AAA-PCI-092-P07
AAA-PCI-092-P07
    LOTES(嘉澤端子)
    CONN-52P_29.9X7.37MM_SM
    本规格涵盖了 0.8mm 间距的 MINI PCI EXPRESS 连接器系列。物理尺寸和 0.8mm 间距的 MINI PCI EXPRESS 连接器在图纸中显示。外壳:高温热塑性塑料。触点:铜合金...
AAA-PCI-092-P07 数据手册
NO: Halogen Free Part TO: SPECIFICATION FOR APPROVAL DESCRIPTION:MINI PCI-E 0.8PITCH 52P 5.2H CUSTOMER P/N: LOTES P/N:AAA-PCI-092-P07 CUSTOMER APPROVAL SIGN: SEND BY QA CONFIRM R&D CONFIRM Barney Lotes SZ Lotes GZ PREPARE BY Xi huang Li Lotes TW www.lotes.cc CopyRight©2003 LOTES CO., LTD All right reserved LOTES CO., LTD INDEX PAGE 1 INDEX PAGE 2 ~ 5 PRODUCT SPECIFICATION PAGE 6 ~ 12 PRODUCT DRAWING AND PACKAGE PAGE 13 ~ 24 PRODUCT TEST REPORT PAGE 25 ~ 65 PRODUCT MATERIAL REPORT &SGS PRODUCT SPECIFICATION REV ECR No. 4C SN14*** DIMENSION 1.This specification covers 0.8mm pitch MINI PCI EXPRESS(AAA-PCI-073/092/093-***) connector series. 2.The physical dimensions and the 0.8mm pitch MINI PCI EXPRESS connector are shown in drawing. MATERIAL AND FINISH 1.Housing: High temperature thermoplastic. 2.Contact: Copper Alloy, Nickel-plating over all, Gold Plating on contact area, Matte Tin plated on solder area. 3.PEG : Copper Alloy , Matte Tin plated on solder area. OPERATING PERFORMANCE 1.Operation Temperature: -40℃ to 80℃ 2.Voltage Rating: 25 V AC per contact 3.Current Rating: 0.5 A ELECTRICAL PERFORMANCE Test item Examination of product Low Level Contact Resistance Test condition Requirements ‧ Visual inspection ‧ No physical damage ‧ EIA-364-18 ‧Mate connectors: apply a current of 10mA(max) at open circuit voltage of 20mV (max) ‧ 55mΩ MAX. per contact (Initial) ‧△LLCR=20mΩ Max.(Final) EIA-364-23 ‧Applying 500VDC between adjacent contacts of Insulation resistance unmated and unmount connectors ‧ 500MΩ MIN EIA-364-21 Dielectric withstanding voltage ‧ Measured by applying 300VAC for one minute between adjacent contacts of unmated connector assemblies. EIA-364-20 ‧ No breakdown or flash ‧ Current leakage:1mA PRODUCT NAME: 0.8mm PITCH MINI PCI EXPRESS CONNECTOR DOCUMENT No: REV: SP-AAA-PCI-073 LOTES CO., LTD PAGE: 4C 1 OF 4 APPROVED BY: CHECKED BY: WRITTEN BY: Barney 01/09'14 1 Vito 01/09'14 Lxh 01/09'14 PRODUCT SPECIFICATION REV ECR No. 4C SN14*** MECHANICAL PERFORMANCE Test item Test condition Requirements ‧Subject mated connectors and vibrate per EIA Vibration test (Random) ‧No electrical discontinuity greater 364-28 test Condition.Ⅶ test condition letter D(15 than 1 microsecond. minutes in each of 3 mutually perpendicular ‧△LLCR =20mΩ Max.(Final) directions) ‧Subject mated connector to 50Gs,half-sine shock pulses of 11 millisecond duration,3drops in each Mechanical shock direction applied along the 3 mutually perpendicular planes total 18 shock. mate/un-mate) than 1 microsecond ‧△LLCR =20mΩ Max.(Final) ‧No physical damage EIA-364-27 test condition A Durability (repeated ‧No electrical discontinuity greater ‧Repeat insertion the card to the connector and ‧△LLCR =20mΩ Max.(Final) extraction card from the connector for 50 cycles. EIA-364-09 ‧ Insert the card at the specified angle Mating and Unmating force Rotate the card into position ‧2.3 Kgf MAX Reverse the installation sequence to unmating EIA-364-13 TITLE: 0.8mm PITCH MINI PCI EXPRESS CONNECTOR LOTES CO., LTD DOCUMENT No: REV: SP-AAA-PCI-073 PAGE: 4C 2 OF 4 APPROVED BY: CHECKED BY: WRITTEN BY: Barney 01/09'14 2 Vito 01/09'14 Lxh 01/09'14 ENVIRONMENTAL PERFORMANCE REV PRODUCT SPECIFICATION Test item ECR No. 4C Test condition SN14*** Requirements ‧△LLCR =20mΩ Max.(Final) Humidity ‧Expose the mates connectors to 40+2℃,relative (steady state) humidity 90~95%RH for 96 hours.EIA-364-31 Thermal shock Solder ability ‧Insulation resistance:500MΩMin. ‧No physical damage. ‧Expose the connectors to -55℃/30min. and 85℃ ‧△LLCR =20mΩ Max.(Final) /30min.(Repeat 10 cycles)---EIA-364-32 condition Ⅰ ‧No physical damage. Solder temperature:245+5℃ ‧ Wet solder coverage: 95%Min Immersion Duration:3+0.5sec. ‧ Subject the connector to 5%salt-solution Salt spray concentration at 35℃ for 24 hours. ‧△LLCR =20mΩMax .(Final) ‧ EIA-364-26 ‧EIA -364-56C Resistance to Solder Heat IR Reflow : ‧ The peak temperature on the board shall ‧No evidence of physical damage be maintained for 10 second 250+10℃ Soldering iron method Rework temperature Soldering Time : 5 sec. ‧No evidence of physical damage Solder Temperature : 370-400℃ ‧ 0.5 mm from terminal tip Temperature life Mate PCB module and subject to 85±3℃ for 96 hours ‧Contact resistance: △LLCR EIA-364-17 condition A =20mΩ Max.(Final) TEST CONDITIONS The tests shall be carried out under the conditions as the referring. (1).Temperature:15~35℃. (2). Humidity: 45~75%. PACKAGE All parts shall be packaged and packed to protect against physical damage, corrosion and deterioration during shipment and storage. TITLE: 0.8mm PITCH MINI PCI EXPRESS CONNECTOR LOTES CO., LTD DOCUMENT No: REV: SP-AAA-PCI-073 PAGE: 4C 3 OF 4 APPROVED BY: CHECKED BY: WRITTEN BY: Barney 01/09'14 3 Vito 01/09'14 Lxh 01/09'14 REV PRODUCT SPECIFICATION ECR No. 4C SN14*** TEST SEQUENCE: Test or Examination Test Group A B C D E F G H Examination of Product 1,5 1,9 1,5 1,8 1,3 1,5 1,5 1,3 Contact Resistance 2,4 2,6 2,4 2,4 Insulation Resistance 2,6 Dielectric Withstanding Voltage 3,7 Vibration 2,4 3 Durability (Repeated) 5 Mating force 3,7 Unmating force 4,8 Solder ability 2 Humidity (Steady State) 5 Thermal Shock 4 Mechanical shock 3 Temperature life 3 Salt spray 3 Resistance to Soldering Heat 2 RECOMMENDED INFORARED REFLOW CONDITION Suggestion:In SMT process , the thickness of solder paste is 0.13mm minimum PRODUCT NAME: 0.8mm PITCH MINI PCI EXPRESS CONNECTOR LOTES CO., LTD DOCUMENT No: REV: SP-AAA-PCI-073 PAGE: 4C 4 OF 4 APPROVED BY: CHECKED BY: WRITTEN BY: Barney 01/09'14 4 Vito 01/09'14 Lxh 01/09'14 PRODUCT RELIABILITY TEST REPORT Report No. GL-RD090107ʳ ʳ ʳ ʳ ʳ ʳ ʳ Product: Part NO.: Test Object: Sample Quantity: GL-P-027-005 MINI PCI-E 5.2H AAA-PCI-092-*** Product Reliability Test 40PCS Test Environment: 20-24кΔ50-62%RH Date of Test: Jan.08,09~ Mar.02,09 Test Result Summary: Qualification Group Pass / Fail Test Group A Test Group B Test Group C Test Group D Test Group E Test Group F Pass Pass Pass Pass Pass Pass Pass Test Group G Test Group H Comments Pass * * * * * * * * * * * * * * * * * * * ** * * * * * * * * * * * * * * * * * * * * * * * * * * * Approved By:King Checked By:Su Prepared By: Hejie * * * * * * * * * * * * * * * * * * * ** * * * * * * * * * * * * * * * * * * * * * * * * * * * Page 1 of 12 PRODUCT RELIABILITY TEST REPORT Report No. GL-RD090107ʳ ʳ ʳ ʳ ʳ ʳ ʳ GL-P-027-005 1. Testing Sequence: Test group step Test or examination A B C D E F G H 1,8 1,3 1,5 1,5 1,3 2,4 2,4 1 Examination of product 1,5 1,9 1,5 2 Contact Resistance 2,4 2,6 2,4 3 Insulation Resistance 2,6 4 Dielectric withstanding voltage 3,7 5 Vibration 6 Durability 5 7 Mating force 3,7 8 Unmating Force 4,8 9 Solder ability 10 Humidity 5 11 Thermal Shock 4 12 Mechanical shock 13 Temperature life 14 Salt spray 15 Resistance to Solder Heat Specimen quantity (pcs) 3 2 3 3 3 2 5 5 Page 2 of 12 5 5 5 5 5 5 PRODUCT RELIABILITY TEST REPORT Report No. GL-RD090107ʳ ʳ ʳ ʳ ʳ ʳ ʳ GL-P-027-005 2. Test Item & Condition & Requirements Κ 1 2 Test item Examination of product Contact Resistance Test condition Requirements EIA-364-18. No physical damage Meets requirements of product drawing EIA 364-23 Subject mated contacts assembled in 55 milliohms max.