COST-EFFECTIVE
RELIABLE SOCKET 8
G b p s
(1.27 mm) .050" PITCH • FLE SERIES
FLE
Board Mates:
FTSH, FTS, FW
Cable Mates:
FFMD*, FMTP
FLE
-1
NO. PINS
PER ROW
01
02 thru 50
*Note:
Standard FFMD callout will not
mate with FLE, SFMC. Must
use gold plated callouts.
(See drawing on web.)
PLATING
OPTION
–G
DV
OPTION
–A
= 10 µ" (0.25 µm) Gold
= Alignment Pin
(Metal or plastic at
Samtec discretion)
(3 positions minimum)
–K
= (4.25 mm) .167" DIA
Polyimide film
Pick & Place Pad
(5 positions minimum)
SPECIFICATIONS
Insulator Material:
Black Liquid Crystal Polymer
Contact Material:
Phosphor Bronze
Plating:
Au over 50 µ" (1.27 µm) Ni
Current Rating:
2.9 A per pin
(2 pins powered)
Operating Temp Range:
-55 °C to +125 °C
Insertion Depth:
(1.83 mm) .072" to (4.37 mm)
.172" or pass-through
Max Cycles:
100+
–P
= Metal Pick & Place Pad
–TR
= Tape & Reel
–FR
= Full Reel Tape & Reel
(must order maximum
quantity per reel;
contact Samtec for
quantity breaks)
PROCESSING
Lead-Free Solderable:
Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max
1RRI3RVLWLRQV[
ALSO AVAILABLE
Other Plating
(MOQ Required)
—P OPTION
10 YEAR MFG
WITH 30 µ" GOLD
EXTENDED LIFE
PRODUCT
HIGH MATING
CYCLES
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
samtec.com?FLE
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
F-224
很抱歉,暂时无法提供与“FLE-149-01-G-DV-A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 9+103.992809+13.44910
