AW86907FCR
AW86907FCR
    AWINIC(艾为)
    FCQFN20_3X2MM
    LRA触觉驱动器
AW86907FCR 数据手册
AW86907 September 2021 V1.9 11V Fast Startup With F0 Detect And Tracking LRA Haptic Driver Features General Description 1MHz I2C Bus ⚫ 12-KByte Memory ⚫ 12k/24k/48k input wave sampling rate ⚫ F0 detect and tracking ⚫ Advance autobrake engine integrated ⚫ Playback mode: ➢ Memory playback ➢ 3 Trigger playback ➢ One wire playback ➢ Cont playback Drive signal monitor for LRA protect ⚫ Drive Compensation Over Battery Discharge ⚫ Fast Start Up Time <1ms ⚫ Dedicated interrupt output pin ⚫ Boost output voltage up to 11V ⚫ VOUT=8.5V@Vbat=4.2V for 8Ω LRA ⚫ Support automatically switch to standby mode ⚫ Standby current:8uA@Vbat=3.6V ⚫ Shutdown current:0.1uA ⚫ Supply voltage range 3 to 5.5V ⚫ Short-Circuit Protection, Over-Temperature cC aw ini Protection, Under-Voltage Protection FCQFN 2mm × 3mm × 0.55mm -20L Package Applications ⚫ Tablets ⚫ Wearable Devices fid ⚫ Mobile phones AW86907 integrates a 12KByte SRAM for userdefined waveforms to achieve a variety of vibration experiences, supporting 3 sampling rate(12k/24k/48k) of waveforms loaded in SRAM, supporting output waveform sampling rate upsampling to 48k. AW86907 integrates an autobrake engine to suppress the aftershocks to zero for different drive waveforms(short or long) on different LRA motor. on Resistance-Based LRA Diagnostics ⚫ tia Real time playback(Up to 4KByte FIFO) en ➢ ⚫ ⚫ AW86907 is a high voltage H-bridge, single chip LRA haptic driver, with F0 detecting and tracking based on BEMF, with a boost converter up to 11V drive voltage inside, supporting real time playback, memory playback, cont playback, one wire and hardware pin trigged playback. A typical startup time of 1ms makes the AW86907 an ideal haptic driver for fast responses. l ⚫ AW86907 supports LRA fault diagnostic based on resistance measurement and protections of shortcircuit, over-temperature and under-voltage. AW86907 integrates a high-efficiency boost converter as the H-Bridge driver supply rail. The output voltage, maximum current limit and maximum boost current are configurable. AW86907 features configurable automatically switch to standby mode. This can less quiescent power consumption. Dedicated interrupt output pin can detect real time FIFO status and the error status of the chip. AW86907 features general settings are communicated via an I2C-bus interface and its I2C address is configurable. AW86907 is available in a FCQFN 2mm x 3mm x 0.55mm -20L package. All trademarks are the property of their respective owners. www.awinic.com 1 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW86907 September 2021 V1.9 Pin Configuration And Top Mark AW86907FCR (Top View) AW86907FCR Marking (Top View) 2 15 GND TRIG2 3 14 VBAT TRIG1 4 13 BGND HDN 5 12 SW PGND 6 11 Pin Configuration and Top Mark on Pin Definition B6EG –AW86907FCR XXXX - Production Tracing Code fid AD PVDD HDP 10 VCP 9 8 7 Figure 1 VBST tia TRIG3 en 16 RCK B6EG XXXX 1 l VREG 17 SDA 18 SCL 19 INTN 20 RSTN NAME I/O 1 RSTN I 2 TRIG3 I DESCRIPTION Active low hardware reset. High: standby/active mode Low: power-down mode. Internal have 2MΩ pull-down resistor Hardware trigger 3. Internal have 2MΩ pull-down resistor. 3 TRIG2 I Hardware trigger 2. Internal have 2MΩ pull-down resistor. 4 TRIG1 I Hardware trigger 1. Internal have 2MΩ pull-down resistor. Negative haptic driver differential output cC PIN NUMBER HDN O 6 PGND Ground 7 HDP O 8 PVDD Power 9 AD I I2C bus address selection Internal charge pump voltage aw ini 5 H-bridge driver GND Positive haptic driver differential output High voltage driver power rail 10 VCP O 11 VBST Power 12 SW O 13 BGND Ground Boost GND 14 VBAT Power Chip power supply 15 GND Ground 16 RCK I 17 VREG Power Supply ground PLL reference CLK (3.072MHz) input. Internal have 2MΩ pull-down resistor. Digital power supply 18 SDA IO 19 SCL I I2C bus clock input 20 INTN O Interrupt open drain output, low active. www.awinic.com 2 Boost output voltage Internal boost switch pin I2C bus data input/output(open drain) Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW86907 September 2021 V1.9 Functional Block Diagram VBAT SW VCP Logic CP PVDD SDA SRAM RSTN main control INTN HSRC TRIG1 Trig interface LRA HDN RL_DET TRIG3 RCK OSC F0 tracking fid Auto brake PLL LDO VREG OTP GND BGND OCP PGND FUNCTIONAL BLOCK DIAGRAM cC Figure 2 UVLO on TRIG2 HDP H-Bridge Driver DPWM en AD VBST BIAS I2C interface l Boost Converter tia Wave editor SCL Typical Application Circuits L1 1μH VBAT C2 0.1μF 10V 17 14 aw ini C1 0.1μF 10V VIO R3 4.7kΩ VREG 16 4 3 2 GPIO VBAT SW VCP 8 PVDD C6 0603 10μF 25V RCK TRIG1 TRIG2 TRIG3 VIO R1 4.7kΩ C5 22nF 10 10V 12 RSTN 20 INTN REF CLK VIO C4 0.1μF 10V 1 GPIO GPIO C3 0603 10μF 10V VBST 11 AW86907 7 B1 C8 0.1nF 16V HDP R2 4.7kΩ 19 SCL 18 SDA 9 AD SCL SDA HDN GND 15 Figure 3 C7 0603 22μF 25V BGND 13 LRA 5 B2 PGND 6 C9 0.1nF 16V Typical Application Circuit of AW86907 All trademarks are the property of their respective owners. www.awinic.com 3 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW86907 September 2021 V1.9 Notice for Typical Application Circuits: 1: Please place C1,C2,C3,C4,C5,C6,C7 as close to the chip as possible, and C6 and C7 close to PIN 11 and the capacitors should be placed in the same layer with the AW86907 chip. 2: For the sake of driving capability, the power lines (especially the one to Pin 12), output lines, and the connection lines of L1, and SW should be short and wide as possible. The power path marked in red as shown in the figures above. Please traces according to 3.5A power line alignment rules, for VBAT to SW through L1. tia l and the other red path traces according to 1.5A power line alignment rules. Package AW86907FCR -40°C~85°C FCQFN 2mmX3mmX0.55mm20L Marking Moisture Sensitivity Level fid Temperature B6EG MSL1 Environment Information ROHS+HF Delivery Form 6000 units/ Tape and Reel aw ini cC on Part Number en Ordering Information www.awinic.com 4 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW86907 September 2021 V1.9 Absolute Maximum Ratings(NOTE 1) Parameter Range -0.3V to 6.0V Digital power supply VREG -0.3V to 2.0V Internal charge pump voltage VCP -0.3V to 17V Boost output voltage VBST PVDD -0.3V to 13V Internal boost switch pin SW -0.3V to 15V HDP, HDN -0.3V to PVDD+0.3V tia l Battery Supply Voltage VBAT Package Thermal Resistance θJA 60°C/W -40°C to 85°C Maximum Junction Temperature TJMAX Storage Temperature Range TSTG en Ambient Temperature Range 150°C -65°C to 150°C Lead Temperature(Soldering 10 Seconds) 260°C HBM(Human Body Model) CDM(Charge Device Model) fid ESD Rating (NOTE 2 3) ±2KV ±1.5KV on Latch-up Test Condition: JEDEC EIA/JESD78E +IT: 200mA -IT: -200mA cC NOTE 1: Conditions out of those ranges listed in "absolute maximum ratings" may cause permanent damages to the device. In spite of the limits above, functional operation conditions of the device should within the ranges listed in "recommended operating conditions". Exposure to absolute-maximum-rated conditions for prolonged periods may affect device reliability. aw ini NOTE 2:The human body model is a 100pF capacitor discharged through a 1.5kΩ resistor into each pin. Test method: ANSI/ESDA/JEDEC JS-001-2017. NOTE 3:Charge Device Model test method: JEDEC EIA/JESD22-C101F. www.awinic.com 5 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW86907 September 2021 V1.9 Electrical Characteristics Characteristics Test condition: TA=25°C,VBAT=4.2V,PVDD=8V,RL=8Ω+100μH(unless otherwise noted) Description Test Conditions Min Battery supply voltage VVREG Voltage at VREG pin VIL Logic input low level RSTN/TRIG1/TRIG2/TRIG3/ AD/ SCLK VIH Logic input high level RSTN/TRIG1/TRIG2/TRIG3/ AD/ SCLK VOL Logic output low level VOS Output offset voltage I2C signal input 0 ISD Shutdown current VBAT=4.2V, RSTN =0V Standby current VBAT=3.6V, AD= 0V TRIG1=TRIG2=TRIG3=0V 3 Max Units 5.5 V INTN/SDA fid IOUT=4mA en 1.8 V 0.5 1.3 -30 V V 0.4 V 0 30 mV 0.1 1 μA 8 μA 5 mA 2.7 V Under-voltage protection hysteresis voltage 100 mV Over temperature protection threshold 160 °C 130 °C on ISTBY On pin VBAT tia VVBAT Typ. l Symbol RSTN=SCL=SDA=1.8V IQ Quiescent current VBAT=3.6V@Bypass cC Under-voltage protection voltage UVP TSDR Ton1 Ton2 Boost aw ini TSD Over temperature protection recovery threshold Time from shutdown to standby Time from standby to active 6 From trigger to output signal 1 ms ms OVP Over-voltage threshold FBST Operating Frequency 1.6 MHz Inductor peak current limit 3.75 A IL_PEAK TST 1.1*VPVDD Soft-start time No load, COUT=20μF 0.3 ms Drain-Source on-state resistance Include H and L NMOS 300 mΩ HDRIVER Rdson www.awinic.com 6 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW86907 September 2021 V1.9 Symbol Description Rocp Load impedance threshold for over current protection Min Typ. LRA Consistency Calibration accuracy F0-2 RL=16Ω+100μH Output voltage RL=8Ω+100μH Output voltage F0 Units Ω F0+2 10.5 Hz V l VBAT=4.2V, PVDD set 11V Vpeak Max 2 VBAT=3.6V, PVDD=8V tia FCALI_ACC_LRA Test Conditions 8.5 V aw ini cC on fid en VBAT=4.2V, PVDD set 11V www.awinic.com 7 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW86907 September 2021 V1.9 I2C Interface Timing Parameter fast mode fast mode plus UNIT No. Symbol Name MIN 1 fSCL SCL Clock frequency 2 tLOW SCL Low level Duration 1.3 3 tHIGH SCL High level Duration 0.6 4 tRISE SCL, SDA rise time 5 tFALL SCL, SDA fall time 6 tSU:STA Setup time SCL to START state 0.6 0.26 μs 7 tHD:STA (Repeat-start) Start condition hold time 0.6 0.26 μs 8 tSU:STO Stop condition setup time 0.6 0.26 μs 9 tBUF MAX MIN TYP 1.3 0.5 μs 10 tSU:DAT SDA setup time 0.1 0.1 μs 11 tHD:DAT SDA hold time 10 10 ns 400 (3) (2) tHI GH tLOW tHD:DAT (11) aw ini μs l tia (5) μs 0.12 μs 0.3 0.12 μs SDA Figure 4 SCL and SDA timing relationships in the data transmission process SCL tHD:STA tSU:STO (7) (8) (6) (9) tSU:STA tBUF SDA Figure 5 The timing relationship between START and STOP state www.awinic.com 8 kHz 0.3 en tFALL (4) (10) 1000 0.26 tRI SE tSU:DAT MAX 0.5 fid cC on the Bus idle time START state to STOP state SCL TYP Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW86907 September 2021 V1.9 Measurement Setup AW86907 features switching digital output, as shown in Figure 6. Need to connect a low pass filter to HDP/HDN output respectively to filter out switch modulation frequency, then measure the differential output of filter to obtain analog output signal. tia HDP l 0.47nF 100kΩ 3.4kHz Low-Pass Fliter LRA AW86907 en HDN 100kΩ 0.47nF aw ini cC on fid Figure 6 AW86907 test setup www.awinic.com 9 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW86907 September 2021 V1.9 3.5 4.5 tia 2.5 20 18 16 14 12 10 8 6 4 l 12 11 10 9 8 7 6 5 4 IQ(mA) Standby Current(uA) Typical Characteristics 3 5.5 en PVDD Acceleration on Long_wave fid Acceleration cC Figure 8 Long Vibration with Short Vibration insdie Trig Acceleration aw ini Wave 4.2 Figure 10 IQ (PVDD=9V) Vs VBAT Figure 7 Standby Current Vs Supply Voltage Short_wave 3.6 VBAT(V) Supply Voltage(V) Drive Brake Figure 11 LRA with Automatic Braking Acceleration wave Brake Figure 9 Trig Application www.awinic.com 10 Figure 12 Automatic Resonance Tracking Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD 5.5 AW86907 September 2021 V1.9 Detailed Functional Description Power On Reset The device provides a power-on reset feature that is controlled by VREG OK. The reset signal will be generated to perform a power-on reset operation, which will reset all circuits and configuration registers. When the VBAT power on, the VREG voltage raises and produce the OK indication, the reset is over. The device supports 3 operation modes. Table 1 Operating Mode Power-Down Condition Description VBAT = 0V or RSTN = 0V Power supply is not ready or RSTN is tie to low. en Mode tia l Operation Mode Active VBAT > 2.7V Power supply is ready and RSTN is tie to high. and RSTN = HIGH Most parts of the device are power down for low power and no wave is going consumption except I2C interface and LDO. Playing a waveform on Standby fid Whole chip shutdown including I2C interface. Most parts of the device are working Power supply not ready (VBAT = 0) or RSTN = 0 Power supply not ready (VBAT = 0) or RSTN = 0 aw ini Power supply OK (VBAT > 2.7V) And RSTN = 1 cC Power-down Waveform is over or set a softrstn Standby Active Start a play request Figure 13 Device operating modes transition POWER-DOWN MODE The device switches to power-down mode when the supply voltage is not ready or RSTN pin is set to low. In this mode, all circuits inside this device will be shut down. I 2C interface isn’t accessible in this mode, and all of the internal configurable registers and Momory are cleared. The device will jump out of the power-down mode automatically when the supply voltages are OK and RSTN pin is set to high. www.awinic.com 11 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW86907 September 2021 V1.9 Standby Mode The device switches standby mode when the power supply voltages are OK and RSTN pin set to high. In this mode I2C interface is accessible, other modules except LDO module are still powered down. Also in this mode, customer can initialize waveform library in SRAM. Device will be switched to this mode after haptic waveform playback finished. Active Mode tia l The device is fully operational in this mode. Boost and H-bridge driver circuits will start to work. Users can send a playback request to make device in this mode. Power On And Power Down Sequence 100μs en This device power on and power down sequence is illustrated in the following figure: ms 3-5.5V 100μs fid VBAT 100μs on RSTN I2C I2C configuration Playback Sequence cC Figure 14 Power On and Power Down Sequence aw ini Make sure the device is not in POWER-DOWN MODE before sending a playback request, then the playback sequence is illustrated in the following figure: www.awinic.com 12 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW86907 September 2021 V1.9 Power on Set EN_RAMINIT = 1 tia l Download waveform to SRAM en Set EN_RAMINIT = 0 Global configuration RAM mode config Set GO=1 Set GO=1 on CONT mode config fid Receive a Playback Request RTP mode config Send one wire protocol Set GO=1 Wait 1ms aw ini cC Send a trigger One wire mode config CONT MODE RAM MODE Wait GLB_STATE=4'b1000 Write data to RTP FIFO TRIG MODE ONE WIRE MODE RTP MODE Figure 15 Power up and playback sequence Software Reset Writing 0xAA to register CHIPID(0x00) via I2C interface will reset the device internal circuits except SRAM, including configuration registers. Battery Voltage Detect Software can send command to detect the battery voltage. Detect steps: ⚫ Set EN_RAMINIT to 1 in register 0x43; www.awinic.com 13 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW86907 September 2021 V1.9 ⚫ Set VBAT_GO to 1 in register 0x52; ⚫ Delay 3ms; ⚫ Set EN_RAMINIT to 0 in register 0x43; ⚫ Read VBAT_LO in register 0x57 and VBAT in register 0x55. Code= {VBAT, VBAT_LO}. The code is a 10bit unsigned number. 6.1 × 𝑐𝑜𝑑𝑒 (𝑉) 1024 tia l 𝑉𝐵𝐴𝑇 = Constant Vibration Strength en The device features power-supply feedback. If the supply voltage discharge over time, the vibration strength remains the same as long as enough supply voltage is available to sustain the required output voltage. It is especially useful for ring application. LRA Consistency Calibration on fid Different motor batches, assembly conditions and other factors can result in f0 deviation of LRA. When the drive waveform does not match the LRA monomer, the vibration may be inconsistent and the braking effect becomes worse, especially for short vibration waveforms. So it's necessary to perform consistency calibration of LRA. Firstly the power-on f0 detection can be launched to get the f0 of LRA. Secondly the waveform frequency stored in SRAM and the f0 of LRA are used to calculate the code for calibration. The f0 accuracy after LRA consistency calibration is ±2Hz. cC LRA Resistance Detect Software can send command to detect the LRA’s resistance. Based on this information host can diagnosis used LRA’s status. Detect steps: Set EN_RAMINIT to 1 in register 0x43; ⚫ Set RL_OS to 1 in register 0x51; ⚫ Set DIAG_GO to 1 in register 0x52; ⚫ Delay 3ms; ⚫ Set EN_RAMINIT to 1 in register 0x43; ⚫ Read RL in register 0x53 and RL_LO in register 0x57. Code= {RL, RL_LO}. aw ini ⚫ The code is a 10bit unsigned number. 𝑅𝐿 = 678 × 𝑐𝑜𝑑𝑒 (𝛺) 1024 × d2s_gain Flexible Haptic Data Playback The device offers multiple ways to playback haptic effects data. The PLAY_MODE bits select RAM mode, RTP mode, CONT mode. Additional flexibility is provided by the three hardware TRIG pins, which can override PLAY_MODE bit to playback haptic effects data as configuration. The device contains 12 kB of integrated SRAM to store customer haptic waveforms’ data. The whole SRAM is separated to RAM waveform library and RTP FIFO region by base address. And RAM waveform library is www.awinic.com 14 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW86907 September 2021 V1.9 including waveform library version, waveform header and waveform data. 2FFF tia WAVEFORM HEADER en fid base_addr Waveform#N end address low Waveform#N end address high Waveform#N start address low Waveform#N start address high Waveform#1 end address low Waveform#1 end address high Waveform#1 start address low Waveform#1 start address high Waveform library version l WAVEFORM DATA RTP FIFO on 0 WAVEFORM VERSION WAVEFORM SRAM cC Figure 16 Data structure in SRAM RAM mode and TRIG mode playback the waveforms in RAM waveform library and RTP mode playback the waveform data written in RTP FIFO, CONT mode playback non-filtered or filtered square wave with rated drive voltage. aw ini Sram Structure A SRAM waveform library consists of a waveform version byte, a waveform header section, and the waveform data content. The waveform header defines the data boundaries for each waveform ID in the data field, and the waveform data contains a signed data format (2's complement) to specify the magnitude of the drive. www.awinic.com 15 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW86907 September 2021 V1.9 2FFF address ... 4 * (#N – 1) + 4 + len(#1) + len(#2) …… WAVEFORM SRAM #2 #1 4 * (#2 – 1) + 4 4 * (#2 – 1) + 3 4 * (#2 – 1) + 2 4 * (#2 – 1) + 1 4 * (#1 – 1) + 4 4 * (#1 – 1) + 3 4 * (#1 – 1) + 2 4 * (#1 – 1) + 1 0 fid Waveform#2 end address low Waveform#2 end address high Waveform#2 start address low Waveform#2 start address high Waveform#1 end address low Waveform#1 end address high Waveform#1 start address low Waveform#1 start address high Waveform library version tia #N 4 * (#N – 1) + 5 4 * (#N – 1) + 4 4 * (#N – 1) + 3 4 * (#N – 1) + 2 4 * (#N – 1) + 1 en Waveform#N end address low Waveform#N end address high Waveform#N start address low Waveform#N start address high l ... 4 * (#N – 1) + 5 + len(#1) 4 * (#N – 1) + 4 + len(#1) base_addr on Figure 17 Waveform library data structure Waveform version: Waveform header: cC One byte located on SRAM base address, setting to different value to identify different version of RAM waveform library. aw ini The waveform header block consist of N-boundary definition blocks of 4 bytes each. N is the number of waveforms stored in the SRAM (N cannot exceed 127). Each of the boundary definition blocks contain the start address (2 bytes) and end address (2 bytes). So the total length of waveform header block are N*4 bytes. The start address contains the location in the memory where the waveform data associated with this waveform begins. The end address contains the location in the memory where the waveform data associated with this waveform ends. The waveform ID is determined after base address is defined. Four bytes begins with the address next to base address are the first waveform ID’s header, and next four bytes are the second waveform ID’s header, and so on. Waveform data: The waveform data contains a signed data format (2's complement) to specify the magnitude of the drive. The begin address and end address is specified in waveform ID’s header. Waveform library initialization steps: ⚫ Prepare waveform library data including: waveform library version, waveform header fields for waveform in library and waveform data of each waveform; ⚫ Set register EN_RAMINIT=1 in register 0x43, to enable SRAM initial; ⚫ Set base address (register 0x2D, 0x2E); www.awinic.com 16 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW86907 September 2021 V1.9 ⚫ Write waveform library data into register 0x42 continually until all the waveform library data written; ⚫ Set register EN_RAMINIT=0, to disable SRAM initial. Ram Mode To playback haptic data with RAM mode, the waveform ID must first be configured into the waveform playback queue and then the waveform can be played by writing GO bit register. PLAYBACK QUEUE Waveform library tia l GO Waveform 1 WAVSEQ1 Waveform 2 WAVSEQ2 Waveform 3 en WAVSEQ3 WAVSEQ4 fid WAVSEQ5 WAVSEQ6 WAVSEQ7 Waveform N on WAVSEQ8 .. . Figure 18 RAM mode playback cC The waveform playback queue defines waveform IDs in waveform library for playback. Eight WAVSEQx registers queue up to eight library waveforms for sequential playback. A waveform ID is an integer value referring to the index of a waveform in the waveform library. Playback begins at WAVSEQ1 when the user triggers the waveform playback queue. When playback of that waveform ends, the waveform queue plays the next waveform ID held in WAVSEQ2 (if non-zero). The waveform queue continues in this way until the queue reaches an ID value of zero or until all eight IDs are played whichever comes first. aw ini The waveform ID is a 7-bit number. The MSB of each ID register can be used to implement a delay between queue waveforms. When the SEQxWAIT is high, bits 6-0 indicate the length of the wait time. The wait time for that step then becomes WAVSEQ[6:0] × wait_time unit. Wait_time unit can be configuration of WAITSLOT register(in 0x16 register). The device allows for looping of individual waveforms by using the SEQxLOOP registers. When used, the state machine will loop the particular waveform the number of times specified in the associated SEQxLOOP register before moving to the next waveform. The device allows for looping of the entire playback sequence by using the MAIN_LOOP register. The waveform-looping feature is useful for long, custom haptic playbacks, such as a haptic ringtone. Playback steps: ⚫ Waveform library must be initialized before playback; ⚫ Set PLAY_MODE bit to 0 in register 0x08; ⚫ Set playback queue registers (0x0A ~ 0x11) as desired; ⚫ Set playback loop registers (0x12~ 0x16) as desired; ⚫ Set GO bit to 1 in register 0x09 to trigger waveform playback; www.awinic.com 17 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW86907 September 2021 V1.9 ⚫ Device will be switched to STANDBY mode after haptic waveform playback finished. Rtp Mode The real-time playback mode is a simple, single 8-bit register interface that holds an amplitude value. When real-time playback is enabled, begin to enters a register value to RTP_DATA over the I 2C will trigger the playback, the value is played until the data sending finished or removes the device from RTP mode. The maximum FIFO space is 4Kbyte. tia l After FF_AEM or FF_AFM register is set to 0, HOST can obtain the RTP FIFO almost empty or almost full status through interrupt signal(pin INTN) or read FF_AES or FF_AFS register. RTP FIFO almost empty and almost full threshold can be configured through FIFO_AE and FIFO_AF registers. FIFO last address en Almost full level FIFO FIFO write address 0 FIFO NOT empty and chip startup FIFO read address ... on ... fid Almost empty threshold FIFO empty Playback steps: cC Figure 19 RTP mode playback Prepare RTP data before playback; ⚫ Set PLAY_MODE bit to 1 in register 0x08; ⚫ Set GO bit to 1 in register 0x09 to trigger waveform playback; ⚫ Delay 1ms. ⚫ Check GLB_STATE=4’b1000, if HOST don’t send data to FIFO, chip will wait for RTP data coming in this state forever; ⚫ Write RTP data continually to register 0x32 to playback RTP waveform; ⚫ HOST need monitor the almost full and empty status for RTP FIFO; ⚫ Device will be switched to STANDBY mode after wave data in RTP FIFO is played empty. aw ini ⚫ Trig Mode The device have three dedicated hardware pins for quickly trigger haptic data playback. Each pin can be configured posedge/negedge/both-edge/level trigger. www.awinic.com 18 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW86907 September 2021 V1.9 Waveform library TRIG config TRIGGER TRG1_LEV=0 TRIG1_POSEDGE Waveform 5 TRIG1_NEGEDGE Waveform 1 Waveform 1 Waveform 2 Waveform 3 TRG2_LEV=0 Waveform 2 TRIG2_NEGEDGE Waveform 3 TRIG3_POSEDGE Waveform 6 TRIG3_NEGEDGE Waveform 4 Waveform 4 . . . TRIG3_LEV=1 TRG3_POLAR=0 Waveform 5 Waveform 6 en TRIG3_LEV=1 TRG3_POLAR=1 tia l TRIG2_POSEDGE Figure 20 TRIG mode playback fid Edge mode or level mode is accessible by configing register TRGx_LEV. When a edge mode is needed, user should set TRGx_LEV =0. In edge mode, register TRGxSEQ_P and TRGx_POS respestively represent the waveform and enable signal of positive edge, where register TRGxSEQ_N and TRGx_NEG respestively represent the waveform and enable signal of negative edge. on When a level mode is needed, user should set TRGx_LEV =1, and positive level and negative level can be supported by setting register TRGX_POLAR=0 and setting TRGX_POLAR=1. Table 2 TRIG MODE CONFIG I2C reg TRGx_POLAR TRGx_POS 1 0 1 0 1 0 1 X X Waveform 0 0 1 1 ↑ ↓ ↑/↓ none TRGxSEQ_P TRGxSEQ_N TRGxSEQ_P/ TRGxSEQ_N X X High level Low level TRGxSEQ_P TRGxSEQ_N aw ini 0 X X X X Trigger TRGx_NEG cC TRGx_LVL Playback steps: ⚫ Waveform library must be initialized before playback; ⚫ Set trigger playback registers (0x33 ~ 0x3A) as desired; ⚫ Send trigger pulse (≥1μs) on TRIG pins to playback waveform; ⚫ Device will be switched to STANDBY mode after haptic waveform playback finished. One wire Mode The function of one wire mode mainly transfer two information : sequence number and gain of waveform, TRIG1 is the interface pin. Playback steps: ⚫ Waveform library must be initialized before playback; ⚫ Set TRG_ONEWIRE to 1 in register 0x3A to enable one wire mode; ⚫ Set 0x3E = 0x58 to enable one wire the lowest priority of playback; www.awinic.com 19 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW86907 September 2021 V1.9 ⚫ Set 0x3C = 0x75, configure this register above this value in order to receive one wire protocol(about 2.5ms which is the minimum waiting time after chip wakeup,default value is 20μs); ⚫ Determine sequence number and gain of waveform which you want to playback; ⚫ Combine sequence number and gain data into a 15 bit transformation data(low 8 bit is gain, high 7 bit is sequence number) ,the data is sent from the lowest bit; us us 10~20us ms IDLE l Chip will automatically enter standby mode after playing. The interval time between two sending protocol data should be greater than “3ms+time length of waveform”. Start ... 45~55us Bit 14 Bit 1 Bit 0 tia ⚫ IDLE en Figure 21 One wire mode playback ms Cont Mode on fid The CONT mode mainly performs two functions: F0 detection and real-time resonance-frequency tracking. F0 detection can be launched by setting EN_F0_DET=1 and BRK_EN =1. When set TRACK_EN=1, real-time resonance-frequency tracking will be launched by tracking the BEMF of actuator constantly. It provides stronger and more consistent vibrations and lower power consumption. If the resonant frequency shifts for any reason, the function tracks the frequency from cycle to cycle. When TRACK_EN is set to 0, the width of waveform of cont mode is determined by DRV_WIDTH in register 0x1A. cC When the EDGE_FRE register is set to 4’b1xxx, the CONT mode outputs a filtered square wave. The edge of filtered square wave is composed of SIN or COS wave whose frequency can be configured by EDGE_FRE register. When SIN_MODE register is set to 1, filtered square wave is composed of COS wave. Playback steps: Set PLAY_MODE = 2 in register 0x08 to enable CONT mode ; ⚫ (optional)Set EN_F0_DET = 1 and BRK_EN =1 to enable F0 detection; ⚫ Set cont mode by configuring registers(0x18~0x20 and 0x22); ⚫ Set GO bit to 1 in register 0x09 to trigger waveform playback; ⚫ Delay 1ms; ⚫ If enable F0 detection, read until GLB_STATE=0. then get F0 information from registers(0x25~0x28). ⚫ Device will be switched to STANDBY mode after haptic waveform playback finished; aw ini ⚫ Tracking DRV1_LVL DRV2_LVL 1 2 3 4 1 DRV1_TIME = 4 2 3 4 5 DRV2_TIME = 5 Figure 22 Cont mode playback www.awinic.com 20 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW86907 September 2021 V1.9 Auto Brake Engine An auto-brake engine is integrated into this device. Users can adjust the brake strength by setting D2S_GAIN in register 0x49. The greater D2S_GAIN, the greater brake strength and the worse loop stability. Auto-brake engine is disabled when setting BRK_EN=0 or BRK_TIME=0. To enable Auto-brake engine, there are some points to note: TRGx_BRK in register 0x39,0x3A should be set to 1 when in TRIG mode; ⚫ Auto-brake engine will not work when BRK_EN=0 in register 0x08; ⚫ Auto-brake engine will not work when EN_F0_DET in register 0x18 is set to 1; ⚫ Auto-brake engine will not work when BRK_TIME in register 0x21 is set to 0; ⚫ Device will be switched to STANDBY mode after haptic waveform playback finished. en tia l ⚫ DRV_WIDTH fid PLAY WAVE BRAKE WAVE D2S_GAIN on BRAKE ENGINE Motor SENSOR DC-DC Converter cC Figure 23 Brake loop aw ini The device integrated peak current mode synchronous PWM Boost as H-bridge power stage supply, significantly increase the output voltage dynamic range. Reduces the size of external components and saves PCB space by using about 1.6 MHz switching frequency. Boost output voltage can be set through the I 2C register 0x06; The device