AW88298QNR
AW88298QNR
    AWINIC(艾为)
    WBQFN-24L_3.5X3.5MM-EP
    10.25V BOOST数字智能K音频放大器
AW88298QNR 数据手册
AW88298 May. 2022 V1.6 I2S/TDM Input, 10.25V BOOST Digital Smart K Audio Amplifier FEATURES DESCRIPTION ⚫ ⚫ The AW88298 is an I2S/TDM input, high efficiency digital Smart K audio amplifier with an integrated 10.25V smart boost converter. Due to its 12uV noise floor and ultra-low distortion, clean listening is guaranteed. It can deliver 5.2W output power into an 8Ω speaker at 1% THD+N. l Smart BOOST with total efficiency up to 84% High RF noise suppression, eliminate the ⚫ ⚫ Extensive Pop-Click Suppression Volume Control (from -96dB to 0dB) ⚫ I2S/TDM interface: I2S, Left-Justified and Right-Justified ◼ Supports four slots TDM ◼ ◼ Input Sample Rates from 8kHz to 96kHz Data Width: 16, 20, 24, 32 Bits ⚫ I2C-bus control interface(400kHz) ⚫ Power Supplies: ◼ ◼ ◼ VDDIO: 1.65V~3.6V Short-Circuit Protection, Over-Temperature cC ⚫ VDD: 3.0V-5.5V DVDD: 1.65V~1.95V Protection, Under-Voltage Protection and Over⚫ Voltage Protection QFN 3.5mm X3.5mm X0.75mm-24L package ⚫ ⚫ ⚫ The AW88298 offers Short Circuit Protection, Over-Temperature Protection, Under-Voltage Protection and Over-Voltage Protection to protect the device. aw ini APPLICATIONS The AW88298 features high RF suppression and eliminates TDD noise completely benefited from the digital audio input interface. General settings are communicated via an I2C-bus interface, and the device address is configurable. on ◼ The AW88298 integrates a high-efficiency smart boost converter as the Class-D amplifier supply rail. The output voltage of boost converter can be adjusted smartly according to the input amplitude, which extremely improves the efficiency without clipping distortion. en Low noise: 12uV THD+N: 0.02% fid ⚫ ⚫ tia TDD noise completely Mobile phones Tablets Portable Audio Devices www.awinic.com 1 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW88298 May. 2022 V1.6 PIN CONFIGURATION AND TOP MARK AW88298QNR MARKING SW 5 14 SCL NC 6 13 SDA tia 15 BCK on fid en 4 AD1 12 VBST RSTN 11 16 DATAI INTN 10 3 9 PVDD VDD 17 WCK 8 2 GND VOP 7 18 VDDIO BGND 1 2HU3 XXXX VON l 19 DATAO 20 DVDD 21 TEST2 22 TEST1 23 AD2 24 PGND AW88298QNR TOP VIEW 2HU3 – AW88298QNR XXXX – Product Tracing Code PIN DESCRIPTION cC AW88298QNR pin diagram top view and device marking Pin Name 1 VON aw ini Pin No www.awinic.com Description Inverting Class-D output 2 VOP Non-inverting Class-D output 3 PVDD Power stage supply 4 VBST Boost output 5 SW Boost switch pin 6 NC Not connected, connect to ground 7 BGND 8 GND GND 9 VDD Battery power supply 10 INTN Interrupt output 11 RSTN Active low hardware reset 12 AD1 I2C address select input 13 SDA I2C data I/O Boost GND 2 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW88298 May. 2022 V1.6 Pin No Pin Name Description 14 SCL I2C clock input 15 BCK I2S/TDM bit clock input 16 DATAI 17 WCK 18 VDDIO IO Voltage 19 DATAO I2S/TDM data out 20 DVDD Digital power supply 21 TEST2 Test Pin, connect to ground 22 TEST1 Test Pin, connect to ground 23 AD2 24 PGND I2S/TDM data input tia aw ini cC on fid Power GND en I2C address select input l I2S word select input / TDM frame sync signal www.awinic.com 3 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW88298 May. 2022 V1.6 FUNCTIONAL BLOCK DIAGRAM DVDD SCL SDA VDD BOOST I2C Interface INTN Digital Audio Processing path Digital Audio Interface DATA Collector Class-D Amplifier VON VOP AW8896 PLL fid M U X DAC PVDD en BCK WCK DATAI DATAO tia l AD2 AD1 VBST SW ADC on OVP,OCP,OTP DGND BGND Temp Sense PVDD/VBAT Sense PGND aw ini cC FUNCTIONAL BLOCK DIAGRAM www.awinic.com 4 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW88298 May. 2022 V1.6 APPLICATION DIAGRAM VBAT 1.8V L 1uH 4A C3 10uF 1.65V ~ 3.6V 20 I2S Interface PVDD 16 19 11 10 SCL SDA AD2 AD1 BCK WCK AW88298 DATAI DATAO RSTN INTN en 13 23 12 15 17 VBST VOP fid I C Interface SW VDD C11 0.1uF 14 2 DVDD VDDIO on C10 1uF 5 9 3 tia 18 C4 0.1uF l C2 1uF C1 1uF 2 B+ optional VON GND BGND PGND 8 7 24 1 C6 10uF 25V C5 10uF 25V C7 0.1nF SPK B- optional C8 0.1nF cC NC TEST1TEST2 6 22 21 4 AW88298 Application Circuit Note: Traces carry high current are marked in red in the above figure aw ini All trademarks are the property of their respective owners. www.awinic.com 5 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW88298 May. 2022 V1.6 ORDERING INFORMATION Product Type Temperature Moisture Device Environmenta Sensitivity Delivery Form Marking l Information Level Package WBQFN -40℃~85℃ 3.5mmX3.5mm24L 2HU3 MSL3 RoHS+HF 6000 units/ Tape and Reel aw ini cC on fid en tia l AW88298QNR www.awinic.com 6 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW88298 May. 2022 V1.6 ABSOLUTE MAXIMUM RATING(NOTE1) Range Battery Supply Voltage VDD -0.3V to 6V Digital Supply Voltage VDVDD -0.3V to 2V Digital Supply Voltage VDDIO -0.3V to 4.6V Boost output voltage VPVDD -0.3 to 13V Boost SW pin voltage -0.3 to VPVDD+2V (Note 2) tia l Parameter VOP/VON pin voltage -0.3 to VPVDD+2V (Note 2) Minimum load resistance RL 3.2Ω(Note 3) 60°C/W en Package Thermal Resistance θJA Ambient Temperature Range Maximum Junction Temperature TJMAX fid Storage Temperature Range TSTG Lead Temperature (Soldering 10 Seconds) ESD Rating 165°C -65°C to 150°C 260°C (Note 4,5) on HBM (Human Body Model) -40°C to 85°C CDM (Charge Device Model) ±2000V ±1000V Latch-up cC Test Condition:JEDEC STANDARD NO.78E SEPTEMBER 2016 +IT:450mA -IT:-450mA Note 1: Stresses beyond those listed under "absolute maximum ratings" may cause permanent damage to the device. These aw ini are stress ratings only and functional operation of the device at these or any other conditions beyond those indicated under "recommended operating conditions" is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. Note 2: SW/VOP/VON pin can handle 16V transients for less than 5ns Note 3: When the load resistance RL is less than 5Ω, please refer to the corresponding application notes and the maximum boost output voltage VPVDD should be less than 9V. Note 4: The human body model is a 100pF capacitor discharged through a 1.5kΩ resistor into each pin. Test method: ESDA/JEDEC JS-001 Note 5: Test method: ESDA/JEDEC JS-002 www.awinic.com 7 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW88298 May. 2022 V1.6 ELECTRICAL CHARACTERISTICS CHARACTERISTICS Test condition: TA=25°C,VDD=3.6V,DVDD=1.8V , VDDIO=1.8V, PVDD=10.25V,RL=8Ω+33μH,f=1kHz(unless otherwise noted) Test Conditions Battery supply voltage On pin VDD VDVDD Digital supply voltage On pin DVDD VDDIO Digital IO supply voltage On pin VDDIO IVDD Battery supply current IDVDD Digital supply current Operating mode Power down mode Over-voltage threshold IL_PEAK Inductor peak current limit Max Units 5.5 V 1.95 V 3.6 V 5.5 on OVP hysteresis voltage 1.8 1.65 Power down mode Boost output voltage VOVP 1.65 fid VPVDD 3 Operating mode Boost Typ. l VDD Min tia Description en Symbol 2 A 4.5 mA 5 A 10.25(Note1) V VPVDD+0.5 V 500 mV 3.75(Note1) A 1.6 MHz 90 % Operating Frequency DMAX The maximum duty cycle ηBST Boost converter efficiency VDD=4.2V, Iload = 0.5A SmartBoost 88 % Drain-Source on-state resistance High side MOS + Low side MOS 300 mΩ THD+N=1%, RL=8Ω+33μH, VDD=4.2V, PVDD=10.25V 5.2 W THD+N=10%, RL=8Ω+33μH, VDD=4.2V, PVDD=10.25V 6.2 W THD+N=1%, RL=6Ω+33μH, VDD=4.2V, PVDD=10.25V 5.35 W THD+N=10%, RL=6Ω+33μH, VDD=4.2V, PVDD=10.25V 6.5 W cC FBST Po aw ini Class-D Rdson fs = 48KHz 0.3 mA VOS η www.awinic.com Speaker Output Power Output offset voltage I2S signal input 0 Total efficiency (Class-D) VDD=4.2V, Po=0.5W, RL=8Ω+33μH 89 % Total efficiency (SmartBoost+Class-D) VDD=4.2V, Po=1W, RL=8Ω+33μH 84 % 8 -30 0 30 mV Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW88298 May. 2022 V1.6 Description Total harmonic distortion plus noise EN SNR RL=8Ω+33μH, f=1kHz, PVDD=10.25V Receiver Mode Output noise A-weighting 12 μV VDD=4.2V, PVDD=10.25V, Po=5.2W, RL=8Ω+33μH, en 217Hz 1kHz fid Logic input low level Logic input high level VIL Logic input low level VIH Logic input high level VOL Logic output low level IOUT=2mA VOH Logic output high level IOUT=-2mA on VIH cC RSTN, SCL, SDA, AD1, AD2 Pin 109 dB -85 dB -80 dB 0.7 x VDDIO 0.7 x VDVDD VDDIO 0.45 0.3 x VDDIO V VDDIO V 0.3 x VDVDD V 3.6 V 0.45 V VDDIO V Over temperature protection threshold 160 °C Over temperature protection recovery threshold 130 °C Under-voltage protection voltage 2.6 V Under-voltage protection hysteresis voltage 100 mV aw ini UVP % μV BCK, WCK, DATAI Pin TSDR 0.02 22 Digital Logical Interface TSD Units A-weighting Receiver Mode, Power supply rejection ratio VDD=4.2V, Vp-p_sin=200mV Protection Max VDD=4.2V, Po=1W, A-weighting VIL Typ. Speaker Mode Output noise Signal-to-noise ratio PSRR Min l THD+N Test Conditions tia Symbol Note 1:Registers are adjustable; Refer to the list of registers. www.awinic.com 9 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW88298 May. 2022 V1.6 I2C INTERFACE TIMING Parameter MIN MAX UNIT 400 kHz Sym 1 fSCL SCL Clock frequency 2 tLOW SCL Low level Duration 1.3 μs 3 tHIGH SCL High level Duration 0.6 μs 4 tRISE SCL, SDA rise time 5 tFALL SCL, SDA fall time 6 tSU:STA Setup time SCL to START state 7 tHD:STA (Repeat-start) Start condition hold time 8 tSU:STO Stop condition setup time 9 tBUF 10 11 tia l Name TYP No. 0.3 μs 0.3 μs en 0.6 μs μs 0.6 μs the Bus idle time START state to STOP state 1.3 μs tSU:DAT SDA setup time 0.1 μs tHD:DAT SDA hold time 10 ns SDA (2) tLOW on (3) tHI GH cC SCL fid 0.6 tRI SE tFALL (4) (5) tSU:DAT tHD:DAT (10) (11) aw ini SCL and SDA timing relationships in the data transmission process SCL tHD:STA tSU:STO (7) (8) (6) (9) tSU:STA tBUF SDA The timing relationship between START and STOP state www.awinic.com 10 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW88298 May. 2022 V1.6 DIGITAL AUDIO INTERFACE TIMING Min Parameter Name Typ. Max Units sampling frequency, on pin WCK 8 96 kHz fbck Bit clock frequency, on pin BCK 32*fs 128*fs Hz tsu WCK, DATAI Setup time to BCK 10 th WCK, DATAI hold time to BCK 10 td DATAO output delay time to BCK ns 50 ns en tia ns fid WCK BCK td cC DATAI th on tsu DATAO l fs aw ini Digital Audio Interface Timing www.awinic.com 11 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW88298 May. 2022 V1.6 TYPICAL CHARACTERISTIC CURVES THD+N VS. FREQUENCY on fid en tia l THD+N VS. FREQUENCY THD+N VS. OUTPUT POWER aw ini cC THD+N VS. OUTPUT POWER www.awinic.com 12 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW88298 May. 2022 V1.6 OUTPUT POWER VS. Din on fid en tia l GAIN VS. FREQUENCY EFFICIENCY VS. OUTPUT POWER aw ini cC EFFICIENCY VS. OUTPUT POWER www.awinic.com 13 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW88298 May. 2022 V1.6 aw ini cC on fid en tia l RECEIVER PSRR VS. FREQUENCY www.awinic.com 14 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW88298 May. 2022 V1.6 DETAIL FUNCTIONAL DESCRIPTION POWER ON RESET The device provides a power-on reset feature that is controlled by VDD and DVDD supply voltage. When the VDD supply voltage raises from 0V to 2.1V, or DVDD supply voltage raises from 0V to 1.1V. The reset signal will be generated to perform a power-on reset operation, which will reset all circuits and configuration registers. The device supports 4 operation modes. Table 1 Operating Mode tia l OPERATION MODE Condition Description Power-Down VDD < 2.1V VDVDD < 1.1V Power supply is not ready, chipset is power down. Stand-By VDD > 3V VDVDD > 1.65V Power supply is ready, most parts of the device are power down for low power consumption except I2C interface Configuring PWDN = 0 Device is biased while boost and class-D output is floating. System configuration carried out in this mode Operating AMPPD = 0 Amplifier is fully operating on fid en Mode cC Power-down Power supply fault (VBAT < 2.1V, VDVDD < 1.1V) Power supply OK (VBAT > 3.0V, VDVDD > 1.65V) aw ini SYSCTRL.PWDN = 0 Stand-By SYSCTRL.AMPPD = 0 Configuring SYSCTRL.PWDN = 1 Operating SYSCTRL.AMPPD = 1 Device operating modes transition POWER-DOWN MODE The device switches to power-down mode when any of the following events occurred: ◼ VDVDD < 1.1 V ◼ VDD < 2.1 V ◼ RSTN pin goes LOW In this mode, all circuits inside this device will be shut down except the power-on-reset circuit. I2C interface isn’t accessible in this mode, and all of the internal configurable registers are cleared. The device will jump out of the power-down mode automatically when all of the supply voltages are OK: www.awinic.com 15 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW88298 May. 2022 V1.6 VDVDD > 1.65 V and VDD > 3 V And RSTN goes HIGH. STAND-BY MODE l The device switches stand-by mode when the power supply voltages are OK and RSTN pin is HIGH. In this mode I2C interface is accessible, other modules are still powered down. Customer can set device to mode when the device is no needed to work. tia CONFIG MODE en The device switches to OFF mode when: ◼ SYSCTRL.PWDN = 0; ◼ SYSCTRL.AMPPD = 1; In this mode the internal bias, OSC, PLL will start to work OPERATING MODE SET PWDN = 0 Bias, OSC, PLL DataPath Cfg SET AMPPD = 0 2 Assuming I S Clock is active and stable at this time Wait until PLL Locked cC DAP configuring on Power Up fid The device is fully operational in this mode. Boost, amplifier loop and power stage circuits will start to work. Customer can set SYSCTRL.AMPPD = 0 to make device in this mode. This device power up sequence is illustrated in the following figure: Boost bootup Class D bootup aw ini SET HMUTE = 0 Mute disable Power up sequence Detail description for each step is listed in the following table. www.awinic.com 16 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW88298 May. 2022 V1.6 Table 2 Detail Description of Power up sequence Index description Mode 1 Wait for VDD、DVDD supply power up Power-Down 2 I2S + Data Path Configuration Stand-By 3.1 Enable system (SYSCTRL.PWDN = 0) 3.2 3.3 Bias, OSC, PLL active Waiting for PLL locked Enable Boost and amplifier (SYSCTRL.AMPPD =0) Boost and Amplifier boot up wait SYSST.SWS =1 Release Hard-Mute Data Path active tia l Configuring 4.2 5 Operating en 4.1 Power up sequence considering I2S, I2C timing shows as below: 2 3 4 5 >= 0 ms VBAT 6 7 8 9 10 7 8 9 10 fid 1 on DVDD >100 μs RSTN >1 ms cC I2S