ARF6-08-S-RA-TR
ARF6-08-S-RA-TR
    SAMTEC(申泰)
    插件
    ARF6-08-S-RA-TR
ARF6-08-S-RA-TR 数据手册
SLIM, DIRECT ATTACH CABLE ASSEMBLIES (0.635 mm) .025" PITCH 64 FEATURES & BENEFITS • Slimmest cable assembly in the industry – 7.6 mm width • High-density 2-row design • 8, 16 and 24 differential pair configurations • 34 AWG, 100 Ω Eye Speed® ultra low skew twinax cable • Multiple wiring options including reverse polarity • Mating board level socket (ARF6 Series) features standard rugged weld tabs for increased stability on the PCB Right-angle available. Visit samtec.com?ARF6-RA for specifications. • Rugged metal latching and shielding • Supports 64 Gbps PAM4 (32 Gbps NRZ) applications • PCIe® 6.0/CXL™ 3.1 capable Contacts directly soldered to the twinax for improved signal integrity • Utilizes Samtec’s Flyover® Technology to simplify board layout and extend signal reach KEY SPECIFICATIONS (ARC6/ARF6) PITCH CABLE SIGNAL ROUTING INSULATOR MATERIAL CONTACT MATERIAL PLATING OPERATING TEMP RANGE (0.635 mm) .025" 34 AWG Eye Speed® ultra low skew twinax 100 Ω Differential Black LCP Copper Alloy Au over 50 µ" (1.27 µm) Ni -40 °C to +125 °C PCI-SIG®, PCI Express® and the PCIe® design marks are registered trademarks and/or service marks of PCI-SIG. F-224 (Rev 19DEC23) samtec.com/AcceleRate-Cable Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. 6.0 SOLUTIONS (0.635 mm) .025" • SLIM CABLE & SOCKET ARC6 - NO OF PAIRS - –08 - CABLE LENGTH –“XX.X” –24 - –LU = Length in Inches 03.0" (76.2 mm) minimum –16 END 1 - END 2 –LU = Latch Up - WIRING OPTION CABLE TYPE –2 = Latch Up –1 = Pin 1 to Pin 2 (End 2 -LD option only) –LD = 34 AWG 100 Ω Eye Speed ® Ultra low skew twinax –3 = Latch Down = Pin 1 to Pin N-1 (End 2 -LU option only) –2R ARC6 = Pin 1 to Pin 2 Reversed Polarity (End 2 -LD option only) 06.0" (152.4 mm) min. cable length Board Mates: ARF6 –3R = Pin 1 to Pin N-1 Reversed Polarity (End 2 -LU option only) 06.0" (152.4 mm) min. cable length LENGTH = (CABLE LENGTH + (8.1) .319) ±1% CABLE LENGTH ±1% A (15.00) .591 (5.65) .222 ARC6–08–XX.X-LU–LU–3–X SHOWN Notes: Cable lengths longer than 40.00" (1 meter) are not supported with S.I. test data. ARF6 - A N N-1 –08 (10.90) .429 26 25 –16 (18.52) .729 50 49 –24 (26.14) 1.029 74 73 View complete specifications at: samtec.com?ARC6 NO. OF PAIRS –08 –16 –24 ARF6 NO. OF PAIRS - - PLATING –S ROW - –D = 30 µ" (0.76 µm) Gold on contact area, Matte Tin on tail = Double Row A –A = Alignment Pin - - K “X”R –K = Polyimide film Pick & Place Pad –STL = 30 µ" (0.76 µm) Gold on contact area, Matte Tin/Lead on tail Cable Mates: ARC6 –TR = Tape & Reel –FR = Full Reel Tape & Reel (must order maximum quantity per reel; contact Samtec for quantity breaks) A (12.51) .493 (7.21) .284 B Notes: Tape & Reel packaging and K-Dot are standard. Some sizes, styles and options are non-standard, non-returnable. NO. OF PAIRS A B C –08 (12.46) .491 (7.62) .300 (9.59) .378 –16 (20.08) .791 (15.24) .600 (17.21) .678 –24 (27.70) 1.091 (22.86) .900 (24.83) .978 C ARF6–16–S–D–A SHOWN View complete specifications at: samtec.com?ARF6 samtec.com/AcceleRate-Cable F-224 (Rev 19DEC23) Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
ARF6-08-S-RA-TR
PDF文档中包含以下信息:
1. 物料型号:型号为ELC31S-Q2-13.6 2. 器件简介:该器件为一款晶体振荡器,具有高精度和高稳定性的特点,适用于通信设备、工业控制系统等。
3. 引脚分配:共有4个引脚,分别为VDD、GND、OUT和NC。
4. 参数特性:工作频率为13.6MHz,负载电容为12pF,工作电压为2.5V至5.5V。
5. 功能详解:提供稳定的时钟信号,用于系统同步。
6. 应用信息:适用于需要精确时钟信号的场合,如通信基站、工业自动化设备等。
7. 封装信息:采用3225尺寸的表面贴装封装。
ARF6-08-S-RA-TR 价格&库存
很抱歉,暂时无法提供与“ARF6-08-S-RA-TR”相匹配的价格&库存,您可以联系我们找货
ARF6-08-S-RA-TR
    • 1+87.08040
    • 10+76.62600
    • 30+70.24320
    • 100+64.89720
    库存:199
    ARF6-08-S-RA-TR
    • 1+145.466391+18.87415
    • 10+123.5979610+16.03674
    • 100+107.08897100+13.89471
    库存:478
    ARF6-08-S-RA-TR
    • 275+87.49115275+11.35191
    库存:478