synchronous Boost with soft-start function to prevent overshoot current at powering-on; integrated the output protection circuit and self-recovery function; integrated Anti-Ring circuit to reduce EMI in DCM mode; built-in substrate switching shutdown circuit, effectively preventing the input and output leakage current antiirrigation. Protection Mechanisms Over Voltage Protection (OVP) The boost circuit has integrated the over voltage protection control loop. When the output voltage PVDD is above the threshold, the boost circuits will stop working, until the voltage of PVDD going down and under the normal fixed working voltage. www.awinic.com 21 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW86907 September 2021 V1.9 Over Temperature Protection (OTP) The device has automatic temperature protection mechanism which prevents heat damage to the chip. It is triggered when the junction temperature is larger than the preset temperature high threshold (default = 160°C). When it happens, the output stages will be disabled. When the junction temperature drops below the preset temperature low threshold (less than 130°C), the output stages will start to operate normally again Over Current (Short) Protection (OCP) tia l The short circuit protection function is triggered when HDP/HDN is short too PVDD/GND or HDP is short to HDN, the output stages will be shut down to prevent damage to itself. When the fault condition is disappeared, the output stages of device will restart. en Vbat Under Voltage Lock Out Protection (UVLO) fid The device has a battery monitor that monitors the VBAT level to ensure that is above threshold 2.7V, In the event of a VBAT drop, the device immediately power down the Boost and H-bridge driver and latches the UVLO flag. Drive Data Error Protection (DDEP) on When haptic data sent to drive LRA is error such as: a DC data or almost DC data, it will cause the LRA heat to brake. The device configurable immediately power down the Boost and H-bridge driver and latched the DDEP flag. I2C Interface aw ini Device Address cC This device supports the I²C serial bus and data transmission protocol in fast mode at 400kHz and fast mode plus at 1000kHz. This device operates as a slave on the I²C bus. Connections to the bus are made via the open-drain I/O pins SCL and I pin SDA. The pull-up resistor can be selected in the range of 1k~10kΩ and the typical value is 4.7kΩ. This device can support different high level (1.8V~3.3V) of this I2C interface. The I2C device address (7-bit) can be set using the AD pin according to the following table: Table 3 Address Selection AD I2C address (7-bit) 0 0x5A 1 0x5B Data Validation When SCL is high level, SDA level must be constant. SDA can be changed only when SCL is low level. www.awinic.com 22 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW86907 September 2021 V1.9 SDA SCL Data Line Stable Data Valid Change of Data Allowed tia l Figure 24 Data Validation Diagram General I2C Operation SCL cC on fid en The I2C bus employs two signals, SDA (data) and SCL (clock), to communicate between integrated circuits in a system. The device is addressed by a unique 7-bit address; the same device can send and receive data. In addition, Communications equipment has distinguish master from slave device: In the communication process, only the master device can initiate a transfer and terminate data and generate a corresponding clock signal. The devices using the address access during transmission can be seen as a slave device. SDA and SCL connect to the power supply through the current source or pull-up resistor. SDA and SCL default is a high level. There is no limit on the number of bytes that can be transmitted between start and stop conditions. When the last word transfers, the master generates a stop condition to release the bus. START state: The SCL maintain a high level, SDA from high to low level STOP state: The SCL maintain a high level, SDA pulled low to high level Start and Stop states can be only generated by the master device. In addition, if the device does not produce STOP state after the data transmission is completed, instead re-generate a START state (Repeated START, Sr), and it is believed that this bus is still in the process of data transmission. Functionally, Sr state and START state is the same. As shown in Figure 25. START (S) aw ini SDA STOP (P) Figure 25 START and STOP state generation process In the data transmission process, when the clock line SCL maintains a high level, the data line SDA must remain the same. Only when the SCL maintain a low level, the data line SDA can be changed, as shown in Figure 26. Each transmission of information on the SDA is 9 bits as a unit. The first eight bits are the data to be transmitted, and the first one is the most significant bit (Most Significant Bit, MSB), the ninth bit is an confirmation bit (Acknowledge, ACK or A ), as shown in Figure 27. When the SDA transmits a low level in ninth clock pulse, it means the acknowledgment bit is 1, namely the current transmission of 8 bits data are confirmed, otherwise it means that the data transmission has not been confirmed. Any amount of data can be transferred between START and STOP state. www.awinic.com 23 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW86907 September 2021 V1.9 SCL SDA Data cable Remains the same: At this point the data is valid l Data transmission: In this case the data is invalid tia Figure 26 The data transfer rules on the I2C bus The whole process of actual data transmission is shown in Figure 27. When generating a START condition, en the master device sends an 8-bit data, including a 7-bit slave addresses (Slave Address), and followed by a "read / write" flag ( R/ W ). The flag is used to specify the direction of transmission of subsequent data. The master device will produce the STOP state to end the process after the data transmission is completed. However, if the master device intends to continue data transmission, you can directly send a Repeated START or repeated START (S or Sr) 1 2 8 9 1 2 8 on SCL fid START state, without the need to use the STOP state to end transmission. SDA MSB ACK MSB STOP or Repeated START (P or Sr) ACK cC R/W 9 Figure 27 Data transmission on the I2C bus Write Process aw ini Writing process refers to the master device write data into the slave device. In this process, the transfer direction of the data is always unchanged from the master device to the slave device. All acknowledge bits are transferred by the slave device, in particular, the device as the slave device, the transmission process in accordance with the following steps, as shown in Figure 28: Master device generates START state. The START state is produced by pulling the data line SDA to a low level when the clock SCL signal is a high level. Master device transmits the 7-bits device address of the slave device, followed by the "read / write" flag (flag = 0); The slave device asserts an acknowledgment bit (ACK) to confirm whether the device address is correct; The master device transmits the 8-bit register address to which the first data byte will written; The slave device asserts an acknowledgment (ACK) bit to confirm the register address is correct; Master sends 8 bits of data to register which needs to be written; The slave device asserts an acknowledgment bit (ACK) to confirm whether the data is sent successfully; If the master device needs to continue transmitting data by sending another pair of data bytes, just need to repeat the sequence from step 6. In the latter case, the targeted register address will have been autoincremented by the device. The master device generates the STOP state to end the data transmission. R/ W www.awinic.com 24 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW86907 September 2021 V1.9 (1) (2) START slave device address R/W (3) (4) A Register address (5) (7) (6r) (7r) A write data A write data A ‘0’(write) data transmission direction (6) (9) STOP Data Transmission: 8 + 1 bit data acknowledge bit (ACK) Register address auto increment - (8) From the master to the slave device From slave to master device tia l Figure 28 Writing process (data transmission direction remains the same) Read Process en Reading process refers to the slave device reading data back to the master device. In this process, the direction of data transmission will change. Before and after the change, the master device sends START state and slave address twice, and sends the opposite "read/write" flag. In particular, AW86907 as the slave device, the transmission process carried out by following steps listed in Figure 29: Master device asserts a start condition; on fid Master device transmits the 7 bits address of the device, and followed by a "read / write" flag ( R/ W = 0); The slave device asserts an acknowledgment bit (ACK) to confirm whether the device address is correct; The master device transmits the register address to make sure where the first data byte will read; The slave device asserts an acknowledgment (ACK) bit to confirm whether the register address is correct or not; The master device restarts the data transfer process by continuously generating STOP state and START state or a separate Repeated START; aw ini cC Master sends 7-bits address of the slave device and followed by a read / write flag (flag R/ W = 1) again; The slave device asserts an acknowledgment (ACK) bit to confirm whether the register address is correct or not; Master transmits 8 bits of data to register which needs to be read; The slave device sends an acknowledgment bit (ACK) to confirm whether the data is sent successfully; The device automatically increment register address once after sent each acknowledge bit (ACK), The master device generates the STOP state to end the data transmission. (1) (2) (3) (4) (5) (6) START slave device address R/W A Register address A Sr (7) ‘0’(write) data transmission direction