I2S Clock Valid >1 ms I2C Chip Configuration aw ini Power down sequence considering I2S, I2C timing shows as below: 1 I2C I2S 2 3 4 5 6 Chip Configuration >0 ms I2S Clock Valid >0 ms RSTN 100 μs DVDD >0 ms VBAT www.awinic.com 17 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW88298 May. 2022 V1.6 SOFTWARE RESET Writing 0x55AA to register ID (0x00) via I2C interface will reset the device internal circuits and all configuration registers. DIGITAL AUDIO INTERFACE BCK WCK DATAI DATAO tia ◼ ◼ ◼ ◼ l Audio data is transferred between the host processor and the device via the Digital Audio Interface. The digital audio interface is in full-duplex via 4 dedicated pins: en Two-slot I2S and 4-slot TDM are supported in this device. The digital audio Interface on this device is slave only and flexible with data width options, including 16, 20, 24, or 32 bits by configurable registers. fid Three modes of I2S are supported, including standard I2S mode, left-justified mode and right-justified data mode, which can be configured via I2SCTRL.I2SMD. These modes are all MSB-first, with data width programmable via I2SCTRL.I2SFS. on The word clock WCK is used to define the beginning of a frame. The frequency of this clock corresponds to the sampling frequency. The device supports the following sample rates (fs): 8 kHz, 11.025 kHz, 12 kHz, 16 kHz, 22.05 kHz, 24 kHz, 32 kHz, 44.1 kHz, 48 kHz and 96 kHz. It is selected via configurable register I2SCTRL.I2SSR. cC The bit clock BCK is used to sample the digital audio data across the digital audio interface. The number of bitclock pulses in a frame is defined as slot length. Three kind of slot length are supported (16/24/32) via configurable register I2SCTRL.I2SBCK. The frequency of BCK can be calculated according to the following equation: BCK frequency = SampleRate * SlotLength * SlotNumber SampleRate: Sample rate for this digital audio interface; SlotLength: The length of one audio slot in unit of BCK clock; aw ini SlotNumber: How many slots supported in this audio interface. For example: 2-slot supported in I2S mode, 4slot supported in TDM mode. The word selects and bit clock signals of the I2S input are the reference signals for the digital audio interface and Phased Locked Loop (PLL). The input audio data can be attenuated -6dB in this module, by setting bit I2SCTRL.INPLEV. The audio source can be from left channel, right channel or the average of the left and right channel, which is controlled by I2SCTRL.CHSEL. www.awinic.com 18 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW88298 May. 2022 V1.6 Table 3 Supported I2S interface parameters Data width BCK frequency Standard I2S 16b/20b/24b/32b 32fs /48fs /64fs left-justified 16b/20b/24b/32b 32fs /48fs /64fs right-justified 16b/20b/24b/32b 32fs /48fs /64fs tia l Interface format(MSB first) The output port DATAO, can be enabled or disabled via bit I2SCFG1.I2STXEN. The unused slots can be set to Hi-z or zero, which is controlled by I2SCFG1.DOHZ. … RIGHT CHANNEL LEFT CHANNEL WCK … MSB fid … … BCK DATA en STANDARD I2S MODE 0 MSB … … 0 sample data of right channel on sample data of left channel I2S Timing for Standard I2S Mode When WCK=0 indicating the left channel data, and WCK=1 indicating the right channel data. ⚫ The MSB of the left channel is valid on the second rising edge of the bit clock after the falling edge of the word clock. Similarly, the MSB of the right channel is valid on the second rising edge of the bit clock after the rising edge of the word clock. LEFT-JUSTIFIED MODE BCK DATA … aw ini WCK cC ⚫ LEFT CHANNEL RIGHT CHANNEL … … … MSB … 0 … MSB 0 sample data of right channel sample data of left channel I2S Timing for Left-Justified Mode ⚫ When WCK=1 indicating the left channel data, and WCK=0 indicating the right channel data. ⚫ The MSB of the left channel is valid on the first rising edge of the bit clock after the rising edge of the word clock. Similarly, the MSB of the right channel is valid on the first rising edge of the bit clock after the falling edge of the word clock. www.awinic.com 19 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW88298 May. 2022 V1.6 RIGHT-JUSTIFIED MODE … LEFT CHANNEL WCK RIGHT CHANNEL … … … N-1 DATA … 0 … N-1 0 sample data of right channel N=16/20/24/32 sample data of left channel N=16/20/24/32 tia I2S Timing for Right-Justified Mode l BCK When WCK is high indicating the left channel data, and WCK=0 indicating the right channel data. ⚫ The LSB (bit 0) of the left channel is valid on the rising edge of the bit clock preceding the falling edge of the word clock. Similarly, the LSB (bit 0) of the right channel is valid on the rising edge of the bit clock preceding the rising edge of the word clock. en ⚫ fid TDM MODE All of the three kind of bit synchronization modes (standard, left-justified, right-justified) are also supported in TDM mode. The difference between TDM and I2S is the slot number supported. 4-slot is supported in TDM mode, while 2-slot is supported in I2S mode ... BCK ... Slot0 ... ... ... ... ... Slot1 Slot2 Slot3 cC DATA ... on WCK TDM Timing aw ini Note: The high level pulse width of WCK signal can be one slot time or one period of BCK. www.awinic.com 20 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW88298 May. 2022 V1.6 DIGITAL AUDIO PROCESSING HAGC en Volume Mute fid HDCC tia l This device provides algorithm supporting for audio signal processing. The following functions are processed in this module. ⚫ HDCC ⚫ Hardware AGC ⚫ Volume control ⚫ Mute The signal processing flow in the DAP (Digital Audio Processor) is illustrated in the following figure. Block Diagram of DAP on HDCC This module performs hardware DC canceling for the input audio stream. It blocks DC components into analog class D loop. cC HAGC aw ini In the actual audio application, system output power tends to be more than rated power of speaker, such as in the 10.25V power supply, as for 8ohms speaker, the maximum undistorted power is about 5.3W, but many speakers’ rated power is about 1W, if there is no output power control, the overload signal can cause damage to the speaker. The audio power amplifier with hardware AGC can protect the speaker effectively, When the output power is not exceeding the setting threshold, the hardware AGC module will not attenuate the internal gain. Once the output power exceeds the setting threshold, the hardware AGC module will reduce the internal gain of amplifier and restricts the output power under the setting threshold. VOLUME CONTROL The volume control function attenuates the audio signal at the end of digital audio processing. The range of volume setting is from 0db to -96db with 0.5db/step MUTE This module performs mute control for the audio stream DC-DC CONVERTER This device using smart boost converter generates the amplifier supply rail, working in 1.6MHz. The DC-DC converter can work in different mode via BSTCTRL2.BST_MODE: www.awinic.com 21 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW88298 May. 2022 V1.6 ⚫ Pass-through mode: the voltage of VDD is transparently passed to output of converter PVDD ⚫ Force boost