AW32710CSR
AW32710CSR
    AWINIC(艾为)
    WLCSP12B_1.57X1.17MM
    具备浪涌保护功能的过压保护负载开关
AW32710CSR 数据手册
AW32705/AW32710 Oct. 2018 V1.0 Over-Voltage Protection Load Switch with Surge Protection GENERAL DESCRIPTION  The AW327XX family OVP load switch features surge protection, an internal clamp circuit protects the device from surge voltages up to 100V.      ti a n n This device features over-temperature protection that prevents itself from thermal damaging. o Smartphones Tablets Charging Ports The AW327XX is available in a RoHS compliant WLCSP 1.17×1.57-12B package. C  The device features an open-drain output ACOK, when VIN_UVLO < VIN < VIN_OVLO and the switch is on, ACOK will be driven low to indicate a good power input, otherwise it is high impedance. APPLICATIONS   The default OVP threshold is 6.8V (AW32705) and 10.5V (AW32710), the OVP threshold can be adjusted from 4V to 20V through external OVLO pin. e   The AW327XX features an ultra-low 24mΩ (typ.) Rdson nFET load switch. When input voltage exceeds the OVP threshold, the switch is turned off very fast to prevent damage to the protected downstream devices. The IN pin is capable of withstanding fault voltages up to 35VDC. fi d    Surge protection  IEC 61000-4-5: > 100V Integrated low Rdson nFET switch: typical 24mΩ 5A continuous current capability Default Over-Voltage Protection (OVP) threshold  AW32705: 6.8V  AW32710: 10.5V OVP threshold adjustable range: 4V to 20V Input system ESD protection  IEC 61000-4-2 Contact discharge: ±8kV  IEC 61000-4-2 Air gap discharge: ±15kV Input maximum voltage rating: 35VDC Fast turn-off response: typical 50ns Over-Temperature Protection (OTP) Under-Voltage Lockout (UVLO) WLCSP 1.17×1.57-12B package l FEATURES ic TYPICAL APPLICATION CIRCUIT USB Port CIN 0.1µF 50V in TVS a w Optional Optional R1 Charger/ PMIC OUT IN VIO AW32705 OVLO AW32710 R2 COUT 1µF Battery 10kΩ ACOK Controller EN GND Figure 1 AW327XX typical application circuit R1 and R2 are used for OVP threshold adjustment, to use default OVP threshold, connect OVLO to ground. All the trademarks mentioned in the document are the property of their owners. www.awinic.com.cn 1 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32705/AW32710 Oct. 2018 V1.0 DEVICE COMPARISON TABLE VIN_OVLO (V) Min. Typ. Max. VIN_OVLO hysteresis (mV) AW32705 VIN rising 6.66 6.80 6.94 140 AW32710 VIN rising 10.29 10.50 10.71 210 ti a l Condition Device PIN CONFIGURATION AND TOP MARK AW327XXCSR Marking (Top View) 4 A EN OUT OUT GND B ACOK OUT IN GND C OVLO IN IN GND 2 1 3 4 e 3 XX YY A fi d 2 B C n 1 n AW327XXCSR (Top View) C o XX – LT: AW32705CSR, TX: AW32710CSR YY – Production Tracing Code Figure 2 Pin Configuration and Top Mark Pin A1 ic PIN DEFINITION Name EN Description Enable pin, active low ACOK Power good flag, active-low, open-drain C1 OVLO OVP threshold adjustment pin C2, C3, B3 IN w in B1 Switch input and device power supply OUT Switch output A4, B4, C4 GND Device ground a A2, A3, B2 www.awinic.com.cn 2 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32705/AW32710 Oct. 2018 V1.0 FUNCTIONAL BLOCK DIAGRAM OUT Clamp Detect Gate Driver & Charge pump Logic Control ACOK e OV comp n VIN Divider Selection OVLO ti a l IN UV&OT comp Oscillator EN GND fi d Bandgap & Ibias a w in ic C o n Figure 3 Functional Block Diagram www.awinic.com.cn 3 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32705/AW32710 Oct. 2018 V1.0 TYPICAL APPLICATION CIRCUITS CIN 0.1µF 50V VIO AW32705 OVLO AW32710 10kΩ Controller ACOK Optional EN n GND USB Port OUT IN TVS CIN 0.1µF 50V R1 AW32705 OVLO AW32710 R2 VIO COUT 1µF Battery 10kΩ ACOK EN Charger/ PMIC Controller n Optional e AW327XX typical application circuit(using default OVP threshold) fi d Figure 4 Battery COUT 1µF l TVS Charger/ PMIC OUT IN ti a USB Port o GND C Figure 5 AW327XX typical application circuit(using external resistors set OVP threshold) Notice