ICO-320-JGG
ICO-320-JGG
    SAMTEC(申泰)
ICO-320-JGG 数据手册
F-211-1 SUPPLEMENT ICO–320–CTT ICO–624–MGT (2,54mm) .100" ICO SERIES LOW PROFILE OPEN BODY DIP SOCKETS Mates with: APA ROW SPACING & NO. OF CONTACTS ICO Specify from chart below • Low profile down to (2,11mm) .083" above printed circuit board • Side & end stackable • Open body design • Surface mountable lead sockets (2,54) .100 x No. of Positions (7,64) .300 (10,16) .400 or (15,24) .600 Row Spacing +(2,41) .095 (2,54) .100 x No. of Spaces (2,54) .100 TYP –L 08 14 16 18 20 22 24 22 24 28 32 40 .300 (7,62) .400 (10,16) .600 (15,24) = Locking Socket = 30µ" (0,76µm) Gold Contact, 10µ" (0,25µm) Gold Shell Requires Style –S, –ZS or –P and (0,89mm) .035" ± (0,08mm) .003" board hole. GT = 30µ" (0,76µm) Gold Contact, Tin Shell Requires GT Plating Option TT = Tin Contact and Shell (–C, –S, –ZS, –A, –L, –M, –N, only) ST = 10µ" (0,25µm) Gold Contact, Tin Shell (Styles –S & –ZS only) (1,27) .050 SPECIFICATIONS (Leave Blank for Standard Version) GG Row Space Contacts –308 –314 –316 –318 –320 –322 –324 –422 –624 –628 –632 –640 OPTION PLATING OPTION STYLE OPTION Note: Some sizes, styles and options are nonstandard, non-returnable. For complete specifications see www.samtec.com?ICO Insulator Material: Black Glass Filled Polyester Contact: BeCu Shell: Brass except style K Phosphor Bronze Plating: Au or Sn over 50µ" (1,27µm) Ni Flammability Rating: UL 94V-O Insulation Resistance: 5000 MΩ min Temperature Range: -55°C to +125°C with Gold -55°C to +105°C with Tin Withstanding Voltage: 1000 VRMS @ 60 Hz Current Rating: 1A Contact Resistance: 10mΩ max Lead Size Range: (0,38mm) .015" to (0,56mm) .022" DIA and most IC leads except C, L, M, and N Insertion Force: (Single Contact only) Standard = 9 oz avg, 16 oz max; Low Insertion Force = 2.5 oz avg, 5.5 oz max Withdrawal Force: (Single Contact only) Standard = 2.5 oz avg, 1.5 oz min; Low Insertion Force = 2.0 oz avg, 0.35 oz min except Lead-Free Solderable: Wave only RoHS Compliant: Yes –L –M –N = Low Profile = Low Profile For LIF Specify –ZM = Micro Socket (0,76) .030 (0,51) .020 (5,84 ±0,25) .230 (2,74) ±.010 .108 ±.010 (1,32) .052 DIA (0,51) .020 (6,10 ±0,25) .240 ±.010 (1,32) .052 DIA (0,76) .030 DIA (2,74) .108 ±.010 (0,51) .020 DIA (0,76) .030 DIA Lead DIA Accepted = (0,41mm) .016" to (0,53mm) .021" Lead DIA Accepted = (0,38mm) .015" to (0,51mm) .020" (4,83 ±0,25) .190 (2,41) ±.010 .095 ±.010 (1,32) .052 DIA Lead DIA Accepted = (0,41mm) .016" to (0,51mm) .020" –C –S, –ZS, –ZA = Micro Socket For LIF Specify –ZC = Printed Circuit –ZS & –ZA= Low Insertion Force (0,25) .010 (4,19) .165 (0,76) .030 (2,11) .083 (1,32) .052 DIA LEAD STYLE (1,32) .052 DIA (0,74) .029 DIA Z –ZA X Lead DIA Accepted = (0,41mm) .016" to (0,51mm) .020" WWW.SAMTEC.COM –S or –ZS Y Y X DIA TAIL (0,51) .020 (0,51) .020 Z (3,18) (7,62) .125 .300 (4,57) (8,89) .180 .350 Locking lead (–L) available. See OPTION.
ICO-320-JGG
物料型号:ICO-624-MGT 和 ICO-320-CTT
器件简介:这些插座设计用于与APA和ICO系列的IC兼容,具有低剖面设计,高度仅为2.11mm,并且可以侧向和端向堆叠。
引脚分配:提供了多种行间距和引脚数量的选项,例如-308为0.300英寸间距,8个引脚;-624为0.600英寸间距,24个引脚等。
参数特性:包括30µ"金接触点和10µ"金壳,或锡壳选项。还提供了不同的镀层选项,如GT(锡镀层)和ST(10µ"金接触点,锡壳)。
功能详解:这些插座是表面贴装式引脚插座,具有开放式设计,允许IC引脚直接与PCB接触。
应用信息:适用于需要低剖面和高可靠性的电子应用。
封装信息:绝缘材料为黑色玻璃填充聚酯,接触材料为铍铜。具有UL94V-0的阻燃等级,工作温度范围为-55°C至+125°C(金接触点)或-55°C至+105°C(锡接触点)。
ICO-320-JGG 价格&库存
很抱歉,暂时无法提供与“ICO-320-JGG”相匹配的价格&库存,您可以联系我们找货
ICO-320-JGG
    • 1+171.22320
    • 198+68.32080
    • 506+66.04200
    • 990+64.90800
