FTR-134-52-S-D-P-A-TR 数据手册
F-217
FTR–110–52–G–S
FTR–107–02–G–D–A
(1.27 mm) .050"
FTR–132–52–G–D–P
FTR SERIES
SMT MICRO HEADER
SPECIFICATIONS
Single and
double row
Mates with:
RSM, SMS, SLM
For complete specifications and
recommended PCB layouts
see www.samtec.com?FTR
Insulator Material:
Black Liquid Crystal Polymer
Terminal Material:
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Current Rating (FTR/RSM):
3.1 A per pin
(1 pin powered per row)
Operating Temp Range:
-55 °C to +105 °C with Tin;
-55 °C to +125 °C with Gold
RoHS Compliant:
Yes
(2.54 mm)
.100"
OPTIONS
–P OPTION
Surface
mount
PROCESSING
RECOGNITIONS
For complete scope of
recognitions see
www.samtec.com/quality
Available with optional
pick & place pad
Micro pitch
(1.27 mm) .050"
Lead-Free Solderable:
Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max (02-20)
(0.15 mm) .006" max (21-40)
FTR
1
NO. PINS
PER ROW
FILE NO. E111594
02 thru 40
ALSO AVAILABLE
LEAD
STYLE
PLATING
OPTION
Specify
LEAD
STYLE
from
chart
= 10 µ" (0.25 µm)
Gold on post,
Matte Tin on tail
• Other platings
Contact Samtec.
40
(1.27) .050 x
No. of Positions
01
–S
–L
= Single
Row
–D
–G
(MOQ Required)
(10.16)
.400
x
(5.08)
.200
ROW
OPTION
= Double
Row
= 10 µ" (0.25 µm)
Gold on post,
Gold flash on tail
(1.27)
.050
(1.27)
.050 TYP
80
(1.27)
.050
79
(0.46)
.018
SQ
Note: Some sizes, styles and
options are non-standard,
non-returnable.
(5.84) .230
(2.54) .100
(3.18) .125
(4.83) .190
(5.21) .205
(7.24) .285
(8.51) .335
(9.91) .390
(10.29) .405
(10.92) .430
–P
(1.02)
.040
(1.09)
.043 DIA
–A OPTION
(2.54)
.100
(1.27)
.050
(0.46)
.018
SQ
= Plastic Pick
& Place Pad
(–D = 5 positions
minimum)
(–S = 8 positions
minimum)
–TR
–P OPTION
B
(0.51)
.020
–A
= Alignment Pin
(5 positions
minimum –D only)
(Metal or plastic at
Samtec discretion)
(N/A with -LC)
= Locking Clip
(6 positions
minimum –D only)
(N/A with -A)
(Manual placement
required)
B
–01
–02
–03
–51
–52
–53
–54
–55
–56
–57
(9.53) (9.91)
.375 x .390
(4.98) (7.52)
.196 .296
01
LEAD
STYLE
–P OPTION
(2.54)
.100
–“XX”
= Polarized
–LC
(2.48)(5.03)
.098 .198
02
OPTION
(1.27)
.050
B
(1.27)
.050
–S OPTION
= Tape & Reel
(–S = 4 positions
minimum)
(0.46)
.018
SQ
(1.40)
.055
–D OPTION
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
–LC OPTION
FTR-134-52-S-D-P-A-TR 价格&库存
很抱歉,暂时无法提供与“FTR-134-52-S-D-P-A-TR”相匹配的价格&库存,您可以联系我们找货
