HTSW-132-07-S-T-LL
HTSW-132-07-S-T-LL
    SAMTEC(申泰)
    CONN HEADER VERT 96POS 2.54MM
HTSW-132-07-S-T-LL 数据手册
TSW–209–09–F–S–RA F-210-1 TSW–108–05–L–Q TM EXTENDED LIFE PRODUCT (2,54mm) .100" TSW–116–11–G–S 10 Year Mixed Flowing Gas (MFG) Call Samtec for maximum cycles TSW, HTSW SERIES THROUGH-HOLE .025" SQ POST HEADER Mates with: SSW, SSQ, ESW, ESQ, BCS, BSW, IDSD, IDSS, CES, SLW TYPE STRIP SPECIFICATIONS HTSW TSW Insulator Material: Black Glass Filled Polyester Terminal Material: Phosphor Bronze Plating: Au or Sn over 50µ" (1,27µm) Ni Operating Temp Range: -55°C to +125°C with Gold -55°C to +105°C with Tin Voltage Rating: 550 VAC mated with SSW; 500 VAC mated with BCS or ESQ; 450 VAC -RA/-RE mated with BCS or SSM RoHS Compliant: Yes 40°C (5,08mm) Centers, – 2 = .200" Every Other Position Filled (5,08) .200 (2,54) .100 = Hi-Temp Strip (2,54) .100 x No. of Positions Straight Pin Versions (2,54) .100 (2,54) .100 (2,48) .098 50 02 (2,54) .100 –S 01 100 (5,08) .200 (2,54) (5,02) .100 .198 01 03 CURRENT RATING TSW mated with AMBIENT TEMP ESW SSW SLW SSQ SSM BCS 20°C (2,54mm) Centers, –1 = .100" All Positions Filled TSW = Standard Strip For complete specifications see www.samtec.com?TSW NO. PINS PER ROW PIN CENTERS –D 99 150 (2,54) (7,62) .100 .300 (5,08) (7,56) .200 .298 01 03 –T 148 150 6.9A 6.9A 7.1A 7.6A 6.9A 5.9A 6A 6.1A 6.2A 6.9A 6A 5.2A 60°C 5.3A 5.3A 5.8A 5.9A 5.3A 4.7A 95°C 3.5A 3.5A 3.7A 3.9A 3.5A 3A (5,08) (7,56) .200 .298 (7,62) .300 01 TSW –Q 148 = .100" (2,54mm) Center Version HTSW 6 POSITIONS (2x3) POWERED (2,54) .100 x No. of Positions Processing: Lead–Free Solderable: Wave Only Right Angle Versions (2,54) .100 (3,02) .119 (1,78) .070 (3,09) (1,78) .120 .070 –S 01 SPECIFICATIONS 100 02 50 For complete specifications see www.samtec.com?HTSW HTSW Processing: Max Processing Temp: 230°C for 30 to 60 seconds, or 260°C for 20 seconds 3x Lead–Free Solderable: Yes (2,54) .100 (6,10) .240 (1,78) .070 (5,56) .219 (1,78) .070 Same as TSW except: Insulator Material: Natural Liquid Crystal Polymer (8,12) .320 APPLICATIONS BCS 01 99 03 150 (2,54) .100 HORIZONTAL (8,10) .319 –T (1,78) .070 (1,78) .070 TSW –D 01 148 03 150 (5,08) .200 (8,10) .319 (1,78) .070 (1,78) .070 01 TSW HTSW 02 thru 25 = .200"(5,08mm) Center Version (5,08) .200 (8,12) .320 Note: Some lengths, styles and options are non-standard, non-returnable. 01 thru 50 148 WWW.SAMTEC.COM –Q TSW–109–09–F–D–RA TSW–112–16–T–S–RE TSW–112–07–G–T TSW–120–13–L–D PLATING OPTION LEAD STYLE ROW OPTION –S –F –NA –D –L (4,19) .165 Contact Area = 10µ" (0,25µm) Gold on contact area, Matte Tin on tail = Right Angle (using straight body for coplanar mating with SSW-RA series) –T –G –T Note: Other Gold plating options available. Contact Samtec. * * * * A B C (3,30) .130 (2,41) .095 (2,54) .100 (5,08) .200 (10,16) .400 (12,70) .500 (15,24) .600 (17,78) .700 (22,86) .900 (8,51) .335 (7,62) .300 (10,92) .430 (13,46) .530 (18,54) .730 (21,08) .830 (23,62) .930 (26,16) 1.030 (31,24) 1.230 (13,46) .530 (2,67) .105 (2,67) .105 – 06 – 07 – 08 – 09 –10 –11 –12 –13 –14 * –15 * –16 * –17 * *Available