(initial). housing to closed circuit current of 10mA ϦR=20 milliohms max. at open circuit voltage of 20mV max.(Final) max. EIA 364-20 Subject mated connector with a voltage Dielectric No disruptive discharge or of 3 Withstanding Voltage 300VAC for 1.0minute between adjacent leakage greater than 1.0 mA(max) contacts. 4 5 6 Insulation Resistance Durability Vibration 7 Mechanical Shock EIA 364-21 Impressed voltage 500V DC. Test between adjacent contacts of unmated connectors. 500 Mȍmin EIA 364-9 Show no physical damage Repeated insertion and Removal of P.C.B ϦR=20 milliohms from the connector for 50 cycles max.(Final) EIA 364-28 Subject mated connectors to 10-55-10Hz traversed in 1 minute at 1.52 mm amplitude 2hours each of 3 mutually perpendicular planes.100mA applied. EIA 364-27 Subject mated specimens to 50G’s halfsine shock pulses of 11 milliseconds duration three shocks in each direction applied along three mutually perpendicular planes (18 shocks) Page 3 of 12 No electrical discontinuity greater Than 1.0microsecond shall occur. ϦR=20 mȍ max.(Final) No electrical discontinuity greater than 1.0 microsencond shall occur. ϦR=20 mȍ max.(Final) PRODUCT RELIABILITY TEST REPORT Report No. GL-RD090107ʳ ʳ ʳ ʳ ʳ ʳ ʳ 8 9 10 Mating and Unmating force Temperature Life Thermal Shock Humidity temperature 11 cycling 12 13 14 Solder ability Salt Spray EIA 364-13 Insert the card at the specified angle Rotate the card into position Reverse the installtion sequence to unmating EIA 364-17 Expose mated connectors to a temperature of 85+/-3к for 96hours. EIA 364-32 Mated connector -55к/30 min., +85к/30min. Making this a cycle, repeat 10 cycles GL-P-027-005 2.3kgfmax. Show no physical damage. ϦR=20 mȍ max.(Final) Show no physical damage. ϦR=20 mȍ max.(Final) Show no physical damage. EIA 364-31 ϦR=20 mȍmax.(Final) Subject specimens to 96 hours at 40+/Insulationresistance:500Mȍ 2к,with RH of 90~95% min EIA 364-52 Wet solder coverage 95% Solder Temperature(Tin): 245±5к min. Immersion Durating::3+0.5 sec. EIA 364-26 Mated connector expose to 24 hours at 35±2к and 5% salt-solution concentration.After the test,specimens Show no physical damage shall be washed with running water and dried naturally before the measurement of contact resistance. EIA-364-56 Resistance to solder Max.peak temperature of 260+/-5к heat 300к with 10second(sohdering iron) Page 4 of 12 Show no physical damage. PRODUCT RELIABILITY TEST REPORT Report No. GL-RD090107ʳ ʳ ʳ ʳ ʳ ʳ ʳ GL-P-027-005 3. Testing Equipment: Name Microscope Milliohmmeter Withstanding voltage & insulation auto tester Load cell auto tester Thermal shock test chamber Temperature & humidity cycling chamber Mechanical shock tester Vibration tester High temperature oven Salt Spray tester PCB soldering machine Model MITUTOYO-TM KEITHLEY-580 ZENTECH-9052 ALGOL-1220s CHANGHONG-SH-T-601 WT-RF-5EE King Design-DP-1200-ST-250 King Design-9363EM-600F2K-40N120 SMO-4 SSF-060 JIAZE-PS-2000 4. Testing Result: Group A: 1 2 3 4 5 Examination step/ item Sample 1 Examination of product Normal ˇ˃ˁˆˊʳʳ LLCR Vibration Normal ˇ˅ˁˋˉʳʳ LLCR Examination of product Normal Sample 2 Normal ˆˊˁˋˇʳʳ Normal ˇˇˁˊˊʳʳ Normal Sample 3 Sample 4 Sample 5 Unit Pass/fail Normal Normal Normal / Pass ˆˉˁˌˆʳʳ ˆˌˁˇ˄ʳʳ ˇ˅ˁˊˉʳʳ mȍ Pass Normal Normal Normal / Pass ˆˊˁˌˊʳʳ ˇ˃ˁˈˇʳʳ ˇˉˁ˅ˆʳʳ mȍ Pass Normal Normal Normal / Pass Group B: Examination step/ item Sample 1 Sample 2 Sample 3 1 Examination of Product Normal Normal Normal ˆˌˁˊˌʳʳ ˇ˅ˁ˄ˇʳʳ ˇ˄ˁˇˇʳʳ 2 LLCR ˃ˁ˄ˈʳ ˃ˁˆ˅ʳ ˃ˁ˄˃ʳ 3 Mating force ˃ˁ˃ˌʳ ˃ˁ˅˃ʳ ˃ˁ˃ˉʳ 4 Unmating force 5 Durability Normal Normal Normal ˈˆˁ˄˃ʳʳ ˈ˅ˁˋˊʳʳ ˈ˄ˁ˄ˋʳʳ 6 LLCR ˃ˁˆ˄ʳ ˃ˁ˅˄ʳ ˃ˁ˅ˇʳ 7 Mating force ˃ˁ˃˅ʳ ˃ˁ˃ˈʳ ˃ˁ˃ˈʳ 8 Unmating force 9 Examination of Product Normal Normal Normal Page 5 of 12 Sample 4 Normal ˇ˅ˁ˃ˇʳ ˃ˁ˄ˆʳ ˃ˁ˃˄ʳ Normal ˈ˄ˁ˃ˉʳ ˃ˁ˄ˈʳ ˃ˁ˃ˆʳ Normal Sample 5 Normal ˇ˄ˁˊˊʳʳ ˃ˁ˄ˌʳ ˃ˁ˃ˊʳ Normal ˈ˅ˁˊˈʳʳ ˃ˁ˅ˈʳ ˃ˁ˃ˌʳ Normal Unit Pass/fail / Pass mȍ Pass kgf Pass kgf Pass / Pass mȍ Pass kgf Pass kgf Pass / Pass PRODUCT RELIABILITY TEST REPORT Report No. GL-RD090107ʳ ʳ ʳ ʳ ʳ ʳ ʳ GL-P-027-005 Group C: Examination step/ item Sample 1 Sample 2 Sample 3 1 Examination of Product Normal Normal Normal ˇ˅ˁˆˇʳʳ ˆˌˁˇˋʳʳ ˆˊˁ˅˄ʳʳ 2 LLCR 3 Mechanical shock Normal Normal Normal ˆˋˁˌˇʳʳ ˆˋˁˇˌʳʳ ˆˊˁ˄ˊʳʳ 4 LLCR 5 Examination of Product Normal Normal Normal Sample 4 Normal ˆˋˁˇˌʳ Normal ˆˊˁˆˉʳ Normal Sample 5 Unit Pass/fail Normal / Pass ˇ˄ˁˇ˅ʳʳ mȍ Pass Normal / Pass ˆˋˁ˄ˋʳʳ mȍ Pass Normal / Pass Sample 4 Normal >500 300 Normal Normal >500 300 Normal Sample 5 Unit Pass/fail Normal / Pass >500 Mȍ Pass 300 V Pass Normal / Pass Normal / Pass >500 Mȍ Pass 300 V Pass Normal / Pass Group D: Examination step/ item Sample 1 Sample 2 Sample 3 1 Examination of Product Normal Normal Normal 2 IR >500 >500 >500 3 DWV 300 300 300 4 Thermal shock Normal Normal Normal 5 Humidity Normal Normal Normal 6 IR >500 >500 >500 7 DWV 300 300 300 8 Examination of Product Normal Normal Normal Group E: Examination Step/ Item 1 Examination of product 2 Solder ability 3 Examination of product Sample 1 Normal Normal Normal Sample 2 Normal Normal Normal Sample 3 Sample 4 Sample 5 Unit Pass/fail Normal Normal Normal / Pass Normal Normal Normal / Pass Normal Normal Normal / Pass Group F: Examination step/ item Sample 1 Sample 2 Sample 3 1 Examination of Product Normal Normal Normal ˆˈˁˌˈʳʳ ˆˊˁˈˈʳʳ ˆˈˁˊ˃ʳʳ 2 LLCR 3 Temperature life Normal Normal Normal ˇ˃ˁ˄ˆʳʳ ˇ˅ˁˇ˅ʳʳ ˇ˃ˁˇˉʳʳ 4 LLCR 5 Examination of Product Normal Normal Normal Page 6 of 12 Sample 4 Normal ˆˈˁ˃˃ʳ Normal ˆˌˁ˅ˊʳ Normal Sample 5 Unit Pass/fail Normal / Pass ˆˈˁˈˈʳʳ mȍ Pass Normal / Pass ˇ˄ˁˇˋʳʳ mȍ Pass Normal / Pass PRODUCT RELIABILITY TEST REPORT Report No. GL-RD090107ʳ ʳ ʳ ʳ ʳ ʳ ʳ GL-P-027-005 Group G: Examination step/ item Sample 1 Sample 2 Sample 3 1 Examination of Product Normal Normal Normal ˇ˃ˁˋˌʳʳ ˆˌˁˋˈʳʳ ˇ˅ˁˊˆʳʳ 2 LLCR 3 Salt spray Normal Normal Normal ˇˇˁˇˈʳʳ ˇ˄ˁˉ˃ʳʳ ˆˉˁˌˈʳʳ 4 LLCR 5 Examination of Product Normal Normal Normal