mode: the output voltage is boosted to the programmed output voltage ⚫ Smart boost 1 mode: the output voltage can be switch between VDD and programmed output voltage according to the input audio level. ⚫ Smart boost 2 mode: the output voltage can be dynamically adjusted according to the amplifier output's signal swing requirements in order to maximize efficiency. Pass-through mode tia l The internal boost circuit is not working; the voltage of VDD is passed to PVDD directly. Force boost mode en The boost circuit is always working and converts the voltage of VDD to the programmed output voltage. The output voltage is configured via BSTCTRL2.VOUT_VREFSET Smart boost 1 mode fid Smart boost 1 mode can dynamically turn off the boost according to the amplifier output's signal swing requirements in order to maximize efficiency. Smart boost 2 mode cC on The boost circuits working dynamically according to the input audio level. When the level of input audio signal is below the setting threshold, the boost circuit will be deactivated. Till the level of input audio signal raised up and above the threshold, the boost circuit starts to work and boost the amplifier supply rail to the voltage fit the requirement of output signal before the audio stream arriving at amplifier power stage. Audio Signal Input Tdeglitch aw ini PVDD VBAT Audio Signal Output Tpath_delay Boost Circuit Behavior in Smart Boost 2 Mode PROTECTION MECHANISMS Over Voltage Protection (OVP) The boost circuit has integrated the over voltage protection control loop. When the output voltage PVDD is above the threshold, the boost circuits will stop working, until the voltage of PVDD going down and under the normal fixed working voltage. Over Temperature Protection (OTP) www.awinic.com 22 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW88298 May. 2022 V1.6 The device has automatic temperature protection mechanism which prevents heat damage to the chip. It is triggered when the junction temperature is larger than the preset temperature high threshold (default = 160°C). When it happens, the output stages will be disabled. When the junction temperature drops below the preset temperature low threshold (less than 130°C), the output stages will start to operate normally again Over Current (short) Protection (OCP) l The short circuit protection function is triggered when VOP/VON is short to PVDD/GND or VOP is short to VON, the output stages will be shut down to prevent damage to itself. When the fault condition is disappeared, the output stages of device will restart. tia Under Voltage Detection (UVL) en The interrupt bit SYSINT.UVLI will be set to 1 when under voltage occurs, which will be cleared by a read operation of SYSINT register. Usually the SYSINT.UVLI bit can be used to check whether an unexpected undervoltage event has taken place. BATTERY VOLTAGE MONITORING fid The device monitors the voltage on the VDD pin, which is most commonly the battery for the system. The battery voltage level is available via bits VBAT_DET in the Battery Supply Voltage register VDD. Status bits BAT_DET can be used to calculate the battery voltage. The battery voltage level VDD is: 𝑉𝐵𝐴𝑇_𝐷𝐸𝑇 × 6.025𝑉 210 − 1 For example, if VBAT_DET = 1001100011, the battery voltage level VDD is equal to 3.6V. on 𝑉𝐵𝐴𝑇 = PVDD VOLTAGE MONITORING cC The device monitors the voltage on the PVDD pin, which is most commonly the PVDD voltage level for the system. The PVDD pin voltage level is available via bits PVDD_DET in the Power Supply Voltage monitor register PVDD. Status bits PVDD_DET can be used to calculate the PVDD voltage. The PVDD voltage level VPVDD is: 𝑃𝑉𝐷𝐷_𝐷𝐸𝑇 × 12.05𝑉 210 − 1 For example, if PVDD_DET = 1001100011, the PVDD voltage level VPVDD is equal to 7.2V. aw ini 𝑉𝑃𝑉𝐷𝐷 = DIE TEMPERATURE MONITORING The device monitors the die temperature and the result is available via bits TEMP_DET in the Temperature register TEMP. The TEMP_DET is a two’s complement value. For example, if TEMP_DET = 00011001, the die temperature is 25℃. AMPLIFIER TRANSFER FUNCTION The transfer function from the input to the amplifier PWM output (when no gain and attenuation is applied in digital signal domain) is: 𝑉𝑜 = 𝐴𝑀𝑃_𝑁𝑂𝑅𝑀_𝑉 × 𝐷𝑖𝑛 Din: the level of input signal with a range from -1 to +1 AMP_NORM_V: the equivalent amplifier output voltage when Din is 1. In receiver mode the AMP_NORM_V is www.awinic.com 23 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW88298 May. 2022 V1.6 5V, in speaker mode it’s 16V. RECEIVER MODE aw ini cC on fid en tia l The device built-in Receiver mode is easy to realize the Speaker and Receiver combo applications, it saves the system cost and board space. If the receiver magnification is one times, the noise floor will be 12μV. Speaker and Receiver combo applications can be realized without changing any hardware. When the device is set to receiver mode, the power supply of Class D driver stage is from VDD directly without boost. www.awinic.com 24 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW88298 May. 2022 V1.6 I2C INTERFACE This device supports the I²C serial bus and data transmission protocol in fast mode at 400 kHz. This device operates as a slave on the I²C bus. Connections to the bus are made via the open-drain I/O pins SCL and SDA. The pull-up resistor can be selected in the range of 1k~10kΩ and the typical value is 4.7kΩ. This device can support different high level (1.8V~3.3V) of this I2C interface. DEVICE ADDRESS AD1 0 0 0 1 1 0 Address(7-bit) 0x34 0x35 fid AD2 en Table 4 Address Selection tia l The I2C device address (7-bit) can be set using the AD pin according to the following table: The AD1, AD2 pin configures the two LSB bits of the following 7-bit binary address A6-A0 of 01101xx. The permitted I2C addresses are 0x34(7-bit) through 0x37(7-bit). 1 1 0x37 on DATA VALIDATION 0x36 cC When SCL is high level, SDA level must be constant. SDA can be changed only when SCL is low level. SDA SCL aw ini Data Line Stable Data Valid Change of Data Allowed Data Validation Diagram I2C START/STOP I2C start: SDA changes form high level to low level when SCL is high level. I2C stop: SDA changes form low level to high level when SCL is high level. www.awinic.com 25 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW88298 May. 2022 V1.6 SDA SCL S/Sr P P: STOP condition tia l S: START condition Sr: START Repeated condition I2C Start/Stop Condition Timing en ACK (ACKNOWLEDGEMENT) fid ACK means the successful transfer of I2C bus data. After master sends 8bits data, SDA must be released; SDA is pulled to GND by slave device when slave acknowledges. When master reads, slave device sends 8bit data, releases the SDA and waits for ACK from master. If ACK is send and I2C stop is not send by master, slave device sends the next data. If ACK is not send by master, slave device stops to send data and waits for I 2C stop. on Data Output by Transmiter Not Acknowledge(NACK) SCL From Master cC Data Output by Receiver 1 Acknowledge(ACK) 2 8 9 Clock Pulse for Acknowledgement START condition aw ini I2C ACK Timing WRITE CYCLE One data bit is transferred during each clock