AW33801CSR
AW33801CSR
    AWINIC(艾为)
    WLCSP9_1.245X1.245MM
    停产 过压保护负载开关
AW33801CSR 数据手册
AW33801/AW33802 AW33805/AW33809/AW33812 Sep. 2018 V1.3 Over-Voltage Protection Load Switch GENERAL DESCRIPTION    The AW338XX features an ultra-low 29m (typ.) Rdson nFET load switch. When input voltage exceeds the OVP threshold, the switch is turned off very fast to prevent damage to the protected downstream devices. The IN pin is capable of withstanding fault voltages up to 35VDC.   ti a n e n o Smartphones Tablets Charging Ports C  This device features over-temperature protection that prevents itself from thermal damaging. The AW338XX is available in a RoHS compliant 9bump 1.245mm × 1.245mm WLCSP. APPLICATIONS   The default OVP threshold is 5.95V (AW33801), 6.2V (AW33802), 6.8V (AW33805), 9.98V (AW33809) and 14V (AW33812). The OVP threshold can be adjusted from 4V to 20V through external OVLO pin. fi d     Integrated low Rdson nFET switch: typical 29m 4.5A continuous current capability Default Over-Voltage Protection (OVP) threshold  AW33801: 5.95V  AW33802: 6.2V  AW33805: 6.8V  AW33809: 9.98V  AW33812: 14V OVP threshold adjustable range: 4V to 20V Input maximum voltage rating: 35VDC Fast turn-off response: typical 90ns Over-Temperature Protection (OTP) Under-Voltage Lockout (UVLO) 1.245mm × 1.245mm WLCSP-9 package l FEATURES USB Port ic TYPICAL APPLICATION CIRCUIT CIN 0.1µF 50V a w in TVS R1 R2 Charger OUT IN AW33801 AW33802 AW33805 OVLO AW33809 AW33812 COUT 1µF 35V Battery PMIC GND Figure 1 AW338XX typical application circuit All the trademarks mentioned in the document are the property of their owners. www.awinic.com.cn 1 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW33801/AW33802 AW33805/AW33809/AW33812 Sep. 2018 V1.3 DEVICE COMPARISON TABLE VIN_OVLO(V) Min. Typ. Max. VIN_OVLO Hysteresis(mV) AW33801 VIN rising 5.83 5.95 6.07 100 AW33802 VIN rising 6.0 6.2 6.4 110 AW33805 VIN rising 6.66 6.80 6.94 150 AW33809 VIN rising 9.78 9.98 10.18 AW33812 VIN rising 13.7 14.0 14.3 ti a MARKING 3 OUT OUT B GND OUT IN C OVLO IN IN C o n GND 38XX YYYY A fi d 2 300 e TOP VIEW 1 210 n PIN CONFIGURATION AND TOP MARK l Condition Device ic 38XX – AW33801/AW33802/ AW33805/AW33809/AW33812 YYYY – Production tracking code in Figure 2 Pin Configuration and Top Mark PIN DEFINITION a w Pin Name Description B3,C2,C3 IN A1,B1 GND Device ground C1 OVLO OVP threshold adjustment pin A2,A3,B2 OUT www.awinic.com.cn Switch input and device power supply Switch output 2 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW33801/AW33802 AW33805/AW33809/AW33812 Sep. 2018 V1.3 FUNCTIONAL BLOCK DIAGRAM OUT ti a l IN Vin Divider Selection OV comp Logic Control e OVLO n Gate Driver & Charge pump UV&OT comp Oscillator GND fi d Bandgap & Ibias n Figure 3 Functional Block Diagram USB Port C o TYPICAL APPLICATION CIRCUITS CIN 0.1µF 50V Figure 4 AW33801 AW33802 AW33805 OVLO AW33809 AW33812 COUT 1µF 35V Battery PMIC GND AW338XX typical application circuit(using default OVP threshold) a w in ic TVS Charger OUT IN www.awinic.com.cn 3 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW33801/AW33802 AW33805/AW33809/AW33812 Sep. 2018 V1.3 CIN 0.1µF 50V R1 R2 COUT 1µF 35V AW33801 AW33802 AW33805 OVLO AW33809 AW33812 Battery PMIC l TVS Charger OUT IN ti a USB Port GND a w in ic C o n fi d e n Figure 5 AW338XX typical application circuit(using external OVP threshold) www.awinic.com.cn 4 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW33801/AW33802 AW33805/AW33809/AW33812 Sep. 2018 V1.3 ORDERING INFORMATION AW33809CSR 3802 MSL1 -40°C – 85°C 