FL14/6
FL14/6
    BLOCK
    BLOCK - FL14/6 - Isolation Transformer, UI 39 x 10.2, 14 VA, 2 x 6V, 1.16 A, 2 x 115V, FL Series
FL14/6 数据手册
Safety isolating transformer FL 14/6 Advantages Minimum size at high output Low height Dual input voltage for series or parallel connection Dual output voltage for series or parallel connection Permanent corrosion protection, high insulation value and maximum electrical reliability thanks to XtraDenseFill resin encapsulation Self-extinguishing potting material Applications As a mains transformer for adjustment of the voltage and simple electrical isolation. As an isolating transformer for the safe electrical isolation of the input and output sides. The transformer may be used to set up protective separation as a protective measure in accordance with VDE 0100. As a safety isolating transformer for the safe electrical isolation of the input and output sides. The transformer is suitable for creating SELV and PELV circuits because of the limit on the output voltage. Sample application Picture shows FL 42/12 Standards Z Approvals W 2 w Z VDE, UL 5085-1/-2, CSA 22.2 No.66 Safety isolating transformer FL 14/6 FL 14/6 Rated input voltage Rated frequency 2 x 115 Vac 50 - 60 Hz Output Rated output voltage Rated Power No-load voltage (app. x factor) No-load loss (typ.) Efficiency 2 x 6 Vac 14 VA 1.28 1.20 W 74.0 % Standards Classification Safety isolating transformer Type FL 14/6 Terminal and mounting Pins for PCB Terminals Measures and weights UI 39/10,2 0.32 kg Core type Weight 5.5 16.0 15.0 2.5 0.8 PRI SEC Approvals Approvals cURus, VDE Environment Ambient temperature max. 40 °C 11.5 26.0 10.0 50.0 57.0 0.0 0.0 24.4 45.0 62.5 68.0 Safety and protection Type Insulation class Protection index Safety class (prepared) Short circuit strength Encapsulated VDE=E, UL=class 105 IP 00 II non-short-circuit proof Order numbers Order Number FL 14/6 Subject to change. + Input 30 Type
FL14/6 价格&库存
很抱歉,暂时无法提供与“FL14/6”相匹配的价格&库存,您可以联系我们找货