Sample 4 Normal ˇˇˁˈ˃ʳ Normal ˆˈˁ˅˃ʳ Normal Sample 5 Unit Pass/fail Normal / Pass ˇ˃ˁ˃˄ʳʳ mȍ Pass Normal / Pass ˆˈˁˉ˃ʳʳ mȍ Pass Normal / Pass Sample 4 Normal Normal Normal Sample 5 Unit Pass/fail Normal / Pass Normal / Pass Normal / Pass Group H: Examination step/ item Sample 1 Sample 2 Sample 3 1 Examination of Product Normal Normal Normal 2 Resistance to solder heat Normal Normal Normal 3 Examination of Product Normal Normal Normal Page 7 of 12 PRODUCT RELIABILITY TEST REPORT Report No. GL-RD090107ʳ ʳ ʳ ʳ ʳ ʳ ʳ GL-P-027-005 5. The LLCR as follow: Group A A-Vibration NO ˄ˀˆʳ ˈˀˊʳ ˌˀ˄˄ʳ ˄ˆˀ˄ˈʳ ˄ˊˀ˄ˌʳ ˅˄ˀ˅ˆʳ ˅ˈˀ˅ˊʳ ˅ˌˀˆ˄ʳ ˆˆˀˆˈʳ ˆˊˀˆˌʳ ˇ˄ˀˇˆʳ ˇˈˀˇˊʳ ˇˌˀˈ˄ʳ ˅ˀˇʳ ˉˀˋʳ ˄˃ˀ˄˅ʳ ˄ˇˀ˄ˉʳ ˄ˋˀ˅˃ʳ ˅˅ˀ˅ˇʳ ˅ˉˀ˅ˋʳ ˆ˃ˀˆ˅ʳ ˆˇˀˆˉʳ ˆˋˀˇ˃ʳ ˇ˅ˀˇˇʳ ˇˉˀˇˋʳ ˈ˃ˀˈ˅ʳ Max Min Avg Stdev A1 ˆˋˁˈˈʳʳ ˆˉˁˌˊʳʳ ˆˊˁˈˊʳʳ ˆˊˁ˅ˋʳʳ ˆˉˁˋ˄ʳʳ ˆˉˁˋ˄ʳʳ ˆˊˁ˃ˊʳʳ ˆˋˁˆ˄ʳʳ ˆˊˁˋˆʳʳ ˆˊˁˇˌʳʳ ˇ˃ˁˆˊʳʳ ˆˊˁ˄ˇʳʳ ˆˊˁˆˆʳʳ ˅ˈˁˉˇʳʳ ˅ˊˁˆˈʳʳ ˅ˉˁˇˉʳʳ ˅ˉˁˇ˃ʳʳ ˅ˉˁˌ˃ʳʳ ˅ˉˁˈˆʳʳ ˅ˉˁˆ˄ʳʳ ˅ˉˁˉ˅ʳʳ ˅ˉˁˉˈʳʳ ˅ˈˁˌˌʳʳ ˅ˈˁˈˉʳʳ ˅ˈˁˉˋʳʳ ˅ˈˁ˃ˉʳʳ ˇ˃ˁˆˊʳʳ ˅ˈˁ˃ˉʳʳ ˆ˄ˁˌˈʳʳ ˈˁˋˋʳʳ A2 ˆˊˁ˃ˆʳʳ ˆˉˁˌˇʳʳ ˆˉˁˋˈʳʳ ˆˊˁ˃ˊʳʳ ˆˊˁ˄ˈʳʳ ˆˉˁˋˇʳʳ ˆˊˁ˅ˇʳʳ ˆˉˁˋˈʳʳ ˆˊˁ˄ˇʳʳ ˆˉˁˉ˃ʳʳ ˆˊˁˋˇʳʳ ˆˊˁˈˊʳʳ ˆˊˁ˃ˆʳʳ ˅ˊˁ˃ˉʳʳ ˅ˊˁ˄ˉʳʳ ˅ˊˁˌˌʳʳ ˅ˋˁˉ˄ʳʳ ˅ˉˁˌˇʳʳ ˅ˊˁ˃˄ʳʳ ˅ˉˁˋˈʳʳ ˅ˊˁˈˇʳʳ ˅ˉˁˆ˅ʳʳ ˅ˉˁˉˆʳʳ ˅ˉˁˆ˃ʳʳ ˅ˉˁˌˉʳʳ ˅ˈˁˌˊʳʳ ˆˊˁˋˇʳʳ ˅ˈˁˌˊʳʳ ˆ˅ˁ˃ˉʳʳ ˈˁ˄ˉʳʳ Initial A3 ˆˉˁˌˆʳʳ ˆˉˁˊ˃ʳʳ ˆˉˁˈˇʳʳ ˆˉˁˊ˄ʳʳ ˆˉˁˆ˄ʳʳ ˆˉˁˆˊʳʳ ˆˉˁ˃ˌʳʳ ˆˉˁˆˊʳʳ ˆˉˁ˅ˇʳʳ ˆˉˁ˃ˋʳʳ ˆˉˁ˃ˆʳʳ ˆˉˁˈˉʳʳ ˆˉˁˉˆʳʳ ˅ˉˁˊˋʳʳ ˅ˌˁˊ˄ʳʳ ˅ˉˁˊˈʳʳ ˅ˉˁˇˊʳʳ ˅ˉˁˇ˃ʳʳ ˅ˈˁˌˇʳʳ ˅ˋˁˋˇʳʳ ˅ˉˁˆ˃ʳʳ ˅ˉˁ˃ˌʳʳ ˅ˈˁˋ˄ʳʳ ˅ˊˁˇˈʳʳ ˅ˈˁˌ˅ʳʳ ˅ˈˁˈ˄ʳʳ ˆˉˁˌˆʳʳ ˅ˈˁˈ˄ʳʳ ˆ˄ˁˈˌʳʳ ˈˁ˃˃ʳʳ A4 ˆˊˁˆ˃ʳ ˆˊˁ˅ˉʳ ˆˊˁˊˌʳ ˆˉˁˉˈʳ ˆˊˁˈˆʳ ˆˊˁˈ˅ʳ ˆˌˁˇ˄ʳ ˆˋˁ˄˅ʳ ˆˌˁ˄ˊʳ ˆˊˁ˃ˊʳ ˆˊˁˆˆʳ ˆˉˁˉˈʳ ˆˊˁ˄ˉʳ ˅ˈˁˋˉʳ ˅ˉˁ˃ˌʳ ˅ˋˁˈˈʳ ˅ˈˁˌˈʳ ˅ˉˁˆˊʳ ˅ˉˁˆˆʳ ˅ˉˁˆ˅ʳ ˅ˉˁˊˊʳ ˅ˉˁˉˋʳ ˅ˉˁˋ˄ʳ ˅ˉˁˈˉʳ ˅ˉˁˊˈʳ ˅ˈˁˌˆʳ ˆˌˁˇ˄ʳ ˅ˈˁˋˉʳ ˆ˅ˁ˃ˊʳ ˈˁˊ˃ʳ A5 ˆˋˁ˃ˆʳ ˆˈˁˌˉʳ ˆˊˁˊˈʳ ˆˉˁˈ˅ʳ ˆˋˁˆ˃ʳ ˆˋˁ˃ˊʳ ˆˋˁˊˉʳ ˆˊˁˈ˃ʳ ˇ˅ˁˊˉʳ ˆˋˁˈˆʳ ˆˊˁ˃ˇʳ ˆˊˁˊˈʳ ˆˊˁˋˋʳ ˅ˊˁˇˇʳ ˅ˈˁˌˆʳ ˅ˈˁˊˊʳ ˅ˉˁˇˊʳ ˅ˊˁˈˊʳ ˅ˉˁˇ˃ʳ ˅ˉˁ˃ˉʳ ˅ˊˁˆˌʳ ˅ˈˁˊˈʳ ˅ˉˁˆˇʳ ˅ˈˁˋˉʳ ˅ˈˁˊˊʳ ˅ˉˁ˅˅ʳ ˇ˅ˁˊˉʳ ˅ˈˁˊˈʳ ˆ˅ˁ˅˅ʳ ˉˁ˃ˋʳ Page 8 of 12 A1 ˇ˅ˁˋˉʳ ˆˌˁˆˋʳ ˆˌˁˋˉʳ ˆˌˁˋˋʳ ˆˊˁˉˉʳ ˆˊˁˊˉʳ ˆˋˁ˄˄ʳ ˇ˃ˁ˄ˋʳ ˆˌˁ˃ˇʳ ˆˋˁˋˋʳ ˇ˅ˁˋˇʳ ˆˌˁˆ˅ʳ ˇ˃ˁ˃ˋʳ ˅ˉˁˋˆʳ ˅ˉˁˌ˃ʳ ˅ˉˁˈˆʳ ˅ˉˁ˄˃ʳ ˅ˊˁ˃ˇʳ ˅ˉˁˆ˃ʳ ˅ˊˁ˅ˉʳ ˅ˉˁ˅ˇʳ ˅ˊˁˇˌʳ ˅ˉˁˋ˃ʳ ˅ˊˁ˅ˆʳ ˅ˊˁ˃ˉʳ ˅ˉˁˋˋʳ ˇ˅ˁˋˉʳ ˅ˉˁ˄˃ʳ ˆˆˁ˅ˈʳ ˉˁˉˉʳ After Vibration A2 A3 A4 ˆˊˁ˃ˋʳ ˆˊˁˌˊʳʳ ˆˋˁ˄ˋʳʳ ˇˇˁˊˊʳ ˆˊˁˇˈʳʳ ˆˊˁˉˋʳʳ ˆˌˁˈˊʳ ˆˉˁˉˆʳʳ ˆˋˁˈ˅ʳʳ ˆˊˁˈˌʳ ˆˊˁ˅˅ʳʳ ˆˊˁ˃ˌʳʳ ˆˊˁ˃˃ʳ ˆˉˁˈˋʳʳ ˆˊˁˊ˅ʳʳ ˆˉˁˇˈʳ ˆˉˁ˅ˇʳʳ ˆˋˁ˃ˉʳʳ ˆˉˁˌ˃ʳ ˆˉˁ˄ˋʳʳ ˇ˃ˁˈˇʳʳ ˆˉˁˇˋʳ ˆˉˁˉˊʳʳ ˆˋˁˊ˄ʳʳ ˆˊˁ˃ˇʳ ˆˉˁˌˋʳʳ ˆˋˁˊ˄ʳʳ ˆˉˁˇ˅ʳ ˆˉˁ˃ˌʳʳ ˆˊˁˈˉʳʳ ˆˊˁ˃ˉʳ ˆˉˁ˄ˆʳʳ ˆˋˁ˅ˉʳʳ ˆˉˁˊˈʳ ˆˉˁˉ˄ʳʳ ˆˊˁ˄ˆʳʳ ˆˊˁ˄ˊʳ ˆˊˁ˃ˉʳʳ ˆˉˁˋˈʳʳ ˅ˈˁˆˌʳ ˅ˉˁ˅˄ʳʳ ˅ˈˁ˄ˉʳʳ ˅ˈˁˋˈʳ ˅ˈˁˇ˅ʳʳ ˅ˈˁˉˊʳʳ ˅ˈˁˋˋʳ ˅ˈˁˉˌʳʳ ˅ˉˁ˃˃ʳʳ ˅ˉˁ˅ˆʳ ˅ˈˁˊˊʳʳ ˅ˈˁˊˋʳʳ ˅ˈˁˊ˄ʳ ˅ˈˁˉ˄ʳʳ ˅ˈˁˌˋʳʳ ˅ˊˁ˃˅ʳ ˅ˈˁˆ˃ʳʳ ˅ˈˁˉˇʳʳ ˅ˉˁˇˇʳ ˅ˉˁˇ˅ʳʳ ˅ˈˁˉˊʳʳ ˅ˉˁˆˇʳ ˅ˉˁ˃˄ʳʳ ˅ˉˁˉˇʳʳ ˅ˉˁˉˆʳ ˅ˉˁˈ˅ʳʳ ˅ˈˁˌˌʳʳ ˅ˉˁˈ˅ʳ ˅ˉˁ˅˄ʳʳ ˅ˈˁˌˈʳʳ ˅ˉˁˈˇʳ ˅ˈˁˊˉʳʳ ˅ˈˁˉˉʳʳ ˅ˉˁˌ˃ʳ ˅ˋˁˉˈʳʳ ˅ˈˁˉˉʳʳ ˅ˉˁ˃ˉʳ ˅ˊˁˇˈʳʳ ˅ˈˁˉˋʳʳ ˇˇˁˊˊʳ ˆˊˁˌˊʳʳ ˇ˃ˁˈˇʳʳ ˅ˈˁˆˌʳ ˅ˈˁˆ˃ʳʳ ˅ˈˁ˄ˉʳʳ ˆ˄ˁˌˌʳ ˆ˄ˁˇˌʳʳ ˆ˄ˁˌˇʳʳ ˉˁ˃ˈʳ ˈˁˇ˅ʳʳ ˉˁˆ˃ʳʳ A5 ˆˋˁˈ˅ʳ ˆˌˁ˄ˊʳ ˆˋˁˇ˃ʳ ˆˋˁ˃ˆʳ ˆˌˁ˃ˋʳ ˆˋˁˋˋʳ ˇ˃ˁˇ˄ʳ ˆˋˁˇˇʳ ˇˉˁ˅ˆʳ ˆˌˁ˄˃ʳ ˆˊˁˊˋʳ ˆˋˁˊ˃ʳ ˆˋˁˌˆʳ ˅ˉˁˇ˄ʳ ˅ˉˁ˅ˆʳ ˅ˉˁˇˇʳ ˅ˉˁˇ˃ʳ ˅ˉˁˉˊʳ ˅ˊˁˆˋʳ ˅ˊˁˌˈʳ ˅ˉˁˊ˃ʳ ˅ˋˁ˃ˌʳ ˅ˉˁˉˈʳ ˅ˉˁˌ˄ʳ ˅ˊˁˆˈʳ ˅ˊˁ˅ˆʳ ˇˉˁ˅ˆʳ ˅ˉˁ˅ˆʳ ˆˆˁ˄ˈʳ ˉˁˈ˄ʳ PRODUCT RELIABILITY TEST REPORT Report No. GL-RD090107ʳ ʳ ʳ ʳ ʳ ʳ ʳ GL-P-027-005 Group B B-Durability NO ˄ˀˆʳ ˈˀˊʳ ˌˀ˄˄ʳ ˄ˆˀ˄ˈʳ ˄ˊˀ˄ˌʳ ˅˄ˀ˅ˆʳ ˅ˈˀ˅ˊʳ ˅ˌˀˆ˄ʳ ˆˆˀˆˈʳ ˆˊˀˆˌʳ ˇ˄ˀˇˆʳ ˇˈˀˇˊʳ ˇˌˀˈ˄ʳ ˅ˀˇʳ ˉˀˋʳ ˄˃ˀ˄˅ʳ ˄ˇˀ˄ˉʳ ˄ˋˀ˅˃ʳ ˅˅ˀ˅ˇʳ ˅ˉˀ˅ˋʳ ˆ˃ˀˆ˅ʳ ˆˇˀˆˉʳ ˆˋˀˇ˃ʳ ˇ˅ˀˇˇʳ ˇˉˀˇˋʳ ˈ˃ˀˈ˅ʳ Max Min Avg Stdev B1 ˆˊˁˋˊʳʳ ˆˋˁ˅˅ʳʳ ˆˋˁ˄ˈʳʳ ˆˋˁˇˉʳʳ ˆˉˁˌ˃ʳʳ ˆˊˁˉˊʳʳ ˆˊˁˈ˄ʳʳ ˆˊˁˋˌʳʳ ˆˋˁ˅ˊʳʳ ˆˋˁˊˆʳʳ ˆˋˁˆˋʳʳ ˆˌˁˊˌʳʳ ˆˋˁˊˈʳʳ ˅ˈˁˌˆʳʳ ˅ˈˁˊ˃ʳʳ ˅ˉˁˆ˄ʳʳ ˅ˉˁˇˌʳʳ ˅ˈˁˈˉʳʳ ˅ˉˁ˄ˋʳʳ ˅ˈˁˈˌʳʳ ˅ˉˁˈˈʳʳ ˅ˉˁˈˊʳʳ ˅ˉˁˊˇʳʳ ˅ˉˁˈˈʳʳ ˅ˊˁ˄ˇʳʳ ˅ˉˁˉˇʳʳ ˆˌˁˊˌʳʳ ˅ˈˁˈˉʳʳ ˆ˅ˁ˅ˈʳʳ ˉˁ˃ˌʳʳ B2 ˇ˃ˁˌˆʳʳ ˆˌˁˉˈʳʳ ˇ˅ˁ˄ˇʳʳ ˇ˃ˁ˄˅ʳʳ ˆˋˁˊˈʳʳ ˆˌˁ˄˅ʳʳ ˆˋˁ˃˄ʳʳ ˆˋˁ˄ˋʳʳ ˆˌˁ˄ˉʳʳ ˆˋˁˆˇʳʳ ˆˊˁˋˊʳʳ ˆˊˁˌˉʳʳ ˆˋˁˊˉʳʳ ˅ˊˁˉˈʳʳ ˅ˋˁˈˋʳʳ ˅ˊˁˉˊʳʳ ˅ˋˁ˃˃ʳʳ ˅ˊˁ˃˄ʳʳ ˅ˊˁˇ˄ʳʳ ˅ˊˁ˃ˊʳʳ ˅ˊˁˈˈʳʳ ˅ˋˁ˅ˋʳʳ ˅ˊˁˊˇʳʳ ˅ˊˁˉˌʳʳ ˅ˊˁ˄˃ʳʳ ˅ˉˁˌˊʳʳ ˇ˅ˁ˄ˇʳʳ ˅ˉˁˌˊʳʳ ˆˆˁˆˊʳʳ ˈˁˌˊʳʳ Initial B3 ˇ˄ˁˇˇʳʳ ˆˊˁˌˆʳʳ ˆˋˁˇˌʳʳ ˆˈˁˌˈʳʳ ˆˊˁˉˈʳʳ ˆˋˁ˄ˋʳʳ ˆˋˁˈˇʳʳ ˆˉˁˈ˅ʳʳ ˆˊˁˊˇʳʳ ˆˉˁˆˈʳʳ ˆˊˁ˅ˉʳʳ ˆˉˁˇ˄ʳʳ ˆˉˁˉ˃ʳʳ ˅ˉˁ˅ˆʳʳ ˅ˉˁˋˋʳʳ ˅ˉˁˌ˃ʳʳ ˅ˉˁ˄ˆʳʳ ˅ˉˁ˄ˈʳʳ ˅ˉˁ˃ˌʳʳ ˅ˉˁ˃ˋʳʳ ˅ˈˁˋˋʳʳ ˅ˉˁ˃ˈʳʳ ˅ˉˁ˅ˊʳʳ ˅ˉˁ˃ˋʳʳ ˅ˉˁˌ˅ʳʳ ˅ˉˁˆ˃ʳʳ ˇ˄ˁˇˇʳʳ ˅ˈˁˋˋʳʳ ˆ˄ˁˌˉʳʳ ˈˁˋˉʳʳ B4 ˇ˅ˁ˃ˇʳ ˇ˃ˁˇˇʳ ˆˋˁ˄ˆʳ ˆˊˁ˅ˇʳ ˆˊˁ˃ˋʳ ˇ˃ˁˈˉʳ ˆˌˁ˅ˆʳ ˆˋˁˈˇʳ ˆˋˁ˃ˊʳ ˆˊˁˋˋʳ ˆˊˁˋˋʳ ˆˋˁˆˋʳ ˆˉˁˌˆʳ ˅ˉˁˈˉʳ ˅ˉˁˆ˄ʳ ˅ˊˁˆ˅ʳ ˅ˉˁˌˇʳ ˅ˊˁˈˋʳ ˅ˊˁ˄ˉʳ ˅ˊˁ˃ˆʳ ˅ˉˁˊˈʳ ˅ˉˁˋˋʳ ˅ˊˁ˄˄ʳ ˅ˉˁˌˊʳ ˅ˉˁˌ˅ʳ ˅ˉˁˌˇʳ ˇ˅ˁ˃ˇʳ ˅ˉˁˆ˄ʳ ˆ˅ˁˋ˃ʳ ˉˁ˃ˉʳ B5 ˆˊˁˊ˄ʳ ˆˊˁ˄ˊʳ ˇ˄ˁ˅ˇʳ ˇ˃ˁˉˈʳ ˆˊˁˋˋʳ ˆˋˁˆˋʳ ˆˋˁ˄ˋʳ ˆˋˁˋ˃ʳ ˆˋˁˈˊʳ ˆˋˁˌˆʳ ˆˌˁˊˆʳ ˇ˄ˁˊˊʳ ˇ˃ˁ˃ˈʳ ˅ˉˁˇˌʳ ˅ˊˁ˅ˇʳ ˅ˉˁˌˋʳ ˅ˉˁˊ˃ʳ ˅ˊˁ˄˃ʳ ˅ˉˁˌˈʳ ˅ˉˁˌˋʳ ˅ˊˁˇˈʳ ˅ˊˁˈˇʳ ˅ˊˁˌ˃ʳ ˅ˊˁˊˈʳ ˅ˋˁ˃ˉʳ ˅ˊˁˉˋʳ ˇ˄ˁˊˊʳ ˅ˉˁˇˌʳ ˆˆˁ˅˅ʳ ˉˁ˄ˇʳ Page 9 of 12 B1 ˇˌˁˌˋʳ ˈ˅ˁˉˆʳ ˈ˅ˁ˃ˈʳ ˈ˄ˁ˄ˌʳ ˈˆˁ˄˃ʳ ˇˋˁˌˌʳ ˈ˅ˁ˃ˌʳ ˇˋˁˉˋʳ ˇˌˁˋˆʳ ˈ˄ˁˇˊʳ ˈ˅ˁˉˆʳ ˈ˄ˁˌˈʳ ˈ˅ˁˊ˄ʳ ˆˊˁˈ˃ʳ ˆˊˁˈ˄ʳ ˆˌˁ˄ˇʳ ˆˌˁ˃ˆʳ ˆˌˁˇˈʳ ˆˋˁˊ˄ʳ ˆˌˁˊ˃ʳ ˆˋˁˈˌʳ ˆˌˁˋˊʳ ˆˋˁˈˉʳ ˆˌˁˆˊʳ ˆˌˁ˅˅ʳ ˆˌˁ˄ˇʳ ˈˆˁ˄˃ʳ ˆˊˁˈ˃ʳ ˇˈˁ˄˅ʳ ˉˁˇˇʳ After B2 ˈ˅ˁˋˊʳ ˈ˅ˁˈ˃ʳ ˈ˅ˁ˄ˉʳ ˈ˅ˁ˃˅ʳ ˇˉˁˈ˅ʳ ˇˉˁˈˆʳ ˇˊˁ˃ˆʳ ˇˊˁˌˆʳ ˈ˅ˁˋˊʳ ˇˋˁˋˉʳ ˇˌˁˊˇʳ ˈ˄ˁˇˆʳ ˈ˄ˁˋˌʳ ˇ˃ˁ˅ˆʳ ˇ˃ˁˈˇʳ ˇ˃ˁ˅ˇʳ ˇ˄ˁ˃ˆʳ ˆˌˁˇˋʳ ˆˋˁˋ˃ʳ ˆˌˁ˃˅ʳ ˆˌˁˇˌʳ ˆˌˁˉ˃ʳ ˇ˄ˁˋˌʳ ˆˌˁˉˌʳ ˆˋˁˋˋʳ ˆˌˁˌ˄ʳ ˈ˅ˁˋˊʳ ˆˋˁˋ˃ʳ ˇˈˁ˃ˇʳ ˈˁˈˈʳ Durabilitye B3 B4 ˈ˄ˁ˄ˋʳʳ ˈ˄ˁ˃ˉʳ ˇˈˁˇˉʳʳ ˇˊˁˈˇʳ ˇˋˁ˃ˈʳʳ ˇˋˁˉˆʳ ˇˋˁˈˆʳʳ ˇˊˁ˄ˊʳ ˇˊˁ˃ˉʳʳ ˇˊˁ˅˄ʳ ˇˊˁˇˇʳʳ ˇˉˁ˅ˊʳ ˇˌˁ˅ˌʳʳ ˇˌˁ˃˄ʳ ˇˊˁ˄ˈʳʳ ˇˉˁˌˇʳ ˇˋˁˉˇʳʳ ˇˉˁˈˆʳ ˇˊˁˋ˅ʳʳ ˇˉˁˌˇʳ ˇˋˁˆ˃ʳʳ ˇˊˁˊˇʳ ˇˋˁˇˊʳʳ ˇˊˁˉˈʳ ˇˌˁ˅˄ʳʳ ˇˌˁˌˉʳ ˇ˄ˁ˃ˆʳʳ ˆˋˁˊˈʳ ˇ˃ˁˉˆʳʳ ˆˋˁˈˌʳ ˇ˃ˁˆˋʳʳ ˆˌˁˉ˅ʳ ˇ˄ˁˋˋʳʳ ˆˋˁˉˌʳ ˇ˃ˁˋ˄ʳʳ ˆˌˁ˃˄ʳ ˇ˃ˁˊ˃ʳʳ ˆˋˁˇˇʳ ˆˌˁˈˌʳʳ ˆˋˁˈˋʳ ˇ˃ˁ˄˃ʳʳ ˆˋˁˈ˄ʳ ˇ˄ˁ˅ˉʳʳ ˆˌˁ˅ˊʳ ˆˌˁ˅ˊʳʳ ˆˋˁ˃ˊʳ ˇ˄ˁˈˌʳʳ ˆˋˁˆˌʳ ˆˌˁ˅˃ʳʳ ˆˋˁˋ˃ʳ ˇ˃ˁˉˋʳʳ ˆˊˁˊˌʳ ˈ˄ˁ˄ˋʳʳ ˈ˄ˁ˃ˉʳ ˆˌˁ˅˃ʳʳ ˆˊˁˊˌʳ ˇˇˁˆˊʳʳ ˇˆˁ˅ˊʳ ˇˁ˃ˉʳʳ ˇˁˋ˅ʳ B5 ˈ˄ˁˋ˄ʳ ˈ˅ˁˉˊʳ ˈ˄ˁˋˋʳ ˈ˃ˁˉˌʳ ˇˋˁˆ˅ʳ ˇˉˁ˄ˇʳ ˇˌˁˆ˄ʳ ˇˋˁˋˉʳ ˈ˄ˁ˄ˇʳ ˈ˄ˁˇˇʳ ˈ˅ˁˊˈʳ ˈ˄ˁ˄ˋʳ ˈ˄ˁ˅ˆʳ ˆˌˁˇ˃ʳ ˆˌˁˊˆʳ ˆˌˁˊˇʳ ˇ˅ˁ˃ˋʳ ˆˌˁˋˋʳ ˆˌˁ˃ˌʳ ˆˌˁ˄ˇʳ ˆˌˁ˄ˌʳ ˆˋˁ˅ˋʳ ˆˋˁˋ˅ʳ ˆˋˁˉˆʳ ˆˌˁˊˈʳ ˆˌˁ˃ˌʳ ˈ˅ˁˊˈʳ ˆˋˁ˅ˋʳ ˇˈˁ˃˄ʳ ˈˁˋˉʳ PRODUCT RELIABILITY TEST REPORT Report No. GL-RD090107ʳ ʳ ʳ ʳ ʳ ʳ ʳ GL-P-027-005 Group C NO ˄ˀˆʳ ˈˀˊʳ ˌˀ˄˄ʳ ˄ˆˀ˄ˈʳ ˄ˊˀ˄ˌʳ ˅˄ˀ˅ˆʳ ˅ˈˀ˅ˊʳ ˅ˌˀˆ˄ʳ ˆˆˀˆˈʳ ˆˊˀˆˌʳ ˇ˄ˀˇˆʳ ˇˈˀˇˊʳ ˇˌˀˈ˄ʳ ˅ˀˇʳ ˉˀˋʳ ˄˃ˀ˄˅ʳ ˄ˇˀ˄ˉʳ ˄ˋˀ˅˃ʳ ˅˅ˀ˅ˇʳ ˅ˉˀ˅ˋʳ ˆ˃ˀˆ˅ʳ ˆˇˀˆˉʳ ˆˋˀˇ˃ʳ ˇ˅ˀˇˇʳ ˇˉˀˇˋʳ ˈ˃ˀˈ˅ʳ Max Min Avg Stdev C1 ˇ˃ˁ˃ˌʳʳ ˆˌˁˆˇʳʳ ˆˌˁˆˇʳʳ ˇ˃ˁˋˆʳʳ ˆˌˁˈ˃ʳʳ ˇ˅ˁˆˇʳʳ ˇ˃ˁˇˋʳʳ ˆˋˁˉˈʳʳ ˆˋˁˉ˃ʳʳ ˆˊˁ˄ˌʳʳ ˆˋˁ˅ˆʳʳ ˆˌˁˈˊʳʳ ˆˋˁ˃ˊʳʳ ˅ˉˁˆˊʳʳ ˅ˊˁˆ˃ʳʳ ˅ˉˁˉˈʳʳ ˅ˉˁˉˊʳʳ ˅ˉˁˋˋʳʳ ˅ˉˁ˄ˉʳʳ ˅ˉˁˇ˅ʳʳ ˅ˉˁˉˌʳʳ ˅ˉˁˆˌʳʳ ˅ˉˁˆˈʳʳ ˅ˈˁˋ˅ʳʳ ˅ˉˁ˃ˊʳʳ ˅ˋˁ˃ˇʳʳ ˇ˅ˁˆˇʳʳ ˅ˈˁˋ˅ʳʳ ˆˆˁ˃˃ʳʳ ˉˁˉ˄ʳʳ C2 ˆˌˁˆˉʳʳ ˆˋˁ˄˃ʳʳ ˆˋˁˆˊʳʳ ˆˌˁˇˋʳʳ ˆˉˁˋˌʳʳ ˆˊˁ˅ˈʳʳ ˆˋˁ˅ˋʳʳ ˆˉˁˈ˄ʳʳ ˆˊˁˋ˅ʳʳ ˆˉˁˉˋʳʳ ˆˊˁˈˈʳʳ ˆˊˁ˄ˊʳʳ ˆˋˁ˄ˈʳʳ ˅ˋˁ˃˅ʳʳ ˅ˈˁˊˋʳʳ ˅ˊˁˊˋʳʳ ˅ˉˁ˃˅ʳʳ ˅ˌˁˊ˃ʳʳ ˅ˉˁ˃˅ʳʳ ˅ˊˁ˃˄ʳʳ ˅ˉˁˆˌʳʳ ˅ˋˁˋˇʳʳ ˅ˋˁ˅ˆʳʳ ˅ˉˁˊˈʳʳ ˅ˉˁ˄˃ʳʳ ˅ˉˁˈˊʳʳ ˆˌˁˇˋʳʳ ˅ˈˁˊˋʳʳ ˆ˅ˁˇˌʳʳ ˈˁˈˆʳʳ Initial C3 ˆˉˁˊˋʳʳ ˆˉˁˇ˄ʳʳ ˆˉˁˋˆʳʳ ˆˉˁˌˊʳʳ ˆˉˁˇ˄ʳʳ ˆˊˁ˃ˊʳʳ ˆˉˁ˅ˋʳʳ ˆˉˁˈˈʳʳ ˆˉˁ˃ˋʳʳ ˆˉˁ˅ˈʳʳ ˆˉˁ˅ˋʳʳ ˆˉˁˌˌʳʳ ˆˊˁ˅˄ʳʳ ˅ˈˁ˃ˉʳʳ ˅ˈˁˋˉʳʳ ˅ˉˁ˅ˌʳʳ ˅ˉˁˉˌʳʳ ˅ˈˁˌˇʳʳ ˅ˊˁˌˈʳʳ ˅ˉˁˆˇʳʳ ˅ˉˁˇˈʳʳ ˅ˉˁˇˇʳʳ ˅ˉˁˉ˃ʳʳ ˅ˉˁˉ˅ʳʳ ˅ˉˁˉˋʳʳ ˅ˉˁˉˆʳʳ ˆˊˁ˅˄ʳʳ ˅ˈˁ˃ˉʳʳ ˆ˄ˁˈ˅ʳʳ ˈˁ˅ˆʳʳ C-Mechanical shock After Mechanical shock C4 C5 C1 C2 C3 C4 ˆˊˁˇˈʳ ˆˋˁ˅ˈʳ ˆˊˁˈˊʳ ˆˊˁˌ˄ʳ ˆˉˁ˃ˌʳʳ ˆˉˁˉ˄ʳʳ ˆˋˁˆ˃ʳ ˆˌˁˇˇʳ ˆˊˁˈˉʳ ˆˊˁˇˆʳ ˆˉˁ˅ˆʳʳ ˆˊˁ˄˅ʳʳ ˆˋˁ˅˃ʳ ˆˋˁ˄ˌʳ ˆˊˁ˄˅ʳ ˆˊˁˌˇʳ ˆˉˁ˅ˌʳʳ ˆˊˁ˃ˉʳʳ ˆˋˁˇˌʳ ˆˉˁ˄ˇʳ ˆˊˁ˄ˋʳ ˆˋˁ˄ˌʳ ˆˉˁˋˆʳʳ ˆˊˁˆˉʳʳ ˆˉˁ˄ˇʳ ˆˊˁˌˌʳ ˆˉˁˌ˅ʳ ˆˊˁ˄ˉʳ ˆˉˁ˄ˈʳʳ ˆˉˁˈˌʳʳ ˆˊˁˈˇʳ ˆˌˁ˄ˉʳ ˆˋˁˌˇʳ ˆˊˁ˄ˌʳ ˆˉˁˊ˄ʳʳ ˆˉˁˋ˄ʳʳ ˆˊˁ˃ˈʳ ˇ˄ˁˇ˅ʳ ˆˋˁ˅˅ʳ ˆˋˁˇˌʳ ˆˉˁˇˈʳʳ ˆˉˁˈˆʳʳ ˆˊˁ˃ˇʳ ˆˊˁˈ˄ʳ ˆˋˁ˅ˋʳ ˆˊˁˉ˄ʳ ˆˊˁ˃ˊʳʳ ˆˉˁˊ˄ʳʳ ˆˉˁˊ˄ʳ ˆˊˁˌˉʳ ˆˊˁˇ˃ʳ ˆˊˁˊˋʳ ˆˉˁ˃ˊʳʳ ˆˉˁˈˊʳʳ ˆˊˁ˃˄ʳ ˆˊˁˆˆʳ ˆˊˁˋˈʳ ˆˉˁˇ˅ʳ ˆˊˁ˃ˇʳʳ ˆˉˁˊˆʳʳ ˆˊˁ˃ˊʳ ˆˉˁˊˋʳ ˆˊˁ˄ˈʳ ˆˊˁ˅ˋʳ ˆˉˁˊˋʳʳ ˆˉˁˉˉʳʳ ˆˊˁ˄ˊʳ ˆˉˁˌ˃ʳ ˆˊˁˊˉʳ ˆˊˁ˃ˈʳ ˆˊˁ˄ˊʳʳ ˆˊˁ˃˅ʳʳ ˆˊˁ˅ˌʳ ˆˊˁˇˆʳ ˆˉˁˌ˄ʳ ˆˉˁˋˉʳ ˆˉˁˊˇʳʳ ˆˉˁ˄˄ʳʳ ˅ˉˁ˃˃ʳ ˅ˉˁˈ˃ʳ ˅ˉˁ˃ˋʳ ˅ˉˁˇ˄ʳ ˅ˈˁˊ˃ʳʳ ˅ˉˁˉˊʳʳ ˅ˉˁˇˇʳ ˅ˊˁˌˇʳ ˅ˈˁ˅ˇʳ ˅ˈˁˊˊʳ ˅ˉˁ˃˃ʳʳ ˅ˉˁˋˋʳʳ ˅ˉˁˋˆʳ ˅ˌˁˉ˃ʳ ˅ˈˁ˅˅ʳ ˅ˉˁ˅ˋʳ ˅ˉˁ˄˃ʳʳ ˅ˉˁˋˆʳʳ ˅ˋˁ˄ˇʳ ˅ˋˁ˃ˉʳ ˅ˈˁˈˈʳ ˅ˊˁ˄˃ʳ ˅ˉˁ˃˄ʳʳ ˅ˉˁˌˊʳʳ ˅ˊˁˆˉʳ ˅ˊˁˇˊʳ ˅ˉˁˊˆʳ ˅ˊˁˉˇʳ ˅ˈˁˊˌʳʳ ˅ˉˁˇˌʳʳ ˅ˊˁˈˈʳ ˅ˈˁˋ˄ʳ ˅ˉˁˇˊʳ ˅ˈˁˋˌʳ ˅ˉˁ˃˅ʳʳ ˅ˉˁˈ˅ʳʳ ˅ˊˁˌˆʳ ˅ˊˁ˄ˋʳ ˅ˉˁ˅˃ʳ ˅ˉˁ˃ˋʳ ˅ˈˁˌˇʳʳ ˅ˉˁˈˋʳʳ ˅ˊˁˇˊʳ ˅ˊˁˆ˅ʳ ˅ˉˁˇˋʳ ˅ˈˁˊˆʳ ˅ˉˁ˅ˆʳʳ ˅ˉˁˋ˃ʳʳ ˅ˊˁˉ˄ʳ ˅ˉˁˈˉʳ ˅ˉˁˇˈʳ ˅ˉˁˋˆʳ ˅ˈˁˋˈʳʳ ˅ˉˁ˄ˉʳʳ ˅ˋˁˊˆʳ ˅ˊˁ˃ˆʳ ˅ˉˁˈˋʳ ˅ˈˁˉˉʳ ˅ˈˁˌˈʳʳ ˅ˉˁˆˌʳʳ ˅ˋˁˌˉʳ ˅ˊˁˈˊʳ ˅ˈˁˊˈʳ ˅ˊˁ˄˅ʳ ˅ˈˁˉ˃ʳʳ ˅ˉˁˇ˅ʳʳ ˅ˋˁ˅ˆʳ ˅ˊˁ˄ˌʳ ˅ˉˁ˄ˋʳ ˅ˈˁˇˊʳ ˅ˈˁˇˊʳʳ ˅ˈˁˋ˄ʳʳ ˅ˋˁ˅ˈʳ ˅ˊˁ˅ˈʳ ˅ˈˁˈ˃ʳ ˆ˃ˁˉˋʳ ˅ˈˁ˃ˋʳʳ ˅ˈˁˉˌʳʳ ˆˋˁˇˌʳ ˇ˄ˁˇ˅ʳ ˆˋˁˌˇʳ ˆˋˁˇˌʳ ˆˊˁ˄ˊʳʳ ˆˊˁˆˉʳʳ ˅ˉˁ˃˃ʳ ˅ˈˁˋ˄ʳ ˅ˈˁ˅˅ʳ ˅ˈˁˇˊʳ ˅ˈˁ˃ˋʳʳ ˅ˈˁˉˌʳʳ ˆ˅ˁˈ˃ʳ ˆ˅ˁˉˌʳ ˆ˄ˁˋ˅ʳ ˆ˅ˁ˃ˊʳ ˆ˄ˁ˅˃ʳʳ ˆ˄ˁˉ˅ʳʳ ˈˁ˃˃ʳ ˈˁˈˊʳ ˈˁˌˆʳ ˈˁˉ˄ʳ ˈˁˈ˃ʳʳ ˈˁ˅ˈʳʳ Page 10 of 12 C5 ˆˉˁˈˌʳ ˆˊˁˊˋʳ ˆˊˁ˃ˈʳ ˆˉˁˉˇʳ ˆˊˁ˅ˈʳ ˆˋˁ˄ˋʳ ˆˉˁˌˈʳ ˆˊˁ˃ˋʳ ˆˉˁˋˈʳ ˆˉˁˋˇʳ ˆˉˁ˄ˋʳ ˆˉˁˋˋʳ ˆˉˁˉˆʳ ˅ˈˁ˅ˈʳ ˅ˈˁˌˋʳ ˅ˈˁˋˉʳ ˅ˈˁˋˌʳ ˅ˉˁˆ˃ʳ ˅ˉˁ˅ˋʳ ˅ˉˁ˄ˇʳ ˅ˉˁˈˆʳ ˅ˉˁˆ˅ʳ ˅ˊˁˌˋʳ ˅ˉˁˋ˃ʳ ˅ˉˁˋˊʳ ˅ˈˁˊˋʳ ˆˋˁ˄ˋʳ ˅ˈˁ˅ˈʳ ˆ˄ˁˉˈʳ ˈˁˇˋʳ PRODUCT RELIABILITY TEST REPORT Report No. GL-RD090107ʳ ʳ ʳ ʳ ʳ ʳ ʳ GL-P-027-005 Group F F- Temperature life NO ˄ˀˆʳ ˈˀˊʳ ˌˀ˄˄ʳ ˄ˆˀ˄ˈʳ ˄ˊˀ˄ˌʳ ˅˄ˀ˅ˆʳ ˅ˈˀ˅ˊʳ ˅ˌˀˆ˄ʳ ˆˆˀˆˈʳ ˆˊˀˆˌʳ ˇ˄ˀˇˆʳ ˇˈˀˇˊʳ ˇˌˀˈ˄ʳ ˅ˀˇʳ ˉˀˋʳ ˄˃ˀ˄˅ʳ ˄ˇˀ˄ˉʳ ˄ˋˀ˅˃ʳ ˅˅ˀ˅ˇʳ ˅ˉˀ˅ˋʳ ˆ˃ˀˆ˅ʳ ˆˇˀˆˉʳ ˆˋˀˇ˃ʳ ˇ˅ˀˇˇʳ ˇˉˀˇˋʳ ˈ˃ˀˈ˅ʳ Max Min Avg Stdev F1 ˆˈˁˌˈʳʳ ˆˇˁ˃˃ʳʳ ˆˆˁˋˈʳʳ ˆ˅ˁˆˈʳʳ ˆˆˁˉˈʳʳ ˆˇˁˌˈʳʳ ˆˇˁˌ˃ʳʳ ˆˇˁˆˈʳʳ ˆˇˁˆ˃ʳʳ ˆˆˁˆˈʳʳ ˆˆˁ˃ˈʳʳ ˆˆˁˈˈʳʳ ˆˆˁˌ˃ʳʳ ˅ˆˁˈ˃ʳʳ ˅ˆˁˇˈʳʳ ˅ˆˁˈ˃ʳʳ ˅ˆˁˇˈʳʳ ˅ˈˁ˄˃ʳʳ ˅ˆˁ˅ˈʳʳ ˅ˇˁˆ˃ʳʳ ˅ˇˁ˄˃ʳʳ ˅ˈˁ˃ˈʳʳ ˅ˇˁˆ˃ʳʳ ˅ˇˁˇˈʳʳ ˅ˆˁˈ˃ʳʳ ˅˅ˁˉ˃ʳʳ ˆˈˁˌˈʳʳ ˅˅ˁˉ˃ʳʳ ˅ˋˁˌˈʳʳ ˈˁ˅ˆʳʳ F2 ˆˉˁ˄ˈʳʳ ˆˉˁˆˈʳʳ ˆˊˁ˅˃ʳʳ ˆˊˁˈˈʳʳ ˆˈˁˆ˃ʳʳ ˆˈˁˊˈʳʳ ˆˉˁˉ˃ʳʳ ˆˈˁ˅ˈʳʳ ˆˆˁˉˈʳʳ ˆˇˁ˅˃ʳʳ ˆˇˁˌˈʳʳ ˆˉˁ˅ˈʳʳ ˆˆˁ˃˃ʳʳ ˅˅ˁ˄ˈʳʳ ˅ˆˁ˃ˈʳʳ ˅˅ˁˌˈʳʳ ˅ˆˁ˃˃ʳʳ ˅ˆˁ˃˃ʳʳ ˅ˆˁ˅ˈʳʳ ˅˅ˁˋ˃ʳʳ ˅˅ˁˈˈʳʳ ˅˅ˁˊˈʳʳ ˅˅ˁˋ˃ʳʳ ˅ˆˁˆ˃ʳʳ ˅˅ˁˇˈʳʳ ˅˅ˁ˄ˈʳʳ ˆˊˁˈˈʳʳ ˅˅ˁ˄ˈʳʳ ˅ˌˁ˄ˊʳʳ ˉˁˈˋʳʳ Initial F3 ˆˇˁˇ˃ʳʳ ˆˆˁˆ˃ʳʳ ˆˇˁ˃ˈʳʳ ˆˆˁˇˈʳʳ ˆˆˁˇˈʳʳ ˆˆˁˊ˃ʳʳ ˆˇˁ˃˃ʳʳ ˆˆˁˊ˃ʳʳ ˆˇˁˈˈʳʳ ˆˆˁˌ˃ʳʳ ˆˈˁˊ˃ʳʳ ˆˈˁ˃˃ʳʳ ˆˈˁˊ˃ʳʳ ˅˅ˁˊ˃ʳʳ ˅ˆˁˈˈʳʳ ˅ˆˁ˄ˈʳʳ ˅ˆˁˆ˃ʳʳ ˅ˆˁˇˈʳʳ ˅ˆˁˈˈʳʳ ˅ˇˁ˃ˈʳʳ ˅ˆˁˌ˃ʳʳ ˅ˇˁ˃˃ʳʳ ˅ˆˁˊˈʳʳ ˅ˆˁˋ˃ʳʳ ˅ˆˁˌ˃ʳʳ ˅ˆˁˈ˃ʳʳ ˆˈˁˊ˃ʳʳ ˅˅ˁˊ˃ʳʳ ˅ˋˁˌ˃ʳʳ ˈˁˇˉʳʳ F4 ˆˆˁˊ˃ʳ ˆ˅ˁˇˈʳ ˆˈˁ˃˃ʳ ˆˇˁˇ˃ʳ ˆ˅ˁˌˈʳ ˆ˅ˁˌ˃ʳ ˆˆˁˋ˃ʳ ˆ˅ˁˌ˃ʳ ˆˇˁˆ˃ʳ ˆˆˁˈˈʳ ˆˇˁ˃˃ʳ ˆˆˁ˃˃ʳ ˆˆˁˌˈʳ ˅˅ˁˈˈʳ ˅ˆˁ˃ˈʳ ˅˅ˁˌ˃ʳ ˅ˆˁ˄ˈʳ ˅˅ˁˌˈʳ ˅˅ˁˋ˃ʳ ˅˅ˁˌ˃ʳ ˅˅ˁˋ˃ʳ ˅˅ˁˋˈʳ ˅ˊˁˋ˃ʳ ˅˅ˁˉˈʳ ˅˅ˁˉˈʳ ˅˅ˁ˄ˈʳ ˆˈˁ˃˃ʳ ˅˅ˁ˄ˈʳ ˅ˋˁˆˌʳ ˈˁˇˇʳ F5 ˆˈˁˈˈʳ ˆˇˁˆˈʳ ˆˆˁ˅˃ʳ ˆ˅ˁˋ˃ʳ ˆˆˁˉ˃ʳ ˆˈˁ˅ˈʳ ˆˇˁˊ˃ʳ ˆˆˁˋ˃ʳ ˆˆˁˆˈʳ ˆ˅ˁˌ˃ʳ ˆ˅ˁˌ˃ʳ ˆˆˁˊ˃ʳ ˆˆˁ˄ˈʳ ˅˅ˁ˄˃ʳ ˅˅ˁ˃ˈʳ ˅˅ˁ˄ˈʳ ˅˅ˁ˅˃ʳ ˅˅ˁˇˈʳ ˅˅ˁˈ˃ʳ ˅˅ˁ˅˃ʳ ˅˅ˁˆˈʳ ˅˅ˁ˅˃ʳ ˅˅ˁˈˈʳ ˅˅ˁˇ˃ʳ ˅˅ˁˋ˃ʳ ˅˅ˁ˅˃ʳ ˆˈˁˈˈʳ ˅˅ˁ˃ˈʳ ˅ˋˁ˃ˈʳ ˈˁˋˋʳ Page 11 of 12 F1 ˇ˃ˁ˄ˆʳ ˆˌˁ˄˄ʳ ˆˋˁˈˈʳ ˆˉˁˈˆʳ ˆˋˁˉˆʳ ˇ˃ˁ˃ˊʳ ˇ˃ˁ˃ˊʳ ˆˌˁˉ˅ʳ ˆˋˁˆˆʳ ˆˊˁˌ˅ʳ ˆˉˁˆ˄ʳ ˆˊˁˉ˄ʳ ˆˊˁ˄˅ʳ ˅ˋˁ˃ˊʳ ˅ˋˁˇˈʳ ˅ˊˁˊˌʳ ˅ˊˁˋˊʳ ˅ˊˁˌ˃ʳ ˅ˊˁˌˊʳ ˅ˋˁˊˈʳ ˅ˋˁ˅˄ʳ ˅ˋˁ˄˃ʳ ˅ˊˁˋˌʳ ˅ˊˁˈ˄ʳ ˅ˉˁˊˇʳ ˅ˉˁˆˉʳ ˇ˃ˁ˄ˆʳ ˅ˉˁˆˉʳ ˆˆˁ˄ˇʳ ˈˁˈ˅ʳ After Temperature life F2 F3 F4 ˇ˄ˁ˄ˊʳ ˇ˃ˁˇˉʳʳ ˆˋˁ˅˃ʳ ˆˌˁˆ˃ʳ ˆˋˁ˄ˉʳʳ ˆˉˁˊˈʳ ˇ˃ˁˊ˃ʳ ˆˋˁˋˌʳʳ ˆˌˁ˅ˊʳ ˇ˃ˁˋˇʳ ˆˈˁˋˊʳʳ ˆˋˁ˄ˋʳ ˆˌˁˇˊʳ ˆˋˁ˃ˇʳʳ ˆˊˁ˄ˊʳ ˆˌˁˋˆʳ ˆˉˁ˅ˈʳʳ ˆˉˁˋˉʳ ˆˌˁˉˋʳ ˆˊˁˋˌʳʳ ˆˊˁˋ˃ʳ ˇ˅ˁˇ˅ʳ ˆˋˁ˄ˊʳʳ ˆˊˁ˅ˈʳ ˆˌˁˉˊʳ ˆˋˁ˄˅ʳʳ ˆˊˁˌ˄ʳ ˆˌˁˋˈʳ ˆˋˁ˃ˆʳʳ ˆˊˁˉ˅ʳ ˆˌˁˋˆʳ ˆˋˁˈ˅ʳʳ ˆˊˁ˄ˇʳ ˇ˄ˁˌˈʳ ˆˋˁˉˆʳʳ ˆˊˁˌˆʳ ˆˊˁˉ˄ʳ ˆˌˁ˅ˌʳʳ ˆˋˁˉˇʳ ˅ˊˁ˄˃ʳ ˅ˊˁ˅˃ʳʳ ˅ˊˁˉˇʳ ˅ˊˁˈ˅ʳ ˅ˊˁˆˋʳʳ ˅ˋˁˆ˅ʳ ˅ˊˁˉˋʳ ˅ˊˁˆˉʳʳ ˅ˋˁˆˉʳ ˅ˊˁˇˊʳ ˅ˊˁˆˋʳʳ ˅ˋˁ˅˅ʳ ˅ˊˁˋ˄ʳ ˅ˊˁ˅ˆʳʳ ˅ˊˁ˃˄ʳ ˅ˊˁˌ˃ʳ ˅ˊˁˇ˃ʳʳ ˅ˊˁˋˆʳ ˅ˊˁˊˈʳ ˅ˊˁˈˊʳʳ ˅ˊˁˇˋʳ ˅ˊˁˉˊʳ ˅ˊˁˉˊʳʳ ˅ˊˁ˄ˉʳ ˅ˊˁˆˈʳ ˅ˊˁˉˋʳʳ ˅ˊˁˇ˃ʳ ˅ˊˁˇ˅ʳ ˅ˊˁˈ˅ʳʳ ˅ˊˁˈˌʳ ˅ˊˁˌ˅ʳ ˅ˊˁˆˌʳʳ ˅ˋˁˋ˄ʳ ˅ˉˁˋˆʳ ˅ˊˁˈˆʳʳ ˅ˋˁ˄ˉʳ ˅ˉˁˈˇʳ ˅ˋˁ˄ˉʳʳ ˅ˉˁˈˊʳ ˇ˅ˁˇ˅ʳ ˇ˃ˁˇˉʳʳ ˆˌˁ˅ˊʳ ˅ˉˁˈˇʳ ˅ˊˁ˅˃ʳʳ ˅ˉˁˈˊʳ ˆˆˁˋ˅ʳ ˆ˅ˁˋˇʳʳ ˆ˅ˁˊˇʳ ˉˁˈˈʳ ˈˁˈ˄ʳʳ ˈˁ˄ˈʳ F5 ˇ˃ˁˊˆʳ ˆˌˁˌˈʳ ˆˋˁˉˈʳ ˆˊˁˌ˃ʳ ˆˋˁˋ˄ʳ ˆˌˁ˄ˌʳ ˆˌˁ˄ˌʳ ˇ˄ˁˇˋʳ ˆˌˁˌˇʳ ˇ˃ˁˊˈʳ ˆˌˁˈˊʳ ˇ˃ˁˋˊʳ ˇ˃ˁ˄˄ʳ ˅ˊˁˉˈʳ ˅ˊˁˌˆʳ ˅ˊˁˋˈʳ ˅ˊˁˊ˄ʳ ˅ˊˁˊ˄ʳ ˅ˋˁ˃ˆʳ ˅ˋˁ˅ˊʳ ˅ˋˁˈˉʳ ˅ˋˁˊˆʳ ˅ˋˁˌˋʳ ˅ˌˁˉˇʳ ˅ˌˁˋ˃ʳ ˆ˃ˁ˄ˉʳ ˇ˄ˁˇˋʳ ˅ˊˁˉˈʳ ˆˇˁ˄ˉʳ ˈˁˋ˄ʳ PRODUCT RELIABILITY TEST REPORT Report No. GL-RD090107ʳ ʳ ʳ ʳ ʳ ʳ ʳ GL-P-027-005 Group G G-Salt Spray NO ˄ˀˆʳ ˈˀˊʳ ˌˀ˄˄ʳ ˄ˆˀ˄ˈʳ ˄ˊˀ˄ˌʳ ˅˄ˀ˅ˆʳ ˅ˈˀ˅ˊʳ ˅ˌˀˆ˄ʳ ˆˆˀˆˈʳ ˆˊˀˆˌʳ ˇ˄ˀˇˆʳ ˇˈˀˇˊʳ ˇˌˀˈ˄ʳ ˅ˀˇʳ ˉˀˋʳ ˄˃ˀ˄˅ʳ ˄ˇˀ˄ˉʳ ˄ˋˀ˅˃ʳ ˅˅ˀ˅ˇʳ ˅ˉˀ˅ˋʳ ˆ˃ˀˆ˅ʳ ˆˇˀˆˉʳ ˆˋˀˇ˃ʳ ˇ˅ˀˇˇʳ ˇˉˀˇˋʳ ˈ˃ˀˈ˅ʳ Max Min Avg Stdev G1 ˆˌˁ˄ˈʳʳ ˆˌˁ˃ˉʳʳ ˇ˃ˁˋˌʳʳ ˆˋˁˊˉʳʳ ˆˊˁˉ˃ʳʳ ˆˋˁˉˉʳʳ ˆˌˁ˄˅ʳʳ ˅ˉˁ˄˄ʳʳ ˇ˃ˁ˅ˊʳʳ ˆˌˁˌ˄ʳʳ ˆˌˁˆˈʳʳ ˆˌˁˋ˅ʳʳ ˆˋˁˈˆʳʳ ˅ˉˁˈˇʳʳ ˅ˊˁˇ˅ʳʳ ˅ˉˁˌ˅ʳʳ ˅ˊˁˆˌʳʳ ˅ˊˁˈ˄ʳʳ ˅ˊˁˈ˅ʳʳ ˅ˊˁˆˊʳʳ ˅ˊˁ˄ˊʳʳ ˅ˉˁˋˊʳʳ ˅ˊˁ˅˄ʳʳ ˅ˊˁˆˊʳʳ ˅ˊˁ˃ˋʳʳ ˅ˉˁˈ˅ʳʳ ˇ˃ˁˋˌʳʳ ˅ˉˁ˄˄ʳʳ ˆ˅ˁˉˌʳʳ ˉˁ˅˄ʳʳ G2 ˆˌˁ˅˃ʳʳ ˆˋˁˇˈʳʳ ˆˌˁˋˈʳʳ ˆˋˁ˄ˈʳʳ ˆˋˁˇ˃ʳʳ ˆˊˁˉˇʳʳ ˆˋˁˌˊʳʳ ˆˋˁˇˋʳʳ ˆˋˁˊˊʳʳ ˆˊˁˊˇʳʳ ˆˋˁˉˊʳʳ ˆˋˁˊˌʳʳ ˆˋˁˊˌʳʳ ˅ˊˁˇ˄ʳʳ ˅ˊˁ˅ˊʳʳ ˅ˋˁ˃˅ʳʳ ˅ˊˁˉ˄ʳʳ ˅ˊˁˌˊʳʳ ˅ˋˁˉ˄ʳʳ ˅ˋˁˋ˅ʳʳ ˅ˋˁˈˈʳʳ ˅ˋˁˌˌʳʳ ˅ˋˁˆˉʳʳ ˅ˋˁˇˋʳʳ ˅ˋˁˆˋʳʳ ˅ˊˁˋ˅ʳʳ ˆˌˁˋˈʳʳ ˅ˊˁ˅ˊʳʳ ˆˆˁˆˌʳʳ ˈˁˆˆʳʳ Initial G3 ˇ˅ˁˊˆʳʳ ˆˌˁˊ˄ʳʳ ˆˌˁˊˊʳʳ ˆˉˁˋˋʳʳ ˆˌˁˉ˅ʳʳ ˇ˄ˁ˃˄ʳʳ ˇ˄ˁˉˌʳʳ ˆˌˁ˃ˆʳʳ ˆˋˁˋ˃ʳʳ ˆˊˁˌ˃ʳʳ ˆˊˁˉ˄ʳʳ ˆˊˁˉˇʳʳ ˆˊˁˇˋʳʳ ˅ˊˁˈˇʳʳ ˅ˊˁ˄ˈʳʳ ˅ˊˁˋ˃ʳʳ ˅ˌˁˇˆʳʳ ˆ˄ˁ˄ˇʳʳ ˅ˋˁˌˊʳʳ ˅ˌˁˌˆʳʳ ˅ˋˁˇˇʳʳ ˅ˋˁ˃ˇʳʳ ˅ˊˁˉ˄ʳʳ ˅ˊˁˈˉʳʳ ˅ˋˁˇˈʳʳ ˅ˉˁˌ˅ʳʳ ˇ˅ˁˊˆʳʳ ˅ˉˁˌ˅ʳʳ ˆˆˁˋ˃ʳʳ ˈˁˋ˄ʳʳ G4 ˇˆˁ˄ˇʳ ˇˆˁ˄ˌʳ ˆˌˁˆˆʳ ˆˊˁˈ˅ʳ ˆˋˁ˃˄ʳ ˇˇˁˈ˃ʳ ˇ˄ˁˉˋʳ ˆˌˁ˃˄ʳ ˆˋˁ˄ˇʳ ˆˌˁˆˊʳ ˆˋˁˆˊʳ ˆˋˁˉ˃ʳ ˆˋˁ˃˄ʳ ˆ˄ˁˈˉʳ ˅ˋˁˇ˅ʳ ˅ˊˁˈˉʳ ˅ˋˁ˃ˊʳ ˅ˊˁˊˇʳ ˅ˊˁˆˊʳ ˅ˊˁˉˋʳ ˅ˊˁˋˋʳ ˅ˊˁˋˋʳ ˅ˋˁˌ˃ʳ ˅ˋˁˌˌʳ ˅ˋˁ˄ˊʳ ˅ˊˁ˄ˉʳ ˇˇˁˈ˃ʳ ˅ˊˁ˄ˉʳ ˆˇˁ˃ˋʳ ˉˁˆˆʳ G5 ˆˌˁ˄ˋʳ ˆˋˁˈˈʳ ˇ˃ˁ˃˄ʳ ˆˋˁˈˇʳ ˆˊˁˋˇʳ ˆˊˁ˅˄ʳ ˆˊˁˈˆʳ ˆˊˁˉ˄ʳ ˆˋˁ˃˃ʳ ˆˊˁˇˌʳ ˆˋˁˈˌʳ ˆˊˁˋˊʳ ˆˋˁ˃ˌʳ ˅ˉˁ˅ˈʳ ˅ˊˁˆˇʳ ˅ˉˁˌ˅ʳ ˅ˊˁˆ˅ʳ ˅ˉˁˇ˅ʳ ˅ˉˁˋˉʳ ˅ˉˁˊ˄ʳ ˅ˉˁ˅˅ʳ ˅ˉˁˇˈʳ ˅ˉˁˉˇʳ ˅ˉˁ˄˅ʳ ˅ˉˁˉˋʳ ˅ˉˁ˃ˆʳ ˇ˃ˁ˃˄ʳ ˅ˉˁ˃ˆʳ ˆ˅ˁˇ˃ʳ ˈˁˌ˄ʳ Page 12 of 12 G1 ˆˈˁ˃˃ʳ ˆˉˁˈ˃ʳ ˇˆˁˋ˃ʳ ˇˇˁˇˈʳ ˆˆˁˊˈʳ ˆˆˁˉˈʳ ˆˆˁˈ˃ʳ ˆˇˁˆˈʳ ˆˆˁˊˈʳ ˆˆˁˋˈʳ ˆˇˁˆ˃ʳ ˆˇˁˇˈʳ ˆˆˁˇ˃ʳ ˅˅ˁˌ˃ʳ ˅˅ˁˌ˃ʳ ˅ˆˁ˃˃ʳ ˅ˇˁˆ˃ʳ ˅ˆˁˆ˃ʳ ˅ˆˁ˅ˈʳ ˅˅ˁ˅˃ʳ ˅˅ˁˆ˃ʳ ˅˅ˁ˄˃ʳ ˅˅ˁˉ˃ʳ ˅˅ˁˆ˃ʳ ˅˅ˁˈ˃ʳ ˅˅ˁˈˈʳ ˇˇˁˇˈʳ ˅˅ˁ˄˃ʳ ˅ˌˁ˅ˊʳ ˊˁˇˇʳ After G2 ˆˊˁˆˈʳ ˆˈˁˉ˃ʳ ˇ˄ˁˉ˃ʳ ˆˊˁ˄˃ʳ ˆˇˁ˃˃ʳ ˆˆˁˈˈʳ ˆˇˁ˃ˈʳ ˆˇˁ˃ˈʳ ˆˇˁˇ˃ʳ ˆˇˁ˃ˈʳ ˆˈˁ˃˃ʳ ˆˇˁˆˈʳ ˆˇˁˇˈʳ ˅ˆˁˈ˃ʳ ˅ˆˁˆˈʳ ˅ˆˁˆˈʳ ˅ˆˁˇ˃ʳ ˅ˆˁˆˈʳ ˅˅ˁˉˈʳ ˅ˆˁ˄˃ʳ ˅ˆˁ˅˃ʳ ˅ˆˁˊˈʳ ˅ˆˁ˄˃ʳ ˅ˆˁˈ˃ʳ ˅ˆˁˇ˃ʳ ˅ˆˁˆˈʳ ˇ˄ˁˉ˃ʳ ˅˅ˁˉˈʳ ˅ˌˁˆˆʳ ˉˁˈˇʳ Salt Spray G3 G4 ˆˈˁˆˈʳʳ ˆˈˁ˅˃ʳʳ ˆˇˁ˃ˈʳʳ ˆˇˁˉˈʳʳ ˆˆˁˇˈʳʳ ˆˇˁ˃ˈʳʳ ˆ˅ˁˈˈʳʳ ˆˆˁ˅˃ʳʳ ˆˆˁˉ˃ʳʳ ˆˆˁ˅ˈʳʳ ˆˇˁˋ˃ʳʳ ˆˆˁˌˈʳʳ ˆˉˁˌˈʳʳ ˆˆˁˊ˃ʳʳ ˆˇˁ˅˃ʳʳ ˆˇˁ˃˃ʳʳ ˆˆˁˌˈʳʳ ˆˆˁ˃ˈʳʳ ˆˇˁ˄ˈʳʳ ˆˆˁˋ˃ʳʳ ˆˆˁˈˈʳʳ ˆ˅ˁˌˈʳʳ ˆˇˁˆ˃ʳʳ ˆˆˁˆˈʳʳ ˆˇˁ˄˃ʳʳ ˆˆˁ˃˃ʳʳ ˅˅ˁˉ˃ʳʳ ˅ˆˁˆˈʳʳ ˅˅ˁˈˈʳʳ ˅ˆˁ˃˃ʳʳ ˅ˆˁ˄ˈʳʳ ˅ˆˁˈˈʳʳ ˅˅ˁˊˈʳʳ ˅ˆˁˈ˃ʳʳ ˅ˆˁ˅˃ʳʳ ˅ˇˁ˃˃ʳʳ ˅ˆˁ˃ˈʳʳ ˅ˇˁˊ˃ʳʳ ˅ˆˁ˅ˈʳʳ ˅ˊˁˈ˃ʳʳ ˅ˆˁˆˈʳʳ ˆ˄ˁˉˈʳʳ ˅ˆˁˈ˃ʳʳ ˅ˊˁ˄ˈʳʳ ˅ˆˁˌ˃ʳʳ ˆ˃ˁ˅ˈʳʳ ˅ˆˁˈˈʳʳ ˅ˉˁ˅ˈʳʳ ˅ˇˁˆˈʳʳ ˆˇˁˋˈʳʳ ˅˅ˁˈ˃ʳʳ ˅ˋˁˊˈʳʳ ˆˉˁˌˈʳʳ ˆˈˁ˅˃ʳʳ ˅˅ˁˈ˃ʳʳ ˅ˆˁ˃˃ʳʳ ˅ˋˁˊ˅ʳʳ ˆ˃ˁ˅ˉʳʳ ˈˁˊ˄ʳʳ ˇˁˇˉʳʳ G5 ˆˇˁˇˈʳ ˆˆˁˋ˃ʳ ˆˈˁˇˈʳ ˆˇˁ˄˃ʳ ˆˆˁˌ˃ʳ ˆˆˁˈˈʳ ˆˈˁˉ˃ʳ ˆˆˁˌ˃ʳ ˆˇˁˈ˃ʳ ˆˆˁˉ˃ʳ ˆˇˁˋ˃ʳ ˆˇˁˊˈʳ ˆˇˁˈ˃ʳ ˅˅ˁˋ˃ʳ ˅ˆˁˈ˃ʳ ˅ˇˁ˄˃ʳ ˅ˇˁ˅ˈʳ ˅ˆˁ˄˃ʳ ˅ˆˁˉ˃ʳ ˅ˆˁˆ˃ʳ ˅ˆˁ˅˃ʳ ˅ˆˁˈˈʳ ˅ˆˁˈˈʳ ˅ˆˁˆ˃ʳ ˅ˆˁˌˈʳ ˅˅ˁˉˈʳ ˆˈˁˉ˃ʳ ˅˅ˁˉˈʳ ˅ˋˁˌ˄ʳ ˈˁˈˊʳ PDF created with pdfFactory trial version www.pdffactory.com UL iQ™ for Plastics Page 1 of 1 Need more information? Click Here to go to the UL iQ™ for Plastics database E91944 Component - Plastics JX NIPPON OIL & ENERGY CORP 3-1 YAKO 2-CHOME, KAWASAKI-KU, KAWASAKI-SHI KANAGAWA 210-8545 JP MG-350(r3), LCP MG-350(r3) Liquid Crystal Aromatic Polymer (LCAP), "Xydar", furnished as pellets Min Thk (mm) 0.17 0.30 0.50 0.75 0.89 1.5 3.0 Color BK NC, BK Flame Class V-0 V-0 V-0 V-0 V-0 V-0 V-0 HWI 4 4 3 1 1 HAI 4 4 1 1 0 Comparative Tracking Index (CTI): 3 RTI Elec 130 130 130 130 240 240 240 RTI Imp 130 130 130 130 220 240 240 RTI Str 130 130 130 130 240 240 240 Inclined Plane Tracking (IPT): Volume Resistivity (10x ohm-cm) : 12 Dielectric Strength (kV/mm): 45 High-Voltage Arc Tracking Rate (HVTR): 0 High Volt, Low Current Arc Resis (D495): 4 Dimensional Stability (%): 0 r3 - Virgin and Regrind from 26-50% by weight inclusive have the same Flame at 0.5mm and Tensile Impact characteristics at 3.0mm. ANSI/UL 94 small-scale test data does not pertain to building materials, furnishings and related contents. ANSI/UL 94 small-scale test data is intended solely for determining the flammability of plastic materials used in the components and parts of end-product devices and appliances, where the acceptability of the combination is determined by UL. Report Date: 1990-01-05 Last Revised: 2011-02-24 © 2012 UL LLC IEC and ISO Test Methods Thickness Test Name Flammability Test Method IEC 60695-11-10 Units Class (color) C C Volts (Max) Tested (mm) 0.17 0.30 0.50 0.75 0.89 1.5 3.0 - Value V-0 (BK) V-0 (NC, BK) V-0 (NC, BK) V-0 (NC, BK) V-0 (NC, BK) V-0 (NC, BK) V-0 (NC, BK) - Glow-Wire Flammability (GWFI) Glow-Wire Ignition (GWIT) IEC Comparative Tracking Index IEC 60695-2-12 IEC 60695-2-13 IEC 60112 IEC Ball Pressure ISO Heat Deflection (1.80 MPa) ISO Tensile Strength ISO Flexural Strength IEC 60695-10-2 ISO 75-2 ISO 527-2 ISO 178 C C MPa MPa - - ISO Tensile Impact ISO 8256 kJ/m2 - - ISO Izod Impact ISO 180 kJ/m2 - - ISO Charpy Impact ISO 179-2 kJ/m2 - - © 2012 UL LLC The materials covered in this database are incomplete in certain constructional features or restricted in performance capabilities and are intended for use as components of complete equipment submitted for investigation rather than for direct separate installation in the field. THE FINAL ACCEPTANCE OF THE COMPONENT IS DEPENDENT UPON ITS INSTALLATION AND USE IN COMPLETE PRODUCTS SUBMITTED TO UNDERWRITERS LABORATORIES. Notice of Disclaimer http://data.ul.com/link/plastics.aspx?PR=IBXXEANHRUVDGDGWUUPDESHUYV... 2012/11/27 測試報告 Test Report 號碼(No.) : CE/2014/24076 日期(Date) : 2014/03/05 JX NIPPON OIL & ENERGY CORPORATION 頁數(Page) : 1 of 15 *CE/2014/24076* SPECIALTY CHEMICALS & MATERIALS DIVISION ADVANCED MATERIALS DEPT. 3-1, YAKO 2-CHOME, KAWASAKI–KU, KAWASAKI CITY 210-8545 JAPAN 以下測試樣品係由申請廠商所提供及確認 (The following sample(s) was/were submitted and identified by/on behalf of the applicant as): 送樣廠商(Sample Submitted By) : JX NIPPON OIL & ENERGY CORPORATION SPECIALTY CHEMICALS & MATERIALS DIVISION 樣品名稱(Sample Description) ADVANCED MATERIALS DEPT. : LIQUID CRYSTAL POLYMER 樣品型號(Style/Item No.) : XYDAR MG-350BPRL 收件日期(Sample Receiving Date) : 2014/02/20 測試期間(Testing Period) : 2014/02/20 TO 2014/03/05 ==================================================================================================================== 測試結果(Test Results) : 請見下一頁 (Please refer to next pages). 結論(Conclusion) : 根據客戶所提供的樣品, 其鎘、鉛、汞、六價鉻、多溴聯苯及多溴聯苯醚的測試結果符合 RoHS指令2002/95/EC的更新指令2011/65/EU之要求 (Based on the performed tests on submitted samples, the test results of Cadmium, Lead, Mercury, Hexavalent Chromium Cr(VI), PBBs and PBDEs comply with the limits as set by RoHS Directive 2011/65/EU Annex II; recasting 2002/95/EC.) This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at http://www.sgs.com/en/Terms-and-Conditions.aspx and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at http://www.sgs.com/en/Terms-and-Conditions/Termse-Document.aspx. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 33, Wu Chuan Rd., New Taipei Industrial Park, New Taipei City, Taiwan / 新北市新北產業園區五權路33號 t+886 (02)2299 3279 f+886 (02)2299 3237 www.sgs.tw Member of the SGS Group 測試報告 Test Report 號碼(No.) : CE/2014/24076 日期(Date) : 2014/03/05 頁數(Page) : 2 of 15 JX NIPPON OIL & ENERGY CORPORATION *CE/2014/24076* SPECIALTY CHEMICALS & MATERIALS DIVISION ADVANCED MATERIALS DEPT. 3-1, YAKO 2-CHOME, KAWASAKI–KU, KAWASAKI CITY 210-8545 JAPAN 測試結果(Test Results) 測試部位(PART NAME)No.1 : 黑色塑膠粒 (BLACK PLASTIC PELLETS) 測試項目 (Test Items) 鎘 / Cadmium (Cd) 鉛 / Lead (Pb) 汞 / Mercury (Hg) 六價鉻 / Hexavalent Chromium Cr(VI) 銻 / Antimony (Sb) 三氧化二銻 / Antimony trioxide (Sb₂O₃)*** (CAS No.: 1309-64-4) 鈹 / Beryllium (Be) 聚氯乙烯 / PVC 五氯酚 / Pentachlorophenol (PCP) (CAS No.: 87-86-5) 方法偵測 結果 法規 限值 極限值 (Result) (Limit) (MDL) No.1 mg/kg 參考IEC 62321-5: 2013方法, 以感應耦合電漿 2 n.d. 100 原子發射光譜儀檢測. / With reference to mg/kg IEC 62321-5: 2013 and performed by ICP2 n.d. 1000 AES. 單位 (Unit) 測試方法 (Method) mg/kg 參考IEC 62321-4: 2013方法, 以感應耦合電漿 原子發射光譜儀檢測. / With reference to IEC 62321-4: 2013 and performed by ICPAES. mg/kg 參考IEC 62321: 2008方法, 以UV-VIS檢測. / With reference to IEC 62321: 2008 and performed by UV-VIS. mg/kg 參考US EPA 3052方法, 以感應耦合電漿原子發 射光譜儀檢測. / With reference to US EPA Method 3052. Analysis was performed by ICP-AES. mg/kg 參考US EPA 3052方法, 以感應耦合電漿原子發 射光譜儀檢測. / With reference to US EPA Method 3052. Analysis was performed by ICP-AES.*** mg/kg 參考US EPA 3052方法, 以感應耦合電漿原子發 射光譜儀檢測. / With reference to US EPA Method 3052. Analysis was performed by ICP-AES. ** 以紅外光譜分析及焰色法檢測. / Analysis was performed by FTIR and FLAME Test. mg/kg 參考US EPA 8041A方法, 以氣相層析/質譜儀檢 測. / With reference to US EPA 8041A method. Analysis was performed by GC/MS. 2 n.d. 1000 2 n.d. 1000 2 n.d. - - n.d. - 2 n.d. - - Negative - 1 n.d. - This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at http://www.sgs.com/en/Terms-and-Conditions.aspx and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at http://www.sgs.com/en/Terms-and-Conditions/Termse-Document.aspx. