ERM8-010-01-L-D-EM2-DS-TR
    SAMTEC(申泰)
    P=0.8mm
    板对板连接器 板边缘,跨骑式安装 针脚数:20Pin 间距:0.8mm 排数:2
ERM8-010-01-L-D-EM2-DS-TR 数据手册
RUGGED HIGH-SPEED STRIPS FEATURES & BENEFITS Edge Rate® rugged high-speed connector strips are designed for high-speed, high cycle applications, and enabled by Samtec's signal integrity-optimized Edge Rate® contact system. • Up to 1.5 mm contact wipe for a reliable connection • 20 to 200 positions • Choice of 0.50 mm, 0.635 mm or 0.80 mm pitch • 0.50 mm pitch system offers up to 40% PCB space savings vs. 0.80 mm pitch • 0.635 mm pitch system with extremely slim 2.5 mm body width • Rugged latching, extended guide posts and 360° shielding Signal integrity-optimized Edge Rate® contact system reduces broadside coupling • Severe Environment Testing qualified (ERM8/ERF8); aligns with MIL-DTL-55302. Visit samtec.com/set EDGE RATE® STACK HEIGHT FLEXIBILITY (shown in mm) 5 7 8 ERM6/ ERF6 10 9 12 11 ERM5/ERF5 13 14 15 16 18 17 ERM8/ERF8 Rugged 360º shielding reduces EMI KEY SPECIFICATIONS SERIES PITCH ERM5 / ERF5 0.50 mm ERM6 / ERF6 0.635 mm ERM8 / ERF8 0.80 mm F-224 INSULATOR MATERIAL TERMINAL MATERIAL Phosphor Bronze or BeCu (ERM5), BeCu (ERF5) Black LCP Copper Alloy Phosphor Bronze or BeCu (ERM8), BeCu (ERF8) PLATING Au or Sn over 50 µ" (1.27 µm) Ni OPERATING TEMP RANGE -55 °C to +125 °C CURRENT RATING VOLTAGE RATING 1.5 A 190 VAC 1.4 A 155 VAC 1.4 A 225 VAC LEAD-FREE SOLDERABLE Yes samtec.com/EdgeRate Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. (0.80 mm) .0315" PITCH • RIGHT-ANGLE & EDGE MOUNT HIGH-SPEED HEADERS - ERM8 Right-Angle Terminal POSITIONS PER ROW - 01 –010, –013, –020, –025, –030, –040, –049, –050, –060, –070, –075 - - PLATING OPTION D RA - - OPTIONS –L –K = 10 µ" (0.25 µm) Gold on contact area, Matte Tin on tail –TR = (6.00 mm) .236" DIA Polyimide Film Pick & Place Pad = Tape & Reel –FR –L = Full Reel Tape & Reel (must order maximum quantity per reel; contact Samtec for quantity breaks) = Latching –DS ERM8-RA Board Mates: ERF8 Cable Mates: ERCD (5.75) .226 No. of Positions x (0.80) .0315 + (13.00) .512 "X"R = Differential Pair (–013, –025 Positions only) (Hot Swap) (11.00) .433 (6.25) .246 (7.52) .296 –L View complete specifications at: samtec.com?ERM8-RA ERM8 - Edge Mount Terminal POSITIONS PER ROW –010, –013, –020, –025, –030, –040, –049, –050, –060, –070, –075 - 01 PLATING OPTION –L = 10 µ" (0.25 µm) Gold on contact area, Matte Tin on tail - D - EM2 = (1.60 mm) .062" Thick PCB - OPTIONS –L "X"R –TR = Latching (Mates to ERF8 Lead Style –05.0 or –RA Only) = Tape & Reel –FR –DS = Full Reel Tape & Reel (must order maximum quantity per reel; contact Samtec for quantity breaks) = Differential Pair (–013 & –025 Positions only) (Hot Swap) –EGPS = Extended Guide Post Shield (–010, –020, –025, –030 Positions Only) –DSS = Differential Pair + Extended Guide Post Shield (–025 Positions Only) (Hot Swap) ERM8-EM Board Mates: ERF8 Cable Mates: ERCD No. of positions x (0.80) .0315 + (9.00) .354 EGPS = No. of positions x (0.80) .0315 + (10.00) .394 (3.82) .150 (3.20) .126 Note: Some lengths, styles and options are non-standard, non-returnable. (5.60) .220 (5.70) .224 (6.80) .268 (12.95) 0.51 –L –L (14.79) .582 –EGPS View complete specifications at: samtec.com?ERM8-EM samtec.com/EdgeRate Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-224
- 物料型号: ERM5/ERF5, ERM6/ERF6, ERM8/ERF8 - 器件简介: Edge Rate®高速连接器条设计用于高速、高循环应用,采用信号完整性优化的Edge Rate®接触系统。 - 引脚分配: 提供了不同系列的引脚分配信息,例如ERM8/ERF8系列的引脚分配。 - 参数特性: 包括接触间距、绝缘体材料、端子材料、镀层、工作温度范围、电流额定值、电压额定值和无铅焊接能力。 - 功能详解: 包括减少侧面耦合的信号完整性优化接触系统和减少EMI的360°屏蔽。 - 应用信息: 适用于高速数据传输和高循环应用,符合MIL-DTL-55302标准。 - 封装信息: 提供了不同系列的封装尺寸和选项,如ERM8/ERF8系列的封装信息
ERM8-010-01-L-D-EM2-DS-TR 价格&库存
很抱歉,暂时无法提供与“ERM8-010-01-L-D-EM2-DS-TR”相匹配的价格&库存,您可以联系我们找货
    • 1+87.48000
    • 250+34.90560
    • 500+33.73920
    • 1000+33.16680