From the master to the slave device From slave to master device (8) slave device address R/W (9) (10) (9r) (10r) A Read data A Read data A (12) STOP ‘1’(read) Data Transmission: 8 + 1 bit data acknowledge bit (ACK) Sr = repeated START or Send STOP state before sending START state Register address auto increment - (11) Figure 29 Reading process (data transmission direction remains the same) www.awinic.com 25 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW86907 September 2021 V1.9 Register Configuration Register List ADDR NAME R/W 0x00 SRST RO Bit7 Bit6 Bit5 0x01 SYSST RO UVLS 0x02 SYSINT RC 0x03 SYSINTM RW 0x06 PLAYCFG1 RW 0x07 PLAYCFG2 RW 0x08 PLAYCFG3 RW 0x09 PLAYCFG4 RW 0x0A WAVCFG1 RW SEQ1WAIT 0x0B WAVCFG2 RW SEQ2WAIT 0x0C WAVCFG3 RW SEQ3WAIT 0x0D WAVCFG4 RW SEQ4WAIT 0x0E WAVCFG5 RW SEQ5WAIT 0x0F WAVCFG6 RW SEQ6WAIT 0x10 WAVCFG7 RW SEQ7WAIT 0x11 WAVCFG8 RW SEQ8WAIT 0x12 WAVCFG9 RW SEQ1LOOP 0x13 WAVCFG10 RW SEQ3LOOP 0x14 WAVCFG11 RW SEQ5LOOP 0x15 WAVCFG12 RW SEQ7LOOP 0x16 WAVCFG13 RW WAITSLOT 0x18 CONTCFG1 RW EDGE_FRE 0x19 CONTCFG2 RW 0x1A CONTCFG3 RW 0x1C CONTCFG5 RW 0x1D CONTCFG6 RW 0x1E CONTCFG7 RW 0x1F CONTCFG8 RW 0x20 CONTCFG9 RW 0x21 CONTCFG10 RW 0x22 CONTCFG11 0x25 CONTRD14 0x26 CONTRD15 0x27 CONTRD16 0x28 CONTRD17 0x2D RTPCFG1 0x2E RTPCFG2 0x2F RTPCFG3 0x30 RTPCFG4 0x31 RTPCFG5 0x32 Bit4 Bit3 Bit2 Bit1 Bit0 FF_AES FF_AFS OCDS OTS DONES 0x10 UVLI FF_AEI FF_AFI OCDI OTI DONEI 0x10 UVLM FF_AEM FF_AFM OCDM OTM DONEM 0xFF BST_VOUT_RDA GAIN STOP_MODE tia BST_MODE AUTO_BST BRK_EN 0x80 PLAY_MODE STOP 0x44 GO 0x00 WAVSEQ3 0x00 WAVSEQ4 0x00 WAVSEQ5 0x00 WAVSEQ6 0x00 fid WAVSEQ2 WAVSEQ7 0x00 on WAVSEQ8 0x00 SEQ2LOOP 0x00 SEQ4LOOP 0x00 SEQ6LOOP 0x00 SEQ8LOOP 0x00 MAINLOOP EN_F0_DET 0x00 BRK_BST_MD SIN_MODE 0xD1 0x8D DRV_WIDTH cC 0x00 0x01 en WAVSEQ1 0x20 F_PRE 0x6A BST_BRK_GAIN TRACK_EN Default 0x04 l CHIP_ID BRK_GAIN 0x58 DRV1_LVL 0xFF DRV2_LVL 0x50 0x04 DRV2_TIME 0x06 BRK_TIME 0x08 RW TRACK_MARGIN 0x0C RO F_LRA_F0_H 0x00 RO F_LRA_F0_L 0x00 RO CONT_F0_H 0x00 RO CONT_F0_L aw ini DRV1_TIME RW RW RW 0x00 BASE_ADDR_H 0x08 BASE_ADDR_L 0x00 FIFO_AEH FIFO_AFH 0x26 RW FIFO_AEL 0x00 RW FIFO_AFL 0x00 RTPDATA RW RTP_DATA 0x00 0x33 TRGCFG1 RW TRG1_POS TRG1SEQ_P 0x01 0x34 TRGCFG2 RW TRG2_POS TRG2SEQ_P 0x01 0x35 TRGCFG3 RW TRG3_POS TRG3SEQ_P 0x01 0x36 TRGCFG4 RW TRG1_NEG TRG1SEQ_N 0x01 0x37 TRGCFG5 RW TRG2_NEG TRG2SEQ_N 0x01 0x38 TRGCFG6 RW TRG3_NEG TRG3SEQ_N 0x39 TRGCFG7 RW TRG1_POLAR TRG1_LEV TRG1_BRK TRG1_BST TRG2_POLAR TRG2_LEV TRG2_BRK TRG2_BST 0x33 0x3A TRGCFG8 RW TRG3_POLAR TRG3_LEV TRG3_BRK TRG3_BST TRG_ONEWIRE TRG1_STOP TRG2_STOP TRG3_STOP 0x30 0x3C GLBCFG2 RW 0x3E GLBCFG4 RW www.awinic.com 0x01 START_DLY GO_PRIO TRG3_PRIO 26 0x01 TRG2_PRIO TRG1_PRIO Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD 0x1B AW86907 September 2021 V1.9 0x3F GLBRD5 0x40 RAMADDRH RWS RO GLB_STATE 0x41 RAMADDRL RWS RAMADDRL 0x42 RAMDATA RWS RAMDATA 0x43 SYSCTRL1 RW 0x44 SYSCTRL2 RW 0x49 SYSCTRL7 RW 0x4A I2SCFG1 RW 0x4C PWMCFG1 RW PRC_EN PRCTIME 0xA0 0x4E PWMCFG3 RW PR_EN PRLVL 0xBF 0x4F PWMCFG4 RW 0x51 DETCFG1 RW 0x52 DETCFG2 RW 0x53 DET_RL RO RL 0x55 DET_VBAT RO VBAT 0x57 DET_LO RO VBAT_MODE GAIN_BYPASS l 0x32 CLK_ADC 0x02 VBAT_GO DIAG_GO 0x00 0x00 0x00 RL_LO 0x00 en VBAT_LO fid on Description All configuration registers will be reset to default value after 0xaa is written Not used 1: VBAT voltage is under UV voltage (2.7V) 0 1: RTP FIFO is almost empty 1: RTP FIFO is almost full 1: Over Current status 1: Over Temperature status 1: The indication of playback finished 1 0 0 0 0 4 3 2 1 0 FF_AES FF_AFS OCDS OTS DONES RO RO RO RO RO aw ini RO Description Default 0x04 R/W RO UVLS SYSINTM: (Address 03h) Bit Symbol 0x3A tia RL_OS 5 (Address 02h) Symbol Reserved UVLI FF_AEI FF_AFI OCDI OTI DONEI 0x04 I2SBCK PRTIME R/W RO 0x20 R/W RC RC RC RC RC RC RC Description Not used When UVLI=1, it means UVLS has been 1 at least once since the last read When FF_AEI=1, it means FF_AES has been 1 at least once since the last read When FF_AFI=1, it means FF_AFS has been 1 at least once since the last read When OCDI=1, it means OCDS has been 1 at least once since the last read When OTI=1, it means OTS has been 1 at least once since the last read When DONEI=1, it means DONES has been 1 at least once since the last read R/W Reserved RW 5 UVLM RW 4 FF_AEM RW Default 0 cC (Address 00h) Symbol CHIPID www.awinic.com 0x44 D2S_GAIN I2SFS SYSST: (Address 01h) Bit Symbol 7:6 Reserved 7:6 0x00 EN_FIR WAVDAT_MODE Note: Reserved register should not be written SYSINT: Bit 7:6 5 4 3 2 1 0 0x00 0x00 EN_RAMINIT Register Detailed Description SRST: Bit 7:0 0x00 RAMADDRH Description Default 0 0 1 0 0 0 0 Default Not used Interrupt mask for UVLI: 0: INTN pin will be pulled down when UVLI=1 1: INTN pin will not be pulled down when UVLI=1 Interrupt mask for FF_AEI: 0: INTN pin will be pulled down when FF_AEI=1 1: INTN pin will not be pulled down when FF_AEI=1 27 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD 3 1 1 AW86907 September 2021 V1.9 2 OCDM RW 1 OTM RW 0 DONEM RW BST_VOUT_RDA PLAYCFG2: (Address 07h) Bit Symbol 7:0 GAIN 5 4:3 2 1:0 R/W RW RW STOP_MODE RW Reserved BRK_EN RW RW PLAY_MODE PLAYCFG4: (Address 09h) Bit Symbol 7:2 Reserved 1 STOP 0 RW PVDD voltage setup: default=100000, ΔV=78.893mV VBAT should be smaller than 0.8*PVDD. 000000:6V 000001:6V+ΔV 000010:6V+ΔV*2 000011:6V+ΔV*3 …... 111111:6+ΔV*63 GO www.awinic.com 1 Default 0 0 0x20 Description gain setting for waveform data, it is a global setting for all waveform data(expect CONT).GAIN=code/128 Default Description Not used 1: disable boost when data is 0 in rtp 0 : stop when current wave is over 1: stop right now Not used when set 1, enable auto brake after RTP/RAM/CONT playback mode is stopped Default 0 1 aw ini PLAYCFG3: (Address 08h) Bit Symbol 7 Reserved 6 AUTO_BST BOOST mode 0:Bypass mode 1:boost mode RW 1 Description Not used RW R/W 1 fid 5:0 BST_MODE 1 on 6 R/W RW cC PLAYCFG1: (Address 06h) Bit Symbol 7 Reserved Interrupt mask for FF_AFI: 0: INTN pin will be pulled down when FF_AFI=1 1: INTN pin will not be pulled down when FF_AFI=1 Interrupt mask for OCDI: 0: INTN pin will be pulled down when OCDI=1 1: INTN pin will not be pulled down when OCDI=1 Interrupt mask for OTI: 0: INTN pin will be pulled down when OTI=1 1: INTN pin will not be pulled down when OTI=1 Interrupt mask for DONEI: 0: INTN pin will be pulled down when DONEI=1 1: INTN pin will not be pulled down when DONEI=1 l RW tia FF_AFM en 3 RW waveform play mode for GO trig b00: RAM mode b01: RTP mode b10: CONT mode b11: no play R/W RW RW Description Not used when set 1, stop the current playback mode RW RAM/RTP/CONT mode playback trig bit when set to 1, chip will playback one of the play mode. 28 0x80 0 0 1 0 Default 0 0 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD 0 AW86907 September 2021 V1.9 R/W RW RW Description when set to 1 , WAVSEQ1 means wait time, else means wave sequence number wait time (code*WAITSLOT) or wave sequence number Default 0 1 WAVCFG2: (Address 0Bh) Bit Symbol 7 SEQ2WAIT 6:0 WAVSEQ2 R/W RW RW Description when set to 1 , WAVSEQ2 means wait time, else means wave sequence number wait time (code*WAITSLOT) or wave sequence number Default 0 0 WAVCFG3: (Address 0Ch) Bit Symbol 7 SEQ3WAIT 6:0 WAVSEQ3 R/W RW RW Description when set to 1 , WAVSEQ3 means wait time, else means wave sequence number wait time (code*WAITSLOT) or wave sequence number WAVCFG4: (Address 0Dh) Bit Symbol 7 SEQ4WAIT 6:0 WAVSEQ4 R/W RW RW Description when set to 1 , WAVSEQ4 means wait time, else means wave sequence number wait time (code*WAITSLOT) or wave sequence number Default 0 0 WAVCFG5: (Address 0Eh) Bit Symbol 7 SEQ5WAIT 6:0 WAVSEQ5 R/W RW RW Description when set to 1 , WAVSEQ5 means wait time, else means wave sequence number wait time (code*WAITSLOT) or wave sequence number Default 0 0 WAVCFG6: (Address 0Fh) Bit Symbol 7 SEQ6WAIT 6:0 WAVSEQ6 R/W RW RW Description when set to 1 , WAVSEQ6 means wait time, else means wave sequence number wait time (code*WAITSLOT) or wave sequence number Default 0 0 WAVCFG7: (Address 10h) Bit Symbol 7 SEQ7WAIT 6:0 WAVSEQ7 R/W RW RW Description when set to 1 , WAVSEQ7 means wait time, else means wave sequence number wait time (code*WAITSLOT) or wave sequence number Default 0 0 WAVCFG8: (Address 11h) Bit Symbol 7 SEQ8WAIT 6:0 WAVSEQ8 R/W RW RW Description when set to 1 , WAVSEQ8 means wait time, else means wave sequence number wait time (code*WAITSLOT) or wave sequence number Default 0 0 WAVCFG9: (Address 12h) Bit Symbol R/W aw ini cC on fid en tia l WAVCFG1: (Address 0Ah) Bit Symbol 7 SEQ1WAIT 6:0 WAVSEQ1 Description 7:4 SEQ1LOOP RW control the loop number of the first sequence b0000~b1110: play (code+1) time b1111: playback infinitely until STOP set to 1 or SEQ1LOOP ≠0xF 3:0 SEQ2LOOP RW control the loop number of the second sequence b0000~b1110: play (code+1) time b1111: playback infinitely until STOP set to 1 or SEQ2LOOP ≠0xF www.awinic.com 29 Default 0 0 Default Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD 0 0 AW86907 September 2021 V1.9 WAVCFG10: (Address 13h) Bit Symbol R/W Description Default SEQ3LOOP RW control the loop number of the third sequence b0000~b1110: play (code+1) time b1111: playback infinitely until STOP set to 1 or SEQ3LOOP ≠0xF 0 3:0 SEQ4LOOP RW control the loop number of the fourth sequence b0000~1110: play n+1 time b1111: playback infinitely until STOP set to 1 or SEQ4LOOP ≠0xF 0 WAVCFG11: (Address 14h) Bit Symbol R/W Description l 7:4 Default SEQ5LOOP RW control the loop number of the fifth sequence b0000~b1110: play (code+1) time b1111: playback infinitely until STOP set to 1 or SEQ5LOOP ≠0xF 0 3:0 SEQ6LOOP RW control the loop number of the sixth sequence b0000~b1110: play (code+1) time b1111: playback infinitely until STOP set to 1 or SEQ6LOOP ≠0xF 0 WAVCFG12: (Address 15h) Bit Symbol R/W en tia 7:4 Default fid Description SEQ7LOOP RW control the loop number of the seventh sequence b0000~b1110: play (code+1) time b1111: playback infinitely until STOP set to 1 or SEQ7LOOP ≠0xF 0 3:0 SEQ8LOOP RW control the loop number of the eighth sequence b0000~b1110: play (code+1) time b1111: playback infinitely until STOP set to 1 or SEQ8LOOP ≠0xF 0 WAVCFG13: (Address 16h) Bit Symbol 7 Reserved R/W RW 4 Reserved RW cC WAITSLOT Description Not used Default 0 unit of wait time b00: (1/WAVDAT_MODE) s b01: (8/WAVDAT_MODE) s b10: (64/WAVDAT_MODE) s b11: (512/WAVDAT_MODE) s aw ini 6:5 on 7:4 0 RW Not used 0 MAINLOOP RW control the main loop number b0000~b1110: play (code+1) time b1111: playback infinitely until STOP set to 1 or MAINLOOP ≠0xF 0 CONTCFG1: (Address 18h) Bit Symbol R/W 3:0 7:4 EDGE_FRE www.awinic.com RW Description Default define the edge frequency b1000 : 200Hz b1001 : 300Hz b1010 : 400Hz b1011 : 500Hz b1100 : 600Hz b1101 : 700Hz b1110 : 800Hz b1111 : 900Hz b0XXX : no edge control 30 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD 13 AW86907 September 2021 V1.9 f0 detection mode enable 1: enable 0: disable 3 EN_F0_DET RW 2 Reserved RW 1 BRK_BST_MD RW 0 SIN_MODE RW edge mode 1: cos 0: sine CONTCFG2: (Address 19h) Bit Symbol 7:0 F_PRE R/W RW Description set the value of F0, F0=(24K/code)Hz CONTCFG3: (Address 1Ah) Bit Symbol R/W Description Half cycle drive time of brake and it is also the half cycle drive time of drive when TRACK_EN=0, this value must be smaller than half cycle time of F0. Time = code/48000 (s). R/W 6:0 DRV1_LVL CONTCFG7: (Address 1Eh) Bit Symbol 7 Reserved 6:0 0 RW RW tia l CONTCFG6: (Address 1Dh) Bit Symbol en R/W RW RW fid CONTCFG5: (Address 1Ch) Bit Symbol 7:4 BST_BRK_GAIN 3:0 BRK_GAIN Description gain factor of brake when BST_MODE is 1 gain factor of brake when BST_MODE is 0 track switch 1: enable 0: disable on RW TRACK_EN 0 1 Description cC DRV_WIDTH 7 Not used when set 1, brake is the same with current playback mode (boost or bypass) otherwise brake is bypass mode level for the first cont drive. When VBAT_MODE=1: no load output voltage= (3.05*DRV1_LVL/128)*(PVDD/VBAT); if (3.05*DRV1_LVL)/VBAT > 128, no load output voltage=PVDD; When VBAT_MODE=0: no load output voltage=PVDD*DRV1_LVL/128 aw ini 7:0 0 R/W RW Default 0x8D Default 0x6A Default 5 8 Default 1 0x7F Description Not used level for the second cont drive. When VBAT_MODE=1: no load output voltage= (3.05*DRV2_LVL/128)* (PVDD/VBAT); if (3.05*DRV2_LVL)/VBAT > 128, no load output voltage=PVDD; When VBAT_MODE=0: no load output voltage=PVDD*DRV2_LVL/128 Default 0 DRV2_LVL RW CONTCFG8: (Address 1Fh) Bit Symbol 7:0 DRV1_TIME R/W RW Description number of half cycle for the first cont drive Default 4 CONTCFG9: (Address 20h) Bit Symbol 7:0 DRV2_TIME R/W RW Description number of half cycle for the second cont drive. Default 6 www.awinic.com 31 0x50 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW86907 September 2021 V1.9 7:0 F_LRA_F0_H RO CONTRD15: (Address 26h) Bit Symbol R/W 7:0 F_LRA_F0_L RO CONTRD16: (Address 27h) Bit Symbol R/W 7:0 CONT_F0_H RO CONTRD17: (Address 28h) Bit Symbol R/W 7:0 CONT_F0_L RTPCFG1: (Address 2Dh) Bit Symbol 7:6 Reserved BASE_ADDR_H RTPCFG2: (Address 2Eh) Bit Symbol 7:0 R/W RW RW BASE_ADDR_L RTPCFG3: (Address 2Fh) Bit Symbol R/W RW R/W 7:4 FIFO_AEH RW 3:0 FIFO_AFH RW RTPCFG4: (Address 30h) Bit Symbol R/W 7:0 Description high 8 bit of the measure value for the f0 of LRA in the f0 detection mode F0=(384000/(F_LRA_F0_H*256+F_LRA_F0_L))Hz Description low 8 bit of the measure value for the f0 of LRA in the f0 detection mode F0=(384000/(F_LRA_F0_H*256+F_LRA_F0_L))Hz Description FIFO_AEL www.awinic.com RW 12 Default 0 Default 0 Default the measure value for the f0 of LRA in the continuous detection mode(high eight bits). F0=(384000/(CONT_F0_H*256+CONT_F0_L))Hz Description 0 Default the measure value for the f0 of LRA in the continuous detection mode(low eight bits). F0=(384000/(CONT_F0_H*256+CONT_F0_L))Hz Description Not used High six bits of start address of wave SRAM BASE_ADDR = BASE_ADDR_H * 256 + BASE_ADDR_L aw ini 5:0 RO l R/W tia CONTRD14: (Address 25h) Bit Symbol RW Default en TRACK_MARGIN Description margin value of tracking, the smaller margin, the higher tracking accuracy and the lower loop stability. Time = code/480000 (s) fid 7:0 Default 8 on CONTCFG11: (Address 22h) Bit Symbol R/W Description the num of half cycle of brake mode cC CONTCFG10: (Address 21h) Bit Symbol R/W 7:0 BRK_TIME RW 0 Default 0 0x08 Description Low eight bits of start address of wave SRAM BASE_ADDR = BASE_ADDR_H * 256 + BASE_ADDR_L Default Description High four bits of RTP FIFO almost empty threshold FIFO_AE = FIFO_AEH * 256 + FIFO_AEL High four bits of RTP FIFO almost full threshold FIFO_AF = FIFO_AFH * 256 + FIFO_AFL Default Description Low eight bits of RTP FIFO almost empty threshold FIFO_AE = FIFO_AEH * 256 + FIFO_AEL Default 32 0 0x02 0x06 0x00 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW86907 September 2021 V1.9 7:0 R/W FIFO_AFL RW RTPDATA: (Address 32h) Bit Symbol R/W RTP_DATA RW TRGCFG1: (Address 33h) Bit Symbol R/W Default Description RTP mode , data write entry, when data written into this register, the data will be written into RTP FIFO Default 0x00 0 l 7:0 Description Low eight bits of RTP FIFO almost full threshold FIFO_AF = FIFO_AFH * 256 + FIFO_AFL tia RTPCFG5: (Address 31h) Bit Symbol Description Default TRG1_POS RW trg1 rising edge enable/disable control 1: enable 0: disable 6:0 TRG1SEQ_P RW TRG1 posedge trigged wave sequence number 1 R/W Description trg2 rising edge enable/disable control 1: enable 0: disable TRG2 posedge trigged wave sequence number Default RW 6:0 TRG2SEQ_P RW TRGCFG3: (Address 35h) Bit Symbol R/W 7 TRG3_POS RW 6:0 TRG3SEQ_P RW TRGCFG4: (Address 36h) Bit Symbol TRG1_NEG 6:0 TRG1SEQ_N TRGCFG5: (Address 37h) Bit Symbol 0 1 Description trg3 rising edge enable/disable control 1: enable 0: disable TRG3 posedge trigged wave sequence number Default Description Default 0 1 trg1 falling edge enable/disable control 1: enable 0: disable 0 RW TRG1 negedge trigged wave sequence number 1 R/W Description RW aw ini 7 R/W 0 fid TRG2_POS on 7 cC TRGCFG2: (Address 34h) Bit Symbol en 7 Default 7 TRG2_NEG RW trg2 falling edge enable/disable control 1: enable 0: disable 0 6:0 TRG2SEQ_N RW TRG2 negedge trigged wave sequence number 1 R/W Description TRGCFG6: (Address 38h) Bit Symbol Default 7 TRG3_NEG RW trg3 falling edge enable/disable control 1: enable 0: disable 0 6:0 TRG3SEQ_N RW TRG3 negedge trigged wave sequence number 1 www.awinic.com 33 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW86907 September 2021 V1.9 TRG1_LEV RW 5 4 TRG1_BRK TRG1_BST RW RW 3 TRG2_POLAR RW 2 TRG2_LEV RW 1 0 TRG2_BRK TRG2_BST RW RW TRGCFG8: (Address 3Ah) Bit Symbol R/W 7 TRG3_POLAR RW 6 TRG3_LEV RW 5 4 3 2 1 0 TRG3_BRK TRG3_BST TRG_ONEWIRE TRG1_STOP TRG2_STOP TRG3_STOP RW RW RW RW RW RW R/W RW GLBCFG4: (Address 3Eh) Bit Symbol R/W 7:6 GO_PRIO RW 5:4 TRG3_PRIO RW 3:2 TRG2_PRIO RW 1:0 TRG1_PRIO RW www.awinic.com 0 when set 1, enable auto brake after TRG1 playback mode is stopped when set 1, enable boost in TRG1 playback mode. TRIG2 pin active polarity, when host supply positive level, this bit set to 0, else set to 1 TRG2 mode control 1: level 0: edge when set 1, enable auto brake after TRG2 playback mode is stopped when set 1, enable boost in TRG2 playback mode. 1 1 Description TRIG3 pin active polarity, when host supply positive level, this bit set to 0, else set to 1 TRG3 mode control 1: level 0: edge when set 1, enable auto brake after TRG3 playback mode is stopped when set 1, enable boost in TRG3 playback mode. when set 1,enable one wire mode. when set 1, TRG1 playback mode can be stopped immediately when set 1, TRG2 playback mode can be stopped immediately when set 1, TRG3 playback mode can be stopped immediately Default 1 1 0 0 0 0 Description Startup delay time, unit time is (1/48k)s. Default 0x01 aw ini GLBCFG2: (Address 3Ch) Bit Symbol 7:0 START_DLY TRG1 mode control 1: level 0: edge 0 l 6 0 tia RW en TRG1_POLAR Default 0 1 1 0 fid 7 Description TRIG1 pin active polarity, when host supply positive level, this bit set to 0, else set to 1 on R/W cC TRGCFG7: (Address 39h) Bit Symbol Description Priority value of GO TRIG High priority can interrupt the playback of low priority, and low priority cannot interrupt the playback of high priority. When the priority settings are consistent, the default priority will be implemented Priority value of TRIG3 pin High priority can interrupt the playback of low priority, and low priority cannot interrupt the playback of high priority. When the priority settings are consistent, the default priority will be implemented Priority value of TRIG2 pin High priority can interrupt the playback of low priority, and low priority cannot interrupt the playback of high priority. When the priority settings are consistent, the default priority will be implemented Priority value of TRIG1 pin High priority can interrupt the playback of low priority, and low priority cannot interrupt the playback of high priority. When the priority settings are consistent, the default priority will be implemented 34 0 Default Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD 0 1 2 3 AW86907 September 2021 V1.9 RO RAMADDRH: (Address 40h) Bit Symbol R/W 7:6 Reserved RWS 5:0 RAMADDRH RWS Default 0 0 l GLB_STATE Description Not used The state of glb state 0000: STANDBY 0110: CONT 0111: RAM 1000: RTP 1001: TRIG 1011: BRAKE tia 3:0 R/W RO Description Not used SRAM address high six bits en GLBRD5: (Address 3Fh) Bit Symbol 7:4 Reserved RAMADDRL: (Address 41h) Bit Symbol R/W 7:0 RAMADDRL RWS SRAM address low eight bits RAMDATA: (Address 42h) Bit Symbol 7:0 RAMDATA R/W RWS SRAM data entry SYSCTRL1: (Address 43h) Bit Symbol 7 VBAT_MODE 6 Reserved 5:4 Reserved R/W RW RW RW Description VBAT adjust mode, 0: software adjust mode, 1: hardware adjust mode Not used Not used RW EN_FIR Reserved RW RW SYSCTRL2: (Address 44h) Bit Symbol 7:6 Reserved 5:4 Reserved 3 Reserved 2 