for Typical Application Circuits: ic 1. If VBUS is required to pass surge voltage greater than 100V, external TVS is needed, the maximum clamping voltage of the TVS should be below 37V. 2. When the default OVP threshold is used, connect OVLO pin to GND directly or through a 0Ω resistor. OVLO pin cannot be left floating. in 3. If R1 and R2 are used to adjust the OVP threshold, it is better to use 1% precision resistors to improve the OVP threshold precision. w 4. If ACOK is not used, it can be left floating, or short to GND. a 5. CIN = 0.1μF is recommended for typical application, larger CIN is also acceptable. The rated voltage of CIN should be larger than the TVS maximum clamping voltage, if no TVS is applied and only AW327XX is used, the rated voltage of CIN should be 50V. 6. COUT = 1μF is recommended for typical application, larger COUT is also acceptable. The rated voltage of COUT should be larger than the OVP threshold. For example, if the OVP threshold is 6.8V, the rated voltage of COUT should be 10V or higher. www.awinic.com.cn 4 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32705/AW32710 Oct. 2018 V1.0 ORDERING INFORMATION -40°C~85°C WLCSP 1.17mm×1.57mm12B ABSOLUTE MAXIMUM RATINGS (NOTE 1) Condition Input voltage VOUT Output voltage VOVLO OVLO voltage VACOK ACOK voltage MSL1 n VIN Parameter TX MSL1 o Symbol LT Delivery Form ROHS+HF 3000 units/ Tape and Reel ROHS+HF 3000 units/ Tape and Reel l -40°C~85°C WLCSP 1.17mm×1.57mm12B Environmental Information ti a Marking n AW32710CSR Package e AW32705CSR Temperature fi d Part Number Moisture Sensitivity Level Min. Max. Unit -0.3 35 V -0.3 See(NOTE 2) V -0.3 6 V -0.3 6 V -0.3 6 V EN voltage ISW Continuous current of switch IN-OUT(NOTE 3) Continuous current on IN and OUT pin 5 A IPEAK Peak current Peak input and output current on IN and OUT pin(10ms) 8 A IDIODE Continuous diode current Continuous forward current through the nFET body diode 1.5 A ic C VEN Ambient temperature -40 85 °C TJ Junction temperature -40 150 °C TSTG Storage temperature -65 150 °C TLEAD Soldering temperature At leads, 10 seconds 260 °C Input surge protection IEC61000-4-5 test with 2Ω equivalent series resistance w in TA Surge 100 V a NOTE1: Conditions out of those ranges listed in “absolute maximum ratings” may cause permanent damages to the device. In spite of the limits above, functional operation conditions of the device should within the ranges listed in “recommended operating conditions”. Exposure to absolute-maximum-rated conditions for prolonged periods may affect device reliability. NOTE2: 29V or VIN+0.3V, whichever is smaller. NOTE3: Limited by thermal design. www.awinic.com.cn 5 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32705/AW32710 Oct. 2018 V1.0 THERMAL INFORMATION Symbol RJA Parameter Condition Value Unit Thermal resistance from junction to ambient (NOTE 1) In free air 90 °C/W ti a ESD AND LATCH-UP RATINGS ILatch-up Value Unit IEC61000-4-2 system ESD on IN pin Contact discharge ±8 kV ±15 kV Human Body Model ANSI/ESDA/JEDEC JS-001 ±2 kV Charged Device Model JESD22-C101 ±1.5 kV Machine Model JESD22-A115C ±200 V Latch-up JEDEC78 ±200 mA n Condition Air gap discharge e VESD Parameter fi d Symbol l NOTE1: Thermal resistance from junction to ambient is highly dependent on PCB layout. VIN Input DC voltage CIN Input capacitance Output load capacitance Min. Typ. 3 Max. Unit 30 V 0.1 μF 1 μF a w in ic COUT o Parameter C Symbol n RECOMMENDED OPERATING CONDITIONS www.awinic.com.cn 6 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32705/AW32710 Oct. 2018 V1.0 ELECTRICAL CHARACTERISTICS TA = -40°C to 85°C unless otherwise noted. Typical values are guaranteed for VIN = 5V, CIN = 0.1μF, IIN≤ 5A and TA = 25°C. Symbol Description Test Conditions VIN_CLAMP Input clamp voltage IIN = 10mA Rdson Switch on resistance VIN = 5V, IOUT = 1A, TA = 25°C 24 35 mΩ Input quiescent current