HSEC8-180-01-S-DV-A-WT-K 数据手册
HSEC8–125–01–L–DV–A
F-217
HSEC8–149–01–L–DV–A
(0.80 mm) .0315"
HSEC8-DV SERIES
VERTICAL EDGE RATE CARD SOCKET
SPECIFICATIONS
For complete specifications and
recommended PCB layouts see
www.samtec.com?HSEC8-DV
Insulator Material:
Black Liquid Crystal Polymer
Contact:
BeCu
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Current Rating:
2.8 A per pin
(2 adjacent pins powered)
Operating Temp:
-55 °C to +125 °C
RoHS Compliant:
Yes
10 YEAR MFG
WITH 30 µ" GOLD
EXTENDED LIFE
PRODUCT
HIGH MATING
CYCLES
HIGH-SPEED CHANNEL PERFORMANCE
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max (10-60)
RECOGNITIONS
HSEC8-DV
Rating based on Samtec reference channel.
For full SI performance data visit Samtec.com
or contact SIG@samtec.com
HSEC8
For complete scope
of recognitions see
www.samtec.com/quality
1
32
Custom designs compensate for
misalignment. Contact Samtec.
G b p s
POSITIONS
PER ROW
PLATING
OPTION
CARD
THICKNESS
–01
FILE NO: 090871_0_000
09, 10, 13, 20,
25, 30, 37, 40, 49,
50, 60, 70, 80, 100
(13, 25, 49 only available
with –L or –L2 option;
09 only available with –L2 option;
37 only available with –L option)
01
–03
CABLE CONNECTOR
HSEC8–109–L2
HSEC8–113–L2
HSEC8–125–L2
HSEC8–149–L2
Notes:
While optimized for 50 W
applications, this connector
with alternative signal/ground
patterns may also perform well
in certain 75 W applications.
Contact Samtec for further
information.
Some lengths, styles and
options are non-standard,
non-returnable.
–S
= 30 µ" (0.76 µm) Gold on contact,
Matte Tin on tail
POSITIONS
PER ROW
09*†
13*†
25*†
37†
40
49*†
50
60
70†
80†
(1.32)
100†
B
.052
(No. of Positions + 6) x (0.80) .0315 + (0.60) .024
A
= 10 µ" (0.25 µm) Gold on contact,
Matte Tin on tail
= (2.36 mm) .093"
thick card
A
DV
–L
= (1.60 mm) .062"
thick card
No. of Positions x (0.80) .0315 + (7.80) .307
02
ECDP–04
ECDP–08
ECDP–16
ECDP–32
MISALIGNMENT
MITIGATION
Cable Mates:
ECDP
PROCESSING
FILE NO. E111594
Mates with (1.60 mm) .062"
or (2.36 mm) .093" cards
Card Mates:
(1.60 mm) .062" card,
(2.36 mm) .093" card,
HSC8
A
B
(4.50) .177 (11.80) .465
(6.10) .240 (15.00) .591
(6.10) .240 (24.60) .969
(18.10) .713 (34.20) 1.346
(18.90) .744 (36.60) 1.441
(22.90) .902 (43.80) 1.724
(22.90) .902 (44.60) 1.756
(26.90) 1.059 (52.60) 2.071
(26.90) 1.059 (60.60) 2.386
(26.90) 1.059 (68.60) 2.701
(26.90) 1.059 (84.60) 3.331
Positions where no dimensions are given
do not have keying feature.
* Mates with ECDP Series.
† Available with –01 Card Only.
09, 13, 25, 37, 100
No. of Positions x (0.80) .0315 + (4.60) .181
02
01
(7.98)
.314
(7.80)
.307
(7.00)(5.60)
.276 .220
(0.80) .0315
(1.75)
.070
(1.12) .044 DIA
No. of Positions x (0.80) .0315 + (2.20) .087
10, 20 & 30
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
OTHER
OPTION
–K
= (7.01 mm) .276" DIA
Polyimide Film
Pick & Place Pad
(with –01 card)
= (6.25 mm) .246" DIA
Polyimide Film
Pick & Place Pad
(with –03 card)
–BL
= Board Locks
(40, 50, 60, 80 only)
(Other sizes available.
Contact Samtec.)
(Weld tab standard)
–L
= Latching Option
(13, 25, 37, 49 only)
(Weld tab standard)
–L2
= ECDP Latching
(09, 13, 25, 49 only)
(For use with ECDP)
(Weld tab standard)
–WT
= Weld tab
–TR
= Tape & Reel
(09 - 70 only)
HSEC8-180-01-S-DV-A-WT-K 价格&库存
很抱歉,暂时无法提供与“HSEC8-180-01-S-DV-A-WT-K”相匹配的价格&库存,您可以联系我们找货