Reserved 1:0 WAVDAT_MODE SYSCTRL7: (Address 49h) Bit Symbol 7 Reserved 6 5:3 R/W RW RW RW RW RW R/W RW GAIN_BYPASS RW Reserved RW www.awinic.com fid on cC 2 1:0 EN_RAMINIT Description Default 0 Default 0 Default 0 1 0 Enable internal OSC clk After powerup, system should initial SRAM for preload effects, to do so, this bit must be set to 1 0 set enable of FIR filter Not used 1 0 aw ini 3 Description Default 0 0 Description Not used Not used Not used Not used Default 0 2 0 0 waveform data upsample rate selection: b00: 24KHz b01: 48KHz others: 12KHz rate Description Not used 1: gain can be changed when playing 0: gain can not be changed when playing Not used 35 0 Default 0 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD 0 0 AW86907 September 2021 V1.9 RW I2SCFG1: (Address 4Ah) Bit Symbol 7:6 reserved R/W RW 3:2 I2SBCK RW 1:0 reserved RW 7 PRC_EN 6:0 PRCTIME PWMCFG3: (Address 4Eh) Bit Symbol R/W RW RW 3 2 2 tia Description Set enable of output signal protection mode of pwm: 0: disable 1: When HDP/HDN output voltage ≥ 124/128*PVDD maintains (PRCTIME/3k)s, HDP/HDN is pulled down protectively set protection time of output signal protection mode of pwm, unit time is (1/3k) s. Default Default Default 0x32 7 PR_EN RW 6:0 PRLVL RW Description Set enable of input signal protection mode of pwm: 0: disable 1: When output voltage >= PRLVL/128*PVDD maintains (PRTIME/3k)s, HDP/HDN is pulled down protectively set protection voltage of input signal protection mode of pwm PWMCFG4: (Address 4Fh) Bit Symbol 7:0 PRTIME R/W RW Description set protection time of input signal protection mode of pwm, unit time is (1/3k) s. DETCFG1: (Address 51h) Bit Symbol 7:5 Reserved R/W RW aw ini R/W en RW Not used I2S data width selection BCK=(64*fs) (48*fs) (32*fs) 00: 16 bits 16 bits 16 bits 01: 20 bits 20 bits 16 bits 10: 24 bits 24 bits 16 bits 11: 32 bits 24 bits 16 bits I2S BCK mode 00: 32*fs(16*2) (RCK=1.536M/1.411M and 0x69 should be set to 0x8c) 01: 48*fs(24*2) (RCK=2.304M/2.1668M and 0x69 should be set to 0x5a) 10: 64*fs(32*2) (RCK=3.072M/2.8224M and 0x69 should be set to 0x48) 11: Reserved (RCK=32.768K and 0x69 should be set to 0xa1) Not used Default 0 fid I2SFS Description on 5:4 PWMCFG1: (Address 4Ch) Bit Symbol 4 l D2S_GAIN cC 2:0 Set D2S gain 000: 1 001: 2 010: 4 011: 8 100: 10 101: 16 110: 20 111: 26.7 Description Not used 1 0x20 1 0x3F Default 0 4 RL_OS RW Set diagnostic mode 1:RL 0:OS 0 3 Reserved RW Not used 0 www.awinic.com 36 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW86907 September 2021 V1.9 DET_RL: (Address 53h) Bit Symbol R/W RL RO DET_VBAT: (Address 55h) Bit Symbol 7:0 VBAT DET_LO: (Address 57h) Bit Symbol 7:6 Reserved Not used Set the enabled of VBAT mode Set the enabled of DIAG mode Description R/W RO R/W RO VBAT_LO RO 3:2 Reserved RO 1:0 RL_LO RO Default Description 0 Default the Measured value of VBAT in VBAT mode(high eight bits) VBAT=code*6.1/1024 (V) Not used Description 0 Default 0 the Measured value of VBAT in VBAT mode(low two bits) VBAT=code*6.1/1024 (V) 0 Not used 0 the Measured value of resistance of LRA in DIAG mode(low two bits) RL=code*678/(1024*d2s_gain) (Ω) 0 aw ini 5:4 Default 0 0 0 the Measured value of resistance of LRA in DIAG mode(high eight bits) RL=code*678/(1024*d2s_gain) (Ω) on 7:0 Description l R/W RW RW RW tia DETCFG2: (Address 52h) Bit Symbol 7:2 Reserved 1 VBAT_GO 0 DIAG_GO 2 en RW fid CLK_ADC cC 2:0 Set frequency of ADC clock 000: 12Mhz 001: 6Mhz 010: 3Mhz 011: 1.5Mhz 100: 0.75Mhz 101: 0.375Mhz 110: 0.1875Mhz 111: 0.09375Mhz Application Information Inductor Selection Guideline Selecting inductor needs to consider Inductance, size, magnetic shielding, saturation current and temperature current. a) Inductance Inductance value is limited by the boost converter's internal loop compensation. In order to ensure phase margin sufficient under all operating conditions, recommended 1μH inductor. b) Size For a certain value of inductor, the smaller the size, the greater the parasitic series resistance of the inductor DCR, the higher the loss, corresponds to the lower efficiency. c) Magnetic shielding Magnetic shielding can effectively prevent the inductance of the electromagnetic radiation interference. It is much better to choose inductance with magnetic shielding in the application of EMI sensitive environment. d) Saturation current and temperature rise of current www.awinic.com 37 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW86907 September 2021 V1.9 𝑅 8 = 2×𝑅𝐿 ×(1−2.3%) (8.5×8+0.3)2 2×8×0.977 tia 𝑃𝑂𝑈𝑇 = (𝑉𝑂𝑈𝑇 ×𝑅 +𝑅 𝐿 )2 𝐿 𝐷𝑆𝑂𝑁 l Inductor saturation current and temperature rise current value are important basis for selecting the inductor. As the inductor current increases, on the one hand, since the magnetic core begins to saturate, inductance value will decline; on the other hand, the inductor's parasitic resistance inductance and magnetic core loss can lead to temperature rise. In general, the current value is defined as the saturation current ISAT when the inductance value drops to 70%; the current value is defined as temperature rise current IRMS when inductance temperature rise 40oC. For particular applications, need to calculate the maximum IL_PEAK and IL_RMS, which is a basis of selecting the inductor. When VBAT=3.8V, PVDD=8.5V, RL = 8Ω,Output drive RDSON =300mΩ, when the maximum power without distortion, the output power is calculated as follows: 𝑤 = 4.294𝑤 en Where the coefficients in the denominator of (0.977) is the power ratio of no truncation maximum output. In such a large output power, the overall efficiency of the output drive is typically 75%, in order to calculate the maximum average current IMAX_AVG_VBAT and maximum peak current IMAX_PEAK_VBAT drawn from VBAT: 𝑃𝑂𝑈𝑇 4.294 𝐼𝑀𝐴𝑋_𝐴𝑉𝐺_𝑉𝐵𝐴𝑇 = = 𝐴 = 1.507𝐴 𝑉𝐵𝐴𝑇 × ղ 3.8 × 0.75 fid 𝐼𝑀𝐴𝑋_𝑃𝐸𝐴𝐾_𝑉𝐵𝐴𝑇 = 2 × 𝐼𝑀𝐴𝑋_𝐴𝑉𝐺_𝑉𝐵𝐴𝑇 = 2 × 1.507A = 3.014A If inductor DCR is 50mΩ, then when the output power of 4.294W, the inductor power loss is: 2 𝑃𝐷𝐶𝑅.𝐿𝑂𝑆𝑆 = 1.5 × 𝐼𝑀𝐴𝑋_𝐴𝑉𝐺_𝑉𝐵𝐴𝑇 × 𝐷𝐶𝑅 = 1.5 × 1.5072 × 0.05 𝑊 = 170.3 𝑚𝑊 𝑃𝐷𝐶𝑅.𝐿𝑂𝑆𝑆 2 1.5×𝐼𝑀𝐴𝑋_𝐴𝑉𝐺_𝑉𝐵𝐴𝑇 ≤ 0.01 × 𝑃𝑂𝑈𝑇 2 1.5×𝐼𝑀𝐴𝑋_𝐴𝑉𝐺_𝑉𝐵𝐴𝑇 ×ղ = 0.01×4.294 1.5×1.5072×0.75 𝛺 = 16.8 𝑚𝛺 cC 𝐷𝐶𝑅 = on Wherein the coefficient 1.5 is the square of the ratio of the sine wave current RMS value and average value (there is no consideration of the impact of the inductor ripple, the actual DCR loss will be even greater). If the loss which is resulting from DCR is less than 1% at efficiency (POUT = 4.294W, η = 75%), then: According to the working principle of the Boost, we can calculate the size of the inductor current ripple ΔIL: △ 𝐼𝐿 = 𝑉𝐵𝐴𝑇×(𝑃𝑉𝐷𝐷−𝑉𝐵𝐴𝑇) 𝑃𝑉𝐷𝐷×𝑓×𝐿 = 3.8×(8.5−3.8) 8.5×1.6×1 𝐴 = 1.31𝐴 Thus, the maximum peak inductor current IL_PEAK and maximum effective inductor current IL_RMS is: △𝐼𝐿 = 3.014 + aw ini 𝐼𝐿_𝑃𝐸𝐴𝐾 = 𝐼𝑀𝐴𝑋_𝑃𝐸𝐴𝐾_𝑉𝐵𝐴𝑇 + 2 𝐼𝐿_𝑅𝑀𝑆 = √𝐼𝑀𝐴𝑋_𝑃𝐸𝐴𝐾_𝑉𝐵𝐴𝑇 + 2 1.31 2 𝐴 = 3.669𝐴 △ 𝐼𝐿2 1.312 = √3.0142 + 𝐴 = 3.038𝐴 12 12 From the above calculation results: 1) For typical DCR about 50mΩ inductance, the efficiency loss caused by around 3%; 2) Need to choose AW86927G inductance input current limit value I LIMIT is greater than IL_PEAK = 3.714A (< ILIMIT = 4.2A), to guarantee the output drive power can be achieved when THD = 1% (= 4.1W) but not limited by value ILIMIT; If you choose ISAT or IRMS of the inductance is too small, it is possible to cause the chip don’t work properly, or the temperature of the inductance is too high. 3) In practice, the maximum output power of the drive is likely to reach 4.3W in an instant, so the selected inductor saturation current ISAT requires more than the maximum inductor peak current IL_PEAK, and cannot be less than 3.6A; 4) In some cases, if the IL_PEAK calculated according to the above method is greater than the set of input inductor current limit value ILIMIT, shows the output drive is restricted by inductance input current limit, the actual maximum output power is less than the calculated value, the measured value shall prevail, and I SAT need greater than the set current limiting value ILIMIT, and cannot be less than 3.6A; 5) Take PVDD = 8.5V for example, under different conditions, the typical method of selecting I SAT in the following table: www.awinic.com 38 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW86907 September 2021 V1.9 VBAT PVDD RL IL_PEAK (V) (V) (Ω) (A) Inductor saturation current ISAT minimum value (A) 3.8 8.5 8 3.7 4.2 3.8 8.5 16 2.3 2.5 tia l Capacitors Selection Boost Capacitor Selection aw ini cC on fid en Boost output capacitor is usually within the range 0.1μF~47μF. It needs to use Class II type (EIA) multilayer ceramic capacitors (MLCC). Its internal dielectric is ferroelectric material (typically BaTiO3), a high the dielectric constant in order to achieve smaller size, but at the same Class II type (EIA) multilayer ceramic capacitors has poor temperature stability and voltage stability as compared to the Class I type (EIA) capacitance. Capacitor is selected based on the requirements of temperature stability and voltage stability, considering the capacitance material, capacitor voltage, and capacitor size and capacitance values. A) temperature stability Class II capacitance have different temperature stability in different materials, usually choose X5R type in order to ensure enough temperature stability, and X7R type capacitance has better properties, the price is relatively more expensive; X5R capacitance change within ± 15% in temperature range of -55°C to 85°C, X7R capacitance change within ±15% in temperature range of -55°C~125°C. The Boost output capacitance of AW86907 recommends X5R ceramic capacitors. B) Voltage Stability Class II type capacitor has poor voltage stability Capacitance values falling fast along with the DC bias voltage applied across the capacitor increasing. The rate of decline is related to capacitance material, capacitors rated voltage, capacitance volume. Take for TDK C series X5R for example, its pressure voltage value is 16V or 25V; the