BSE-100-01-L-D-A
BSE-100-01-L-D-A
    SAMTEC(申泰)
    SMD,P=0.8mm
    板对板连接器 立贴 针脚数:200Pin 间距:0.8mm 排数:2
BSE-100-01-L-D-A 数据手册
BASIC BLADE & BEAM HEADER & SOCKET (0.80 mm) .0315" PITCH • BTE/BSE SERIES BTE BTE Mates: BSE BSE - NO. OF POSITIONS PER ROW - –020, –040,–060, –080, –100, –120 Mates: BTE SPECIFICATIONS Insulator Material: Liquid Crystal Polymer Contact Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Current Rating: 2 A per pin (2 pins powered) Operating Temp Range: -55 °C to +125 °C Voltage Rating: 225 VAC with 5 mm Stack Height Max Cycles: 100 LEAD STYLE Specify LEAD STYLE from chart -D-A- –F (5.97) .235 A BSE - NO. OF POSITIONS PER ROW - 01 - –020, –040, –060, –080, –100, –120 MOQ Required 30 µ" (0.76 µm) Gold Edge Mount Capability Friction Lock option 11 mm, 14 mm, 16.10 mm, 19.10 mm, 22 mm, 25 mm and 30 mm Stack Height (Caution: Some automatic placement/ inspection machines may have component height restrictions. Please consult machinery specifications.) = (7.00 mm) .275" DIA Polyimide Film Pick & Place Pad –L = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail –TR = Tape & Reel (80 positions maximum) A MATED HEIGHT –01 (4.27) .168 LEAD STYLE MATED HEIGHT* –02 (7.21) .284 PLATING OPTION –L = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail –C* EXTENDED LIFE PRODUCT –01 (5.00 mm) .1971" –02 (8.00 mm) .315" *Processing conditions will affect mated height. –F = Electro-Polished Selective 50 µ" (1.27 µm) min Au over 150 µ" (3.81 µm) Ni on Signal Pins in contact area, Matte Tin over 50 µ" (1.27 µm) min Ni on all solder tails (*–C Plating passes 10 year MFG testing) (7.24) .285 –FR = Full Reel Tape & Reel (must order maximum quantity per reel; contact Samtec for quantity breaks) (80 positions maximum) LEAD STYLE = Gold Flash on contact, Matte Tin on tail No. of positions x (0.80) .0315 + (5.27) .2075 OTHER OPTION –K = Gold Flash on contact, Matte Tin on tail = Electro-Polished Selective 50 µ" (1.27 µm) min Au over 150 µ" (3.81 µm) Ni on Signal Pins in contact area, Matte Tin over 50 µ" (1.27 µm) min Ni on all solder tails (*–C Plating passes 10 year MFG testing) No. of positions x (0.80) .0315 + (4.00) .1575 ALSO AVAILABLE 10 YEAR MFG WITH 50 µ" GOLD PLATING OPTION –C* PROCESSING Lead-Free Solderable: Yes SMT Lead Coplanarity: (0.10 mm) .004" max (020-080) (0.15 mm) .006" max (100-120)* *(.004" stencil solution may be available; contact ipg@samtec.com) Board Stacking: For applications requiring more than two connectors per board or 80 positions or higher, contact ipg@samtec.com - -D-A- OTHER OPTION –TR = Tape & Reel (80 positions maximum) –FR = Full Reel Tape & Reel (must order maximum quantity per reel; contact Samtec for quantity breaks) (80 positions maximum) (3.25) .128 HIGH MATING CYCLES Note: Some lengths, styles and options are non-standard, non-returnable. (3.05) .120 samtec.com?BTE or samtec.com?BSE Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-224
BSE-100-01-L-D-A
- 物料型号:BTE/BSE系列,具有不同的引脚数量和样式。 - 器件简介:BTE和BSE系列连接器,具有0.80毫米(0.0315英寸)的引脚间距。 - 引脚分配:文档中提到了不同引脚数量的配置,如-01和-02,以及对应的接合高度。 - 参数特性:绝缘体材料为液晶聚合物,接触材料为磷青铜。镀层选项包括金或锡,电流额定值为每针2安培,工作温度范围为-55°C至+125°C,电压额定值为225VAC,最大堆叠高度为5毫米,最大周期数为100。 - 功能详解:文档描述了无铅焊接能力、SMT引脚共面性、板堆叠信息等。 - 应用信息:提供了边缘安装能力、摩擦锁定选项和堆叠高度信息。 - 封装信息:提供了不同的镀层选项,如-C电抛光选择性镀金,以及Tape & Reel(胶带和卷轴)选项。
BSE-100-01-L-D-A 价格&库存
很抱歉,暂时无法提供与“BSE-100-01-L-D-A”相匹配的价格&库存,您可以联系我们找货
BSE-100-01-L-D-A
  • 6+57.409926+7.38781
