HCMD-17-D-10.00-02-S
    SAMTEC(申泰)
    SAMTEC - HCMD-17-D-10.00-02-S - Ribbon Cable, IDC Plug to IDC Plug, 34 Ways, 10 ", 254 mm, 2.54 mm, ...
HCMD-17-D-10.00-02-S 数据手册
F-224 Web HCMD–10–S–03.00–01 (2.54 mm) .100" IDC SOCKET & TERMINAL CABLE Mates with: TSW, MTSW, TST, HTST, EW, ZST, MTLW, TSM, EJH-02 (HCSD only) TYPE STRIP ROW OPTION NO. PINS PER ROW S –05, –08, –10, –12, –13, –15, –17, –20 SPECIFICATIONS For complete specifications and recommended PCB layouts see www.samtec.com?HCSD or www.samtec.com?HCSS = Single D HCSD, HCSS Insulator Material: Black Liquid Crystal Polymer Flammability Rating: UL 94V-O Temperature Range: -20 °C to +105 °C (Rainbow Cable) -40 °C to +105 °C (Gray Cable) Voltage Rating: 425 VAC/600 VDC Contact: Phosphor Bronze Plating: 10 µ" (0.25 µm) Au on contact area, 150 µ" (3.81 µm) Sn on balance over 50 µ" (1.27 µm) Ni. Lead Size Range: .024" (0.61 mm) SQ to .026" (0.66 mm) SQ Lead Insertion Depth: .185" (4.70 mm) to .250" (6.35 mm) Wire: 28 AWG 7/36 stranded Tinned Copper RoHS Compliant: Yes SPECIFICATIONS = Double (Color coded cable N/A for 36 pins/row. See –G option.) Assembled Length in INCHES (±1/8") 2 inches minimum (3.30) .130 –S = Single End (5.08) .200 (7.87) .310 REF (0.51) .020 (0.64) .025 SQ TYP (2.54) .100 LEAD STYLE –01 –02 HCMD, HCMS Socket or Male Plug on one end A Single (HCMS) (2.54) .100 –D = Double End Double (HCMD) A (3.05) .120 (5.84) .230 HCS = Socket Strip No. of Positions x .100 (2.54) + .180 (4.57) Socket or Male Plug on each end (5.08) .200 (3.30) .130 –T = Transfer End (9.53) .375 REF (2.54) .100 Note: IDC assemblies are non-standard, non-returnable. –“XX.XX” HCM No. of Positions x .100 (2.54) + .180 (4.57) ASSEMBLED LENGTH = Assembled Length = Male Strip For complete specifications and recommended PCB layouts see www.samtec.com?HCMD or www.samtec.com?HCMS Insulator Material: Black Liquid Crystal Polymer Flammability Rating: UL 94V-O Temperature Range: -20 °C to +105 °C (Rainbow Cable) -40 °C to +105 °C (Gray Cable) Voltage Rating: 425 VAC/600 VDC Terminal: Phosphor Bronze Plating: Sn over 50 µ" (1.27 µm) Ni Wire: 28 AWG 7/36 stranded Tinned Copper RoHS Compliant: Yes END ASSEMBLY (0.76) .030 SQ. Single TYP. (HCSS) (2.54) .100 Double (HCSD) Male Plug on one end with socket on other. Begin part number with HCM. WWW.SAMTEC.COM Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. HCSS–15–S–03.00–01–G HCSD–10–S–03.00–01–T–G HCMD, HCMS, HCSD, HCSS SERIES LEAD STYLE PLATING OPTION –N = Notch Polarization –S –01 = HCSS/HCSD or (3.05 mm) .120" tail for HCMS/HCMD = 10 µ" (0.25 µm) Gold on contact area or tail, Tin on balance (Standard on HCSS & HCSD. Leave blank) –02 –T 01 (3.81) .150 Required for HCSS and HCSD. (Not available on HCMS or HCMD, unless Transfer, then only the socket is polarized.) –S “XX” –ST “X” –P “XX” (50.80) 2.00 min. Specify Suffix from table. All dimensions are ± 1/16" (1.59 mm). Not available in 28 positions and higher. 02 01 04 03 02 04 –R = Daisy Chain Single = Stripped & Tinned = Position Polarization 02 (1.27) .050 = Tin (Standard on HCMS & HCMD. Leave blank) = (5.84 mm) .230" tail HCMS/HCMD only OTHER OPTIONS NOTCH POLARIZATION = Reversed “XX” ± /8" (3.18) 1 Single Row Connectors 01 Outer Most (End of Assembly) 03 (101.60) 4.00 minimum Single –ST8 –ST4 –ST2 –ST3 Double Specify “XX” as position. For Double the same position will be polarized on both ends. (Not available on HCM, unless Transfer, then only the socket is polarized) When mating double row connector with two single row connectors, the outer most single will be connected to Conductor #1 and the inside single to Conductor #2. 6 /8" (3.18) 1 /4" (6.35) 1 /2" (12.70) 3 /8" (9.53) 1 –M = Middle Reversed –D “XX” 3 –B “XX” 7 = Daisy Chain, Double = Breakout (50.80) 2.00 min. Specify “XX” as number of conductors to be broken out. “XX” ± /8" (3.18) 1 Double Row Strips Requires –SXX, –WXX or –DXX 7 1 –G “XX” (101.60) 4.00 minimum (127.00) 5.00 max. Breakout starts with Number (50.80) 1 lead indicated by brown 2.00 min. wire or red stripe. Shown on top side. = Gray Cable Standard cable is color coded. Specify –G for Gray cable with one red edge. 2 Outer Most (End of Assembly) 4 –RW = Reversed Wiring #1 wire opposite position #1 5 –O = Outside Reversed 6 –W “XX” = Wiring Reversed Daisy Chain, Single Same as –S “XX” except outer strip connected to conductor #2 and inside strip connected to conductor #1. Requires –SXX, –WXX or –DXX 6 WWW.SAMTEC.COM Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. 7
物料型号:HCMD-10-S-03.00-01 器件简介:该产品是Samtec的IDC插座和端子电缆,用于与TSW, MTSW, TST, HTST, EW, ZST, MTLW, TSM, EJH-02等型号配对。 引脚分配:文档中未明确列出具体的引脚分配,但提到了单排和双排配置。 参数特性:绝缘材料为黑色液晶聚合物,UL 94V-0阻燃等级,温度范围为-20°C至+105°C(彩虹电缆)或-40°C至+105°C(灰色电缆),电压等级为425 VAC/600 VDC。 功能详解:该电缆组件具有多种配置选项,包括单端或双端装配,以及不同的引脚数量和排列。 应用信息:适用于需要高密度连接的应用,具体应用场景未在文档中详述。 封装信息:提供了详细的物理尺寸和引脚规格,以及多种引脚样式和极化选项。
HCMD-17-D-10.00-02-S 价格&库存
很抱歉,暂时无法提供与“HCMD-17-D-10.00-02-S”相匹配的价格&库存,您可以联系我们找货
