HTST-120-02-L-D
HTST-120-02-L-D
    SAMTEC(申泰)
    HIGH TEMP TOP SHROUD
HTST-120-02-L-D 数据手册
ZST–113–03–L–D–0735 F-215 HTST–125–01–L–DV (2,54 mm) .100" TST, HTST, ZST SERIES SHROUDED .025" SQ POST IDC HEADERS Mates with: IDSD, SMSD SPECIFICATIONS TYPE STRIP For complete specifications www.samtec.com?TST, www.samtec.com?HTST or www.samtec.com?ZST Insulator Material: Black Glass Filled Polyester (TST, ZST) Natural PCT (HTST) Insulation Resistance: 5000 MΩ min Terminal Material: Phosphor Bronze Plating: Au or Sn over 50µ" (1,27 µm) Ni Current Rating (IDSD/TST): 3.4 A per pin (1 pin powered per row) Operating Temp Range: -55°C to +125°C with Gold -55°C to +105°C with Tin Flammability Rating: UL 94V-O Withstanding Voltage: 1000 VRMS RoHS Compliant: Yes TST = Cable Strip LEAD STYLE PLATING OPTION 05, 07, 08, 10, 12, 13, 15, 17, 20, 25, 32, 36 Specify LEAD STYLE from chart. (Standard sizes.) HTST ROW OPTION OTHER OPTION –F –D = Gold flash on post, Matte Tin on tail (Not available on –DV) = Double Row Through-hole (lead style –01, –02 & –03 only) Surface Mount (lead style –01 only) (HTST only) –L = High Temp Cable Strip = 10µ" (0,25 µm) Gold on post, Matte Tin on tail (2,54) .100 x No. of Positions + (7,62) .300 (2,54) .100 x No. of Positions + (5,08) .200 –T LEAD T/H STYLE (A) (2,92) .115 (4,19) .165 (14,35) .565 –01 –02 –03 Processing: Lead–Free Solderable: Yes (HTST) Wave Only (TST, ZST) SMT Lead Coplanarity: (0,10 mm) .004" max (05-15) (0,15 mm) .006" max (17-36) NO. PINS PER ROW 1 = Matte Tin 02 (2,54) .100 (2,54) .100 01 –TR = Tape & Reel Packaging –D–RA B (5,08) .200 (11,18) .440 (0,38) .015 –D = Pick & Place Pad = Double Row Right Angle (lead style –04 & –05 only) (6,35) .250 (10,16) .400 (8,89) .350 A LEAD RIGHT STYLE ANGLE (B) –04 (3,30) .130 –05 (5,84) .230 (9,27) .365 –P –DV = Double Row Surface Mount (lead style –01 only) (HTST only) (0,64) .025 SQ TYP –DV (HTST ONLY) –D–RA RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality 1 ZST NO. PINS PER ROW OTHER SOLUTIONS (Standard sizes.) (2,54) .100 x No. of Positions + (7,62) .300 (2,54) .100 x No. of Positions + (5,08) .200 ALSO AVAILABLE (MOQ Required) • Other platings & sizes • Alignment Pins • Single Row • Locking Leads • Polarized Contact Samtec. 02 –L = 10µ" (0,25 µm) Gold on post, Matte Tin on tail (2,54) .100 –T (9,27) .365 (2,54) .100 (6,35) .250 (8,89) .350 (2,29) .090 MIN (0,38) .015 Note: Some lengths, styles and options are non-standard, non-returnable. ZST is non-standard, non-returnable. = Gold flash on post, Matte Tin on tail = Matte Tin 01 (0,64) .025 SQ TYP (2,54) .100 BODY HEIGHT D –F Specify LEAD STYLE from chart. 05, 07, 08, 10, 12, 13, 15, 17, 20, 25, 32, 36 • Shrouded board-to-board headers and stackers to mate with SSW, SSQ, ESW, ESQ, SSM and BCS Series. See TSS, HTSS and ZSS Series. PLATING OPTION LEAD STYLE –“XXXX” = Body Height LEAD STYLE –01 –02 –03 –04 –05 –06 –07 –08 –09 C (OAL) MAX BODY HEIGHT (16,00) .630 (13,72) .540 (18,54) .730 (16,26) .640 (21,08) .830 (18,80) .740 (23,62) .930 (21,34) .840 (26,16) 1.030 (23,88) .940 (28,70) 1.130 (26,42) 1.040 (31,24) 1.230 (28,96) 1.140 (33,78) 1.330 (31,50) 1.240 (36,32) 1.430 (34,04) 1.340 BODY HEIGHT C (OAL) Note: For added mechanical stability, Samtec recommends mechanical board spacers be used in applications with gold or selective gold plated connectors. Contact ipg@samtec.com for more information. WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice.
HTST-120-02-L-D 价格&库存
很抱歉,暂时无法提供与“HTST-120-02-L-D”相匹配的价格&库存,您可以联系我们找货
