FSH-115-03-L-DH
FSH-115-03-L-DH
    SAMTEC(申泰)
    .050 SHROUDED TERMINAL ASSEMBLY
FSH-115-03-L-DH 数据手册
FSH–120–04–F–RA–SL F-224 SUPPLEMENT (Rev 10JAN24) FSH–110–04–L–DH–SL SFMH–130–02–L–D–LC SFMH–105–02–L–D–LC (1.27 mm) .050" FSH–120–04–F–DH SFMH–120–02–L–D FSH, SFMH SERIES HIGH-RELIABLE HORIZONTAL FSH Mates with: SFMH SFMH Mates with: FTSH, FSH 1 FSH SPECIFICATIONS NO. PINS PER ROW 04 05, 10, 15, 20, 25, 30, 35, 40, 45 Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: FSH = Sn or Au over 50 µ" (1.27 µm) Ni SFMH = Au over 50 µ" (1.27 µm) Ni Current Rating (FSH/SFMH): 2.6 A per pin (2 pins powered) Operating Temp Range: -55 °C to +125 °C Insertion Depth: SFMH = (3.35 mm) .132" to (4.57 mm) .180" RoHS Compliant: Yes (3.68) .145 Lead-Free Solderable: Yes (FSH) SMT Lead Coplanarity: (0.10 mm) .004" max (SFMH) (0.15 mm) .006" max (FSH)* *(.004" stencil solution may be available; contact ipg@samtec.com) (1.27) .050 (5.21) .205 –FR –RA = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) (Not available with -RA) (3.94) .155 (3.43) .135 PROCESSING = Tape & Reel (Not available with –RA) (2.29) .090 (3.68) .145 2 4 (1.27) .050 13 (1.27) .050 (1.27) (1.27) .050 .050 No. of positions + 2 x (1.27) .050 –DH (0.89) .035 (0.71) .028 (1.27) .050 (2.16) .085 –RA = (4.50 mm) .177" DIA Polyimide film Pick & Place Pad (10 positions minimum) not available with –RA option –TR (2.51) .099 (0.41) .016 SQ –C = Right-angle (Through-hole) (No. of positions + 4) x (1.27) .050 (6.58) .259 = Solder Locks –RA –L = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail (–RA Option) (Standard sizes) –SL = Double Row Horizontal (Surface Mount) = Gold flash on post, Matte Tin on tail (–DH Option) OPTIONS –DH –F 05, 10, 15, 20, 25 For complete specifications see www.samtec.com?FSH or www.samtec.com?SFMH ROW OPTION PLATING OPTION –DH RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality SFMH 1 NO. PINS PER ROW PLATING OPTION 02 D –L FILE NO. E111594 –LC = 10 µ" (0.25 µm) Gold on contact, Gold flash on tail 05, 10, 15, 20, 25, 30, 35, 40, 45, 50 = Locking Clip (Manual placement required) (0.64) .025 TYP (2.03) .080 APPLICATIONS SFMH FSH HORIZONTAL (0.41) .016 –WT No. of Positions x (1.27) .050 + (2.92) .115 04 Note: Some sizes, styles and options are non-standard, non-returnable. –WT (1.65) .065 (4.57) .180 (1.27) .050 02 03 01 (1.50) .059 = Weld Tab (Not available with 35, 40, 45, 50 positions) –TR = Tape & Reel –FR (1.65) (3.43) .065 .135 No. of Positions x (1.27) .050 + (1.65) .065 OPTION (1.41) .056 DIA (1.02) .040 = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) –LC WWW.SAMTEC.COM Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
FSH-115-03-L-DH
物料型号: - FSH–120–04–F–RA–SL - FSH–110–04–L–DH–SL - SFMH–130–02–L–D–LC - TIGER" EYE SFMH–105–02–L–D–LC - SFMH–120–02–L–D
器件简介: - 这些连接器是高可靠性的水平连接器,FSH系列与SFMH系列兼容。
引脚分配: - FSH系列每排有04个引脚,SFMH系列每排有02个引脚。
参数特性: - 绝缘体材料:黑色液晶聚合物 - 端子材料:磷青铜 - 镀层:FSH为锡或金,覆盖在50微米(1.27微米)镍上;SFMH为金,覆盖在50微米(1.27微米)镍上 - 电流额定值:每针2.6A(2针供电) - 操作温度范围:-55°C至+125°C - 插入深度:SFMH为3.35mm至4.57mm - 符合RoHS标准
功能详解: - 提供了不同的引脚排列选项,如单排、双排(-DH),以及不同的镀层选项。 - 包括了锁紧夹(-LC)和焊接片(-WT)等选项。
应用信息: - 适用于需要高可靠性连接的应用。
封装信息: - 提供了详细的尺寸信息,包括引脚间距和连接器的整体尺寸。
FSH-115-03-L-DH 价格&库存
很抱歉,暂时无法提供与“FSH-115-03-L-DH”相匹配的价格&库存,您可以联系我们找货
FSH-115-03-L-DH
  • 23+60.1087623+7.78160
