ESW-131-38-S-D
ESW-131-38-S-D
    SAMTEC(申泰)
    排母
ESW-131-38-S-D 数据手册
ESQ–132–14–G–D F-218 (Rev 10OCT17) ESQ–110–44–T–D ESW–115–12–G–S (2.54 mm) .100" ESW, ESQ SERIES ELEVATED SOCKET Mates with: TSW, MTSW, EW, MTLW, TSS, ZSS, TSM, DW, ZW, HW, TSSH, HTSS TYPE STRIP 1 NO. PINS PER ROW LEAD STYLE PLATING OPTION ESW SPECIFICATIONS For complete specifications see www.samtec.com?ESW or www.samtec.com?ESQ = Solder Tail –S –L = Single Row –G = Double Row = 10 µ" (0.25 µm) Gold contact, Matte Tin on tail ESQ Insulator Material: Black Glass Filled Polyester Contact Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Current Rating (ESW/TSW): 5.2 A per pin (2 pins powered) Current Rating (ESQ/TSW): 5.7 A per pin (2 pins powered) Voltage Rating: 550 VAC mated with TSW or ESQ Operating Temp Range: -55 °C to +125 °C with Gold -55 °C to +105 °C with Tin Insertion Depth: (3.68 mm) .145" to (6.35 mm) .250" Normal Force: Standard = 125 grams (4.4 N) Max Cycles: 100 with 10 µ" (0.25 µm) Au RoHS Compliant: Yes Lead-Free Solderable: Wave only ROW OPTION = Square Tail –T = Triple Row (ESQ only) –T = Matte Tin (N/A w/LIF contact) (2.41) .095 –S 01 36 (2.54) .100 72 02 03 (5.08) .200 (2.54) .100 –T (ESQ only) FILE NO. E111594 LOW STANDARD INSERTION FORCE INSERTION FORCE 01 (2.54) .100 108 RECOGNITIONS Specify LEAD STYLE from chart below. (4.95) .195 (2.54) .100 71 For complete scope of recognitions see www.samtec.com/quality Two leads per strip crimped. N/A with single row 1 or 2 positions. –“XXX” = Polarized (2.54) .100 X No. of Positions + (0.51) .020 –D –LL = Locking Lead –D = 20 µ" (0.51 µm) Gold contact, Gold Flash on Balance 01 thru 36 OTHER OPTION (7.49) .295 106 01 – 12 – 37 – 13 – 38 – 23 – 48 – 33 – 58 – 14 – 39 – 24 – 49 – 34 – 59 – 44 – 69 A (2.29) .090 (7.36) .290 (4.83) .190 (2.29) .090 (12.19) .480 (9.65) .380 (7.11) .280 (4.57) .180 B (11.05) .435 (13.59) .535 (16.13) .635 (11.05) .435 (13.59) .535 (16.13) .635 (18.67) .735 B A APPLICATIONS ALSO AVAILABLE (MOQ Required) • Other platings Contact Samtec. Note: Some lengths, styles and options are non-standard, non-returnable. (2.54) .100 TYP ESW (0.41) x (0.79) .016 .031 ESQ (0.64) .025 SQ Self g Nestkinets Soc (ESQ Series) PC/104™ J1/P1 “Stackthrough” Connectors Standard Insertion Force ESQ-132-14-G-D Low Insertion Force ESQ-132-39-G-D PC/104™ J1 “Non-Stackthrough” Connectors Standard Insertion Force ESQ-132-12-G-D Low Insertion Force ESQ-132-37-G-D PC/104™ J2/P2 “Stackthrough” Connectors Standard Insertion Force ESQ-120-14-G-D Low Insertion Force ESQ-120-39-G-D PC/104 is a trademark of the PC/104 Consortium. Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
ESW-131-38-S-D
- 物料型号:ESQ-132-14-G-D, ESQ-132-39-G-D, ESQ-132-12-G-D, ESQ-132-37-G-D, ESQ-120-14-G-D, ESQ-120-39-G-D - 器件简介:这些连接器是嵌入式PC/104模块化连接器,用于连接PC/104模块。 - 引脚分配:文档中提到了不同型号的连接器,具有不同的引脚数量和配置。 - 参数特性: - 接触材料:磷青铜 - 绝缘体材料:黑色玻璃填充聚酯 - 镀层:Au或Sn over 50 µ" (1.27 µm) Ni,或20 µ" (0.51 µm) Gold contact, Gold Flash on Balance - 电流额定值:5.2 A每针(2针供电)或5.7 A每针(2针供电,仅限ESQ/TSW) - 电压额定值:550 VAC,配合使用ESQ或TSW - 工作温度范围:-55 °C至+125 °C(金接触)或-55 °C至+105 °C(锡接触) - 插入深度:3.68 mm至6.35 mm - 正常力:标准为125克(4.4 N) - 最大循环次数:100次,使用10 µ" (0.25 µm) Au - RoHS合规性:是 - 功能详解:文档提供了连接器的详细规格和选项,包括不同的引脚样式、镀层选项、电流和电压额定值等。 - 应用信息:适用于需要嵌入式PC/104模块化连接器的应用,如工业自动化、医疗设备等。 - 封装信息:提供了不同型号的连接器的封装尺寸和引脚配置。
ESW-131-38-S-D 价格&库存
很抱歉,暂时无法提供与“ESW-131-38-S-D”相匹配的价格&库存,您可以联系我们找货
