FFMD-17-T-30.00-01-N
    SAMTEC(申泰)
    .050 CABLE PLUG
FFMD-17-T-30.00-01-N 数据手册
F-218 FFMD–20–T–02.00–01–N–R TIGER ™ IDC EYE (1.27 mm) .050" FFMD–10–S–10.00–01 FFMD SERIES TIGER EYE FLAT IDC WIRE CABLES ™ Mates with: FLE*, SFMC*, Transfer End Option Mates with: FTS, FTSH, EHF, SHF, ESHF TYPE STRIP END OPTION NO. PINS PER ROW OVERALL LENGTH SPECIFICATIONS 01 –“XX.XX” For complete specifications see www.samtec.com?FFMD Leave blank for –S and –D End Options. = Assembled Length Insulator Material: Black Glass Filled Polyester Terminal: Phosphor Bronze Contact: BeCu (-T) Plating: Sn over 50 µ" (1.27 µm) Ni Wire: 30 AWG Current Rating: 2.5 A per pin (2 pins powered) Operating Temp Range: -40 °C to +105 °C Voltage Rating: 215 VAC 304 VDC RoHS Compliant: Yes –N Assembled Length in INCHES (± .130") 2 inches minimum –04, –05, –08, –10, –13, –17, –20, –25 = Notch Polarization on socket (-T end only) (Not available with -04 position) (Standard sizes) –S = Single End RECOGNITIONS –T = Transfer End –D = Double End Reverse Daisy –RW = Wiring –D “XX” = Chain For complete scope of recognitions see www.samtec.com/quality (50.8 mm) 2.00 min. –R = Reverse Outside –O = Reverse ± 1/8" 3 01 (MOQ Required) • Other sizes Contact Samtec. 3 (101.60 mm) 4.00 min. Red wire opposite position #1. 1 2 Requires –DXX Not available with –O, –M, –R or –DXX 3 • Strain relief option FFMD = Terminal Strip 01 (3.05) .120 No. of positions x (1.27) .050 + (4.19) .165 (5.08) .200 *Note: Standard FFMD callout will not mate with FLE, SFMC. Must use gold plated callouts. (See drawing on web.) When mated with a socket, Wire 1 mates with Pin 2; Wire 2 mates with Pin 1, etc. Note: This Series is non-standard, non-returnable. No. of positions x (1.27) .050 + (8.00) .315 Requires –DXX Middle –M = Reverse ALSO AVAILABLE Strain –SR = Relief (Mates only with ESHF Series) “XX” FILE NO. E111594 02 OTHER OPTION TRANSFER OPTION (3.07) .121 (0.41) .016 SQ (1.27) .050 Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
FFMD-17-T-30.00-01-N 价格&库存
很抱歉,暂时无法提供与“FFMD-17-T-30.00-01-N”相匹配的价格&库存,您可以联系我们找货
  • 1+195.629981+25.42600