pulse. Data is sampled during the high state of the serial clock (SCL). Consequently, throughout the clock’s high period, the data should remain stable. Any changes on the SDA line during the high state of the SCL and in the middle of a transaction, aborts the current transaction. New data should be sent during the low SCL state. This protocol allows a single data line to transfer both command/control information and data using the synchronous serial clock. Each data transaction is composed of a Start Condition, a number of byte transfers (set by the software) and a Stop Condition to terminate the transaction. Every byte written to the SDA bus must be 8 bits long and is transferred with the most significant bit first. After each byte, an Acknowledge signal must follow. In a write process, the following steps should be followed: a) Master device generates START condition. The “START” signal is generated by lowering the SDA signal while the SCL signal is high. b) Master device sends slave address (7-bit) and the data direction bit (r/w = 0). www.awinic.com 26 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW88298 May. 2022 V1.6 Slave device sends acknowledge signal if the slave address is correct. d) Master sends control register address (8-bit) e) Slave sends acknowledge signal f) Master sends high data byte of 16-bit data to be written to the addressed register g) Slave sends acknowledge signal h) Master sends low data byte of 16-bit data to be written to the addressed register i) Slave sends acknowledge signal j) If master will send further 16-bit data bytes, the control register address will be incremented by one after acknowledge signal of step g (repeat step f to g) k) Master generates STOP condition to indicate write cycle end A6 START A5 A4 A3 … DEVICE ADDRESS A1 A0 R/W ACK A7 A6 … … A3 A2 A1 A0 ACK D7 … D2 D1 D0 ACK D7 D6 WRITE DATAH REGISTER ADDRESS … … D2 D1 D0 NACK WRITE DATAL STOP fid SDA en … … SCL tia l c) I2C Write Byte Cycle on READ CYCLE In a read cycle, the following steps should be followed: Master device generates START condition b) Master device sends slave address (7-bit) and the data direction bit (r/w = 0). c) Slave device sends acknowledge signal if the slave address is correct. d) Master sends control register address (8-bit) e) Slave sends acknowledge signal f) Master generates STOP condition followed with START condition or REPEAT START condition g) Master device sends slave address (7-bit) and the data direction bit (r/w = 1). h) Slave device sends acknowledge signal if the slave address is correct. i) Slave sends read high data byte of 16-bit data from addressed register. j) Master sends acknowledge signal. k) Slave sends read low data byte of 16-bit data from addressed register. l) If the master device sends acknowledge signal, the slave device will increase the control register address by one, then send the next 16-bit data from the new addressed register. aw ini cC a) m) If the master device generates STOP condition, the read cycle is ended. www.awinic.com 27 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW88298 May. 2022 V1.6 … … A6 START A5 A4 A3 … A1 A0 R/W ACK A7 DEVICE ADDRESS A6 RS A5 A4 A3 … A1 A0 R/W ACK D7 A4 A3 A0 ACK … … D2 D1 D0 ACK D7 … A0 R/W ACK D7 … D1 D0 NACK STOP … D2 D1 D0 ACK D7 READ DATAH DEVICE ADDRESS D2 READ DATAL … A1 … D6 D6 en STOP START A5 A1 READ DATAH DEVI CE ADDRESS A6 A2 … … Separated read/write transaction A3 REGISTER ADDRESS … Using repeat start … A6 l SDA tia SCL … D2 D1 D0 NACK READ DATAL STOP aw ini cC on fid I2C Read Byte Cycle www.awinic.com 28 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW88298 May. 2022 V1.6 REGISTER MAP REGISTER DESCRIPTION t n REGISTER LIST ADDR NAME R/W Bit15 Bit14 Bit13 Bit12 Bit11 Bit10 Bit9 Bit8 Bit7 Bit6 RO 0x01 SYSST RO OVP2S UVLS ADPS BSTOCS OVPS BSTS SWS CLIPS 0x02 SYSINT RC OVP2I UVLI ADPI BSTOCI OVPI BSTI SWI CLIPI 0x03 SYSINTM RW OVP2M UVLM ADPM BSTOCM OVPM BSTM SWM CLIPM 0x04 SYSCTRL RW INTMODE INTN RCV_MODE 0x05 SYSCTRL2 RW RMSE 0x06 I2SCTRL RW INPLEV I2SRXEN 0x07 I2SCFG1 RW I2S_TX_SLOTVLD 0x09 HAGCCFG1 RW 0x0a HAGCCFG2 RW 0x0b HAGCCFG3 RW 0x0c HAGCCFG4 RW 0x10 HAGCST RO 0x12 VDD RO 0x13 TEMP RO CHSEL c i in o C f n I2SMD I2SFS I2S_RX_SLOTVLD Bit4 e id 0x00 ID www.awinic.com IDCODE Bit5 CFSEL Bit3 Bit2 Bit1 Bit0 NOCLKS CLKS OCDS CLIP_PRES OTHS PLLS NOCLKI CLKI OCDI CLIP_PREI OTHI PLLI NOCLKM CLKM OCDM CLIP_PREM OTHM PLLM I2SEN WSINV BCKINV IPLL AMPPD PWDN HAGCE HDCCE HMUTE BST_IPEAK I2SBCK DRVSTREN I2SSR DOHZ RVTH w a l ia FSYNC_TYPE SLOT_NUM AVTH ATTH RTTH VOL HOLDTH BSTVOUT_ST VBAT_DET TEMP_DET 29 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD I2SCHS I2STXEN AW88298 May. 2022 V1.6 ADDR NAME R/W 0x14 PVDD RO 0x60 BSTCTRL1 RW 0x61 BSTCTRL2 RW Bit15 Bit14 Bit13 Bit12 Bit11 Bit10 Bit9 Bit8 Bit7 Bit6 Bit5 Bit4 Bit2 PVDD_DET BST_RTH BST_MODE BST_TDEG VOUT_VREFSET f n c i in o C e id w a 30 l ia BST_ATH t n www.awinic.com Bit3 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD Bit1 Bit0 AW88298 May. 2022 V1.6 DETAILED REGISTER DESCRIPTION R/W RO UVLS RO 13 ADPS RO 12 11 10 Reserved BSTOCS OVPS RO RO RO 9 BSTS RO 8 SWS RO 7 CLIPS RO 6 5 Reserved NOCLKS RO RO 4 CLKS RO 3 2 1 OCDS CLIP_PRES OTHS RO RO RO 0 PLLS RO (Address 02h) Symbol OVP2I UVLI ADPI Reserved BSTOCI OVPI BSTI SWI CLIPI R/W RC RC RC RC RC RC RC RC RC aw ini SYSINT: Bit 15 14 13 12 11 10 9 8 7 cC 14 Description Boost OVP2 status indicator VDD under voltage indicator 0: VDD > 2.8V 1: VDD < 2.8V Boost Adaptive status. 0: transparent 1: boost Not used Boost over current indicator Boost OVP status indicator Boost start up finished. 0: not finished 1: finished Amplifier switching status. 0: not switching 1: switching Amplifier clipping status. 0: not clipping 1: clipping Not used The reference clock of PLL is not available All internal clock are stable CLKS = PLLS & ~IDP Over current status in amplifier Amplifier clipping pre status. Die Temperature is higher than 160degrees PLL locked status. 0: unlocked 1: locked www.awinic.com l SYSST: (Address 01h) Bit Symbol 15 OVP2S tia RO IDCODE en 15:0 Description Chip ID (1852h) will be returned after read. All configuration registers will be reset to default value after 0x55aa is written fid R/W on ID: (Address 00h) Bit Symbol Description Interrupt indicator for OVP2S. Interrupt indicator for Power On and UVLS Interrupt indicator for ADPS Not used Interrupt indicator for BSTOCS. Interrupt indicator for OVPS. Interrupt indicator for BSTS. Interrupt indicator for SWS. Interrupt indicator for CLIPS. 31 Default 0x1852 Default 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Default 0 0 0 0 0 0 0 0 0 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW88298 May. 2022 V1.6 R/W RW INTMODE RW 8 INTN RW 7 RCV_MODE RW 6 I2SEN RW 5 WSINV RW 4 BCKINV RW 3 IPLL RW Description Reserved Interrupt pad INTN output mode selection 0: Open-drain 1: Push Pull Interrupt pad INTN pin-source selection 0: SYSINT 1: SYSST Receiver mode enable, active "1". 