AVB1.0/2/9
AVB1.0/2/9
    BLOCK
    BLOCK - AVB1.0/2/9 - PCB Transformer, Class II, Encapsulated Safety Isolating, 2 x 115V, 2 x 9V, 1 V...
AVB1.0/2/9 数据手册
Safety isolating transformer AVB 1,0/2/9 Advantages Minimum size at high output Unconditionally short-circuit proof Double input voltage for series or parallel connection Also with double output voltage for series or parallel connection Designed for high ambient temperatures Permanent corrosion protection, high insulation value and maximum electrical reliability thanks to XtraDenseFill resin encapsulation Coil shell in 2-chamber technology Self-extinguishing potting and hood material Applications As a mains transformer for adjustment of the voltage and simple electrical isolation. As a safety transformer for the safe electrical isolation of the input and output sides. The transformer is suitable for creating SELV and PELV circuits because of the limit on the output voltage. Sample application Picture shows AVB 3,2/2/18 Standards 1 Z Safety isolating transformer to: VDE 0570 Part 2-6, DIN EN 61558-2-6, EN 61558-2-6, IEC 61558-2-6, UL 5085-1/-2, CSA 22.2 No.66 Approvals W Z UL 5085-1/-2, CSA 22.2 No.66 Safety isolating transformer AVB 1,0/2/9 AVB 1,0/2/9 Rated input voltage Rated frequency 2 x 115 Vac 50 - 60 Hz Output Rated output voltage Rated Power No-load voltage (app. x factor) No-load loss (typ.) Efficiency Type AVB 1,0/2/9 Terminal and mounting Pins for printed circuit boards 0.8 Terminals Pin (ø) Measures and weights 2 x 9 Vac 1.00 VA 1.32 0.90 W 55 % EI 30/10,5 0.07 kg Core type Weight 20.0 Standards Classification Approvals Approvals nc 20.0 10.0 PRI SEC 5.0 70 °C 27.3 Safety and protection Type Class of Insulation System Protection index Safety class (prepared) Short circuit strength 5.0 cURus Environment Ambient temperature max. 21.8 32.3 Safety isolating transformer Encapsulated VDE=B, UL=class 105 IP 00 II inherently short-circuit proof Order numbers Order Number AVB 1,0/2/9 Subjects to change. + Input 30 Type
AVB1.0/2/9 价格&库存
很抱歉,暂时无法提供与“AVB1.0/2/9”相匹配的价格&库存,您可以联系我们找货
