BSW-135-04-T-D
BSW-135-04-T-D
    SAMTEC(申泰)
    BOTTOM MOUNT STRIPS
BSW-135-04-T-D 数据手册
F-215 BSW–110–24–T–S BSW–124–04–T–S–S BSW–115–04–G–D (2,54 mm) .100" BSW SERIES BOTTOM MOUNT SOCKET STRIPS Mates with: TSW, MTSW, HTSW, MTLW, TSM, EW, ZW, HW, DW, PHT NO. PINS PER ROW 1 BSW LEAD STYLE FEATURES –04 • Bottom mount socket strips accept .025" SQ terminals. • For low profile connections and high temperature soldering. For complete specifications and recommended PCB layouts see www.samtec.com?BSW Insulator Material: Black Thermoplastic Insulation Resistance: 5000 MΩ min Contact Material: Phosphor Bronze Plating: Au or Sn over 50µ" (1,27 µm) Ni Operating Temp Range: -55°C to +125°C with Gold -55°C to +105°C with Tin Withstanding Voltage: 1000 VRMS @ 60 Hz Contact Resistance: 10 mΩ Insertion Depth: (3,68 mm) .145" to (6,35 mm) .250" Insertion Force: (Single contact only) Standard = 8 oz (2,23 N) avg. Low Insertion Force = 3 oz (0,83 N) avg. Withdrawal Force: (Single contact only) Standard = 8 oz (2,23 N) avg. Low Insertion Force = 3 oz (0,83 N) avg. RoHS Compliant: Yes Lead-Free Solderable: Wave only = Low Insertion Force –S, –M, –E (MOQ Required) (0,79) .031 TYP Row Option –S* –M –E –D* • Other platings Contact Samtec. Z (4,31) .170 *Less (3,43) .135 (0,38 mm) .015" with standoffs (2,54) .100 FILE NO: 090871_0_000 (0,38) .015 –T = Matte Tin (N/A with Low Insertion Force) (–S & –D only) (4,32) .170 (No. of Pos. X (2,54) .100) + (0,51) .020 01 36 X Y 72 –S –M –E –S = Single Row Row Option 02 –S (2,54) .100 (10,16) .400 (2,54) .100 (2,54) .100 71 –M –D –E X Y (2,54) .100 (3,81) .150 (4,31) .170 (5,08) .200 (6,35) .250 (6,86) .270 Body design may vary slightly from drawing shown. 01 Row –M = Single More Plug Space Row –E = Single Extended Plug Space –D = Double Row APPLICATIONS BSW (SINGLE ROW) BSW (DOUBLE ROW) RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality –G ALSO AVAILABLE –D –S = 20µ" (0,51 µm) Gold contact, Gold Flash on tail (8,89) .350 (2,54) .100 TYP OTHER OPTION = Standoffs for single and double rows only. = 10µ" (0,25 µm) Gold contact, Matte Tin on tail –24 (0,41) .016 TYP Z ROW OPTION –L = Standard Lead 02 thru 36 • Ideal for soldering and plugging from the same side of the board. SPECIFICATIONS PLATING OPTION COMPONENT SIDE EW (SINGLE ROW) PC BOARD SOLDER SIDE PC BOARD TSW (SINGLE ROW) TSW (DOUBLE ROW) BSW (SINGLE ROW) Note: Some lengths, styles and options are non-standard, non-returnable. WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice.
BSW-135-04-T-D
物料型号:BSW系列,包括BSW–115–04–G–D、BSW–124–04–T–S–S和BSW–110–24–T–S等型号。
器件简介:BSW系列是底部安装插座条,适用于与TSW、MTSW、HTSW等系列的连接器配合使用,适合从PCB的同一侧进行焊接和插拔,适用于低轮廓连接和高温焊接。
引脚分配:提供了单排和双排的引脚分配选项,以及不同的引脚长度和样式。
参数特性:包括绝缘材料、接触材料、镀层、操作温度范围、耐压、接触电阻、插入深度、插入力和保持力等。
功能详解:BSW系列插座条设计用于从PCB的底部进行连接,支持不同的引脚配置和选项,以满足不同的应用需求。
应用信息:适用于需要低轮廓连接和高温焊接的应用场景。
封装信息:提供了不同行选项和镀层选项的详细信息,以及推荐的PCB布局。
BSW-135-04-T-D 价格&库存
很抱歉,暂时无法提供与“BSW-135-04-T-D”相匹配的价格&库存,您可以联系我们找货