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 33, Wu Chuan Rd., New Taipei Industrial Park, New Taipei City, Taiwan / 新北市新北產業園區五權路33號 t+886 (02)2299 3279 f+886 (02)2299 3237 www.sgs.tw Member of the SGS Group 測試報告 Test Report 號碼(No.) : CE/2014/24076 日期(Date) : 2014/03/05 頁數(Page) : 3 of 15 JX NIPPON OIL & ENERGY CORPORATION *CE/2014/24076* SPECIALTY CHEMICALS & MATERIALS DIVISION ADVANCED MATERIALS DEPT. 3-1, YAKO 2-CHOME, KAWASAKI–KU, KAWASAKI CITY 210-8545 JAPAN 測試項目 (Test Items) 中鏈氯化石蠟 / Medium-Chained Chlorinated Paraffins (C14-C17) (MCCP) (CAS No.: 85535-85-9) 全氟辛烷磺酸 / Perfluorooctane sulfonates (PFOS-Acid, Metal Salt, Amide) 全氟辛酸 / PFOA (CAS No.: 335-671) 六溴環十二烷及所有主要被辨別出的 異構物 / Hexabromocyclododecane (HBCDD) and all major diastereoisomers identified (αHBCDD, β- HBCDD, γ- HBCDD) (CAS No.: 25637-99-4 and 3194-55-6 (134237-51-7, 134237-50-6, 134237-52-8)) 鄰苯二甲酸甲苯基丁酯 / BBP (Benzyl butyl phthalate) (CAS No.: 85-68-7) 鄰苯二甲酸二 (2-乙基己基)酯 / DEHP (Di- (2-ethylhexyl) phthalate) (CAS No.: 117-81-7) 鄰苯二甲酸二異癸酯 / DIDP (Diisodecyl phthalate) (CAS No.: 26761-40-0; 68515-49-1) 鄰苯二甲酸二異壬酯 / DINP (Diisononyl phthalate) (CAS No.: 28553-12-0; 68515-48-0) 結果 方法偵測 法規 限值 極限值 (Result) (Limit) (MDL) No.1 mg/kg 參考US EPA 3540C: 1996方法, 以氣相層析/質 50 n.d. 譜儀檢測. / With reference to US EPA 3540C: 1996 method. Analysis was performed by GC/MS. mg/kg 10 n.d. 參考US EPA 3550C: 2007方法, 以液相層析/質 譜儀檢測. / With reference to US EPA 3550C: 2007. Analysis was performed by mg/kg 10 n.d. LC/MS. 單位 (Unit) 測試方法 (Method) mg/kg 參考IEC 62321: 2008方法, 以氣相層析/質譜 儀檢測. / With reference to IEC 62321: 2008 method. Analysis was performed by GC/MS. % % % % 參考EN 14372, 以氣相層析/質譜儀檢測. With reference to EN 14372. Analysis performed by GC/MS. 參考EN 14372, 以氣相層析/質譜儀檢測. With reference to EN 14372. Analysis performed by GC/MS. 參考EN 14372, 以氣相層析/質譜儀檢測. With reference to EN 14372. Analysis performed by GC/MS. 參考EN 14372, 以氣相層析/質譜儀檢測. With reference to EN 14372. Analysis performed by GC/MS. 5 n.d. - / was 0.003 n.d. - / was 0.003 n.d. - / was 0.01 n.d. - / was 0.01 n.d. - This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at http://www.sgs.com/en/Terms-and-Conditions.aspx and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at http://www.sgs.com/en/Terms-and-Conditions/Termse-Document.aspx. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 33, Wu Chuan Rd., New Taipei Industrial Park, New Taipei City, Taiwan / 新北市新北產業園區五權路33號 t+886 (02)2299 3279 f+886 (02)2299 3237 www.sgs.tw Member of the SGS Group 測試報告 Test Report 號碼(No.) : CE/2014/24076 日期(Date) : 2014/03/05 頁數(Page) : 4 of 15 JX NIPPON OIL & ENERGY CORPORATION *CE/2014/24076* SPECIALTY CHEMICALS & MATERIALS DIVISION ADVANCED MATERIALS DEPT. 3-1, YAKO 2-CHOME, KAWASAKI–KU, KAWASAKI CITY 210-8545 JAPAN 測試項目 (Test Items) 單位 (Unit) 鄰苯二甲酸二正辛酯 / DNOP (Di-noctyl phthalate) (CAS No.: 11784-0) 鄰苯二甲酸二丁酯 / DBP (Dibutyl phthalate) (CAS No.: 84-74-2) % 鄰苯二甲酸二異丁酯 / DIBP (Diisobutyl phthalate) (CAS No.: 8469-5) % 多溴聯苯總和 / Sum of PBBs 一溴聯苯 / Monobromobiphenyl 二溴聯苯 / Dibromobiphenyl 三溴聯苯 / Tribromobiphenyl 四溴聯苯 / Tetrabromobiphenyl 五溴聯苯 / Pentabromobiphenyl 六溴聯苯 / Hexabromobiphenyl 七溴聯苯 / Heptabromobiphenyl 八溴聯苯 / Octabromobiphenyl 九溴聯苯 / Nonabromobiphenyl 十溴聯苯 / Decabromobiphenyl 多溴聯苯醚總和 / Sum of PBDEs 一溴聯苯醚 / Monobromodiphenyl ether 二溴聯苯醚 / Dibromodiphenyl ether 三溴聯苯醚 / Tribromodiphenyl ether 四溴聯苯醚 / Tetrabromodiphenyl ether 五溴聯苯醚 / Pentabromodiphenyl ether 六溴聯苯醚 / Hexabromodiphenyl ether 七溴聯苯醚 / Heptabromodiphenyl ether 八溴聯苯醚 / Octabromodiphenyl ether 九溴聯苯醚 / Nonabromodiphenyl ether 十溴聯苯醚 / Decabromodiphenyl ether % 測試方法 (Method) 參考EN 14372, 以氣相層析/質譜儀檢測. With reference to EN 14372. Analysis performed by GC/MS. 參考EN 14372, 以氣相層析/質譜儀檢測. With reference to EN 14372. Analysis performed by GC/MS. 參考EN 14372, 以氣相層析/質譜儀檢測. With reference to EN 14372. Analysis performed by GC/MS. / was 結果 方法偵測 法規 限值 極限值 (Result) (Limit) (MDL) No.1 0.003 n.d. - / was 0.003 n.d. - / was 0.003 n.d. - 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. 1000 1000 - mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg 參考IEC 62321: 2008方法, 以氣相層析/質譜 mg/kg 儀檢測. / With reference to IEC 62321: mg/kg 2008 and performed by GC/MS. mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at http://www.sgs.com/en/Terms-and-Conditions.aspx and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at http://www.sgs.com/en/Terms-and-Conditions/Termse-Document.aspx. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 33, Wu Chuan Rd., New Taipei Industrial Park, New Taipei City, Taiwan / 新北市新北產業園區五權路33號 t+886 (02)2299 3279 f+886 (02)2299 3237 www.sgs.tw Member of the SGS Group 測試報告 號碼(No.) : CE/2014/24076 Test Report 日期(Date) : 2014/03/05 頁數(Page) : 5 of 15 JX NIPPON OIL & ENERGY CORPORATION *CE/2014/24076* SPECIALTY CHEMICALS & MATERIALS DIVISION ADVANCED MATERIALS DEPT. 3-1, YAKO 2-CHOME, KAWASAKI–KU, KAWASAKI CITY 210-8545 JAPAN 測試項目 (Test Items) 單位 (Unit) 測試方法 (Method) 結果 方法偵測 法規 限值 極限值 (Result) (Limit) (MDL) No.1 鹵素 / Halogen 鹵素 (CAS 鹵素 (CAS 鹵素 (CAS 鹵素 (CAS (氟) No.: (氯) No.: (溴) No.: (碘) No.: / Halogen-Fluorine (F) 14762-94-8) / Halogen-Chlorine (Cl) 22537-15-1) / Halogen-Bromine (Br) 10097-32-2) / Halogen-Iodine (I) 14362-44-8) mg/kg 50 805 - mg/kg 50 n.d. - 50 n.d. - 50 n.d. - 參考BS EN 14582:2007, 以離子層析儀分析. / With reference to BS EN 14582:2007. mg/kg Analysis was performed by IC. mg/kg 備註(Note): 1. mg/kg = ppm;0.1wt% = 1000ppm 2. n.d. = Not Detected (未檢出) 3. MDL = Method Detection Limit (方法偵測極限值) 4. "-" = Not Regulated (無規格值) 5. **= Qualitative analysis (No Unit) 定性分析(無單位) 6. Negative = Undetectable 陰性(未偵測到); Positive = Detectable 陽性(已偵測到) 7. ***: 該物質是由銻之測試結果計算得知. 其MDL是針對銻之評估. (The substance was calculated by the test result of Antimony. The MDL was evaluated for Antimony.) AX = A × F AX A F 三氧化二銻 / Antimony trioxide (Sb₂O₃) 銻 / Antimony 1.1971 PFOS參考資訊(Reference Information) : 持久性有機污染物 POPs - (EU) 757/2010 PFOS濃度在物質或製備中不得超過0.001%(10ppm),在半成品、成品或零部件中不得超過0.1%(1000ppm),在紡織品或塗層 材料中不得超過1µg/㎡。 (Outlawing PFOS as substances or preparations in concentrations above 0.001% (10ppm), in semi-finished products or articles or parts at a level above 0.1%(1000ppm), in textiles or other coated materials above 1µg/㎡.) This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at http://www.sgs.com/en/Terms-and-Conditions.aspx and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at http://www.sgs.com/en/Terms-and-Conditions/Termse-Document.aspx. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 33, Wu Chuan Rd., New Taipei Industrial Park, New Taipei City, Taiwan / 新北市新北產業園區五權路33號 t+886 (02)2299 3279 f+886 (02)2299 3237 www.sgs.tw Member of the SGS Group 測試報告 Test Report 號碼(No.) : CE/2014/24076 日期(Date) : 2014/03/05 頁數(Page) : 6 of 15 JX NIPPON OIL & ENERGY CORPORATION *CE/2014/24076* SPECIALTY CHEMICALS & MATERIALS DIVISION ADVANCED MATERIALS DEPT. 3-1, YAKO 2-CHOME, KAWASAKI–KU, KAWASAKI CITY 210-8545 JAPAN 1) 2) 3) 根據以下的流程圖之條件,樣品已完全溶解。