Safety isolating transformer
AVB 0,35/2/12
Advantages
Minimum size at high output
Unconditionally short-circuit proof
Double input voltage for series or parallel connection
Also with double output voltage for series or parallel connection
Designed for high ambient temperatures
Permanent corrosion protection, high insulation value and maximum
electrical reliability thanks to XtraDenseFill resin encapsulation
Coil shell in 2-chamber technology
Self-extinguishing potting and hood material
Applications
As a mains transformer for adjustment of the voltage and simple electrical
isolation.
As a safety transformer for the safe electrical isolation of the input and output
sides. The transformer is suitable for creating SELV and PELV circuits because
of the limit on the output voltage.
Sample application
Picture shows AVB 3,2/2/18
Standards
1 Z
to: VDE 0570 Part 2-6, DIN EN 61558-2-6, EN 61558-2-6, IEC 61558-2-6,
UL 5085-1/-2, CSA 22.2 No.66
Approvals
W Z
AVB 0,35/2/12
AVB 0,35/2/12
Rated input voltage
Rated frequency
2 x 115 Vac
50 - 60 Hz
Output
Rated output voltage
Rated Power
No-load voltage (app. x factor)
No-load loss (typ.)
Efficiency
Type
AVB 0,35/2/12
Terminal and mounting
Pins for printed circuit boards
0.6
Terminals
Pin (ø)
Measures and weights
2 x 12 Vac
0.35 VA
1.80
1.30 W
30 %
EE 20/6,1
0.02 kg
Core type
Weight
15.0
Standards
Classification
15.0
Approvals
Approvals
22.0
PRI
SEC
0.0
cURus
Environment
Ambient temperature max.
15.0
5.0
70 °C
5.0
22.7
Safety and protection
Type
Class of Insulation System
Protection index
Safety class (prepared)
Short circuit strength
Encapsulated
VDE=B, UL=class 105
IP 00
II
inherently short-circuit proof
Order numbers
Order Number
AVB 0,35/2/12
Subjects to change.
Input
30
Type
很抱歉,暂时无法提供与“AVB0.35/2/12”相匹配的价格&库存,您可以联系我们找货
