HW-07-09-L-D-400-SM-A 数据手册
FLEXIBLE .025" SQ
BOARD STACKERS
(2.54 mm) .100" PITCH • HW SERIES
HW
Board Mates:
SSW, SSQ, ESW, ESQ,
CES, SLW, BSW, BCS,
SSM, HLE, PHF
Cable Mates:
IDSS, IDSD
HW
NO. PINS
PER ROW
01 thru 50
02 thru 36
(Surface
mount)
Insulator Material:
HW-SM Top = Natural LCP
HW-SM Bottom = Black LCP
HW-TH = Natural LCP
Terminal Material:
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Operating Temp Range:
-55 °C to +125 °C with Gold
-55 °C to +105 °C with Tin
Specify
LEAD
STYLE
from
chart
(Through-hole)
SPECIFICATIONS
LEAD
STYLE
LEAD
STYLE
OAL
(TH)
– 07
(10.92) .430
– 08
(13.46) .530
– 09
(18.54) .730
–10
(21.08) .830
–11
(23.62) .930
PROCESSING
–12
(26.16) 1.030
–13
(31.24) 1.230
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0.15 mm) .006" max*
*(.004" stencil solution
may be available; contact
ipg@samtec.com)
–14
(36.32) 1.430
–15
(16.00) .630
–16
(11.30) .445
–17
(12.19) .480
–19
(33.78) 1.330
–20
(28.70) 1.130
PLATING
OPTION
–F
= Gold flash
on contact,
Matte Tin
on tail
–L
= 10 µ"
(0.25 µm)
Gold on
contact
area of
longer tail,
Matte Tin
on tail
–G
= 10 µ"
(0.25 µm)
Gold on
contact
area of
longer tail,
Gold flash
on balance
ROW
OPTION
–S
STACKER
HEIGHT
–“XXX”
= Single
Row
Leave
blank for
Throughhole
= Stacker
Height
(in inches)
–D
= Double
Row
SM
Throughhole =
(5.08 mm)
.200" Min.
–T
= Triple
Row
(Throughhole only)
= Double
Row
.200"
(5.08 mm)
row space
(Throughhole only)
–T
POST
(0.00).000
MIN
= Matte
Tin
OVERALL
LENGTH
(OAL)
STACKER
HEIGHT
(2.54) .100 x
No. of Positions
(2.54)
.100
LEAD
STYLE
OAL
(SMT)
– 08
(11.81) .465
– 09
(16.89) .665
–10
(19.43) .765
–11
(21.97) .865
–12
(24.51) .965
–15
(14.35) .565
–16
(9.65) .380
–17
(10.54) .415
–20
(27.05) 1.065
(4.95)
.195
–D
Other platings
Locking Clip available with
double row HW-SM
(Manual placement required)
This Series is non-standard,
non-returnable.
(2.54)
.100
—S
(5.08)
.200
(7.49)
.295
—D
(2.54)
.100
(2.54)
.100
(2.54)
.100
= HW-TH
Tail Length
(in inches)
(1.40 mm)
.055"min.
Example:
–250
= (6.35 mm) .250"
= Locking Lead
(Throughhole only)
(Shortest
dimension
between the tail
and the post is
the end that will
be crimped.
Available on tails
from (2.29 mm)
.090" to (7.87 mm)
.310" only.)
Single row, 01 &
02 positions & –Q
row not available
–“XXX”
= Polarized
(Specify omitted
pin position)
–A
= Alignment Pin
(Metal or plastic
at Samtec
discretion)
(Surface
mount only)
= Tape & Reel
(4–27 pins
per row only)
(Not Available
on Lead Styles
10, 11, 12 & 20)
(Surface
mount only)
–FR
(7.62)
.300
—T or —Q*
–Q* same as –T except middle
row pins are removed
Notes:
For added mechanical
stability, Samtec recommends
mechanical board spacers be
used in applications with gold or
selective gold plated connectors.
Contact ipg@samtec.com for
more information.
(2.54) .100 x
No. of Positions
(5.08)
.200
MOQ Required
–“XXX”
–TR
—S
ALSO AVAILABLE
OTHER
OPTION
–LL
Surface
mount =
(6.35 mm)
.250"Min.
–Q
(2.54)
.100
HW-TH
= Full Reel
Tape & Reel
(must order max.
quantity per reel;
contact Samtec
for quantity
breaks)
(4–27 pins
per row only)
(Not Available
on Lead Styles
10, 11, 12 & 20)
(Surface
mount only)
HW—SM
samtec.com?HW-TH or samtec.com?HW-SM
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
F-224
HW-07-09-L-D-400-SM-A 价格&库存
很抱歉,暂时无法提供与“HW-07-09-L-D-400-SM-A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 32+37.26507
- 64+31.71531