with – LL (2,79) .110 (7,87) .310 (2,79) .110 (18,54) .730 (21,08) .830 STYLE (5,84) .230 (8,13) .320 (13,21) .520 (8,13) .320 (15,74) .620 (0,64) .025 SQ Post (Locking Lead) Option * * * * * * * * A –18 –19 – 20 (2,79) .110 – 21 – 22 (7,62) .300 – 23 – 24 – 25 – 26 – 27 – 28 – 29 – 30 – 41+ – 42+ (2,92) .115 (5,33) .210 (3,20) .126 (25,40) 1.000 (20,32) .800 (23,11) .910 (18,03) .710 (0,89) .035 (1,27) .050 Specify -07 for best mate with IDXX Series IDC Cable B B C (23,62) .930 (26,16) 1.030 (31,24) 1.230 (36,32) 1.430 (16,00) .630 (11,30) .445 (12,15) .480 (16,00) .630 (11,58) .456 (33,78) 1.330 (28,70) 1.130 (33,78) 1.330 (28,70) 1.130 (9,27) .365 (11,94) .470 (18,29) .720 (20,83) .820 (25,91) 1.020 (30,99) 1.220 * * – 08 – 09 –10 –11 (5,84) .230 (6,73) .265 (8,13) .320 –12 –13 * –16 – 21 (5,84) .230 (8,13) .320 (5,84) .230 (8,13) .320 SINGLE (– S) –RA LEAD STYLE * * – 22 – 25 – 27 – 28 – 29 – 30 A available with HTSW only. DOUBLE (– D) TRIPLE (–T & – Q) A A (2,29) .090 (7,37) .290 (9,91) .390 (12,45) .490 (14,99) .590 (20,07) .790 (5,08) .200 (2,29) .090 (7,37) .290 (9,91) .390 (12,45) .490 (14,99) .590 C (2,29) .090 (7,37) .290 (9,91) .390 (12,45) .490 (14,99) .590 (20,07) .790 (5,08) .200 (25,15) .990 (4,83) .190 (2,54) .100 (22,61) .890 (17,53) .690 (20,32) .800 (15,24) .600 C A (5,84) .230 (8,13) .320 (5,84) .230 (8,13) .320 (5,84) .230 (8,13) .320 (1,78) .070 –10 –11 –12 –13 N/A –16 (5,08) .200 – 21 N/A N/A – 22 (4,83) .190 (2,54) .100 (4,83) .190 (2,54) .100 – 27 N/A (17,53) .690 N/A SINGLE A (4,83) .190 (7,37) .290 (9,91) .390 (12,45) .490 (17,53) .690 (2,54) .100 (22,61) .890 (2,29) .090 (20,07) .790 (14,99) .590 – 09 – 28 C (5,84) .230 (8,13) .320 (5,84) .230 *Available with – LA (Locking Lead) Option N/A (15,24) .600 (1,78) .070 C A (2,54) .100 A (0,64) .025 SQ Tail** – RE LEAD STYLE C A (2,54) .100 **Except: Style –26 (0,46) .018 DIA Tail Shunts. See SNT Series (Specify “LEAD STYLE” from chart and select –RA or –RE from other options) + Style –41 & –42 C –“XXX” = Polarized Position Right Angle Versions (Specify “LEAD STYLE” from chart) – 05 = –RA Option with –LL Option Two leads per strip crimped in opposite directions on or near centerline. See charts for available styles. N/A with single row 1 or 2 positions. Recommended hole size (1,02mm ± 0,03mm) .040" ± .001" Straight Pin Versions STYLE –LA –LL = Locking Lead = Double Row (5,08mm) .200" row space = Matte Tin .025" SQ TERMINAL STRIP (TSW) Requires 4 pin minimum (NA with -T,-Q,-RA or -RE) (1,27) .050 –Q Tail IDSS or IDSD STRIP ASSEMBLY LOCKING CLIP PC BOARD = Triple Row = 10µ" (0,25µm) Gold on contact area, Gold flash on balance = Locking Clip (Styles –08 thru –13 & –22 only) = Right Angle = Double Row Elevated Right Angle option. Call Samtec. –LC – RA or –RE = Single Row = Gold flash on contact area, Matte Tin on tail ALSO AVAILABLE OTHER OPTIONS (1,52) .060 (4,06) .160 (2,54) .100 –RA Options WWW.SAMTEC.COM (2,54) .100 –RE Options (2,54) .100
HTSW-132-07-S-T-LL 价格&库存
很抱歉,暂时无法提供与“HTSW-132-07-S-T-LL”相匹配的价格&库存,您可以联系我们找货
HTSW-132-07-S-T-LL
  • 1+105.243901+13.61270
