BNC5-P-C-HN-ST-CA1
BNC5-P-C-HN-ST-CA1
    SAMTEC(申泰)
    TION: BNC5 STRAIGHT CABLE JACK
BNC5-P-C-HN-ST-CA1 数据手册
50 Ω BNC TO 4 GHz BNC Cable Assemblies RF174, RF178, RF316, RS316 - SERIES END 1 CONNECTOR RF174 - - END 2 CONNECTOR –“XXXX” –04SP3 = RG 174 Cable = BNC Straight Plug (RS316 not available) RF178 = Overall Length in millimeters –04BJ2 = RG 178 Cable = BNC Bulkhead Jack RF316 = RG 316 Cable, Single Braid Shield OVERALL LENGTH –0100 (100 mm) 3.94" minimum ALSO AVAILABLE RS316 50 Ω: MCX, MMCX, SMA, SMB, TNC, N Type = RF174, RF178, RF316 = RG 316 Cable, Double Shielded 50 Ω: MCX, MMCX, SMA, TNC = RS316 BNC Cable Connectors BNC5-CA CONNECTORS FOR INDUSTRY STANDARD CABLES (23.40) .921 *BNC5-P-C-GN-ST-CA1 RG 174/316 Cable *BNC5-P-C-GN-ST-CA2 RG 178 Cable *BNC5-J-C-GN-ST-BH1 RG 174/316 Cable, Bulkhead BNC5-J-C-GN-ST-BH2 RG 178 Cable, Bulkhead BNC5-J-C-GN-ST-BH1S RG 316 Double Shielded Cable, Bulkhead (14.50) .571 Supplied with pins, washers, nuts, gaskets and ferrules. See website for dimensions. (13.80) .543 DIA -P (18.70) .736 (17.50) .689 Hex. *Add ”–B” to the end of the part number for bulk packaging P-C = Cable Plug (29.80) 1.173 -J J-C = Cable Jack GN = Plating (10 µ" Gold on contact, Nickel on body) ST = Straight F-224 samtec.com/BNC Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
BNC5-P-C-HN-ST-CA1 价格&库存
很抱歉,暂时无法提供与“BNC5-P-C-HN-ST-CA1”相匹配的价格&库存,您可以联系我们找货
