DCT12-1
DCT12-1
    BLOCK
    BLOCK - DCT12-1 - Linear Power Supply, Non-Stabilised, ITE, 1 Outputs, 12 W, 12 VDC, 1 A
DCT12-1 数据手册
Single-phase, non-stabilized DC power supply DCT 12-1 Advantages Thermal fuse in the input and a fuse protection for the output Separate windings Capacitor switching at the output Permanent corrosion protection, high insulation value and maximum electrical reliability thanks to XtraDenseFill resin encapsulation Robust plastic housing for rail mounting, e.g. in consumer units or meter mounting boards Applications Robust DC power supply is concentrated on the core task of voltage and power supply. Flat step profile optimized for installation in control panels in building automation. Sample application Picture shows DCT 24-2,5 Standards Z Non-stabilised dc power supply / Safety isolating transformer to VDE 0570 part 2-6, EN 61558-2-6, IEC 61558-2-6 Approvals 1 Z Single-phase, non-stabilized DC power supply DCT 12-1 DCT 12-1 Input rated voltage Rated frequency 230 Vac 50 - 60 Hz Output Output rated voltage Power Output rated current Ripple factor Type DCT 12-1 Terminal and mounting Fixing method Terminals DIN Rail system TS35 Screw-type terminals Measures and weights 12 Vdc 12.00 W 1.00 A Ð5 % 0.51 kg Weight Environment Type of cooling Ambient temperature max. self-cooling +25 °C Safety and protection Insulation class Protection index Safety class (prepared) Type Short circuit strength B IP 00 II Resin encapsulated transformer short-circuit proof 94.0 Order numbers Order Number DCT 12-1 63.0 71.0 Subject to change. + Input 30 Type
DCT12-1 价格&库存
很抱歉,暂时无法提供与“DCT12-1”相匹配的价格&库存,您可以联系我们找货
