164
FILE NO: 090871_0_000
No. of Positions x (1,27) .050 + (0,11) .0045
(1,27)
.050
(1,27)
.050
–TR
(4,74)
.187
(3,33)
.131
= Tape & Reel
–P OPTION
(0,51)
.020
BILITY
EL AVAILA
ALSO AVAILABLE
TAPE & RE
(MOQ Required)
• Other platings
Contact Samtec.
–P
= Metal Pick &
Place Pad
(4,55) (4,36)
.179 .172
(4,60)
.181
arges.
No tooling chthe lesser of
der is
or
um
im
pieces.
in
M
antity or 125
a full reel quantity above minimum.
Order any qudesign, manufacture.
In-house turn-around.
Quick
ions
for specificat
Call Samtecring information.
and orde
Note: Some lengths, styles
and options are non-standard,
non-returnable.
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
很抱歉,暂时无法提供与“FLE-146-01-G-DV”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+154.679201+20.02161
