ESQT-109-02-GF-D-700
    SAMTEC(申泰)
    插件,P=2mm
    排母 间距:2mm 2x9P 直插
ESQT-109-02-GF-D-700 数据手册
FLEXIBLE ELEVATED & SELF-NESTING SOCKETS (2.00 mm) .0787" PITCH • ESQT/ESQT (-368)/PTHF SERIES ESQT Board Mates: TMMH, TMM, MTMM, MMT, TW, LTMM, ZLTMM, ESQT, PTT, TSH, TMMS Cable Mates: TCMD ESQT -1 NO. PINS PER ROW - 02 thru 50 SPECIFICATIONS Insulator Material: Black Liquid Crystal Polymer Contact Material: Phosphor Bronze Plating: Sn or Au over 50 µ" (1.27 µm) Ni Current Rating (ESQT/TMMH): 4.5 A per pin (2 pins powered) Operating Temp Range: -55 °C to +125 °C Insertion Depth: (2.62 mm) .103" to (5.03 mm) .198" with (0.38 mm) .015" wipe Max Cycles: 100 with 10 µ" (0.25 µm) Au Lead–Free Solderable: Yes, for -S, -D & -Q (Wave only for -T, -5 & -6) ESQT (-368)/PTHF Mates: ESQT, PTHF SPECIFICATIONS Insulator Material: Black Liquid Crystal Polymer (ESQT-368) Black High Temp Nylon (PTHF) Contact Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +125 °C Max Cycles: 100 with 10 µ" (0.25 µm) Au Lead–Free Solderable: Yes (ESQT-368) - LEAD STYLE = Single Row –L = Double Row = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail Gold on contact, Matte Tin on tail No. of rows x (2.00) .0787 –GF LEAD STYLE A –03 ESQT NO. PINS PER ROW 30 = Solder Tails PTHF = Press-fit Tails F-224 –D OTHER OPTION –“XXX” = Polarized Position (Indicate position number) (7.87 mm) .310" minimum for –S, –D, –Q –T (9.53 mm) .375" minimum for –T, –5, –6 –Q = Quad Row No. of –5 rows x = Five Row (2.00) .0787 –6 - .250 A MAX TAIL BODY MAX BODY (1.27) TAIL HEIGHT HEIGHT (21.59) (13.72) .850 .540 (11.63) (3.76) .458 .148 LEAD STYLE Specify LEAD STYLE from chart - TAIL (1.27) .050 MIN BODY HEIGHT A .050 (20.32) MIN .800 (10.36) .408 - PLATING OPTION - Q 368 –GF = 15 µ" (0.38 µm) Gold on contact, Gold flash on tail (–02 Lead Style only) –M = 20 µ" (0.51 µm) Gold on contact, Matte Tin on tail (–03 Lead Style only) LEAD STYLE –02 (8.00) .315 –03 ESQT PTHF A B A (21.59) .850 (11.63) .458 (12.24) .482 (2.29) .090 (21.59) .850 (12.34) .486 (60.30) 2.374 TOOLING Note: This Series is non-standard, non-returnable. –“XXX” = Body Height (in inches) = Triple Row (6.35) .250 Press-Fit CAT-PT-PT-130-A-4 For more information, visit www.samtec.com/tooling - BODY HEIGHT = 15 µ" (0.38 µm) Gold on contact, = Six Row Gold flash on tail (Recommended for self-nesting) (–02 lead style only) (6.35) –02 -1 –S = Gold flash on contact, Matte Tin on tail No. of positions–M x (2.00) .0787=+ 20 (0.30) .012 µm) µ" (0.51 (6.35) .250 - ROW OPTION –F Specify LEAD STYLE from chart No. of positions x (2.00) .0787 + (0.30) .012 SERIES - PLATING OPTION (9.35) .368 A A B ESQT (—368) SERIES samtec.com?ESQT or samtec.com?PTHF B PTHF SERIES Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. B (12.24) .482 (3.00) .118
物料型号为ESQT/ESQT (-368)/PTHF系列。
器件简介包括灵活的高架和自嵌套插座,绝缘材料为黑色液晶聚合物,接触材料为磷青铜,镀层为锡或金覆盖50微英寸(1.27微米)镍。
电流额定值(ESQT/TMMH)为每针4.5安培(2针供电),工作温度范围为-55°C至+125°C,插入深度为2.62毫米(0.103英寸)至5.03毫米(0.198英寸),最大周期数为100次。
引脚分配参数特性包括多种引脚排列和行数,例如单行、双行、三行和四行,以及不同的引脚样式和镀层选项。
例如,-02引脚样式具有21.59毫米(0.850英寸)的高度,-03引脚样式具有11.63毫米(0.458英寸)的高度。
功能详解应用信息包括自嵌套功能,适用于需要灵活连接的应用场景。
封装信息提供了详细的尺寸和引脚配置,以及与ESQT和PTHF系列兼容的详细信息。
请注意,这个PDF文档可能还包含更多详细信息,如果需要更深入的分析,请提供具体问题。
ESQT-109-02-GF-D-700 价格&库存
很抱歉,暂时无法提供与“ESQT-109-02-GF-D-700”相匹配的价格&库存,您可以联系我们找货
  • 1+43.139671+5.60711