0: Speaker mode 1: Receiver mode Disable/Enable whole I2S interface module 0: disable 1: enable I2S Left/Right channel switch 0: No switch 1: Left/Right switch I2S bit clock invert control 0: not invert 1: inverted PLL reference clock selection 0: bit clock 1: word selection signal aw ini 9 www.awinic.com 32 l SYSCTRL: (Address 04h) Bit Symbol 15:10 Reserved Description Interrupt mask for OVP2I Interrupt mask for UVLI. Interrupt mask for ADPI Not used Interrupt mask for BSTOCI. Interrupt mask for OVPI Interrupt mask for BSTI. Interrupt indicator for SWI. Interrupt indicator for CLIPI. Not used Interrupt mask for NOCLKI. Interrupt mask for CLKI. Interrupt mask for OCDI. Interrupt mask for CLIP_PREI. Interrupt mask for OTHI. Interrupt mask for PLLI. tia R/W RW RW RW RW RW RW RW RW RW RW RW RW RW RW RW RW 0 0 0 0 0 0 0 en SYSINTM: (Address 03h) Bit Symbol 15 OVP2M 14 UVLM 13 ADPM 12 Reserved 11 BSTOCM 10 OVPM 9 BSTM 8 SWM 7 CLIPM 6 Reserved 5 NOCLKM 4 CLKM 3 OCDM 2 CLIP_PREM 1 OTHM 0 PLLM Not used Interrupt indicator for NOCLKS. Interrupt indicator for CLKS. Interrupt indicator for OCDS Interrupt indicator for CLIP_PRES Interrupt indicator for OTHS. Interrupt indicator for PLLS. fid RC RC RC RC RC RC RC on Reserved NOCLKI CLKI OCDI CLIP_PREI OTHI PLLI cC 6 5 4 3 2 1 0 Default 1 1 1 0 1 1 1 1 1 0 1 1 1 1 1 1 Default 0x10 0 0 0 0 0 0 0 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW88298 May. 2022 V1.6 AMPPD RW 0 PWDN RW SYSCTRL2: (Address 05h) Bit Symbol 15:8 Reserved R/W RW RMSE RW 6 HAGCE RW 5 HDCCE RW 4 HMUTE RW 0 1 1 Default 0 0 0 1 1 on 7 Description Not used Enable of RMS HAGC 0:disable 1:enable Disable/Enable Peak AGC 0:disable 1:enable Enable/Disable Hardware DC Canceling module 0: disable 1: enable Enable/Disable Hardware mute module 0: disable 1: enable l 1 Not used Amplifier power down control bit, Power Down until system configuration finished 0: normal working 1: power down System power down control bit 0: System normal working 1: All circuits will enter power down mode tia RW en Reserved fid 2 cC BST_IPEAK RW aw ini 3:0 Boost peak current limiter threshold 0000: 1.5A 0001: 1.75A 0010: 2.0A 0011: 2.25A 0100: 2.5A 0101: 2.75A 0110: 3.0A 0111: 3.25A 1000: 3.5A 1001: 3.75A 1010: 4A 1011: 4.25A Others: Reserved I2SCTRL: (Address 06h) Bit Symbol 15:14 Reserved R/W RW 13 INPLEV RW 12 I2SRXEN RW www.awinic.com Description Not used Input level selection bit, when it is set to 1, all input signal will be attenuated at first 0: not attenuated 1: attenuated by -6dB Disable/Enable I2S receiver module 0: disable 1: enable 33 8 Default 0 0 1 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW88298 May. 2022 V1.6 3:0 I2SBCK I2SSR 0 RW I2S LSB justified mode data width selection 00: 16 bits 01: 20 bits 10: 24 bits 11: 32 bits RW I2S BCK mode 00: 32*fs(16*2) 01: 48*fs(24*2) 10: 64*fs(32*2) 11: Reserved RW I2S interface sample rate configuration 0000: 8 kHz 0001: 11.025kHz 0010: 12 kHz 0011: 16 kHz 0100: 22.05kHz 0101: 24 kHz 0110: 32 kHz 0111: 44.1 kHz 1000: 48 kHz 1001: 96 KHz 1010: 192KHz Others: Reserved R/W RW 13:12 RW 11:8 tia aw ini I2SCFG1: (Address 07h) Bit Symbol 15:14 Reserved I2S_TX_SLOTVLD I2S_RX_SLOTVLD www.awinic.com l RW I2S interface mode 00: Philip standard I2S (default) 01: MSB justified 10: LSB justified 11: Reserved en 5:4 I2SFS 1 3 2 fid 7:6 I2SMD RW on 9:8 CHSEL 8 cC 11:10 Left/right channel selection for I2S input 00: reserved 01: left 10: right 11: mono, (L+R)/2 RW Description Not used TX slot selection, data will be sent to one of the four slots in TDM mode. 00: Slot 0 01: Slot 1 10: Slot 2 11: Slot 3 RX slots selection, two slots will be chosen as active slots in TDM mode. Valid settings are as follows 0011: Slots 0 and 1 0101: Slots 0 and 2 1001: Slots 0 and 3 0110: Slots 1 and 2 1010: Slots 1 and 3 1100: Slots 2 and 3 Others: Reserved 34 Default 0 0 3 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW88298 May. 2022 V1.6 CFSEL RW 5 DRVSTREN RW 4 DOHZ RW 3 FSYNC_TYPE RW 2 SLOT_NUM RW 1 I2SCHS RW 0 I2STXEN RW 0 I2S_DATAO PAD driving strength setting 0: 2mA 1: 8mA Unused channel data control 0: All Channels available 1: Hi-Z Audio Frame synchronization signal (WCK) pulse width configuration 0: one slot width 1: one BCK clock cycle Slot number selection, the 2-slot mode is compatible with I2S, and 4slot mode is for TDM mode (max 4 slots support). 0: 2 slots 1: 4 slots I2S TX Channel output selection 0: Left channel 1: Right channel Disable/Enable I2S transmitter module 0: disable 1: enable 1 1 AVTH RW HAGCCFG2: (Address 0ah) Bit Symbol R/W ATTH RW HAGCCFG3: (Address 0bh) Bit Symbol R/W 15:0 RTTH RW HAGCCFG4: (Address 0ch) Bit Symbol R/W 15:8 VOL RW 7:0 HOLDTH RW www.awinic.com en fid 0 0 0 Default 0x39 Description Attack time threshold in unit of 20.8μs 0: reserved n: gain decreased 0.5db per n*20.8us Default aw ini 15:0 0 Description Release Amplitude threshold, in percent of signal full scale Attack Amplitude threshold, in percent of signal full scale RMSE = 0 : P0= ((i/256*Gain)**2)/8/2 RMSE = 1 : P0=(i/256)*(Gain**2)/8 cC 7:0 on HAGCCFG1: (Address 09h) Bit Symbol R/W 15:8 RVTH RW tia l 7:6 I2S legacy path output data selection 00: HAGC data Others: Reserved 0x40 0x0030 Description Release time threshold in unit of 20.8μs 0: reserved n: gain decreased 0.5db per n*20.8μs Default Description Volume control, from 0 to -96dB [3:0] : in unit of -0.5dB [7:4] : in unit of -6dB Attack time threshold in unit of about 1.33ms 0: reserved n: attack counter holding at least n*1.33ms Default 35 0x01E0 0 0x64 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW88298 May. 2022 V1.6 VBAT_DET TEMP: (Address 13h) Bit Symbol 15:10 Reserved 9:0 TEMP_DET PVDD: (Address 14h) Bit Symbol 15:10 Reserved RO R/W RO PVDD_DET RO BSTCTRL1: (Address 60h) Bit Symbol 15:14 Reserved R/W RW 13:8 BST_RTH RW 7:6 Reserved RW 5:0 BST_ATH RW BSTCTRL2: (Address 61h) Bit Symbol 15 Reserved R/W RW www.awinic.com Default 0 0 l R/W RO Description Not used Detected Voltage of battery, and the fullrange is 6.025V V_BATS=(VDD)/1023×6.025 Description Not used Detected Die Temperature (Two's Complement), typical values are as follows. 0x3D8: -40degree 0x00: 0 degree 0x01: 1 degree 0x19: 25 degree 0x37: 55 degree Please convert it to decimal number please. Description Not used Detected Voltage of PVDD, and the full range is 12.05V PVDD=(PVDD_DET)/1023×12.05 aw ini 9:0 RO tia 9:0 R/W RO en VDD: (Address 12h) Bit Symbol 15:10 Reserved RO fid BSTVOUT_ST Description Not used Actual setting of boost output voltage (125mV/Step) 001111: 5.0V …... 111001: 10.25V Others: Reserved Default 0 0x263 Default 0 0x019 on 5:0 R/W RO cC HAGCST: (Address 10h) Bit Symbol 15:6 Reserved Default 0 0x263 Description Not used Smart boost release threshold setting, When signal is below the threshold, the voltage of VBST will not be raised up higher than VDD in smart boost mode Release threshold = BST_RTH * 1/64 Full-scale Not used Smart boost attack threshold setting. When signal is above over the threshold, the voltage of VBST will be raised up higher than VDD in smart boost mode Attack threshold = BST_ATH * 1/64 Full-scale Default 0 Description Default 0 Not used 36 4 0 2 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW88298 May. 2022 V1.6 14:12 11 BST_MODE RW Reserved RW BOOST mode selection, Initialize to 6. 