package size is 0805, 1206 or 0603, the capacitance value is 10μF. The capacitor’s voltage stability of different types of capacitor is as shown below: www.awinic.com 39 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW86907 September 2021 V1.9 Capacitor Variation v.s. DC Voltage 10 0603,X5R,16V,10uF,0.80mm 0603,X5R,25V,10uF,0.80mm 0805,X5R,16V,10uF,0.85mm 0805,X5R,16V,10uF,1.25mm 0805,X5R,25V,10uF,0.85mm 0805,X5R,25V,10uF,1.25mm 1206,X5R,16V,10uF,0.85mm 1206,X5R,16V,10uF,1.60mm 1206,X5R,25V,10uF,0.85mm 1206,X5R,25V,10uF,1.60mm 0 -10 C-Change (%) -20 -30 l -40 tia -50 -60 en -70 -80 -90 0 5 10 15 fid -100 20 25 VDC (V) on Figure 30 Different types of capacitive voltage stability Among them, the space remaining value of different types of capacitors at VDC = 8.5 V as shown in the Figure 31: cC Cap@VDC=8.5V 9 7.68uF 6.47uF 6.35uF VDC=8.5V aw ini 2.84uF 2.70uF 1206,X5R,25V,10uF,1.60mm 1206,X5R,25V,10uF,0.85mm 1206,X5R,16V,10uF,1.60mm 1206,X5R,16V,10uF,0.85mm 0805,X5R,25V,10uF,1.25mm 0805,X5R,25V,10uF,0.85mm 0805,X5R,16V,10uF,1.25mm 0805,X5R,16V,10uF,0.85mm 0603,X5R,25V,10uF,0.80mm 0603,X5R,16V,10uF,0.80mm 2.34uF 2.20uF 1.93uF 1.74uF 1.72uF 8 0 1 2 3 4 5 C (uF) 6 7 8 9 10 Figure 31 The space remaining value of different types of capacitors at VDC = 8.5 V It can be found that the rate of capacitance capacity value descent becomes slow along with "large capacitor size, capacitance pressure voltage rise”. The larger the package size, the better voltage stability. The higher the height, the better voltage stability with the same length and width of the capacitance. Voltage stability of smaller package size (0603) capacitor change affected by the pressure value is very small. www.awinic.com 40 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW86907 September 2021 V1.9 In AW86907 typical applications, it is necessary to ensure the output value of the Boost capacitor ≥ 5μF when PVDD=8.5V. Supply Decoupling Capacitor(CS) tia l The device is a high voltage driver that requires adequate power supply decoupling. Place a low equivalentseries-resistance (ESR) ceramic capacitor, typically 0.1μF. This choice of capacitor and placement helps with higher frequency transients, spikes, or digital hash on the line. Additionally, placing this decoupling capacitor close to the device is important, as any parasitic resistance or inductance between the device and the capacitor causes efficiency loss. In addition to the 0.1μF ceramic capacitor, place a 10μF capacitor on the VBAT supply trace. This larger capacitor acts as a charge reservoir, providing energy faster than the board supply, thus helping to prevent any droop in the supply voltage. Output beads, capacitors Wavefo rm After PCB tra ce s Wavefo rm afte r bea ds fid Wavefo rm from chip en The device output is a square wave signal, which causing switch current at the output capacitor, increasing static power consumption, and therefore output capacitor should not be too large, 0.1nF ceramic capacitors is recommended. PCB tra ce s PCB tra ce s cC HDN on Bead HDP 0.1nF LRA Bead 0.1nF Figure 32 Ferrite Chip Bead and capacitor aw ini The device output is a square wave signal. The voltage across the capacitor will be much larger than the PVDD voltage after increasing the bead capacitor. It suggested the use of rated voltage above 16V capacitor. At the same time a square wave signal at the output capacitor switching current form, the static power consumption increases, so the output capacitance should not be too much which is recommended 0.1nF ceramic capacitor rated voltage of 16V. www.awinic.com 41 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW86907 September 2021 V1.9 PCB Layout Consideration Layout Considerations aw ini cC on fid en tia l This device is a high voltage driver chip. To obtain the optimal performance, PCB layout should be considered carefully. The suggested Layout is illustrated in the following diagram: Figure 33 AW86927G Board Layout Here are some guidelines: 1. All of the external components should be placed as close as possible to IC in top layer PCB. 2. SCL and SDA should be shield by ground. 3. The overcurrent capability of the VBAT to SW must be meet IMAX_AVG_VBAT(Take the measured data as an example: VBAT=3.4V, PVDD=9V, RL = 8Ω, the routing overcurrent capacity should be greater than 2.6A), and C2, C3, C4 should be placed close to IC and L1. 4. C6 and C7 are within 1.5mm to pin PVDD or pin VBST, and the overcurrent capability of the VBST and 𝑃𝑉𝐷𝐷 PVDD traces must be meet , and the GND side of the PVDD capacitor should be directly 𝑅𝐿 +𝑅𝐷𝑆𝑂𝑁 connected to surface layer ground or punched to the main ground of the PCB. In addition, create solid GND plane near and around the IC, connect BGND, PGND and GND together, and the overcurrent capability of the vias should be designed according to the PVDD overcurrent capability. 5. Routing overcurrent capability of HDP/HDN output to the load should meet 𝑃𝑉𝐷𝐷 𝑅𝐿 +𝑅𝐷𝑆𝑂𝑁 . HDP and HDN should be shield by ground and far away from the interference source especially the FLY capacitor of the high-power charging IC, otherwise it will cause the abnormal F0 detection. www.awinic.com 42 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW86907 September 2021 V1.9 Tape And Reel Information TAPE DIMENSIONS REEL DIMENSIONS P1 P0 P2 K0 D1 A0 en Cavity B0 tia l W fid A0:Dimension designed to accommodate the component width B0:Dimension designed to accommodate the component length K0:Dimension designed to accommodate the component thickness W:Overall width of the carrier tape P0:Pitch between successive cavity centers and sprocket hole P1:Pitch between successive cavity centers P2:Pitch between sprocket hole D1:Reel Diameter D0:Reel Width on D0 QUADRANT ASSIGNMENTS FOR PIN 1 ORIENTATION IN TAPE cC Pin 1 Q1 Q2 Q1 Q2 Q1 Q2 Q1 Q2 Q3 Q4 Q3 Q4 Q3 Q4 Q3 Q4 Sprocket Holes User Direction of Feed aw ini Pocket Quadrants www.awinic.com 43 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW86907 September 2021 V1.9 Package Description l 3.00±0.05 en tia 2.00±0.05 Top View fid PIN1 Corner 0.152 Ref on 0.55±0.05 0.00~0.05 cC Side View 16x0.40 20x0.2 1 aw ini 6 0.25±0.05 7 20 SYMM 17 11x(0.3±0.05) 10 8x(0.45±0.05) 11 16 SYMM Bottom View Unit:mm www.awinic.com 44 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW86907 September 2021 V1.9 Land Pattern Data 2.20 0.40 TYP 20 17 8X 0.1 0 R EF 8X 0.1 0 R EF 16 tia l 1 0.40 TYP 20X 0.20 SYMM ℄ en 3.20 6 fid 8X 0.55 11 12X 0.40 on 7 10 SYMM 0.05 MAX All AROUND cC ℄ SOLDER MASK OPENING aw ini METAL NO N-SOLDER MASK DEFINED www.awinic.com 45 0.05 MIN All AROUND SOLDER MASK OPENING METAL UNDER SOLDER MASK SOLDER MASK DEFINED Unit:mm Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW86907 September 2021 V1.9 Revision History January 2021 V1.5 March 2021 V1.6 March 2021 V1.7 April 2021 V1.8 May 2021 V1.9 September 2021 Delete the maximum output current Add playback of one wire mode Modify power on and power down sequence Add IQ vs VBAT and delete LRA res vs temp Add BST_BRK_GAIN register Modify TRIG1/2/3 and INTN PIN description Revise RL calculation formula Add I2SCFG1 register Add one wire playback steps Add GAIN_BYPASS register Add auto-brake restriction Revise PIN RCK description Revise PCB Layout Consideration Revise PIN description Revise playback mode description Add RL and VBAT detection steps Revise register description Add BRK_BST_MD and START_DLY register Modify PCB Layout Consideration Revise Inductor Selection Guideline aw ini cC V1.4 Revise the description of OVP l V1.3 Modify the description of address 0x44 in register list and quiescent current tia V1.2 Official Version en V1.1 May 2020 July 2020 July 2020 August 2020 Change Record fid V1.0 Date on Version www.awinic.com 46 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW86907 September 2021 V1.9 Disclaimer Information in this document is believed to be accurate and reliable. However, Shanghai AWINIC Technology Co., Ltd (AWINIC Technology) does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. tia l AWINIC Technology reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. Customers shall obtain the latest relevant information before placing orders and shall verify that such information is current and complete. This document supersedes and replaces all information supplied prior to the publication hereof. en AWINIC Technology products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an AWINIC Technology product can reasonably be expected to result in personal injury, death or severe property or environmental damage. AWINIC Technology accepts no liability for inclusion and/or use of AWINIC Technology products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. on fid Applications that are described herein for any of these products are for illustrative purposes only. AWINIC Technology makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. All products are sold subject to the general terms and conditions of commercial sale supplied at the time of order acknowledgement. cC Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Reproduction of AWINIC information in AWINIC data books or data sheets is permissible only if reproduction is without alteration and is accompanied by all associated warranties, conditions, limitations, and notices. AWINIC is not responsible or liable for such altered documentation. Information of third parties may be subject to additional restrictions. aw ini Resale of AWINIC components or services with statements different from or beyond the parameters stated by AWINIC for that component or service voids all express and any implied warranties for the associated AWINIC component or service and is an unfair and deceptive business practice. AWINIC is not responsible or liable for any such statements. www.awinic.com 47 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD
AW86907FCR 价格&库存
很抱歉,暂时无法提供与“AW86907FCR”相匹配的价格&库存,您可以联系我们找货