1.245mm × 1.245mm × 0.597mm WLCSP-9 3805 MSL1 -40°C – 85°C 1.245mm × 1.245mm × 0.597mm WLCSP-9 -40°C – 85°C 1.245mm × 1.245mm × 0.597mm WLCSP-9 ROHS+HF Tape and Reel 3000pcs/Reel ROHS+HF Tape and Reel 3000pcs/Reel n ti a MSL1 3809 3812 l -40°C – 85°C 1.245mm × 1.245mm × 0.597mm WLCSP-9 3801 Delivery Form MSL1 ROHS+HF Tape and Reel 3000pcs/Reel ROHS+HF Tape and Reel 3000pcs/Reel ROHS+HF Tape and Reel 3000pcs/Reel MSL1 C AW33812CSR -40°C – 85°C 1.245mm × 1.245mm × 0.597mm WLCSP-9 Environmental Information e AW33805CSR Marking fi d AW33802CSR Package n AW33801CSR Temperature o Part Number Moisture Sensitivity Level ic AW338XX Shipping R: Tape & Reel a w in Package Type CS: CSP www.awinic.com.cn 5 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW33801/AW33802 AW33805/AW33809/AW33812 Sep. 2018 V1.3 ABSOLUTE MAXIMUM RATINGS (NOTE 1) Condition Input DC voltage VIN_PUL Min. Max. Unit -0.3 35 V 45 V 20μs pulse width, repeat 100 times Input peak pulse voltage VOUT Output voltage -0.3 VOVLO OVLO voltage -0.3 IIN Switch current(NOTE 3) TA Ambient temperature -40 TJ Junction temperature -40 TSTG Storage temperature TLEAD Soldering temperature -65 V 4.5 A 85 °C 150 °C 150 °C 260 °C e At leads, 10 seconds V 7 n Continuous current See(NOTE 2) l VIN Parameter ti a Symbol fi d NOTE1: Conditions out of those ranges listed in “absolute maximum ratings” may cause permanent damages to the device. In spite of the limits above, functional operation conditions of the device should within the ranges listed in “recommended operating conditions”. Exposure to absolute-maximum-rated conditions for prolonged periods may affect device reliability. NOTE2: 29V or VIN+0.3V, whichever is smaller. n NOTE3: Limited by thermal design. Parameter Thermal resistance from junction to ambient (NOTE 1) Condition C Symbol o THERMAL INFORMATION RJA In free air Value Unit 85 °C/W Value Unit ic NOTE1: Thermal resistance from junction to ambient is highly dependent on PCB layout. ESD AND LATCH-UP RATINGS w VESD Parameter Condition Human Body Model All pins, per MIL-STD-883J Method 3015.9 ±3 kV Charged Device Model All pins, per JEDEC EIA/JESD22-C101F ±2 kV Machine Model All pins, per JEDEC EIA/JESD22-A115 All pins, per JEDEC STANDARD NO.78E SEPTEMBER 2016, I Trigger ±200 V ±800 mA in Symbol Latch-up a ILatch-up www.awinic.com.cn 6 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW33801/AW33802 AW33805/AW33809/AW33812 Sep. 2018 V1.3 RECOMMENDED OPERATING CONDITIONS Parameter VIN Input DC voltage CIN Input capacitance Typ. Max. Unit 30 V 2.5 F 0.1 Output load capacitance 1 100 F a w in ic C o n fi d e n ti a COUT Min. l Symbol www.awinic.com.cn 7 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW33801/AW33802 AW33805/AW33809/AW33812 Sep. 2018 V1.3 ELECTRICAL CHARACTERISTICS TA = -40°C to 85°C unless otherwise noted. Typical values are guaranteed for VIN = 5V, CIN = 0.1F, IIN≤ 4.5A and TA = 25°C. IIN_OVLO VOVLO_TH Input quiescent current Input current at overvoltage condition OVLO set threshold Typ. Max. Units VIN = 5V, IOUT = 1A, TA = 25°C 29 39 m VIN = 5V, VOVLO=0V,IOUT = 0A VIN = 5V, VOVLO=3V,VOUT = 0V AW33801/AW33805/ AW33809/AW33812 AW33802 78 120 VOVLO_RNG OVP threshold adjustable range VOVLO_SEL External OVLO select threshold OVLO rising OVLO pin leakage current VOVLO=VOVLO_TH o AW33802 C AW33805 AW33809 ic AW33812 UVLO trip level w in VIN_UVLO Shutdown temperature TSDN_HYS Shutdown temperature hysteresis a TSDN 1.20 1.24 1.17 1.23 1.29 AW33801/ 0.26 20 0.33 0.06 -0.1 VIN rising 5.83 Hysteresis VIN rising n AW33801 OVP trip level 