000: Transparent Mode 001: Force Boost Mode 011: Reserved 101: Smart Boost 1 Mode Others: Smart Boost 2 Mode Not used 0x6 0 BST_TDEG RW 7:6 Reserved RW Not Used RW BOOST max output voltage control bits (125mV/Step) 001111: 5.0V …... 111001: 10.25V Others: Reserved en fid VOUT_VREFSET 0x6 1 0x33 aw ini cC on 5:0 tia l 10:8 Smart Boost 1 small signal level detection deglitch time 000: 0.33 ms 001: 1.40 ms 010: 5.60 ms 011: 21.30 ms 100: 44 ms 101: 88 ms 110: 352 ms 111: 1.4 s www.awinic.com 37 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW88298 May. 2022 V1.6 APPLICATION INFORMATION EXTERNAL COMPONENTS BOOST INDUCTOR SELECTION aw ini cC on fid en tia l Selecting inductor needs to consider Inductance, size, magnetic shielding, saturation current and temperature current. a) Inductance Inductance value is limited by the boost converter's internal loop compensation. In order to ensure phase margin sufficient under all operating conditions, recommended 1μH inductor. b) Size For a certain value of inductor, the smaller the size, the greater the parasitic series resistance of the inductor DCR, the higher the loss, corresponds to the lower efficiency. c) Magnetic shielding Magnetic shielding can effectively prevent the inductance of the electromagnetic radiation interference. It is much better to choose inductance with magnetic shielding in the application of EMI sensitive environment. d) Saturation current and temperature rise of current Inductor saturation current and temperature rise current value are important basis for selecting the inductor. As the inductor current increases, on the one hand, since the magnetic core begins to saturate, inductance value will decline; on the other hand, the inductor's parasitic resistance inductance and magnetic core loss can lead to temperature rise. In general, the current value is defined as the saturation current ISAT when the inductance value drops to 70%; the current value is defined as temperature rise current IRMS when inductance temperature rise 40℃. For particular applications, need to calculate the maximum IL_PEAK and IL_RMS, which is a basis of selecting the inductor. When VDD = 4.2V, PVDD=9.5V, RL = 8Ω,amplifier RDSON = 300mΩ, when THD = 1% (the maximum power without distortion), the output power is calculated as follows: 2 2 𝑅𝐿 8 (𝑉𝑜𝑢𝑡 × ) (9.5 × ) 𝑅𝐿 + 𝑅𝐷𝑆𝑂𝑁 8 + 0.3 = 5.24𝑊 𝑃𝑜𝑢𝑡 = = 2 × 𝑅𝐿 2×8 In such a large output power, the overall efficiency of the power amplifier is typically 70%, in order to calculate the maximum average current IMAX_AVG_VDD and maximum peak current IMAX_PEAK_VDD drawn from VDD: 𝑃𝑜𝑢𝑡 5.24 𝐼𝑀𝐴𝑋𝐴𝑉𝐺 = = = 1.78𝐴 𝑉𝐷𝐷 𝑉𝑖𝑛 × 𝜂 4.2 × 0.7 𝐼𝑀𝐴𝑋_𝑃𝐸𝐴𝐾_𝑉𝐷𝐷 = 2 × 𝐼𝑀𝐴𝑋_𝐴𝑉𝐺_𝑉𝐷𝐷 = 2 × 1.78𝐴 = 3.6𝐴 If inductor DCR is 50mΩ, the inductor power loss at this time is: 2 𝑃𝐷𝐶𝑅_𝐿𝑂𝑆𝑆 = 1.5 × 𝐼𝑀𝐴𝑋_𝐴𝑉𝐺_𝑉𝐷𝐷 × DCR = 1.5 × 1.782 × 0.05𝑊 = 240𝑚𝑊 Wherein the coefficient 1.5 is the square of the ratio of the sine wave current RMS value and average value (there is no consideration of the impact of the inductor ripple, the actual DCR loss will be even greater). If the loss which is resulting from DCR is less than 1% at maximum efficiency (POUT = 2.5W, η = 80%), then: 𝐼𝐴𝑉𝐺_𝑉𝐷𝐷 = DCR = www.awinic.com 𝑃𝑜𝑢𝑡 2.5 = = 0.75𝐴 𝑉𝑖𝑛 × 𝜂 4.2 × 0.8 𝑃𝐷𝐶𝑅_𝐿𝑂𝑆𝑆 𝑃𝑜𝑢𝑡 0.01 × 2.5 ≤ 1% × = Ω = 37𝑚Ω 2 2 1.5 × 𝐼𝑀𝐴𝑋_𝐴𝑉𝐺_𝑉𝐷𝐷 1.5 × 𝐼𝐴𝑉𝐺_𝑉𝐷𝐷 × 𝜂 1.5 × 0.752 × 0.8 38 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW88298 May. 2022 V1.6 According to the working principle of the Boost, we can calculate the size of the inductor current ripple Δ IL: ∆𝐼𝐿 = 𝑉𝑖𝑛 × (𝑉𝑜𝑢𝑡 − 𝑉𝑖𝑛 ) 4.2 × (9.5 − 4.2) = = 1.46𝐴 𝑉𝑜𝑢𝑡 × 𝑓 × 𝐿 9.5 × 1.6 × 106 × 1 × 10−6 Thus, the maximum peak inductor current IL_PEAK and maximum effective inductor current IL_RMS is: 2 𝐼𝐿_𝑅𝑀𝑆 = √𝐼𝑀𝐴𝑋_𝑃𝐸𝐴𝐾_𝑉𝐷𝐷 + 2 = 3.6 + 1.46 𝐴 = 4.33𝐴 2 l ∆𝐼𝐿 tia 𝐼𝐿_𝑃𝐸𝐴𝐾 = 𝐼𝑀𝐴𝑋_𝑃𝐸𝐴𝐾_𝑉𝐷𝐷 + ∆𝐼𝐿2 1.462 = √3.62 + 𝐴 = 3.62𝐴 12 12 on fid en From the above calculation results: 1) For typical DCR about 50mΩ inductance, the efficiency loss caused by around1.5%; 2) In practice, the maximum output power of the amplifier is likely to reach 5.6W in an instant, so the selected inductor saturation current ISAT requires more than the maximum inductor peak current IL_PEAK; 3) In some cases, if the IL_PEAK calculated according to the above method is greater than the set of input inductor current limit value IPEAK, shows the power amplifier is restricted by inductance input current limit, the actual maximum output power is less than the calculated value, the measured value shall prevail, and ISAT need greater than the set current limiting value IPEAK, and cannot be less than 3.5A; 4) Take PVDD = 9.5V for example, under different conditions, the typical method of selecting I SAT in the following table: PVDD RL IPEAK Efficiency(η) PO IL_PEAK (V) (V) (Ω) (A) (%) (W) (A) 4.2 9.5 8 4.2 9.5 6 cC VDD Inductor saturation current ISAT minimum value (A) 4.25 74 5.2 4.33 4.2 4.25 69 5.4 4.5 4.2 aw ini 5) As the result of the action of AGC,amplifier will not work long hours at maximum power without distortion, the actual average inductor current is far less than the maximum inductor current effective I L_RMS, so when selecting the inductor, the inductor temperature rise current is not usually a limiting factor; 6) Inductor Selection example: the inductor package size is 252012, inductance value is 1μH, DCR Typical value is 48mΩ, the typical saturation current ISAT is 4.2A, the typical temperature rise current IRMS is 3.4A, suitable for VDD=3.6V, PVDD=9.5V, speaker impedance RL=8Ω, inductor input current limit IPEAK= 4.25A. If you choose ISAT or IRMS of the inductance is too small, it is possible to cause the chip don’t work properly, or the temperature of the inductance is too high. www.awinic.com Inductance value size DCR (Ω) (A) IRMS (A) 1μH 2.5×2.0×1.2mm 0.054 4.2 3.4 39 ISAT Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW88298 May. 2022 V1.6 BOOST CAPACITOR SELECTION fid en tia l Boost output capacitor is usually within the range 0.1μF~47μF. It needs to use Class II type (EIA) multilayer ceramic capacitors (MLCC). Its internal dielectric is ferroelectric material (typically BaTiO 3), a high the dielectric constant in order to achieve smaller size, but at the same Class II type (EIA) multilayer ceramic capacitors has poor temperature stability and voltage stability as compared to the Class I type (EIA) capacitance. Capacitor is selected based on the requirements of temperature stability and voltage stability, considering the capacitance material, capacitor voltage, and capacitor size and capacitance values. A) temperature stability Class II capacitance have different temperature stability in different materials, usually choose X5R type in order to ensure enough temperature stability, and X7R type capacitance has better properties, the price is relatively more expensive; X5R capacitance change within ± 15% in temperature range of 55°C to 85°C, X7R capacitance change within ±15% in temperature range of -55°C~125°C. The Boost output capacitance of DEVICE recommends X5R