FL42/9
FL42/9
    BLOCK
    BLOCK - FL42/9 - PCB Transformer, UI 48 x 17, Encapsulated Safety Isolating, 2 x 115V, 2 x 9V, 42 VA...
FL42/9 数据手册
Safety isolating transformer FL 42/9 Advantages Minimum size at high output Low height Dual input voltage for series or parallel connection Dual output voltage for series or parallel connection Permanent corrosion protection, high insulation value and maximum electrical reliability thanks to XtraDenseFill resin encapsulation Self-extinguishing potting material Applications As a mains transformer for adjustment of the voltage and simple electrical isolation. As an isolating transformer for the safe electrical isolation of the input and output sides. The transformer may be used to set up protective separation as a protective measure in accordance with VDE 0100. As a safety isolating transformer for the safe electrical isolation of the input and output sides. The transformer is suitable for creating SELV and PELV circuits because of the limit on the output voltage. Sample application Picture shows FL 42/12 Standards Z Safety isolating transformer to: VDE 0570 Part 2-6, DIN EN 61558-2-6, EN 61558-2-6, IEC 61558-2-6, UL 5085-1/-2, CSA 22.2 No.66 Approvals W 2 w Z VDE, UL 5085-1/-2, CSA 22.2 No.66 Safety isolating transformer FL 42/9 FL 42/9 Rated input voltage Rated frequency 2 x 115 Vac 50 - 60 Hz Output Rated output voltage Rated Power No-load voltage (app. x factor) No-load loss (typ.) Efficiency 2 x 9 Vac 42 VA 1.16 3.50 W 81.0 % Standards Classification Safety isolating transformer Type FL 42/9 Terminal and mounting Pins for PCB Terminals Measures and weights UI 48/17 0.72 kg Core type Weight 0.5 x 1.0 27.0 15.0 PRI SEC Approvals Approvals cURus, VDE Environment Ambient temperature max. 40 °C 15.0 6.5 37.0 10.0 60.0 70.0 0.0 3.1 39.0 53.5 75.0 83.5 Safety and protection Type Insulation class Protection index Safety class (prepared) Short circuit strength Encapsulated VDE=E, UL=class 105 IP 00 II non-short-circuit proof Order numbers Order Number FL 42/9 Subject to change. + Input 30 Type
FL42/9
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光隔离型光电开关,具有高灵敏度和高抗干扰能力。
3. 引脚分配:EL817共有6个引脚,分别为Vcc、Out、GND、A、B、C。
4. 参数特性:工作电压为5V,响应频率为100kHz,隔离电压为2.5kV。
5. 功能详解:EL817通过光电转换实现信号的隔离传输,适用于工业自动化控制等领域。
6. 应用信息:EL817可用于传感器信号采集、数据通信、医疗设备等。
7. 封装信息:EL817采用DIP6封装。
FL42/9 价格&库存
很抱歉,暂时无法提供与“FL42/9”相匹配的价格&库存,您可以联系我们找货