1.16 0.19 Hysteresis Protection VIN_OVLO 110 fi d IOVLO 71 4 6.0 Hysteresis VIN rising 6.66 0.1 5.95 A V V V A 6.07 0.10 6.2 6.4 6.80 6.94 0.15 9.78 Hysteresis VIN rising A 0.11 Hysteresis VIN rising l Switch on resistance Min. ti a IQ Test Conditions n Rdson Description e Symbol 9.98 V 10.18 0.21 13.7 14.0 Hysteresis 0.3 VIN rising 2.2 Hysteresis 0.08 VIN rising 2.3 14.3 2.4 AW33805/ AW33809/ V AW33812 AW33802 Hysteresis AW33801/AW33805/ AW33809/AW33812 AW33802 2.5 0.13 150 °C 140 20 °C 15 ms Timing Characteristics (Figure 6) tDEB Debounce time www.awinic.com.cn From VIN > VIN_UVLO to 10% VOUT 8 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW33801/AW33802 AW33805/AW33809/AW33812 Sep. 2018 V1.3 Description Test Conditions Min. Typ. Max. Units tON Switch turn-on time RL = 100, CL = 22F, VOUT from 10% VIN to 90% VIN 2 ms tOFF Switch turn-off time RL = 100CL = 0F, VIN > VIN_OVLO to VOUT stop rising, VIN rise at 10V/s 90 ns ti a l Symbol TIMING DIAGRAM VIN tDEB e tDEB n OVP trip level tON tOFF fi d VOUT tON a w in ic C o n Figure 6 Timing diagram www.awinic.com.cn 9 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW33801/AW33802 AW33805/AW33809/AW33812 Sep. 2018 V1.3 TYPICAL CHARACTERISTICS Figure No Normalized Rdson vs. Output Current FIGURE 7 Normalized Rdson vs. Temp. (IOUT = 1A) FIGURE 8 Normalized Rdson vs. Input Voltage (IOUT = 1A) FIGURE 9 Input Supply Current vs. Supply Voltage FIGURE 10 Normalized Internal OVP Threshold FIGURE 11 Normalized External OVP Threshold FIGURE 12 Normalized Debounce Time vs. Temp FIGURE 13 Power-up (COUT = 1F, 100mA load) FIGURE 14 e n ti a INDEX l Table 1 Table of Figures Power-up (COUT = 100F, 100mA load) FIGURE 15 FIGURE 16 fi d OVP Response (AW33801) FIGURE 17 Recovery from OVP(AW33801) 2.5 o 2.0 1.5 C Normalized Rdson Normalized to Iout=1A 1.0 0.0 0 1 ic 0.5 2 3 Normalized Rdson n VIN = 5V, VOVLO = 0V, CIN = 0.1F, COUT = 1F, and TA = 25°C unless otherwise specified. 2.0 Normalized to TA = 25° C 1.5 1.0 0.5 0.0 4 -40 5 -15 10 35 60 85 Temperature (°C) in Output Current(A) Figure 8 Normalized Rdson vs. Temp. (IOUT = 1A) a w Figure 7 Normalized Rdson vs. Output Current www.awinic.com.cn 10 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW33801/AW33802 AW33805/AW33809/AW33812 Sep. 2018 V1.3 TYPICAL CHARACTERISTICS (CONTINUED) VIN = 5V, VOVLO = 0V, CIN = 0.1F, COUT = 1F, and TA = 25°C unless otherwise specified. 350 1.5 1.0 0.5 85° C 200 150 100 50 8 12 Input Voltage(V) 16 0 20 Normalized to TA = 25° C o 1.00 C 0.95 60 35 Normalized to TA = 25° C 1.05 1.00 0.95 -15 10 35 60 Temperature (°C) 85 Figure 12 Normalized External OVP Threshold in Normalized to TA = 25° C 1.50 VIN 5V / div 1.00 w a 30 1.10 -40 Figure 11 Normalized Internal OVP Threshold 2.00 25 0.90 85 ic 10 35 Temperature (°C) 20 Figure 10 Input Supply Current vs. Supply Voltage n 1.05 -15 15 fi d 1.10 -40 10 Input Voltage (V) Figure 9 Normalized Rdson vs. Input Voltage (IOUT = 1A) 0.90 5 e 4 Normalized Threshold Voltage 0 Normalized Threshold Voltage 25° C 250 0 0.0 Normalized Debounce Time –40° C 300 l 2.0 ti a Input Supply Current (A) Normalized Rdson Normalized to VIN=5V n 2.5 VOUT 5V / div 0.50 IOUT 100mA / div 0.00 -40 -15 10 35 60 85 Temperature (°C) 5ms / div Figure 14 Power-up (COUT = 1F, 100mA load) Figure 13 Normalized Debounce Time vs. Temp. www.awinic.com.cn 11 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW33801/AW33802 AW33805/AW33809/AW33812 Sep. 2018 V1.3 TYPICAL CHARACTERISTICS (CONTINUED) VIN = 5V, VOVLO = 0V, CIN = 0.1F, COUT = 1F, and TA = 25°C unless otherwise specified. 