FC1–25–02–T–WT
F-219
ZF1–25–01–T–WT
FC1–20–01–T
ZF1–10–01–T–WT
(1.00 mm) .0394"
ZF1, FC1 SERIES
FLAT FLEXIBLE CABLE (FFC) SOCKET
Mates with:
FJ
NO. OF
POSITIONS
ZF1
SPECIFICATIONS
LEAD
STYLE
For complete specifications and
recommended PCB layouts
see www.samtec.com?ZF1
Insulator Material:
Liquid Crystal Polymer
Contact Material:
Phosphor Bronze
Plating:
Sn over 40 µ" (1.02 µm) Ni
Weld Tab: Phosphor Bronze
Operating Temp Range:
-55 °C to +105 °C
RoHS Compliant: Yes
–01
= Contact
Bottom
–05, –10, –15,
–16, –20, –25, –30
(1.50)
.059
(No. of pins x (1.00) .03937)
+ (5.85) .230
01
–02
(0.25)
.010
= Contact
Top
(10 positions
only)
PLATING
OPTION
WT
–T
–WT
= Weld
Tab
= Matte Tin
ALSO
AVAILABLE
(MOQ Required)
• Other positions
Lead-Free Solderable: Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max
(No. of pins x (1.00) .03937) + (7.00) .276
RECOGNITIONS
(5.30) .209
Note:
Some lengths,
styles and options
are non-standard,
non-returnable.
(3.00)
.118
(1.00)
.03937
FILE NO. E111594
Mates with:
FJ
(4.9) .19
NO. OF
POSITIONS
FC1
SPECIFICATIONS
see www.samtec.com?FC1
Insulator Material:
Contact Material:
Phosphor Bronze
Plating:
Sn over 50 µ" (1.27 µm) Ni ALSO AVAILABLE
(MOQ Required)
-55 °C to +105 °C
• Low insertion force
Max Cycles:
25 with FJ
contacts available
RoHS Compliant:
Yes
LEAD
STYLE
PLATING
OPTION
–LC
= Locking Clip
(Manual
placement
required)
(–01 only)
= Tin
= Vertical
–02
= Horizontal
–WT
+ (2.33) .092
01
= Weld Tab
(–02 only)
+ (1.00) .03937
03
PROCESSING
(1.40)
.055
(2.77)
.109
Yes
(0.10 mm) .004" max
02
(1.42)
.056
(1.00) .03937
– LC OPTION
–K
= (4.00 mm) .158"
DIA Polyimide film
Pick & Place Pad
(–01 only)
–TR
= Tape & Reel
Packaging
RECOGNITIONS
FILE NO. E111594
OPTIONS
–T
–01
–05, –10, –15, –20 & –25
For complete scope
of recognitions see
www.samtec.com/quality
–TR
= Tape & Reel
Packaging
APPLICATION
PROCESSING
For complete scope
of recognitions see
OPTION
(5.18)
.204
(6.35)
.250
(4.09)
.161
(1.19)
.047
(0.30) .012
– 02
– 01
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
Note:
Some lengths,
styles and options
are non-standard,
non-returnable.
很抱歉,暂时无法提供与“FC1-07-L2-T-WT”相匹配的价格&库存,您可以联系我们找货
