FTS-113-01-F-D-P
FTS-113-01-F-D-P
    SAMTEC(申泰)
    排针 直插
FTS-113-01-F-D-P 数据手册
MICRO LOW PROFILE TERMINAL STRIPS (1.27 mm) .050" PITCH • FTS SERIES FTS FTS Board Mates: CLP, FLE Cable Mates: FFSD -1 - NO. PINS PER ROW 02 thru 50 (except –S & –SA option = 05 thru 46) SPECIFICATIONS LEAD STYE - PLATING OPTION –01 –F = (3.05 mm) .120" Post (Mates with FFSD) = Gold flash on post, Matte Tin on tail –02 Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Operating Temp Range: -55 °C to +125 °C Plating: Sn or Au over 50 µ" (1.27 µm) Ni Current Rating: 3.4 A per pin (2 pins powered) = (1.91 mm) .075" Post (Mates with FLE) –03 = (1.65 mm) .065" Post (Mates with CLP) - - ROW OPTION –D (–D & –DV only) –DV = End Shroud with Alignment Pin (05 thru 46 positions. Style -02 & -03 only) = Double Through-hole –SA = Double Vertical SMT –L = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail –S –S = End Shroud (05 thru 46 positions. Style -02 & -03 only) = Single Through-hole –SV –P = Single Vertical SMT –04 = Pick & Place Pad (04 positions min.) = (3.81 mm) .150" Post (–D & –DV only) PROCESSING Lead–Free Solderable: Yes SMT Lead Coplanarity: .004" (0.10 mm) max OTHER OPTION –TR = Tape & Reel (-DV only) (Required callout for positions 02 thru 04) 1RRISRVLWLRQV[   –FR         = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) (-DV only) ALSO AVAILABLE Alignment pin (MOQ Required) 1RRISRVLWLRQV[      ²6$ 1RRISRVLWLRQV[      ²6 OPTIONS   —TR OPTION     (Shrouded option removed for clarity) Note: Some lengths, styles and options are non-standard, non-returnable. F-224 A –01 (3.05) .120 –02 (1.91) .075 –03 (1.65) .065 –04 (3.81) .150   $ —SA OPTION —P OPTION LEAD STYLE —S —SV $ —DV —D —S OPTION —P OPTION —S OPTION —SA OPTION samtec.com?FTS Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
FTS-113-01-F-D-P
1. 物料型号:FTS系列,具有不同的引脚排列和选项。 2. 器件简介:这些是微型低压端子条,适用于多种应用,包括与CLP和FLE电缆配合使用。 3. 引脚分配:提供不同数量的引脚排列,从21到142个引脚不等。 4. 参数特性: - 绝缘体材料:黑色液晶聚合物 - 端子材料:磷青铜 - 操作温度范围:-55°C至+125°C - 电流额定值:每针3.4A(2针供电) - 端子镀层选项:金闪镀层和尾部镀锡,或10微英寸金镀层和尾部镀锡 5. 功能详解: - 提供了不同的引脚样式和选项,如双通孔、单垂直SMT、端部护罩等。 - 引脚共面性:最大0.004英寸(0.10毫米)。 6. 应用信息:适用于需要微型端子的应用,如与FFSD、FLE和CLP电缆配合使用。 7. 封装信息:提供了不同尺寸的端子柱,以适应不同的配合需求。
FTS-113-01-F-D-P 价格&库存
很抱歉,暂时无法提供与“FTS-113-01-F-D-P”相匹配的价格&库存,您可以联系我们找货
