EB-GND4
EB-GND4
    BLOCK
    BLOCK - EB-GND4 - GROUND DISTRIBUTION MOD, CKT BREAKER MOD
EB-GND4 数据手册
Ground module EB-GND4 Advantages 0 V collective terminal with 4 or 8 inputs EB-GND4: Output to feed back up to 40 A to the power supply provided Total current up to 40 A per module Applications Ground module to feed back the 0 V signal to the power supply as a replacement for the series terminal. Approvals J N o Z UL 508, UL 2367, DNV GL, VW eCl@ss No.27-37-18-02 (prepared) Ground module EB-GND4 EB-GND4 Input rated voltage Input voltage range Max. total input current Input rated current 12/24/48 Vdc 10 A 4 x 10 A Output Output rated voltage Maximum voltage drop between input and output Output current Resistance to reverse feed max. EB-GND4 Terminal and mounting Measures and weights 0.040 kg 61.2 53.7 99.3 IP 20 2 51.7 Accessory Cross connection 14.8 -25 °C … +70 °C -40 °C … +85 °C Natural convection 30 mm Safety and protection Protection index Degree of pollution "OUT -" 1.5 – 16 mm² "-1" ... "-4" 4 x 0.08 – 2.5 mm² horizontal for standard rail DIN TS35 0 V Output terminal 0 V Input terminal Mounting position Weight 24 Vdc 8 mV max. 40 A 35 Vdc Environment Ambient temperature Storage temperature Type of cooling Required minimum spacing (over/under) Type EB-BAR for bridging modules in series Order numbers Order Number EB-GND4 64.5 12.0 Subject to change. + Input 30 Type
EB-GND4 价格&库存
很抱歉,暂时无法提供与“EB-GND4”相匹配的价格&库存,您可以联系我们找货
