HMTMS-110-02-G-D-100 数据手册
F-215
MTMS–130–02–G–D–100
MTMS–110–02–G–D–100
MTMS–125–51–G–S–200
(1,27 mm) .050"
MTMS, HMTMS SERIES
MODIFIED MICRO TERMINAL
SPECIFICATIONS
Mates with:
SMS, SLM, RSM
For complete specifications
see www.samtec.com?MTMS
or www.samtec.com?HMTMS
Insulator Material:
Black Liquid Crystal
Polymer
Terminal Material:
Phosphor Bronze
Plating:
Au or Sn over
50µ" (1,27 µm) Ni
Operating Temp Range:
-55°C to +105°C with Tin
-55°C to +125°C with Gold
RoHS Compliant:
Yes
Board
Stacking
BO AR D
SPA CE
MA X
INS ERT ION
DE PTH
PO ST
OV ERA LL
PIN
(O AL )
Processing:
SO CK ET
PRO FIL E
TAI L
Lead-Free Solderable:
Yes
Position anywhere
in the body with
(3,05 mm) .120"
minimum tail
BO DY
PRO FIL E
Ideal for board
stacking
applications
Single row
and double row
RECOGNITIONS
For complete scope of
recognitions see
www.samtec.com/quality
TYPE
STRIP
1
NO. PINS
PER ROW
LEAD
STYLE
01
thru
50
Specify
LEAD
STYLE
from
chart
ALSO AVAILABLE
(MOQ Required)
• Other platings
Contact Samtec.
PLATING
OPTION
–L
= 10µ" (0,25 µm)
Gold on post,
Matte Tin on tail
MTMS
= Modified Standard
–G
HMTMS
= 10µ" (0,25 µm)
Gold on post,
Gold flash on tail
= Modified High Temp
ROW
OPTION
POST
HEIGHT
OPTION
–S
–“XXX”
–“XXX”
= Single
Row
–D
= Double
Row
= “B”
Dimension
(Specify Post
Height in
inches
(0,13 mm)
.005"
increments)
B
(1,27) .050 x No. of Positions
LEAD
STYLE
(2,48)
.098
50
01
02
100
(2,54)
.100
(4,98)
.196
01
HMTMS –D
BODY DESIGN
99
(1,27) .050 TYP
(0,46) .018 SQ
B
(0,00) .000
MIN
(2,54)
.100
OAL
(3,05)
C .120
MIN*
(0,51)
.020
(0,51) .020 DIA
SINGLE ROW
Note: This Series is
non-standard, non-returnable.
DOUBLE ROW
–01
–02
–25*
–51
–52
–53
–54
–55
–56
–57
–58
–59
–60
OAL
(Maximum
when C =
(3,05 mm) .120")
(11,43) .450
(5,84) .230
(8,13) .320
(2,54) .100
(8,38) .330
(3,18) .125
(10,41) .410
(4,83) .190
(10,80) .425
(5,21) .205
(12,83) .505
(7,24) .285
(14,10) .555
(8,51) .335
(15,49) .610
(9,91) .390
(15,88) .625
(10,29) .405
(16,51) .650
(10,92) .430
(17,91) .705
(12,32) .485
(19,18) .755
(13,59) .535
(20,96) .825
(15,37) .605
*Style -25 tail C = (2,67 mm) .105" min
is available.
Tail DIA is .020" (0,51 mm) for min .120" (3,05 mm).
Balance of tail is .018" (0,46 mm) SQ.
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
= Polarized
Position
(Specify
position of
omitted pin)
