FLE-129-01-G-DV-A-K
FLE-129-01-G-DV-A-K
    SAMTEC(申泰)
    .050 MICRO STRIPS
FLE-129-01-G-DV-A-K 数据手册
COST-EFFECTIVE RELIABLE SOCKET 8 G b p s (1.27 mm) .050" PITCH • FLE SERIES FLE Board Mates: FTSH, FTS, FW Cable Mates: FFMD*, FMTP FLE -1 NO. PINS PER ROW - 01 - 02 thru 50 *Note: Standard FFMD callout will not mate with FLE, SFMC. Must use gold plated callouts. (See drawing on web.) PLATING OPTION - –G DV - OPTION –A = 10 µ" (0.25 µm) Gold = Alignment Pin (Metal or plastic at Samtec discretion) (3 positions minimum) –K = (4.25 mm) .167" DIA Polyimide film Pick & Place Pad (5 positions minimum) SPECIFICATIONS Insulator Material: Black Liquid Crystal Polymer Contact Material: Phosphor Bronze Plating: Au over 50 µ" (1.27 µm) Ni Current Rating: 2.9 A per pin (2 pins powered) Operating Temp Range: -55 °C to +125 °C Insertion Depth: (1.83 mm) .072" to (4.37 mm) .172" or pass-through Max Cycles: 100+ –P = Metal Pick & Place Pad (5 positions minimum) –TR = Tape & Reel –FR = Full Reel Tape & Reel (must order maximum quantity per reel; contact Samtec for quantity breaks) PROCESSING Lead-Free Solderable: Yes SMT Lead Coplanarity: (0.10 mm) .004" max 1RRI3RVLWLRQV[         ALSO AVAILABLE Other Plating (MOQ Required)     —P OPTION 10 YEAR MFG WITH 30 µ" GOLD EXTENDED LIFE PRODUCT HIGH MATING CYCLES Note: Some lengths, styles and options are non-standard, non-returnable. samtec.com?FLE Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-224
FLE-129-01-G-DV-A-K
1. 物料型号:FLE系列,具有不同的引脚配置选项。 2. 器件简介:这是一种成本效益高且可靠的插座,具有1.27毫米的引脚间距。 3. 引脚分配:文档中提到了不同数量的引脚每排,从01到50+。 4. 参数特性: - 绝缘体材料:黑色液晶聚合物 - 接触材料:磷青铜 - 镀层:金层覆盖在50微米(1.27微米)镍上 - 电流额定值:每针2.9安培(2针供电) - 操作温度范围:-55°C至+125°C - 插入深度:1.83毫米至4.37毫米或通孔 - 最大周期:100+ 5. 功能详解:文档提到了不同的镀层选项,如10微米(0.25微米)金和30微米金的延长寿命产品。 6. 应用信息:适用于需要高插拔次数和高可靠性的应用。 7. 封装信息:提供了不同的封装选项,如对齐销、聚酰亚胺膜Pick & Place Pad、金属Pick & Place Pad和带卷轴的卷带。
FLE-129-01-G-DV-A-K 价格&库存
很抱歉,暂时无法提供与“FLE-129-01-G-DV-A-K”相匹配的价格&库存,您可以联系我们找货
FLE-129-01-G-DV-A-K
  • 15+63.4105815+8.21922
