BSS-100-01-H-D-A
BSS-100-01-H-D-A
    SAMTEC(申泰)
    SMD,P=0.64mm
    板对板连接器 SMT
BSS-100-01-H-D-A 数据手册
BASIC BLADE & BEAM HEADER & SOCKET (0.635 mm) .025" PITCH • BTS/BSS SERIES BTS BTS Mates: BSS - BSS NO. OF POSITIONS PER ROW - 01 - –025, –050, –075, –100 Mates: BTS - PLATING OPTION D - A - –F –K = Gold Flash on contact, Matte Tin on tail = (7.00 mm) .275" DIA Polyimide Film Pick & Place Pad –L SPECIFICATIONS –TR = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail Insulator Material: Liquid Crystal Polymer Terminal Material: Phosphor Bronze Contact Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Current Rating: 1.8 A per pin (2 pins powered) Operating Temp Range: -55 °C to +125 °C OTHER OPTION = Tape & Reel (–100 positions max.) –FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) (–100 positions max.) No. of Positions x (0.635) .025 + (4.13) .163 (5.97) .235 PROCESSING (4.06) .160 Lead-Free Solderable: Yes SMT Lead Coplanarity: (0.10 mm) .004" max Board Stacking: For applications requiring more than two connectors per board or 100 positions or higher, contact ipg@samtec.com ALSO AVAILABLE MOQ Required 30 µ" (0.76 µm) Gold Other platings Other positions BSS - (4.27) .168 NO. OF POSITIONS PER ROW - 01 - –025, –050, –075, –100 -D- –F = Gold Flash on contact, Matte Tin on tail –L = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail MATED HEIGHT LEAD STYLE MATED HEIGHT* –01 PLATING OPTION (5.00 mm) .197" No. of Positions x (0.635) .025 + (5.41) .213 *Processing conditions will affect mated height. A - OTHER OPTION –TR = Tape & Reel (–100 positions maximum) –FR = Full Reel Tape & Reel (must order maximum quantity per reel; contact Samtec for quantity breaks) (–100 positions maximum) (7.24) .285 10 YEAR MFG WITH 50 µ" GOLD EXTENDED LIFE PRODUCT HIGH MATING CYCLES Note: Some lengths, styles and options are non-standard, non-returnable. F-224 (3.43) .135 (3.63) .143 samtec.com?BTS or samtec.com?BSS Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
BSS-100-01-H-D-A
1. 物料型号:BTS/BSS系列,具有不同的引脚间距和配置选项。 2. 器件简介:BTS和BSS是刀片和梁头插座,BTS与BSS兼容。 3. 引脚分配:引脚数量可以根据需要定制,文档中提到了不同数量的引脚配置。 4. 参数特性: - 绝缘体材料:液晶聚合物 - 端子材料:磷青铜 - 接触材料:磷青铜 - 镀层:Au或Sn,覆盖在50 µ" (1.27 µm) Ni上 - 电流额定值:每针1.8 A(2针供电) - 工作温度范围:-55 °C至+125 °C 5. 功能详解:文档提到了无铅焊接性、SMT引脚共面性、板堆叠等技术细节。 6. 应用信息:适用于需要多个连接器或超过100个引脚位置的应用。 7. 封装信息:提供了不同镀层选项,如10 µ" (0.25 µm) 金接触和哑光锡尾部,以及胶带和卷轴选项。
BSS-100-01-H-D-A 价格&库存
很抱歉,暂时无法提供与“BSS-100-01-H-D-A”相匹配的价格&库存,您可以联系我们找货
BSS-100-01-H-D-A
  • 8+137.565418+17.21192
