EW-22-14-G-D-730
EW-22-14-G-D-730
    SAMTEC(申泰)
    CONN HDR 44POS 0.1 STACK T/H
EW-22-14-G-D-730 数据手册
ZW–06–13–L–D–787–118 F-215 DW–11–20–T–D–825 HW–14–08–G–S–300–100 (2,54 mm) .100" DW, EW, ZW, HW SERIES FLEXIBLE .025" SQ BOARD STACKERS Mates with: SSW, SSQ, ESW, ESQ, CES, SLW, BSW, BCS, SSM, IDSS, IDSD, HLE, PHF, SMSD, SMSS TYPE STRIP LEAD STYLE NO. PINS PER ROW PLATING OPTION SPECIFICATIONS For complete specifications see www.samtec.com?DW, www.samtec.com?EW, www.samtec.com?ZW or www.samtec.com?HW-TH Insulator Material: DW, EW, ZW: Black Glass Filled Polyester HW: Natural Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Au or Sn over 50µ" (1,27 µm) Ni Operating Temp Range: -55°C to +125°C with Gold -55°C to +105°C with Tin RoHS Compliant: Yes Lead–Free Solderable: DW, EW, ZW: Wave Only HW: Yes DW Specify LEAD STYLE from chart = (2,79 mm) .110" Tail POST (0,00).000 MIN (2,79) .110 OVERALL LENGTH STACKER HEIGHT (OAL) EW = (8,38 mm) .330" Tail TAIL (1,40) .055 MIN LEAD STYLE OAL – 07 – 08 – 09 –10 –11 –12 –13 –14 –15 –16 –17 –19 – 20 (10,92) .430 (13,46) .530 (18,54) .730 FILE NO: 090871_0_000 STACKER HEIGHT OTHER OPTIONS –S –“XXX” –“XXX” = Single Row = Stacker Height –D STACKER HEIGHT (5,08) .200 MIN = Double Row –T ZW or HW TAIL LENGTH (1,40) .055 MIN = Triple Row (23,62) .930 (26,16) 1.030 (31,24) 1.230 (36,32) 1.430 (16,00) .630 –Q = Double Row .200" (5,08 mm) row space –LL (11,30) .445 (12,19) .480 (33,78) 1.330 (28,70) 1.130 –F = Gold flash on contact, Matte Tin on tail (8,38) .330 –L = 10µ" (0,25 µm) Gold on contact area of longer tail, Matte Tin on tail 01 thru 50 ZW = Custom Tail 50 (2.54) .100 x No. of Positions –G 01 (2.54) .100 02 TAIL LENGTH ALSO AVAILABLE (MOQ Required) • Other platings Contact Samtec. Note: For added mechanical stability, Samtec recommends mechanical board spacers be used in applications with gold or selective gold plated connectors. Contact ipg@samtec.com for more information. HW (2.54) .100 01 99 03 150 (7,52) .296 = High Temp Custom Tail –D –T or –Q* –Q* 148 (2.54) .100 = Same as -T except middle row of pins missing. (2.54) .100 TAIL LENGTH (0,64) .025 SQ TYP WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. –“XXX” Specify omitted pin position B o a rd Stacking SO CK ET PR OF ILE PO ST OV ER AL LLE TH RU HO PIN (O AL ) Note: This Series is non-standard, non-returnable. = Locking Lead (Shortest dimension between the tail and the post is the end that will be crimped. Available on tails from (2,29 mm) .090" to (7,87 mm) .310" only.) Single row, 01 & 02 positions & –Q row not available = Polarized –T = Matte Tin (5,08) .200 01 –S = 10µ" (0,25 µm) Gold on contact area of longer tail, Gold flash on balance 100 (5,08) .200 = ZW or HW Tail Length (21,08) .830 RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality ROW OPTION BO AR D SP AC E ST AC KE R HE IG HT TA IL
EW-22-14-G-D-730 价格&库存
很抱歉,暂时无法提供与“EW-22-14-G-D-730”相匹配的价格&库存,您可以联系我们找货
EW-22-14-G-D-730
  • 2+74.034742+9.56894
库存:123
EW-22-14-G-D-730
  • 1+65.297171+8.43961