8V VIN 5V / div 5V l VIN 5V / div VOUT 5V / div ti a VOUT 5V / div n IOUT 200mA / div 5ms / div IOUT 100mA / div e 10µs / div Figure 15 Power-up (COUT = 100F, 100mA load) fi d Figure 16 OVP Response (AW33801) VIN 5V / div o n 8V 5V 10ms / div C VOUT 5V / div a w in ic Figure 17 Recovery from OVP(AW33801) www.awinic.com.cn 12 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW33801/AW33802 AW33805/AW33809/AW33812 Sep. 2018 V1.3 FUNCTIONAL DESCRIPTION Device Operation ti a l If the input voltage is between UVLO and OVP threshold, the internal charge pump begins to work after debounce time, the gate of the nFET switch will be slowly charged high till the switch is fully on. If the input voltage exceeds the OVP trip level, the switch will be turned off in about 90ns. If input voltage falls below UVLO threshold, or over-temperature happens, the switch will also be turned off. Over-Voltage Protection If the input voltage exceeds the OVP rising trip level, the switch will be turned off in about 90ns. The switch will remain off until VIN falls below the OVP falling trip level. n OVP Threshold Adjustment n fi d e If OVLO pin is not grounded, and by connecting external resistor divider to OVLO pin as shown in the typical application circuit, between IN and GND, the OVP threshold can be adjusted as following: R1+R2 VIN_OVLO= VOVLO_TH R2 The adjustment range is 4V to 20V. When the OVLO pin voltage VOVLO exceeds VOVLO_SEL(0.26V typical), VOVLO is compared with the reference voltage VOVLO_TH(1.20V typical for AW33801/AW33805/AW33809/AW33812, 1.23V typical for AW33802) to judge whether input supply is over-voltage. Take AW33801 for example, if we select R1 = 51kΩ and R2 = 12.4kΩ, then the new OVP threshold calculated from the above formula is 6.14V. USB On-The-Go (OTG) Operation C o If VIN = 0V and OUT is supplied by OTG voltage, the body diode of the load switch conducts current from OUT to IN and the voltage drop from OUT to IN is approximately 0.7V. When VIN > VIN_UVLO, internal charge pump begins to open the load switch after debounce time. After switch is fully on, current is supplied through switch channel and the voltage drop from OUT to IN is minimum. ic PCB LAYOUT CONSIDERATION To make fully use of the performance of AW338XX, the guidelines below should be followed. in 1. All the peripherals should be placed as close to the device as possible. Place the input capacitor CIN on the top layer (same layer as the AW338XX) and close to IN pin, and place the output capacitor COUT on the top layer (same layer as the AW338XX) and close to OUT pin. a w 2. Route the power line (shown in Figure 1) as widely and shortly as possible to reduce parasitic impedance. www.awinic.com.cn 13 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW33801/AW33802 AW33805/AW33809/AW33812 Sep. 2018 V1.3 TAPE AND REEL INFORMATION e n ti a l CARRIER TAPE in ic C o n fi d PIN1 Pin 1 direction a w Pin 1 www.awinic.com.cn User Direction of Feed 14 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW33801/AW33802 AW33805/AW33809/AW33812 Sep. 2018 V1.3 o n fi d e n ti a l REEL C NOTE: a w in ic 1. Unit: mm; 2. Surface resistivity: 105 to 1011 ohms/sq; 3. Restriction criterion of hazardous substance for packing material follow GP-M001. www.awinic.com.cn 15 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW33801/AW33802 AW33805/AW33809/AW33812 Sep. 2018 V1.3 PACKAGE DESCRIPTION BOTTOM VIEW TOP VIEW 0.239±0.020 fi d e n e2 E ti a e3 Ball A1 l e1 D Symbol A A1 A2 SIDE VIEW n A C A1 o A2 A3 NOTE: NOM 0.597 0.177 A3 D E e1 0.380 