SHROUDED .025" SQ
POST IDC HEADERS
(2.54 mm) .100" PITCH • TST/HTST/ZST SERIES
TST/HTST/ZST
Mates:
IDSD, HCSD
SPECIFICATIONS
Insulator Material:
TST, ZST=Black Glass
Filled Polyester
HTST=Natural LCP
Insulation Resistance:
5000 MΩ min
Terminal Material:
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Operating Temp Range:
-55 °C to +125 °C with Gold
-55 °C to +105 °C with Tin
Voltage Rating::
425 VAC/600 VDC
SERIES
-1
TST
NO. PINS
PER ROW
LEAD
STYLE
05, 07, 08, 10,
12, 13, 15, 17,
20, 25, 32, 36
= Cable Strip
HTST
LEAD THROUGHHOLE
STYLE
(A)
–01
(2.92) .115
–02
(4.19) .165
–03
(14.35) .565
= Gold flash
on post,
Matte Tin
on tail
(Not available
on –DV)
(2.54) .100 x No. of Positions + (7.62) .300
MOQ Required
Other platings & sizes
Alignment Pins
Single Row
Locking Leads
Polarized
Surface Mount
(lead style
–01 only)
(HTST only)
–DV
= Pick &
Place Pad
–P
–TR
= Tape & Reel
–FR
= Full Reel
Tape & Reel
(must order max.
quantity per reel;
contact Samtec
for quantity
breaks)
= Double Row
Right-angle
(lead style –04
& –05 only)
–T
(9.27)
.365
—D
—DV
—D—RA
B
LEAD RIGHTSTYLE ANGLE
(B)
(10.16)
.400
(8.89)
.350
A
(11.18) .440
ZST
—DV
(HTST ONLY)
-1
NO. PINS
PER ROW
05, 07, 08, 10,
12, 13, 15, 17,
20, 25, 32, 36
LEAD
STYLE
Specify
LEAD
STYLE
from
chart
(Standard sizes)
PLATING
OPTION
–L
= 10 µ" (0.25 µm)
Gold on post,
Matte Tin on tail
(9.27)
.365
(2.29)
.090
MIN
(2.54)
.100
D
BODY
HEIGHT
C
(OAL)
–04
(3.30) .130
–05
(5.84) .230
–F
= Matte Tin
(8.89)
.350
—D—RA
BODY
HEIGHT
–“XXXX”
= Gold flash on post,
Matte Tin on tail
–T
(2.54) .100 x No. of Positions + (5.08) .200
Note:
Some lengths, styles and
options are non-standard,
non-returnable. ZST is
non-standard, non-returnable.
–D
–D–RA
= Matte Tin
—D
ALSO AVAILABLE
OTHER
OPTION
= Double Row
Surface Mount
(lead style
–01 only)
(HTST only)
= 10 µ"
(0.25 µm)
Gold on post,
Matte Tin
on tail
ROW
OPTION
= Double Row
Through-hole
(lead style –01,
–02 & –03 only)
–L
PROCESSING
Lead–Free Solderable:
HTST=Yes
TST, ZST= No, Lead Wave only
SMT Lead Coplanarity:
(0.10 mm) .004" max (05-15)
(0.15 mm) .006" max (17-36)*
*(.004" stencil solution
may be available; contact
ipg@samtec.com)
PLATING
OPTION
–F
Specify
LEAD
STYLE
from
chart
(Standard sizes)
= High Temp
Cable Strip
= Body Height
LEAD
STYLE
C
(OAL)
MAX BODY
HEIGHT
–01
(16.00) .630
(13.72) .540
–02
(18.54) .730
(16.26) .640
–03
(21.08) .830
(18.80) .740
–04
(23.62) .930
(21.34) .840
–05
(26.16) 1.030
(23.88) .940
–06
(28.70) 1.130
(26.42) 1.040
–07
(31.24) 1.230
(28.96) 1.140
–08
(33.78) 1.330
(31.50) 1.240
–09
(36.32) 1.430
34.04) 1.340
Note:
For added mechanical stability, Samtec
recommends mechanical board spacers
be used in applications with gold or
selective gold plated connectors. Contact
ipg@samtec.com for more information.
samtec.com?TST, samtec.com?HTST or samtec.com?ZST
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
F-224
很抱歉,暂时无法提供与“HTST-106-01-H-DV-A”相匹配的价格&库存,您可以联系我们找货
