HTSW-118-15-F-D
HTSW-118-15-F-D
    SAMTEC(申泰)
    .025'' SQ. TERMINAL STRIPS
HTSW-118-15-F-D 数据手册
TSW–209–09–F–S–RA F-212 TSW–108–05–L–Q (2,54mm) .100" TSW–116–11–G–S TSW, HTSW SERIES THROUGH-HOLE .025" SQ POST HEADER Mates with: SSW, SSQ, SSM, ESW, ESQ, BCS, BSW, CES, SLW, IDSD, IDSS, SMSD, SMSS TYPE STRIP SPECIFICATIONS HTSW TSW Insulator Material: Black Glass Filled Polyester Terminal Material: Phosphor Bronze Plating: Au or Sn over 50µ" (1,27µm) Ni Operating Temp Range: -55°C to +125°C with Gold -55°C to +105°C with Tin Voltage Rating: 550 VAC mated with SSW; 500 VAC mated with BCS or ESQ; 450 VAC -RA/-RE mated with BCS or SSM RoHS Compliant: Yes Lead–Free Solderable: Wave Only (2,54) .100 02 6A (2,54) .100 100 (2,54) (5,02) .100 .198 01 03 –D 99 150 (2,54) (7,62) .100 .300 (5,08) (7,56) .200 .298 01 03 –T 148 150 (5,08) (7,56) .200 .298 (7,62) .300 –Q 6.1A 6.2A 6.9A 6A 5.2A 60°C 5.3A 5.3A 5.8A 5.9A 5.3A 4.7A 95°C 3.5A 3.5A 3.7A 3.9A 3.5A 3A 6 POSITIONS (2x3) POWERED Right Angle Versions SPECIFICATIONS For complete specifications see www.samtec.com?HTSW APPLICATIONS BCS (2,54) .100 (3,09) (1,78) .122 .070 –S 01 100 02 (2,54) .100 (6,10) .240 (1,78) .070 01 99 03 150 (2,54) .100 –D (8,10) .319 –T (1,78) .070 01 148 03 150 (5,08) .200 (8,12) .320 (8,10) .319 (1,78) .070 (1,78) .070 01 TSW HTSW 02 thru 25 = .200" (5,08mm) Center Version (5,08) .200 (1,78) .070 TSW HORIZONTAL 01 thru 50 = .100" (2,54mm) Center Version (2,54) .100 x No. of Positions (3,02) .119 (1,78) .070 (8,12) .320 Note: Some lengths, styles and options are non-standard, non-returnable. 148 HTSW (5,56) .219 (1,78) .070 Same as TSW except: Insulator Material: Natural Liquid Crystal Polymer Shunts. See SNT Series TSW 50 HTSW ALSO AVAILABLE 01 –S 01 (5,08) .200 6.9A 6.9A 7.1A 7.6A 6.9A 5.9A (2,54) .100 (2,48) .098 50 AMBIENT TEMP ESW SSW SLW SSQ SSM BCS 40°C (5,08) .200 (2,54) .100 (2,54) .100 x No. of Positions Straight Pin Versions (5,08mm) Centers, – 2 = .200" Every Other Position Filled = Hi-Temp Strip CURRENT RATING TSW mated with 20°C (2,54mm) Centers, –1 = .100" All Positions Filled TSW = Standard Strip For complete specifications see www.samtec.com?TSW NO. PINS PER ROW PIN CENTERS 148 WWW.SAMTEC.COM –Q TSW–109–10–F–D–RA TSW–112–16–T–S–RE TSW–112–07–G–T TSW–120–13–L–D PLATING OPTION LEAD STYLE ROW OPTION OTHER OPTIONS –S –F = Gold flash on post, Matte Tin on tail –NA = Right Angle (using straight body for coplanar mating with SSW-RA series) = Double Row –G = Triple Row –T y Specif r = Matte Tin fo S –S e ffectiv cost-ey Gold –SS heav e it = 30µ" (0,76µm) Gold stripe on contact area, wher s! Gold flash to tip, Matte Tin on tail count (Mates with SSW, SSQ, SSM, ESW, ESQ, BCS only) (1,27) .050 .025" SQ TERMINAL STRIP (TSW) Requires 4 pin minimum (NA with -T,-Q,-RA or -RE) –LA –LL –Q = –RA Option with –LL Option = Locking Lead = Double Row (5,08mm) .200" row space (Straight lead styles -07, -08, -09 and Right Angle (-RA) -08 only) IDSS or IDSD STRIP ASSEMBLY LOCKING CLIP PC BOARD –T = 10µ" (0,25µm) Gold on post, Gold flash on