VIN = 5V, VOVLO=0V,IOUT = 0A 70 140 μA IIN_OVLO Input current at overvoltage condition VIN = 5V, VOVLO=3V,VOUT = 0V 67 130 μA VOVLO_TH OVLO set threshold 1.24 V 20 V 0.33 V OVP threshold adjustable range VOVLO_SEL External OVLO select threshold 1.20 4 OVLO pin leakage current OVLO rising Hysteresis 0.19 n VOVLO=VOVLO_TH o Protection Max. VIN rising Units l V ti a n 1.16 e VOVLO_RNG IOVLO Typ. 36.3 fi d IQ Min. 0.26 0.06 -0.2 6.66 V 0.2 6.80 μA 6.94 VIN_OVLO OVP trip level C AW32705 Hysteresis 0.14 V VIN rising 10.29 10.50 10.71 w TSDN a TSDN_HYS RDCHG Hysteresis 0.21 VIN rising 2.9 Hysteresis 0.1 UVLO trip level in VIN_UVLO ic AW32710 3.0 V Shutdown temperature 150 °C Shutdown temperature hysteresis 20 °C 50 Ω Output discharge resistance www.awinic.com.cn VOUT=7V,VOVLO=3V 7 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32705/AW32710 Oct. 2018 V1.0 ELECTRICAL CHARACTERISTICS (CONTINUED) TA = -40°C to 85°C unless otherwise noted. Typical values are guaranteed for V IN = 5V, CIN = 0.1μF, IIN≤ 5A and TA = 25°C. Symbol Description Test Conditions Min. Typ. Max. ISINK=1mA ILEAK_ACOK ACOK leakage current VIO=5V, ACOK de-asserted VIH EN input high voltage VIL EN input low voltage ILEAK_EN EN leakage current -0.5 e 1.2 n ACOK output low voltage VEN = 5V 0 fi d VOL ti a l Digital Logical Interface Units Timing Characteristics (Figure 6) 0.4 V 0.5 μA V 0.5 V 2 μA From VIN > VIN_UVLO to 10% VOUT 15 ms Start-up time From VIN > VIN_UVLO to ACOK low 30 ms tON Switch turn-on time RL = 100Ω, CL = 22μF, VOUT from 10% VIN to 90% VIN 2 ms tOFF Switch turn-off time CL = 0μF, RL = 100Ω, VIN > VIN_OVLO to VOUT stop rising, VIN rise at 10V/μs 50 ns o C tSTART n Debounce time tDEB in ic TIMING DIAGRAM a w VIN OVP trip level tDEB tDEB VOUT tON tON tOFF VEN VACOK tSTART tSTART Figure 6 Timing diagram www.awinic.com.cn 8 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32705/AW32710 Oct. 2018 V1.0 TYPICAL CHARACTERISTICS 30.0 28.0 27.5 25.0 24.0 ti a 26.0 l 30.0 Rdson(mΩ) 22.5 20.0 22.0 17.5 15.0 20.0 1 2 3 4 5 -40 Output Current(A) 60 85 fi d n Input Supply Current (A) 350 28.0 26.0 20.0 0 4 8 C o 24.0 22.0 12 16 300 -40℃ 250 25℃ 200 85℃ 150 100 50 0 20 0 5 10 Input Voltage(V) ic OVLO Set Threshold Voltage(V) w 1.02 1.00 0.98 0.96 -15 10 35 Temperature (°C) 60 85 30 35 1.220 1.200 1.180 1.160 -40 Figure 11 Normalized Internal OVP Threshold vs. Temp. www.awinic.com.cn 25 1.240 Normalized to TA = 25° C -40 20 Figure 10 Input Supply Current vs. Supply Voltage in 1.04 15 Input Voltage (V) Figure 9 Rdson vs. Input Voltage (IOUT = 1A) Normalized Threshold Voltage 35 Figure 8 Rdson vs. Temp. (IOUT = 1A) 30.0 a 10 Temperature(℃) Figure 7 Rdson vs. Output Current Rdson(mΩ) -15 e 0 n Rdson(mΩ) VIN = 5V, VEN = 0V, VOVLO = 0V, CIN = 0.1μF, COUT = 1μF, and TA = 25°C unless otherwise specified. 9 -15 10 35 Temperature (°C) 60 85 Figure 12 OVLO set threshold vs. Temp. Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32705/AW32710 Oct. 2018 V1.0 TYPICAL CHARACTERISTICS (CONTINUED) VIN = 5V, VEN = 0V, VOVLO = 0V, CIN = 0.1μF, COUT = 1μF, and TA = 25°C unless otherwise specified. VIN 5V / div VIN 5V / div C1 C1 ACOK 2V / div C3 IOUT 100mA / div C4 ti a ACOK 2V / div C3 VOUT 5V / div C2 C4 n C2 l VOUT 5V / div 20ms / div IOUT 500mA / div e 20ms / div Figure 14 Power-up (COUT = 100μF, 100mA load) VIN 5V / div n C1 fi d Figure 13 Power-up (COUT = 1μF, 100mA load). o VOUT 5V / div C2 C ACOK 2V / div C3 ic 1ms / div a w in Figure 15 OVP Response (AW32705) www.awinic.com.cn 10 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32705/AW32710 Oct. 2018 V1.0 DETAILED FUNCTIONAL DESCRIPTION Device Operation If the AW327XX is enabled and the input voltage is between UVLO and OVP threshold, the internal charge pump begins to work after debounce time, the gate of the nFET switch will be slowly charged high till the switch l is fully on. ACOK will be