F-218
MLE–120–01–G–DV
MLE–150–01–G–DV
10 YEAR MFG
WITH 30 µ" GOLD
EXTENDED LIFE
PRODUCT
CLM–126–02–F–D
CLM–111–02–L–D
HIGH MATING
CYCLES
(1.00 mm) .0394"
CLM, MLE SERIES
RUGGED RELIABLE MICRO SOCKETS
SPECIFICATIONS
CLM
For complete specifications and
recommended PCB layouts
see www.samtec.com?CLM
or www.samtec.com?MLE
Insulator Material:
Black LCP
Contact Material:
CLM: Phosphor Bronze
MLE: BeCu
Plating:
CLM: Au or Sn
over 50 µ" (1.27 µm) Ni
MLE: Au over 10 µ"
(0.25 µm) Ni
Current Rating (CLM/FTM):
2.8 A per pin
(2 pins powered)
Current Rating (MLE/FTM):
2.9 A per pin
(2 pins powered)
Operating Temp Range:
-55 °C to +125 °C
Max Cycles:
CLM: 100 with 10 µ" (0.25 µm) Au
Voltage Rating:
MLE: 310 VAC
Insertion Depth:
CLM: Top Entry = (1.40 mm)
.055" min., Bottom Entry =
(2.41 mm) .095" min.
(Add board thickness for
correct post OAL)
MLE: (1.63 mm) .064" to
(3.18 mm) .125" with
(0.38 mm) .015" wipe,
pass-through, or
(2.44 mm) .096" minimum
for bottom entry
Normal Force:
CLM: 40 grams (0.39 N) average
RoHS Compliant:
Yes
Lead-Free Solderable:
Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max (02-25)
(0.15 mm) .006" max (26-50)
RECOGNITIONS
For complete scope of
recognitions see
www.samtec.com/quality
NO. PINS
PER ROW
1
PLATING
OPTION
02
Mates with:
FTM, FTMH, MW
D
–F
–BE
= Gold flash on
contact,
Matte Tin on tail
02 thru 50
= Bottom Entry
(Required for bottom entry)
–L
(1.00)
.03937
No. of positions x (1.00) .03937
+ (0.318) .0125
100
02
–P
= Pick & Place Pad
(7 positions minimum)
–P
01
(0.28)
.011
(2.26)
.089
(2.12)
.084
PIN/ROW
A
04-15
(3.56)
.140
(7.11)
.280
16-50
–PA
(8.26) .325
by A
(3.81)
.150
APPLICATION
= (3.50 mm) .138" DIA
Polyimide film Pick & Place Pad
(2.41)
.095
(2.54)
.100
(1.00)
.03937
–K
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
(5.72)
.225
x
(3.57)
.140
(1.36)
.054
= Pick & Place Pad with
integral Alignment Pin
(3.00)
.118
–PA
ALSO AVAILABLE
(MOQ Required)
• Alignment pin
• Other Gold plating options
Contact Samtec.
1
NO. PINS
PER ROW
01
Mates with:
FTM, FTMH, MW
PLATING
OPTION
DV
–G
FILE NO. E111594
No. of positions
x (1.00) .03937 + (0.20) .008
(0.71)
.028
(1.00)
02 .03937
(3.07)
.121
(1.00)
.03937
(0.30)
.012
01
(4.32)
.170
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
(3.12)
.123
(0.64)
.025
DIA
= Alignment Pin
(3 positions minimum)
Metal or plastic at Samtec
discretion
–K
= (4.00 mm) .1575" DIA
(5 positions minimum)
–A
–P
(6.35)
.250
x
(3.18)
.125
(3.30)
.130
= Metal Pick & Place Pad
(3.50)
.138
–TR
= Tape & Reel Packaging
–P
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
OPTIONS
–A
= 10 µ"
(0.25 µm)
Gold
02 thru 50
100
–TR
(0.89) .035
DIA
(7.00)
.275
Pass-Thru
MLE
OPTIONS
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
很抱歉,暂时无法提供与“CLM-138-02-L-D-K”相匹配的价格&库存,您可以联系我们找货