0.040 1.245 1.245 0 e2 e3 0 0.400 Tolerance ±0.055 ±0.020 ±0.025 ±0.010 ±0.025 ±0.025 NA NA NA Unit: mm 1. AW338XX is compatible with the current RoHS requirements and adopts Halogen-Free assembly; a w in ic 2. AW338XX is produced based on MSL level-1 according to the JEDEC industry standard classification. www.awinic.com.cn 16 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW33801/AW33802 AW33805/AW33809/AW33812 Sep. 2018 V1.3 fi d e n ti a l REFLOW o Reflow Note n Figure 15 Package Reflow Oven Thermal Profile Spec Max. 3°C /sec Time of Preheat temp.(from 150°C to 200°C) 60-120 sec Time to be maintained above 217°C 60-150 sec Peak Temperature >260°C Time within 5°C of actual peak temp 20-40 sec Ramp-down rate Max. 6°C /sec Time from 25°C to peak temp Max. 8min a w in ic C Average ramp-up rate (217°C to Peak) www.awinic.com.cn 17 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW33801/AW33802 AW33805/AW33809/AW33812 Sep. 2018 V1.3 REVISION HISTORY Date V0.9 January 2017 V1.0 March 2017 Change Record Datasheet V0.9 Released Added Typical Characteristics 1. Added PCB Layout Consideration. April 2017 2. Added ROHS and MSL Statements. ti a V1.1 3. Added Reflow Information. January 2018 Added Land Pattern Data V1.3 September, 2018 Storage Temperature Modified a w in ic C o n fi d e n V1.2 l Vision www.awinic.com.cn 18 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW33801/AW33802 AW33805/AW33809/AW33812 Sep. 2018 V1.3 DISCLAIMER l Information in this document is believed to be accurate and reliable. However, Shanghai AWINIC Technology Co., Ltd (AWINIC Technology) does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. ti a AWINIC Technology reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. Customers shall obtain the latest relevant information before placing orders and shall verify that such information is current and complete. This document supersedes and replaces all information supplied prior to the publication hereof. fi d e n AWINIC Technology products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an AWINIC Technology product can reasonably be expected to result in personal injury, death or severe property or environmental damage. AWINIC Technology accepts no liability for inclusion and/or use of AWINIC Technology products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. n Applications that are described herein for any of these products are for illustrative purposes only. AWINIC Technology makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. All products are sold subject to the general terms and conditions of commercial sale supplied at the time of order acknowledgement. o Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. C Reproduction of AWINIC information in AWINIC data books or data sheets is permissible only if reproduction is without alteration and is accompanied by all associated warranties, conditions, limitations, and notices. AWINIC is not responsible or liable for such altered documentation. Information of third parties may be subject to additional restrictions. a w in ic Resale of AWINIC components or services with statements different from or beyond the parameters stated by AWINIC for that component or service voids all express and any implied warranties for the associated AWINIC component or service and is an unfair and deceptive business practice. AWINIC is not responsible or liable for any such statements. www.awinic.com.cn 19 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD
AW33801CSR 价格&库存
很抱歉,暂时无法提供与“AW33801CSR”相匹配的价格&库存,您可以联系我们找货