driven low about 30ms after VIN valid, indicating the switch is on with a good power ti a input. If the input voltage exceeds the OVP trip level, the switch will be turned off in about 50ns. If EN is pulled high, or input voltage falls below UVLO threshold, or over-temperature happens, the switch will also be turned off. Surge Protection e n The AW327XX integrates a clamp circuit to suppress input surge voltage. For surge voltages between VIN_OVLO and VIN_CLAMP, the switch will be turned off but the clamp circuit will not work. For surge voltages greater than VIN_CLAMP, the internal clamp circuit will detect surge voltage level and discharge the surge energy to ground. The device can suppress surge voltages up to 100V. fi d Over-Voltage Protection If the input voltage exceeds the OVP rising trip level, the switch will be turned off in about 50ns. The switch will remain off until VIN falls below the OVP falling trip level. n OVP Threshold Adjustment o If the default OVP threshold is used, OVLO pin must be grounded. If OVLO pin is not grounded, and by connecting external resistor divider to OVLO pin as shown in the typical application circuit, between IN and GND, the OVP threshold can be adjusted as following: C VIN_OVLO = R1+R2 VOVLO_TH R2 in ACOK Output ic For example, if we select R1 = 1MΩ and R2 = 100kΩ, then the new OVP threshold calculated from the above formula is 13.2V. The OVP threshold adjustment range is from 4V to 20V. When the OVLO pin voltage VOVLO exceeds VOVLO_SEL (0.26V typical), VOVLO is compared with the reference voltage VOVLO_TH (1.2V typical) to judge whether input supply is over-voltage. The device features an open-drain output ACOK, it should be connected to the system I/O rail through a pullup resistor. If the device is enabled and VIN_UVLO < VIN < VIN_OVLO, ACOK will be driven low indicating the switch w is on with a good power input. If OVP, UVLO, or OT occurs, or EN is pulled high, the switch will be turned off and ACOK will be pulled high. a USB On-The-Go (OTG) Operation If VIN = 0V and OUT is supplied by OTG voltage, the body diode of the load switch conducts current from OUT to IN and the voltage drop from OUT to IN is approximately 0.7V. When VIN > VIN_UVLO, internal charge pump begins to open the load switch after debounce time (about 15ms). After switch is fully on, current is supplied through switch channel and the voltage drop from OUT to IN is minimum. www.awinic.com.cn 11 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32705/AW32710 Oct. 2018 V1.0 PCB LAYOUT CONSIDERATION To obtain the optimal performance of AW327XX, PCB layout should be considered carefully. Here are some guidelines: l 1. All the peripherals should be placed as close to the device as possible. Place the input capacitor CIN on the top layer (same layer as the AW327XX) and close to IN pin, and place the output capacitor COUT on the top layer (same layer as the AW327XX) and close to OUT pin. ti a 2. If external TVS is used, IN pin routing passes through the external TVS firstly, and then connect AW327XX. 3. Red bold paths on figure 4 and 5 are power lines that will flow large current, please route them on PCB as straight, wide and short as possible. n 4. The path from device ground pins to the system ground plane must be as short as possible. 