GNC24-5
GNC24-5
    BLOCK
    BLOCK - GNC24-5 - Linear Power Supply, Open Frame, ITE, 1 Outputs, 120 W, 24 VDC, 5 A
GNC24-5 数据手册
Single-phase, non stabilized DC power supply GNC 24-5 Advantages Unsusceptible to voltage surges or transients High overload capacity DC OK signalling via LEDs Capacitor switching at the output Very good corrosion protection and low noise thanks to vacuum impregnation Impulse loading MKT-capacitors Varistor wiring Contact protected screw connection terminals complying with UVV BGV A3 GNC 24-2,5 with combination footplate for bolted and rail mounting Applications Robust DC power supply for harsh industrial applications. Sample application Picture shows GNC 24-10 Standards Z Non-stabilised dc power supply / Safety isolating transformer to VDE 0570 part 2-6, EN 61558-2-6, IEC 61558-2-6, UL 1012 Approvals 2 T Z UL 5085-1/-2, CSA 22.2 No.66 Single-phase, non stabilized DC power supply GNC 24-5 GNC 24-5 Input rated voltage Rated frequency 230/400 Vac, ±15 Vac 50 - 60 Hz Output Output rated voltage Power Output rated current Ripple factor 24 Vdc 120.00 W 5.00 A 3% Approvals Approvals cURus (transformer only) Type GNC 24-5 Terminal and mounting Screw-type terminals Base plate M5 Terminals Fixing method Fixing screws Measures and weights 4.60 kg Weight 57.0 52.0 105.0 Environment Ambient temperature max. Type of cooling 60 °C self-cooling Safety and protection Type Insulation class Protection index Safety class (prepared) Short circuit strength Open type VDE=B, UL=class 130 IP 00 I non-short-circuit proof 160.0 Order numbers Order Number GNC 24-5 80.5 105.0 103.0 86.0 Subject to change. + Input 30 Type
GNC24-5 价格&库存
很抱歉,暂时无法提供与“GNC24-5”相匹配的价格&库存,您可以联系我们找货
