HTMS-149-01-G-S-RA
HTMS-149-01-G-S-RA
    SAMTEC(申泰)
HTMS-149-01-G-S-RA 数据手册
F-215 HTMS–110–03–L–D–RA HTMS–107–01–G–S TMS–110–02–G–D TMS–132–51–G–S (1,27 mm) .050" TMS, HTMS, SNM SERIES THROUGH-HOLE MICRO HEADER SPECIFICATIONS Mates with: SMS, SLM, RSM For complete specifications see www.samtec.com?TMS or www.samtec.com?HTMS Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Au or Sn over 50µ" (1,27 µm) Ni Current Rating (TMS/SMS): 5 A per pin (1 pin powered per row) Operating Temp Range: -55°C to +105°C with Tin; -55°C to +125°C with Gold RoHS Compliant: Yes Important Note: Style -02 does not mate with SMS Series. MICRO SHUNT SNM SERIES Choice of Through-hole and Right Angle. See FTR Series for Surface Mount (1,27) .050 (2,54) .100 (3,30) .130 Part No. Plating SNM–100–BK–T Tin Thirteen terminal styles 10µ" SNM–100–BK–G (0,25 µm) Gold (1,27 mm x 2,54 mm) .050" x .100" pitch SNM For complete specifications see www.samtec.com?SNM Same as HTMS except: Insulator Material: Black Glass Filled Polyester Contact Resistance: 10 mΩ Lead Size accepted: (0,46 mm) .018" SQ Insertion Depth: (3,43 mm) .135" minimum Max Processing Temp: Not recommended for IR/VP TYPE STRIP 1 NO. PINS PER ROW LEAD STYLE 01 thru 50 Specify LEAD STYLE from chart TMS = Standard HTMS Processing: Lead-Free Solderable: Yes = High Temp T/H LEAD STYLE –01 –02 –21 –51 –52 –53 –54 –55 –56 –57 –58 –59 –60 RECOGNITIONS (1,27) .050 x No. of Positions For complete scope of recognitions see www.samtec.com/quality 50 01 (2,48) .098 (1,27) .050 TYP 02 100 (2,54) .100 (4,98) .196 ALSO AVAILABLE 99 (MOQ Required) 01 • Other platings Contact Samtec. A B (11,43) .450 (5,84) .230 (8,13) .320 (2,54) .100 (3,05) .120 (12,83) .505 (5,84) .230 (4,45) .175 (10,41) .410 (4,83) .190 –S –RA = Single Row = Right Angle –D –“XXX” = Double Row –G (15,49) .610 (9,91) .390 (15,88) .625 (10,29) .405 = Polarized Position (Specify position of omitted pin) = 10µ" (0,25 µm) Gold on post, Gold flash on tail RA LEAD STYLE (14,10) .555 (8,51) .335 –01 (3,05) .120 (16,51) .650 (10,92) .430 –02 (17,91) .705 (12,32) .485 –03 (19,18) .755 (13,59) .535 B (5,84) .230 (2,54) .100 (3,18) .125 (20,96) .825 (15,37) .605 (3,56) .140 B A C (3,56) .140 B (1,52) .060 C (0,51) .020 DIA SINGLE ROW –L = 10µ" (0,25 µm) Gold on post, Matte Tin on tail (12,83) .505 (7,24) .285 A (0,51) .020 OPTION (10,80) .425 (5,21) .205 B Note: Some lengths, styles and options are non-standard, non-returnable. C (0,46) .018 SQ (2,54) .100 ROW OPTION PLATING OPTION DOUBLE ROW HTMS –D Body Design (1,52) .060 (0,51) .020 DIA WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. (2,54) .100 B
HTMS-149-01-G-S-RA 价格&库存
很抱歉,暂时无法提供与“HTMS-149-01-G-S-RA”相匹配的价格&库存,您可以联系我们找货