5. If R1 and R2 are used, route OVLO line on PCB as short as possible to reduce parasitic capacitance. e 6. The power trace from USB connector to AW327XX may suffer from ESD event, keep other traces away from it to minimize possible EMI and ESD coupling. a w in ic C o n fi d 7. Use rounded corners on the power trace from USB connector to AW327XX to decrease EMI coupling. www.awinic.com.cn 12 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32705/AW32710 Oct. 2018 V1.0 TAPE AND REEL INFORMATION TAPE DIMENSIONS REEL DIMENSIONS P1 P2 P0 l K0 ti a W B0 D1 A0 n Cavity fi d e A0:Dimension designed to accommodate the component width B0:Dimension designed to accommodate the component length K0:Dimension designed to accommodate the component thickness W:Overall width of the carrier tape P0:Pitch between successive cavity centers and sprocket hole P1:Pitch between successive cavity centers P2:Pitch between sprocket hole D0:Reel width D1:Reel diameter n D0 C o QUADRANT ASSIGNMENTS FOR PIN 1 ORIENTATION IN TAPE Sprocket Holes Q2 Q1 Q2 Q1 Q2 Q1 Q2 Q3 Q4 Q3 Q4 Q3 Q4 Q3 Q4 ic Q1 User Direction of Feed Pocket Quadrants in All dimensions are nominal D0 (mm) A0 (mm) B0 (mm) K0 (mm) P0 (mm) P1 (mm) P2 (mm) W (mm) Pin1 Quadrant 179.00 9.00 1.29 1.69 0.73 2.00 4.00 4.00 8.00 Q2 a w D1 (mm) www.awinic.com.cn 13 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32705/AW32710 Oct. 2018 V1.0 PACKAGE DESCRIPTION 1.570 ±0.025 Pin1 Corner ti a l 1.170 ±0.025 e n Top View 0.380 ±0.025 fi d 0.619 Max Ball TYP 0.194 ±0.020 4 12X(∅0.268±0.020) C B SYMM ℄ A 0.400 TYP 1.200 SYMM ℄ Bottom View Unit: mm a w in 3 C ic 0.800 0.400 TYP 2 o 1 n Side View www.awinic.com.cn 14 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32705/AW32710 Oct. 2018 V1.0 LAND PATTERN DATA 1 2 3 4 12X(∅0.240) 0.400 TYP n C e SYMM ℄ fi d 0.400 TYP 0.05 MIN All AROUND SOLDER MASK OPENING n 0.05 MAX All AROUND SYMM ℄ ti a B l A C Non-solder Mask Defined o METAL SOLDER MASK OPENING METAL UNDER SOLDER MASK Solder Mask Defined a w in ic Unit: mm www.awinic.com.cn 15 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32705/AW32710 Oct. 2018 V1.0 REVISION HISTORY Date Change Record V1.0 October 2018 Datasheet V1.0 Released a w in ic C o n fi d e n ti a l Vision www.awinic.com.cn 16 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32705/AW32710 Oct. 2018 V1.0 DISCLAIMER l Information in this document is believed to be accurate and reliable. However, Shanghai AWINIC Technology Co., Ltd (AWINIC Technology) does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. ti a AWINIC Technology reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. Customers shall obtain the latest relevant information before placing orders and shall verify that such information is current and complete. This document supersedes and replaces all information supplied prior to the publication hereof. fi d e n AWINIC Technology products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an AWINIC Technology product can reasonably be expected to result in personal injury, death or severe property or environmental damage. AWINIC Technology accepts no liability for inclusion and/or use of AWINIC Technology products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. n Applications that are described herein for any of these products are for illustrative purposes only. AWINIC Technology makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. All products are sold subject to the general terms and conditions of commercial sale supplied at the time of order acknowledgement. o Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. C Reproduction of AWINIC information in AWINIC data books or data sheets is permissible only if reproduction is without alteration and is accompanied by all associated warranties, conditions, limitations, and notices. AWINIC is not responsible or liable for such altered documentation. Information of third parties may be subject to additional restrictions. a w in ic Resale of AWINIC components or services with statements different from or beyond the parameters stated by AWINIC for that component or service voids all express and any implied warranties for the associated AWINIC component or service and is an unfair and deceptive business practice. AWINIC is not responsible or liable for any such statements. www.awinic.com.cn 17 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD
AW32710CSR 价格&库存
很抱歉,暂时无法提供与“AW32710CSR”相匹配的价格&库存,您可以联系我们找货
