AVB1.5/2/18
AVB1.5/2/18
    BLOCK
AVB1.5/2/18 数据手册
Mains transformer AVB 1,5/2/18 Advantages Minimum size at high output Inherently short-circuit proof Dual input voltage for series or parallel connection Also with dual output voltage for series or parallel connection Designed for high ambient temperatures Permanent corrosion protection, high insulation value and maximum electrical reliability thanks to XtraDenseFill resin encapsulation Self-extinguishing potting and hood material Applications As a mains transformer for adjustment of the voltage and simple electrical isolation. As a safety transformer for the safe electrical isolation of the input and output sides. The transformer is suitable for creating SELV and PELV circuits because of the limit on the output voltage. Sample application Picture shows AVB 3,2/2/18 Standards Z Mains transformer to: VDE 0570 Teil 2-1, DIN EN 61558-2-1, EN 61558-2-1, IEC 61558-2-1, UL 5085-1/-2, CSA 22.2 No.66 Approvals W & Z UL 5085-1/-2, CSA 22.2 No.66 Mains transformer AVB 1,5/2/18 AVB 1,5/2/18 Rated input voltage Rated frequency 2 x 115 Vac 50 - 60 Hz Output Rated output voltage Rated Power No-load voltage (app. x factor) No-load loss (typ.) Efficiency Type AVB 1,5/2/18 Terminal and mounting Pins for printed circuit boards 0.8 Terminals Pin (ø) Measures and weights 2 x 18 Vac 1.5 VA 1.39 1.00 W 57.0 % EI 30/12,5 0.08 kg Core type Weight 20.0 Standards Classification Approvals Approvals nc 20.0 10.0 PRI 5.0 5.0 70 °C 27.3 Safety and protection Type Insulation class Protection index Safety class (prepared) Short circuit strength SEC cURus Environment Ambient temperature max. 23.8 32.3 Mains transformer Encapsulated VDE=B, UL=class 105 IP 00 II inherently short-circuit proof Order numbers Order Number AVB 1,5/2/18 Subject to change. + Input 30 Type
AVB1.5/2/18
物料型号:AVB 1,5/2/18
器件简介: - 该变压器是一种电源变压器,设计用于高输出时最小尺寸。 - 具有固有的短路保护特性。 - 支持双输入电压,可进行串联或并联连接。 - 也支持双输出电压,可进行串联或并联连接。 - 适用于高环境温度。 - 由于XtraDenseFill树脂封装,具有永久性防腐保护、高绝缘值和最大电气可靠性。 - 自灭性灌封和罩材料。
引脚分配: - 引脚用于印刷电路板,引脚直径为0.8毫米。
参数特性: - 输入额定电压:2 x 115Vac - 额定频率:50 - 60 Hz - 输出额定电压:2 x 18Vac - 额定功率:1.5 VA - 空载电压(大约x因子):1.39 - 空载损耗(典型值):1.00 W - 效率:57.0%
功能详解: - 作为电源变压器,用于调整电压和简单的电气隔离。 - 作为安全变压器,用于输入和输出侧的安全电气隔离。由于输出电压的限制,该变压器适用于创建SELV和PELV电路。
应用信息: - 作为电源变压器,用于电压调整和简单的电气隔离。 - 作为安全变压器,用于安全电气隔离输入和输出侧。
封装信息: - 类型:封装 - 绝缘等级:VDE=B, UL=class 105 - 保护等级:IP 00 - 安全等级(准备):固有短路保护
订单信息: - 订单号:AVB 1,5/2/18 - EI 30/12,5,重量:0.08 kg
AVB1.5/2/18 价格&库存
很抱歉,暂时无法提供与“AVB1.5/2/18”相匹配的价格&库存,您可以联系我们找货