balance = Locking Clip (Styles –08 thru –13 & –22 only) = Right Angle –D –L = 10µ" (0,25µm) Gold on post, Matte Tin on tail –LC – RA or –RE = Single Row Two leads per strip crimped in opposite directions on or near centerline. See charts for available styles. N/A with single row 1 or 2 positions. Recommended hole size (1,02mm ± 0,03mm) .040" ± .001" –“XXX” = Polarized Position Note: Other Gold plating options available. Contact Samtec. Straight Pin Versions Right Angle Versions (Specify “LEAD STYLE” from chart) * * * * STYLE A B C STYLE – 05 (3,30) .130 (2,41) .095 (2,54) .100 (5,08) .200 (10,16) .400 (12,70) .500 (15,24) .600 (17,78) .700 (22,86) .900 (8,51) .335 (7,62) .300 (10,92) .430 (13,46) .530 (18,54) .730 (21,08) .830 (23,62) .930 (26,16) 1.030 (31,24) 1.230 (13,46) .530 (2,67) .105 (2,67) .105 –18 – 06 – 07 – 08 – 09 –10 –11 –12 –13 –14 * * * –15 –16 –17 (2,79) .110 (7,87) .310 (2,79) .110 (18,54) .730 (21,08) .830 * * * * * * * * ▲ (5,84) .230 (8,13) .320 (13,21) .520 (8,13) .320 (15,74) .620 –19 – 20 – 25 – 26 – 27 – 28 – 29 – 30 – 41+ * Available with – LL (Locking Lead) Option – 42+ (0,64) .025 SQ Post (2,79) .110 (7,62) .300 – 23 – 24 B C (23,62) .930 (26,16) 1.030 (31,24) 1.230 (36,32) 1.430 (16,00) .630 (11,30) .445 (12,15) .480 (16,00) .630 (11,58) .456 (33,78) 1.330 (28,70) 1.130 (33,78) 1.330 (28,70) 1.130 (9,27) .365 (11,94) .470 (18,29) .720 (20,83) .820 (25,91) 1.020 (30,99) 1.220 A – 21 – 22 (Specify “LEAD STYLE” from chart and select –RA or –RE from other options) (2,92) .115 (5,33) .210 (3,20) .126 (25,40) 1.000 (20,32) .800 (23,11) .910 (18,03) .710 (0,89) .035 (1,27) .050 –RA LEAD STYLE – 08 – 09 –10 –11 (5,84) .230 (6,73) .265 (8,13) .320 (5,84) .230 –12 –13 * * * (8,13) .320 –16 – 21 – 22 – 25 – 27 – 28 – 29 (5,84) .230 (8,13) .320 – 30 SINGLE (– S) A (2,29) .090 (7,37) .290 (9,91) .390 (12,45) .490 (14,99) .590 (20,07) .790 (5,08) .200 (25,15) .990 (4,83) .190 (2,54) .100 (22,61) .890 (17,53) .690 (20,32) .800 (15,24) .600 (5,84) .230 (8,13) .320 (5,84) .230 (8,13) .320 (5,84) .230 (8,13) .320 + Style –41 & –42 available with HTSW only. C ▲Except: Style –26 C B A (0,46) .018 DIA Tail (2,54) .100 A LEAD STYLE B – RA (1,52) .060 (0,64) .025 SQ Tail Á Specify -07 for best mate with IDXX Series IDC Cable – RE (4,06) .160 WWW.SAMTEC.COM DOUBLE (– D) TRIPLE (–T & – Q) A A (2,29) .090 (7,37) .290 (9,91) .390 (12,45) .490 (14,99) .590 (20,07) .790 (5,08) .200 (2,29) .090 (7,37) .290 (9,91) .390 (12,45) .490 (14,99) .590 C – RE LEAD STYLE SINGLE – 09 (4,83) .190 (7,37) .290 (9,91) .390 (12,45) .490 (17,53) .690 (2,54) .100 (22,61) .890 (2,29) .090 (20,07) .790 (14,99) .590 –10 –11 –12 –13 N/A –16 (5,08) .200 – 21 N/A N/A – 22 (4,83) .190 (2,54) .100 (4,83) .190 (2,54) .100 – 27 N/A C (5,84) .230 (8,13) .320 (5,84) .230 *Available with – LA (Locking Lead) Option (17,53) .690 N/A ALSO AVAILABLE N/A (15,24) .600 (1,78) .070 – 28 A C A (2,54) .100 B (2,54) .100 (2,54) .100 Elevated Right Angle option. Call Samtec.
HTSW-118-15-F-D 价格&库存
很抱歉,暂时无法提供与“HTSW-118-15-F-D”相匹配的价格&库存,您可以联系我们找货
