HSEC8-180-03-S-DV-A-K 数据手册
HIGH-SPEED
EDGE CARD SYSTEMS
0.60 mm, 0.80 mm and 1.00 mm PITCH
FEATURES & BENEFITS
• Maximum Design Flexibility
• Up to 64 Gbps PAM4 performance
• PCI Express® 3.0, 4.0, 5.0 and 6.0
• Edge Rate® contacts optimized for signal
integrity performance and high-cycle life
• Up to 200 positions available
• Vertical, right-angle, edge mount,
pass-through orientations
• Power/signal combo, press-fit tails,
rugged weld tabs, locks and latches
• Mating cable assemblies available
Rugged tucked
beam technology
(HTEC8)
KEY SPECIFICATIONS
Differential pair for
increased speed
(HSEC8-DP)
Custom designs allow
for misalignment in
the X-Y axes (HSEC1)
SERIES
PITCH
TOTAL
POSITIONS
INSULATOR
MATERIAL
CONTACT
MATERIAL
OPERATING
TEMP RANGE
CURRENT
RATING
VOLTAGE
RATING
LEAD-FREE
SOLDERABLE
HSEC6
0.60 mm
56-168
Black LCP
Copper Alloy
-55 ℃ to +125 ℃
1.9 A (2 pins)
240 VAC
Yes
HTEC8
0.80 mm
20-200
Black LCP
Copper Alloy
-55 ℃ to +125 ℃
3.0 A (2 pins)
215 VAC
Yes
HSEC8
0.80 mm
18-200
Black LCP
BeCu
-55 ℃ to +125 ℃
2.8 A (2 pins)
240 VAC
Yes
HSEC1
1.00 mm
20-140
Black LCP
Phosphor Bronze
-55 ℃ to +125 ℃
2.2 A (2 pins)
215 VAC
Yes
F-224 (Rev 04APR24)
samtec.com/EdgeCard
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
(0.80 mm) .0315" PITCH • VERTICAL EDGE CARD SOCKET
HSEC8
POSITIONS
PER ROW
1
09, 10,
13, 20, 25,
30, 37, 40,
49, 50, 60,
70, 80, 100
(13, 25, 49 only
available with
-L or -L2 latching
option; 09 only
available with
-L2 option;
37 only available
with -L latching
option)
CARD
THICKNESS
–01
PLATING
OPTION
DV
A
–L
= (1.60 mm)
.062" thick card
= 10 µ"
(0.25 µm)
Gold on
contact area,
Matte Tin
on tail
–03
= (2.36 mm)
.093" thick card
OTHER
OPTIONS
“X”R
–K
Leave blank for
Tray Packaging
–BL
= Tape & Reel
(09 - 70 only)
= Polyimide
Pick & Place Pad
= Board Locks;
–01 card only
(Weld tab standard)
–S
–L
= 30 µ"
(0.76 µm)
Gold on
contact area,
Matte Tin
on tail
= Latching Option;
–01 card only
(13, 25, 37, 49 only)
(Weld tab standard)
–L2
–TR
–FR
= Full Reel
Tape & Reel
(must order max.
quantities per reel;
contact Samtec for
quantity breaks)
(09-70 only)
= ECDP Latching;
–01 card only
(09, 13, 25, 49 only)
(For use with ECDP)
(Weld tab standard)
HSEC8-DV No. of Positions x (0.80) .0315 + (7.80) .307
–WT
= Weld tab
Card Mates:
(1.60 mm) .062" card,
(2.36 mm) .093" card,
HSC8
(7.00)
.276
A
B
Cable Mates:
ECDP
(7.98)
.314
(7.00)
.276
(No. of Positions + 6) x (0.80) .0315 + (0.60) .024
(1.32)
.052
A
B
No. of Positions
x (0.80) .0315 + (4.60) .181
(7.98)
.314
(5.60)
.220
No. of Positions x (0.80) .0315 + (2.20) .087
10, 20, & 30 POSITIONS
No. of Positions
OTHER SOLUTIONS
(5.60)
.220
For complete edge card system
with cards and sockets,
visit samtec.com?RU8
POSITIONS
PER ROW
B
CABLE
09*†
(4.50) .177
(11.80) .465
ECDP-04
For a card to mate with
an HSEC8 socket,
visit samtec.com?HSC8
13*†
(6.10) .240
(15.00) .591
ECDP-08
HSEC8-113-L2
25*†
(6.10) .240
(24.60) .969
ECDP-16
HSEC8-125-L2
37†
(18.10) .713
(34.20) 1.346
ECDP-32
HSEC8-149-L2
40
(18.90) .744
(36.60) 1.441
49*†
(22.90) .902
(43.80) 1.724
50
(22.90) .902
(44.60) 1.756
10 YEAR MFG
EXTENDED LIFE
PRODUCT
HIGH MATING
CYCLES
(1.32)
.052
09, 13, 25, 37 & 40
THRU 100 POSITIONS
A
60
(26.90) 1.059
(52.60) 2.071
70†
(26.90) 1.059
(60.60) 2.386
80†
(26.90) 1.059
(68.60) 2.701
100†
(26.90) 1.059
(84.60) 3.331
CONNECTOR
HSEC8-109-L2
Positions where no dimensions are given do
not have keying feature.
* Mates with ECDP Series
Note:
Some sizes, styles and
options are non-standard,
non-returnable.
† Available with -01 Card Only
View complete specifications at: samtec.com?HSEC8-DV
samtec.com/EdgeCard
F-224 (Rev 04APR24)
HSEC8-180-03-S-DV-A-K 价格&库存
很抱歉,暂时无法提供与“HSEC8-180-03-S-DV-A-K”相匹配的价格&库存,您可以联系我们找货
