BSW-115-24-S-S
BSW-115-24-S-S
    SAMTEC(申泰)
    BOTTOM MOUNT STRIPS
BSW-115-24-S-S 数据手册
BOTTOM MOUNT SOCKET STRIPS (2.54 mm) .100" PITCH • BSW SERIES BSW Mates: TSW, MTSW, HTSW, MTLW, TSM, EW, ZW, HW, DW, PHT BSW - NO. PINS PER ROW 1 - LEAD STYLE 02 thru 36 ­­– 04 Insulator Material: Black Thermoplastic Insulation Resistance: 5000 MΩ min Contact Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +125 °C with Gold -55 °C to +105 °C with Tin Withstanding Voltage: 1000 VRMS @ 60 Hz Insertion Depth: (3.68 mm) .145" to (6.35 mm) .250" plus board thickness ­­­­– L = Low Insertion Force ROW OPTION ­­–S = 10 µ" (0.25 µm) Gold contact, Matte Tin on tail ­­–24 • Bottom mount socket strips accept .025" SQ terminals. • Ideal for soldering and plugging from the same side of the board. • For low profile connections and high temperature soldering. - PLATING OPTION = Standard Lead FEATURES SPECIFICATIONS - = Single Row ­­– D = Double Row –G = 20 µ" (0.51 µm) Gold contact, Gold Flash on tail ­–T = Matte Tin (Not available with Low Insertion Force) 1RRI3RV;          —S   ROW OPTION Z –S (4.31) .170 –D (4.32) .170 —D = PROCESSING Lead-Free Solderable: Wave only   —S —D ALSO AVAILABLE MOQ Required Other Platings APPLICATIONS BSW (SINGLE ROW) BSW (DOUBLE ROW) COMPONENT SIDE EW (SINGLE ROW) PC BOARD SOLDER SIDE PC BOARD Note: Some lengths, styles and options are non-standard, non-returnable. F-224 (Rev 10JAN24) TSW (SINGLE ROW) TSW (DOUBLE ROW) BSW (SINGLE ROW) samtec.com?BSW Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
BSW-115-24-S-S
1. 物料型号:BSW系列,提供从2到36针每排的型号,具有标准引脚和低插入力选项。 2. 器件简介:底部安装插座条适用于0.025"平方终端,适合在同一侧的板上进行焊接和插接。 3. 引脚分配:文档中提到了单排和双排选项,以及不同的引脚长度和镀层选项。 4. 参数特性: - 绝缘体材料:黑色热塑性绝缘体 - 接触材料:磷青铜 - 镀层:金或锡,覆盖50微米(1.27微米)镍 - 工作温度范围:-55°C至+125°C(金),-55°C至+105°C(锡) - 耐压:1000 VRMS @ 60 Hz - 插入深度:3.68毫米至6.35毫米加上板厚 5. 功能详解:文档描述了插座条的焊接适用性,包括无铅焊接和波峰焊接选项。 6. 应用信息:展示了BSW系列在组件侧和焊接侧的应用,以及与其他系列如TSW、EW的配合使用。 7. 封装信息:提供了不同选项的尺寸信息,例如单排和双排的尺寸。
BSW-115-24-S-S 价格&库存
很抱歉,暂时无法提供与“BSW-115-24-S-S”相匹配的价格&库存,您可以联系我们找货
