CLM-114-02-L-D-BE
CLM-114-02-L-D-BE
    SAMTEC(申泰)
    1MM MICRO STRIPS
CLM-114-02-L-D-BE 数据手册
RUGGED RELIABLE MICRO SOCKETS (1.00 mm) .0394" PITCH • CLM/MLE SERIES CLM Mates: FTM, FTMH, MW CLM -1 MLE - 02 - NO. PINS PER ROW 02 thru 50 Mates: FTM, FTMH, MW –F PROCESSING = Bottom Entry (Required for bottom entry) –K –L = (3.50 mm) .138" DIA Polyimide film Pick & Place Pad (7 positions minimum) = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail PIN/ROW No. of positions x (1.00) .03937 + (0.318) .0125 04-15 (3.56) .140 16-50 (7.11) .280 –PA = Pick & Place Pad with integral Alignment Pin –TR = Tape & Reel –FR = Full Reel Tape & Reel (must order maximum quantity per reel; contact Samtec for quantity breaks) –PA (3.81) .150 (2.26) .089 (2.12) .084 –P MLE -1 - 01 - NO. PINS PER ROW 02 thru 50 PLATING OPTION - DV –G - OPTIONS –A = 10 µ" (0.25 µm) Gold = Alignment Pin (3 positions minimum) Metal or plastic at Samtec discretion –K = (4.00 mm) .1575" DIA Polyimide film Pick & Place Pad (5 positions minimum) MOQ Required No. of positions x (1.00) .03937 + (0.20) .008 Alignment pin Other Gold plating options –P = Metal Pick & Place Pad (5 positions minimum) (3.07) .121 –TR = Tape & Reel 10 YEAR MFG WITH 30 µ" GOLD EXTENDED LIFE PRODUCT F-224 = Pick & Place Pad (7 positions minimum) (8.26) .325 by A ALSO AVAILABLE Note: Some lengths, styles and options are non-standard, non-returnable. –P A (2.54) .100 Lead-Free Solderable: Yes SMT Lead Coplanarity: (0.10 mm) .004" max (02-25) (0.15 mm) .006" max (26-50)* *(.004" stencil solution may be available; contact ipg@samtec.com) HIGH MATING CYCLES OPTIONS –BE = Gold flash on contact, Matte Tin on tail SPECIFICATIONS Insulator Material: Black LCP Contact Material: CLM: Phosphor Bronze MLE: BeCu Plating: CLM: Au or Sn over 50 µ" (1.27 µm) Ni MLE: Au over 10 µ" (0.25 µm) Ni Current Rating (CLM/FTM): 3.1 A per pin (2 pins powered) Current Rating (MLE/FTM): 2.9 A per pin (2 pins powered) Operating Temp Range: -55 °C to +125 °C Max Cycles: CLM: 100 with 10 µ" (0.25 µm) Au Voltage Rating: CLM: 270 VAC MLE: 310 VAC Insertion Depth: CLM: Top Entry = (1.40 mm) .055" min., Bottom Entry = (2.41 mm) .095" min. (Add board thickness for correct post OAL) MLE: (1.63 mm) .064" to (3.18 mm) .125" with (0.38 mm) .015" wipe, pass-through, or (2.44 mm) .096" minimum for bottom entry -D- PLATING OPTION –FR (4.32) .170 (3.12) .123 (3.30) .130 –P –A = Full Reel Tape & Reel (must order maximum quantity per reel; contact Samtec for quantity breaks) samtec.com?CLM or samtec.com?MLE Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
CLM-114-02-L-D-BE
- 物料型号:CLM/MLE系列微型插座,具有1.00毫米的间距。 - 器件简介:这些插座设计用于与FTM, FTMH, MW系列的连接器配合使用。 - 引脚分配:提供了不同排数的引脚分配,从2至50个引脚每排。 - 参数特性: - 绝缘体材料:黑色LCP。 - 接触材料:CLM为磷青铜,MLE为铍铜。 - 电镀选项:CLM为金或锡上50微英寸镍,MLE为金上10微英寸镍。 - 电流额定值:CLM/FTM每针3.1安培(2针供电),MLE/FTM每针2.9安培(2针供电)。 - 工作温度范围:-55°C至+125°C。 - 最大周期数:CLM 100次,MLE未明确。 - 电压额定值:CLM 270 VAC,MLE 310 VAC。 - 插入深度:CLM顶入最小1.40毫米,底入最小2.41毫米。 - 功能详解:文档中提到了“TIGER CLAW”和“TIGER BEAM”接触技术,但没有提供详细的功能解释。 - 应用信息:适用于需要高电流、高可靠性和长寿命的应用。 - 封装信息:提供了不同引脚数量和电镀选项的详细封装规格。
CLM-114-02-L-D-BE 价格&库存
很抱歉,暂时无法提供与“CLM-114-02-L-D-BE”相匹配的价格&库存,您可以联系我们找货