ceramic capacitors. B) Voltage Stability Class II type capacitor has poor voltage stability Capacitance values falling fast along with the DC bias voltage applied across the capacitor increasing. The rate of decline is related to capacitance material, capacitors rated voltage, capacitance volume. Take TDK C series X5R for example, its pressure voltage value is 16V or 25V; the package size is 0805, 1206 or 0603, the capacitance value is 10μF. The capacitor’s voltage stability of different types of capacitor is as shown below: Capacitor Variation v.s. DC Voltage on 10 0 -10 cC -30 -40 -50 -60 aw ini C-Change (%) -20 0603,X5R,16V,10uF,0.80mm 0603,X5R,25V,10uF,0.80mm 0805,X5R,16V,10uF,0.85mm 0805,X5R,16V,10uF,1.25mm 0805,X5R,25V,10uF,0.85mm 0805,X5R,25V,10uF,1.25mm 1206,X5R,16V,10uF,0.85mm 1206,X5R,16V,10uF,1.60mm 1206,X5R,25V,10uF,0.85mm 1206,X5R,25V,10uF,1.60mm -70 -80 -90 -100 0 5 10 15 20 25 VDC (V) Different types of capacitive voltage stability It can be found that the rate of capacitance capacity value descent becomes slow along with "large capacitor size, capacitance pressure voltage rise”. The larger the package size, the better voltage stability. The higher the height, the better voltage stability with the same length and width of the capacitance. Voltage stability of smaller package size (0603) capacitor change affected by the pressure value is very small. In typical applications, it is necessary to ensure the residual capacitance should ≥4μF when PVDD=10.25V. www.awinic.com 40 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW88298 May. 2022 V1.6 Take the following capacitances as the Boost of the output capacitor for example: value material size (mm3) rated voltage (V) quantity value@10.25V 10μF X5R 1.60×0.80×0.40 (0603) 16 3 4.5μF 10μF X5R 2.00×1.25×0.50 (0805) 25 2 4.2μF tia l As for the different manufacturers’ capacitors, it’s important to determine the type and quantity of the capacitors through the capacitor voltage stability data provided by the manufacturer. SUPPLY DECOUPLING CAPACITOR aw ini cC on fid en The device is a high-performance audio amplifier that requires adequate power supply decoupling. Place a low equivalent-series-resistance (ESR) ceramic capacitor, typically 0.1μF. This choice of capacitor and placement helps with higher frequency transients, spikes, or digital hash on the line. Additionally, placing this decoupling capacitor close to the DEVICE is important, as any parasitic resistance or inductance between the device and the capacitor causes efficiency loss. In addition to the 0.1μF ceramic capacitor, place a 10μF capacitor on the VDD supply trace. This larger capacitor acts as a charge reservoir, providing energy faster than the board supply, thus helping to prevent any droop in the supply voltage. www.awinic.com 41 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW88298 May. 2022 V1.6 PACKAGE DESCRIPTION 3.50 BSC tia l PIN1 Corner en 3.50 BSC fid TOP VIEW on 0.00~0.05 SIDE VIEW cC 0.203 REF 2.30±0.10 2.00 BSC 7 12 13 2.00 BSC aw ini 6 2.30±0.10 0.75±0.05 SYMM 0.40 BSC 24x(0.20±0.05) 18 1 24 0.40 BSC 19 SYMM 24x(0.30±0.10) BOTTOM VIEW Dimensions are all in Millimeters www.awinic.com 42 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW88298 May. 2022 V1.6 LAND PATTERN DATA SYMM 0.400 BSC 24 19 18 l 1 tia 0.400 BSC 2.300 en SYMM 3.700 24x 0.400 fid 2.300 24x 0.200 on 6 cC 7 13 12 3.700 SOLDER MASK OPENING aw ini 0.05 MAX All AROUND 0.05 MIN All AROUND METAL SOLDER MASK OPENING METAL UNDE R SOLDER MASK SOLDER MASK DEFINED NON SOLDER MASK DEFINED Dimensions are all in millimeters www.awinic.com 43 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW88298 May. 2022 V1.6 TAPE AND REEL INFORMATION TAPE DIMENSIONS REEL DIMENSIONS P1 P0 P2 K0 W tia l B0 D1 A0 en Cavity fid A0:Dimension designed to accommodate the component width B0:Dimension designed to accommodate the component length K0:Dimension designed to accommodate the component thickness W:Overall width of the carrier tape P0:Pitch between successive cavity centers and sprocket hole P1:Pitch between successive cavity centers P2:Pitch between sprocket hole D0:Reel width D1:Reel diameter on D0 cC QUADRANT ASSIGNMENTS FOR PIN 1 ORIENTATION IN TAPE Sprocket Holes Q2 Q1 Q2 Q1 Q2 Q1 Q2 Q3 Q4 Q3 Q4 Q3 Q4 Q3 Q4 aw ini Q1 User Direction of Feed Pocket Quadrants All dimensions are nominal D1 (mm) 330 www.awinic.com D0 A0 (mm) (mm) 12.4 3.8 B0 (mm) K0 (mm) P0 (mm) P1 (mm) P2 (mm) W (mm) Pin1 Quadrant 3.8 1.1 2 8 4 12 Q1 44 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW88298 May. 2022 V1.6 REVISION HISTORY Date Change Record V1.0 May. 2020 Officially Released V1.1 July. 2020 Fix Typos V1.2 Oct. 2020 Modify Power On/Power Off timing sequence V1.3 Mar.2021 Update Characteristics V1.4 Jun.2021 Update Characteristics V1.5 Oct.2021 Update 4Ω application V1.6 May.2022 Officially Released (Universal version) aw ini cC on fid en tia l Version www.awinic.com 45 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW88298 May. 2022 V1.6 DISCLAIMER Information in this document is believed to be accurate and reliable. However, Shanghai AWINIC Technology Co., Ltd (AWINIC Technology) does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. tia l AWINIC Technology reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. Customers shall obtain the latest relevant information before placing orders and shall verify that such information is current and complete. This document supersedes and replaces all information supplied prior to the publication hereof. en AWINIC Technology products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an AWINIC Technology product can reasonably be expected to result in personal injury, death or severe property or environmental damage. AWINIC Technology accepts no liability for inclusion and/or use of AWINIC Technology products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. on fid Applications that are described herein for any of these products are for illustrative purposes only. AWINIC Technology makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. All products are sold subject to the general terms and conditions of commercial sale supplied at the time of order acknowledgement. cC Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Reproduction of AWINIC information in AWINIC data books or data sheets is permissible only if reproduction is without alteration and is accompanied by all associated warranties, conditions, limitations, and notices. AWINIC is not responsible or liable for such altered documentation. Information of third parties may be subject to additional restrictions. aw ini Resale of AWINIC components or services with statements different from or beyond the parameters stated by AWINIC for that component or service voids all express and any implied warranties for the associated AWINIC component or service and is an unfair and deceptive business practice. AWINIC is not responsible or liable for any such statements. www.awinic.com 46 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD
AW88298QNR 价格&库存
很抱歉,暂时无法提供与“AW88298QNR”相匹配的价格&库存,您可以联系我们找货