(六價鉻測試方法除外) / These samples were 6+ dissolved totally by pre-conditioning method according to below flow chart. (Cr test method excluded) 測試人員:楊登偉 / Name of the person who made measurement: Climbgreat Yang 測試負責人:張啟興 / Name of the person in charge of measurement: Troy Chang 剪裁、製備樣品 / Cutting、Preparation 測試樣品重量 / Sample Measurement 鉛 Pb、鎘 Cd 汞 Hg 依據不同樣品的材質而以適當的酸進行消化(如下表 所示) / Acid digestion by suitable acid depended on different sample material (as below table) 硝酸/鹽酸/氫氟酸的微波消化 / Microwave digestion with HNO 3/HCl/HF 過濾 / Filtration 殘渣 / Residue 溶液 / Solution 1) 2) 鹼熔融法 / Alkali Fusion 鹽酸溶解 / HCl to dissolve 六價鉻 Cr6+ (Note**) 添加適量消化液 / Add appropriate amount of digestion reagent 加熱至適當溫度進行消化萃 取 / Heat to appropriate temperature to extract 冷卻後過濾樣品 / Cool, filter digestate through filter 感應耦合電漿原子發射光譜儀 / ICP-AES 樣品材質 / Sample Material 鋼, 銅, 鋁, 焊錫 / Steel, copper, aluminum, solder 玻璃 / Glass 金, 鉑, 鈀, 陶瓷 / Gold, platinum, palladium, ceramic 銀 / Silver 塑膠 / Plastic 其他 / Others 消化酸液種類 / Digestion Acid 王水, 硝酸, 鹽酸, 氫氟酸, 雙氧水 / Aqua regia, HNO3, HCl, HF, H2O2 硝酸,氫氟酸 / HNO3/HF 王水 / Aqua regia 硝酸 / HNO3 硫酸, 雙氧水, 硝酸, 鹽酸 / H2SO4, H2O2, HNO3, HCl 加入適當的試劑至完全溶解 / Added appropriate reagent to total digestion 加入發色劑顯色 / Add diphenyl-carbazide for color development 以紫外光-可見光光譜儀,量 測樣品溶液在 540 nm 的吸 收度 / measure the absorbance at 540 nm by UV-VIS Note** (For IEC 62321) (1) 針對非金屬材料加入鹼性消化液,加熱至 90~95℃萃取. / For non-metallic material, add alkaline digestion reagent and heat to 90~95℃. (2) 針對金屬材料加入純水,加熱至沸騰萃取. / For metallic material, add pure water and heat to boiling. This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at http://www.sgs.com/en/Terms-and-Conditions.aspx and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at http://www.sgs.com/en/Terms-and-Conditions/Termse-Document.aspx. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 33, Wu Chuan Rd., New Taipei Industrial Park, New Taipei City, Taiwan / 新北市新北產業園區五權路33號 t+886 (02)2299 3279 f+886 (02)2299 3237 www.sgs.tw Member of the SGS Group 測試報告 Test Report 號碼(No.) : CE/2014/24076 日期(Date) : 2014/03/05 頁數(Page) : 7 of 15 JX NIPPON OIL & ENERGY CORPORATION *CE/2014/24076* SPECIALTY CHEMICALS & MATERIALS DIVISION ADVANCED MATERIALS DEPT. 3-1, YAKO 2-CHOME, KAWASAKI–KU, KAWASAKI CITY 210-8545 JAPAN 1) 根據以下的流程圖之條件,樣品已完全溶解。 / These samples were dissolved totally by pre-conditioning method according to below flow chart. 2) 測試人員:楊登偉 / Name of the person who made measurement: Climbgreat Yang 3) 測試負責人:張啟興 / Name of the person in charge of measurement: Troy Chang 元素以 ICP-AES 分析的消化流程圖 (Flow Chart of digestion for the elements analysis performed by ICP-AES) 剪裁、製備樣品 / Cutting、Preparation 測試樣品重量 / Sample Measurement 依據不同樣品的材質而以適當的酸進行消化(如下表所示) / Acid digestion by suitable acid depended on different sample material (as below table) 過濾 / Filtration 殘渣 / Residue 溶液 / Solution 1)鹼熔融法 / Alkali Fusion 2)鹽酸溶解 / HCl to dissolve 感應耦合電漿原子發射光譜儀 / ICP-AES 鋼,銅,鋁,焊錫 / Steel, copper, aluminum, solder 玻璃 / Glass 金,鉑,鈀,陶瓷 / Gold, platinum, palladium, ceramic 銀 / Silver 塑膠 / Plastic 其他 / Others 王水,硝酸,鹽酸,氫氟酸,雙氧水 / Aqua regia, HNO3, HCl, HF, H2O2 硝酸,氫氟酸 / HNO3/HF 王水 / Aqua regia 硝酸 / HNO3 硫酸,雙氧水,硝酸,鹽酸 / H2SO4, H2O2, HNO3, HCl 加入適當的試劑至完全溶解 / Added appropriate reagent to total digestion This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at http://www.sgs.com/en/Terms-and-Conditions.aspx and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at http://www.sgs.com/en/Terms-and-Conditions/Termse-Document.aspx. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 33, Wu Chuan Rd., New Taipei Industrial Park, New Taipei City, Taiwan / 新北市新北產業園區五權路33號 t+886 (02)2299 3279 f+886 (02)2299 3237 www.sgs.tw Member of the SGS Group 測試報告 Test Report 號碼(No.) : CE/2014/24076 日期(Date) : 2014/03/05 頁數(Page) : 8 of 15 JX NIPPON OIL & ENERGY CORPORATION *CE/2014/24076* SPECIALTY CHEMICALS & MATERIALS DIVISION ADVANCED MATERIALS DEPT. 3-1, YAKO 2-CHOME, KAWASAKI–KU, KAWASAKI CITY 210-8545 JAPAN 六溴環十二烷分析流程圖 / HBCDD analytical flow chart   測試人員:翁賜彬 / Name of the person who made measurement: Roman Wong 測試負責人:張啟興 / Name of the person in charge of measurement: Troy Chang 樣品前處理 / Sample pretreatment 樣品萃取 Sample extraction / 超音波萃取法 Ultrasonic method 萃取液濃縮/稀釋 / Concentrate/Dilute Extracted solution 萃取液過濾 / Filter 以氣相層析/質譜儀分析 / Analysis was performed by GC/MS 數據 / Data This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at http://www.sgs.com/en/Terms-and-Conditions.aspx and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at http://www.sgs.com/en/Terms-and-Conditions/Termse-Document.aspx. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 33, Wu Chuan Rd., New Taipei Industrial Park, New Taipei City, Taiwan / 新北市新北產業園區五權路33號 t+886 (02)2299 3279 f+886 (02)2299 3237 www.sgs.tw Member of the SGS Group 測試報告 Test Report 號碼(No.) : CE/2014/24076 日期(Date) : 2014/03/05 頁數(Page) : 9 of 15 JX NIPPON OIL & ENERGY CORPORATION *CE/2014/24076* SPECIALTY CHEMICALS & MATERIALS DIVISION ADVANCED MATERIALS DEPT. 3-1, YAKO 2-CHOME, KAWASAKI–KU, KAWASAKI CITY 210-8545 JAPAN 氯化石蠟分析流程圖 / Chlorinated Paraffins analytical flow chart   測試人員:曾勃鈞 / Name of the person who made measurement: Barry Tseng 測試負責人:張啟興 / Name of the person in charge of measurement: Troy Chang 樣品前處理 / Sample pretreatment 有機溶劑萃取 Sample extraction by organic solvent 萃取液濃縮/稀釋 Concentrate/Dilute the extracted solution 以氣相層析/質譜儀分析 Analysis was performed by GC/MS 數據 / Data This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at http://www.sgs.com/en/Terms-and-Conditions.aspx and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at http://www.sgs.com/en/Terms-and-Conditions/Termse-Document.aspx. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 33, Wu Chuan Rd., New Taipei Industrial Park, New Taipei City, Taiwan / 新北市新北產業園區五權路33號 t+886 (02)2299 3279 f+886 (02)2299 3237 www.sgs.tw Member of the SGS Group 測試報告 Test Report 號碼(No.) : CE/2014/24076 日期(Date) : 2014/03/05 頁數(Page) : 10 of 15 JX NIPPON OIL & ENERGY CORPORATION *CE/2014/24076* SPECIALTY CHEMICALS & MATERIALS DIVISION ADVANCED MATERIALS DEPT. 3-1, YAKO 2-CHOME, KAWASAKI–KU, KAWASAKI CITY 210-8545 JAPAN 聚氯乙烯物質判定分析流程圖 / Analysis flow chart for determination of PVC in material  測試人員:陳君涵 / Name of the person who made measurement: Ginny Chen  測試負責人:張啟興 / Name of the person in charge of measurement: Troy Chang 樣品前處理 / Sample pre-treatment 焰色法檢測 / Flame test 紅外光譜分析 / Sample analyzed by FTIR 確認C-Cl鍵波數 / Check wave-number of C-Cl bonding 數據 / Data This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at http://www.sgs.com/en/Terms-and-Conditions.aspx and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at http://www.sgs.com/en/Terms-and-Conditions/Termse-Document.aspx. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 33, Wu Chuan Rd., New Taipei Industrial Park, New Taipei City, Taiwan / 新北市新北產業園區五權路33號 t+886 (02)2299 3279 f+886 (02)2299 3237 www.sgs.tw Member of the SGS Group 測試報告 Test Report 號碼(No.) : CE/2014/24076 日期(Date) : 2014/03/05 頁數(Page) : 11 of 15 JX NIPPON OIL & ENERGY CORPORATION *CE/2014/24076* SPECIALTY CHEMICALS & MATERIALS DIVISION ADVANCED MATERIALS DEPT. 3-1, YAKO 2-CHOME, KAWASAKI–KU, KAWASAKI CITY 210-8545 JAPAN 全氟辛酸/全氟辛烷磺酸分析流程圖 / PFOA/PFOS analytical flow chart   測試人員:翁賜彬 / Name of the person who made measurement: Roman Wong 測試負責人:張啟興 / Name of the person in charge of measurement: Troy Chang 樣品前處理 / Sample pretreatment 超音波萃取法萃取 / Sample extraction by Ultrasonic extraction (參考方法 Reference method: US EPA 3550C) 萃取液稀釋/濃縮 / Concentrate/Dilute Extracted solution 以液相層析質譜儀分析萃取液 / Analysis was performed by LC/MS 數據 / Data This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at http://www.sgs.com/en/Terms-and-Conditions.aspx and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at http://www.sgs.com/en/Terms-and-Conditions/Termse-Document.aspx. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 33, Wu Chuan Rd., New Taipei Industrial Park, New Taipei City, Taiwan / 新北市新北產業園區五權路33號 t+886 (02)2299 3279 f+886 (02)2299 3237 www.sgs.tw Member of the SGS Group 測試報告 Test Report 號碼(No.) : CE/2014/24076 日期(Date) : 2014/03/05 頁數(Page) : 12 of 15 JX NIPPON OIL & ENERGY CORPORATION *CE/2014/24076* SPECIALTY CHEMICALS & MATERIALS DIVISION ADVANCED MATERIALS DEPT. 3-1, YAKO 2-CHOME, KAWASAKI–KU, KAWASAKI CITY 210-8545 JAPAN 可塑劑分析流程圖 / Analytical flow chart of phthalate content   測試人員:翁賜彬 / Name of the person who made measurement: Roman Wong 測試負責人:張啟興 / Name of the person in charge of measurement: Troy Chang 樣品前處理/分樣 / Sample pretreatment/separation 樣品萃取採用索式萃取法 / Sample extraction by soxhlet method 萃取液濃縮/稀釋 / Concentrate/Dilute Extracted solution 氣相層析質譜儀分析 / Analysis was performed by GC/MS 數據 / Data This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at http://www.sgs.com/en/Terms-and-Conditions.aspx and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at http://www.sgs.com/en/Terms-and-Conditions/Termse-Document.aspx. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 33, Wu Chuan Rd., New Taipei Industrial Park, New Taipei City, Taiwan / 新北市新北產業園區五權路33號 t+886 (02)2299 3279 f+886 (02)2299 3237 www.sgs.tw Member of the SGS Group 測試報告 Test Report 號碼(No.) : CE/2014/24076 日期(Date) : 2014/03/05 頁數(Page) : 13 of 15 JX NIPPON OIL & ENERGY CORPORATION *CE/2014/24076* SPECIALTY CHEMICALS & MATERIALS DIVISION ADVANCED MATERIALS DEPT. 3-1, YAKO 2-CHOME, KAWASAKI–KU, KAWASAKI CITY 210-8545 JAPAN 多溴聯苯/多溴聯苯醚分析流程圖 / PBB/PBDE analytical FLOW CHART   測試人員:翁賜彬 / Name of the person who made measurement: Roman Wong 測試負責人:張啟興 / Name of the person in charge of measurement: Troy Chang 初次測試程序 / First testing process 選擇性篩檢程序 / Optional screen process 確認程序 / Confirmation process Sample / 樣品 Sample pretreatment / 樣品前處理 Screen analysis / 初篩分析 Sample extraction 樣品萃取/ Soxhlet method 索式萃取法 Concentrate/Dilute Extracted solution 萃取液濃縮/稀釋 Filter / 萃取液過濾 Analysis by GC/MS / 氣相層析質譜儀分析 Issue Report 撰打報告 This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at http://www.sgs.com/en/Terms-and-Conditions.aspx and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at http://www.sgs.com/en/Terms-and-Conditions/Termse-Document.aspx. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 33, Wu Chuan Rd., New Taipei Industrial Park, New Taipei City, Taiwan / 新北市新北產業園區五權路33號 t+886 (02)2299 3279 f+886 (02)2299 3237 www.sgs.tw Member of the SGS Group 測試報告 Test Report 號碼(No.) : CE/2014/24076 日期(Date) : 2014/03/05 頁數(Page) : 14 of 15 JX NIPPON OIL & ENERGY CORPORATION *CE/2014/24076* SPECIALTY CHEMICALS & MATERIALS DIVISION ADVANCED MATERIALS DEPT. 3-1, YAKO 2-CHOME, KAWASAKI–KU, KAWASAKI CITY 210-8545 JAPAN 鹵素分析流程圖 / Analytical flow chart of halogen content  測試人員:陳恩臻 / Name of the person who made measurement: Rita Chen  測試負責人:張啟興 / Name of the person in charge of measurement: Troy Chang 樣品前處理/分樣 / Sample pretreatment/separation 秤重及將樣品放入樣品槽中 / Weighting and putting sample in cell 燃燒彈/吸收 Oxygen Bomb Combustion / Absorption 稀釋至固定體積 / Dilution to fixed volume 離子層析儀分析 / Analysis was performed by IC This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at http://www.sgs.com/en/Terms-and-Conditions.aspx and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at http://www.sgs.com/en/Terms-and-Conditions/Termse-Document.aspx. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 33, Wu Chuan Rd., New Taipei Industrial Park, New Taipei City, Taiwan / 新北市新北產業園區五權路33號 t+886 (02)2299 3279 f+886 (02)2299 3237 www.sgs.tw Member of the SGS Group 測試報告 Test Report 號碼(No.) : CE/2014/24076 日期(Date) : 2014/03/05 JX NIPPON OIL & ENERGY CORPORATION 頁數(Page) : 15 of 15 *CE/2014/24076* SPECIALTY CHEMICALS & MATERIALS DIVISION ADVANCED MATERIALS DEPT. 3-1, YAKO 2-CHOME, KAWASAKI–KU, KAWASAKI CITY 210-8545 JAPAN * 照片中如有箭頭標示,則表示為實際檢測之樣品/部位. * (The tested sample / part is marked by an arrow if it's shown on the photo.) ** 報告結尾 (End of Report) ** This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at http://www.sgs.com/en/Terms-and-Conditions.aspx and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at http://www.sgs.com/en/Terms-and-Conditions/Termse-Document.aspx. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 33, Wu Chuan Rd., New Taipei Industrial Park, New Taipei City, Taiwan / 新北市新北產業園區五權路33號 t+886 (02)2299 3279 f+886 (02)2299 3237 www.sgs.tw Member of the SGS Group Test Report Page 1 of 4 Report No. RHS05G011858001 Applicant Address KUNSHAN TIANSHEN COPPER HARDWARE ELECTRICAL AND MECHANICAL CO., LTD. NO. 328-3 DONGCHANG ROAD BACHENG TOWN KUNSHAN CITY The following sample(s) and sample information was/were submitted and identified by/on the behalf of the client Sample Name Brass C2680 Part No. Cu、Zn Material Sample Received Date Apr. 11, 2014 Testing Period Apr. 11, 2014 to Apr. 15, 2014 Test Requested As specified by client, to test Lead(Pb), Cadmium(Cd), Mercury(Hg), Hexavalent Chromium (Cr(VI)) in the submitted sample(s). Test Method Test Item(s) Test Method Measured Equipment(s) Lead(Pb) IEC 62321-5:2013 Ed.1.0 ICP-OES Cadmium(Cd) IEC 62321-5:2013 Ed.1.0 ICP-OES Mercury(Hg) IEC 62321-4:2013 Ed.1.0 ICP-OES Hexavalent Chromium (Cr(VI)) IEC 62321:2008 Ed.1 Annex B UV-Vis Test Result(s) Please refer to the following page(s). Apr. 15, 2014 No. 1087211671 Test Report Page 2 of 4 Report No. RHS05G011858001 Test Result(s) Tested Item(s) Lead(Pb) Cadmium (Cd) Mercury(Hg) Hexavalent Chromium (Cr(VI)) Tested Sample/Part Description Note: Result 9 mg/kg N.D. N.D. Negative MDL 2 mg/kg 2 mg/kg 2 mg/kg / Golden metal The sample(s) had been dissolved totally tested for Lead, Cadmium, Mercury. -MDL = Method Detection Limit -N.D. = Not Detected (
