FSI-140-10-L-D-M-AD
FSI-140-10-L-D-M-AD
    SAMTEC(申泰)
    CONN STACKING 80POS SMD GOLD
FSI-140-10-L-D-M-AD 数据手册
LOW PROFILE AND ELEVATED ONE-PIECE (1.00 mm) .0394" PITCH • FSI SERIES SPECIFICATIONS Insulator Material: Liquid Crystal Polymer Contact Material: BeCu Current Rating: 2.8 A per pin (2 pins powered) Operating Temp Range: -55 °C to +125 °C Plating: Au over 50 µ" (1.27 µm) Ni FSI -1 - BODY HEIGHT 10, 20, 30, 50 - –03 –06 5VVMWVZP[PVUZ_    ROW OPTION - INSERT OPTION –S = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail (Not available with –03 body height) –E Leave blank for no Alignment Pin –AD = Alignment Pin Top & Bottom –D = Double Row   –WT = Weld Tab (Available with –S row option & –06 & –10 body height only) –K –M = 2.00 mm x 0.40 mm screw thread –P = Plastic Pick & Place Pad (5.08 mm) .200" x (12.45 mm) .490" (50 not available with –E) (Not available with –S row option or –03 body height) 5VVMWVZP[PVUZ_  —06 & —10 Contact Detail OTHER OPTION = Polyimide Film Pick & Place Pad (50 position with threaded insert option only) ) Insert Option (10, 20 & 30 pins/row) –TR   = Tape & Reel ( .050" (1.27 mm) Pitch –FR —03—AD Shown Short Version See www.samtec.com?SIBF = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) Insert Option (50 pins/row) Double Row Version —03, —06, —10 (71.20) 2.803 ALSO AVAILABLE MOQ Required BODY HEIGHT No alignment pin Top side alignment pin Bottom side alignment pin Other platings (No. of positions x (1.00) .03937) + (5.00).197 (4.60) .181 F-224 - = #2-56 x 1/16" screw thread See www.samtec.com?SEI Some lengths, styles and options are non-standard, non-returnable. ALIGNMENT OPTION   Low Profile Notes: Applications requiring 40-50 positions without threaded inserts, please contact Samtec Interconnect Processing Group. - Leave blank for Short Version (No screw down inserts or holes) = Single Row (Available with 5, 10 & 20 pins with –AD alignment pin) –L –10 = 10 mm (Short Version) Lead-Free Solderable: Yes SMT Lead Coplanarity: (0.10 mm) .004" max (05-30) (0.15 mm) .006" max (50)* *(.004" stencil solution may be available; contact ipg@samtec.com) Compression Board: Gold Pads required - = 10 µ" (0.25 µm) Gold (–03 only) = 6 mm 05, 10, 20, 30, 50 PLATING OPTION –G = 3 mm (Insert/Screw Option) PROCESSING OTHER SOLUTIONS PINS PER ROW Insert Option (50 pins/row) A B (8.76) .345 –03 (3.00) .118 –06 (6.00) .236 (9.02) .355 –10 (10.00) .394 (9.02) .355 (5.30) .209 —03, —06 & —10 Contact Detail A A Short Version —03—AD Shown Single Row Version —03, —06, —10 –WT Option (—06 & —10 Body only) (No. of positions x (1.00) .03937) + (14.70) .579 Insert Option (10, 20 & 30 pins/row) samtec.com?FSI Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
FSI-140-10-L-D-M-AD
1. 物料型号:文档中提到了多种型号,包括单排和双排版本,以及不同的引脚数量和高度选项,例如-03、-06、-10。
2. 器件简介:连接器采用液晶聚合物作为绝缘材料,BeCu作为接触材料,具有2.8A每针的电流额定值,并且工作温度范围为-55°C至+125°C。
3. 引脚分配:提供了不同引脚数量的选项,如10、20、30、50针每排,以及单排和双排版本。
4. 参数特性:包括金层厚度、无铅可焊性、SMT引脚共面性、压缩板要求等。
5. 功能详解:文档详细描述了连接器的不同选项,如引脚高度、插入选项、对齐选项、其他选项等。
6. 应用信息:提到了某些应用可能需要40-50个位置而不带螺纹插入件,建议联系Samtec Interconnect Processing Group。
7. 封装信息:提供了不同封装选项的详细信息,如引脚间距、高度、对齐销等。
FSI-140-10-L-D-M-AD 价格&库存
很抱歉,暂时无法提供与“FSI-140-10-L-D-M-AD”相匹配的价格&库存,您可以联系我们找货
