CLH-105-F-D-BE
CLH-105-F-D-BE
    SAMTEC(申泰)
    LOW PROFILE/SMT STRIPS
CLH-105-F-D-BE 数据手册
F-211 CLH–108–F–D–DV–P CLH–110–F–D–DV (2,54mm) .100" CLH–120–F–D–BE CLH SERIES SMT LOW PROFILE SOCKET SPECIFICATIONS For complete specifications and recommended PCB layouts see www.samtec.com?CLH Insulator Material: Black Liquid Crystal Polymer Contact Material: Phosphor Bronze Operating Temp Range: -65°C to +125°C with Gold -65°C to +105°C with Tin Plating: Au or Sn over 50µ" (1,27µm) Ni Contact Resistance: 10 mΩ max Insertion Depth: (2,67mm) .105" to (3,43mm) .135" plug from top, (3,18mm) .125" min plus board thickness plug from bottom Insertion Force: 4.0oz (1,11N) average Normal Force: 50 grams (0,48N) Withdrawal Force: 1.1oz (0,31N) average Max Cycles: 100 with 10µ" (0,25µm) Au RoHS Compliant: Yes 1 CLH NO. PINS PER ROW PLATING OPTION D ENTRY OPTION OTHER OPTION –DV Mates with: TSW, MTSW, HW, DW, EW, ZW, TLW, TSM, MTLW –K = Top Entry = (6,50mm) .256" DIA Polyimide film Pick & Place Pad (3 positions min.) –BE = Bottom Entry –F –P = Pick & Place Pad (3 positions minimum) = Pre-plated Gold flash on contact, 75µ" (1,91µm) Matte Tin on tail –L = Pre-plated 10µ" (0,25µm) Gold on contact, 75µ" (1,91µm) Matte Tin on tail (7,11) .280 x (5,71) .225 (3,86) .152 Note: Other Gold plating options available. Contact Samtec. Not always necessary for auto placement. Call Samtec. Processing: –A –TR ==Alignment Pin Tape & Reel (4 positions Packaging minimum) (–DV only) 02 thru 50 Lead–Free Solderable: Yes SMT Lead Coplanarity: (0,10mm) .004" max (1,22) .048 (1,60) .063 DIA –LC = Locking Clip No. of Positions x (2,54) .100 (2,54) .100 02 (1,27) .050 (5,08) .200 (2,54) .100 03 (1,42) .056 01 TAPE & R (3,56) .140 (3,66) .144 (7,11) .280 (0,51) .020 –TR EEL AVAIL ABILITY No to Minimum oling charges. a full reel quorder is the lesser of antity or 12 Order any 5 pieces qu In-house deantity above minimum. sign, manuf . ac Quick turn -around. ture. C all Samtec and orderinfor specifications g informat ion. Note: Some lengths, styles and options are non-standard, non-returnable. WWW.SAMTEC.COM = Tape & Reel Packaging (29 positions maximum)
CLH-105-F-D-BE 价格&库存
很抱歉,暂时无法提供与“CLH-105-F-D-BE”相匹配的价格&库存,您可以联系我们找货
