AW2026DNR
AW2026DNR
    AWINIC(艾为)
    DFN8_1.5X1.5MM_EP
    带I2C接口的三通道呼吸灯LED驱动器
AW2026DNR 数据手册
AW2026 September 2018 V1.3 3-Channel Breathing LED Driver with IIC Interface GENERAL DESCRIPTION  AW2026 is a three channels constant current LED driver. The max output current is 4-level selectable among 3mA, 6mA, 12mA and 25.5mA. Each LED is 256 current levels configurable so as to achieve 256*256*256 color mixing. The 256-level dimming and 12 bits PWM resolution create fine and smooth dimming effect even in low brightness. ti a 256 current levels setting for each LED  Supports 256*256*256 color-mixing  256-level PWM dimming, 12-bit PWM resolution  Automatic breathing light with flexible pattern configuration and running mode three independent pattern controllers  pulses repeating, multiple colors alternative  multiple patterns running successively or cyclically 400kHz fast I2C interface , 1.8V ~ 3.3V  Single power supply, 2.4V~5.5V  Low power consumption AW2026 is available in a 1.5mm×1.5mm×0.45mm DFN-8L package. C  Less than 1μA in shut down mode  Less than 10μA in standby mode 1.5mm×1.5mm×0.45mm DFN-8L package ic  The device requires only 2.4V~5.5V single power supply. An I2C compatible interface in 400kHz fast mode is provided, the device address is 64h. o  In shut down mode, AW2026 turns off all internal circuit and the consumption is less than 1μA. In standby mode, I2C interface works and the consumption is less than 10μA. n  e  fi d 4- level IMAX selections: 3/6/12/25.5mA n 3-channel constant current LED drivers  l FEATURES a w in TYPICAL APPLICATION CIRCUIT VIO VBAT VBAT 4.7k 1uF GND LED1 MCU LED2 SCL SDA LED3 SCL SDA AW2026 All the trademarks mentioned in the document are the property of their owners. www.awinic.com.cn 1 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW2026 September 2018 V1.3 PIN CONFIGURATION AND TOP MARK AW2026 TOP MARKING AW2026 TOP VIEW SDA SCL VBAT 8 7 6 5 ti a l GND A26 XXX 2 3 4 NC LED3 LED2 LED1 A26 ---- AW2026 XXX ---- Manufacture trace code n 1 fi d e n 9 Exposed Pad o PIN DEFINITION NAME 1 NC 2 LED3 3 LED2 LED2 Cathode Driver, anode connected to VBAT LED1 LED1 Cathode Driver, anode connected to VBAT VBAT Power Supply (2.4V-5.5V) 5 ic 4 DESCRIPTION C No. Not connected LED3 Cathode Driver, anode connected to VBAT SCL Serial Clock Input for I2C Interface 7 SDA Serial Data I/O for I2C Interface 8 GND GND w in 6 Exposed Pad Exposed pad, should be connected to GND. a 9 www.awinic.com.cn 2 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW2026 September 2018 V1.3 l OSC ti a LDO GND VBAT FUNCTIONAL BLOCK DIAGRAM PWM Control BG SCL fi d VBAT LED1 LED2 LED3 C o n SDA IDAC Current Source Control I2C e n Powerdown control 4.7k VIO VBAT VBAT 1uF GND LED1 MCU LED2 SCL SDA SCL SDA a w in ic TYPICAL APPLICATION CIRCUITS www.awinic.com.cn LED3 AW2026 3 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW2026 September 2018 V1.3 ORDERING INFORMATION Temperature Package Marking MSL Level ROHS AW2026DNR -40℃~85℃ 1.5mm×1.5mm×0.45mm DFN-8L A26 XXX MSL1 ROHS+HF Delivery Form Tape and Reel 3000pcs/Reel ti a l Part Number AW2026 PARAMETERS Supply voltage range VBAT fi d ABSOLUTE MAXIMUM RATINGS (NOTE 1) e Package Type DN: DFN -0.3V to 6.0V -0.3V to 6.0V LED1~LED3 -0.3V to 6.0V n Output voltage range RANGE SCL, SDA, o Input voltage range n Shipping R: Tape & Reel SDA -0.3V to 6.0V Junction-to-ambient thermal resistance θJA C 121.6℃/W Operating free-air temperature range -40℃ to 85℃ 150℃ Storage temperature TSTG -65℃ to 150℃ ic Maximum Junction temperature TJMAX Lead Temperature (Soldering 10 Seconds) 260℃ ESD(NOTE 2) ±2000V CDM (charge device mode) ±1500V MM (machine mode) ±300V w in HBM (human body mode) Latch-up ±300mA a Test Condition: JEDEC STANDARD NO.78E September 2016 NOTE1: Conditions out of those ranges listed in “absolute maximum ratings” may cause permanent damages to the device. In spite of the limits above, functional operation conditions of the device should within the ranges listed in “recommended operating conditions”. Exposure to absolute-maximum-rated conditions for prolonged periods may affect device reliability. NOTE2: The human body model is a 100pF capacitor discharged through a 1.5kΩ resistor into each pin. Test method: MIL-STD-883J Method 3015.9 www.awinic.com.cn 4 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW2026 September 2018 V1.3 ELECTRICAL CHARACTERISTICS VBAT=3.8V, TA=25℃ for typical values (unless otherwise noted) Symbol Description Test Conditions Min Typ. Max Units 5.5 V 0.1 1 A 5 10 A 100 A Input operation voltage 2.4 ISHUTDOWN Current in Shutdown mode ISTANDBY Current in Standby mode SCL/SDA=1.8V IQ Quiescent Current in Active mode register CHIPEN=1 SCL/ SDA =0V (over 130ms) 80 n all LED off LED2, LED3 off IACTIVE Current in Active mode 277 fi d All channel set to 25.5mA 565 e All channel set to 25.5mA LED1 set to 25.5mA ti a VBAT l Power supply TRISE=2.1s,TON=0.04s TFALL=2.1s, TOFF=1s 181 A LED1 set to 25.5mA n LED2, LED3 off 121 Digital Logical Interface o TRISE=2.1s,TON=0.04s TFALL=2.1s, TOFF=1s Logic input low level VIH Logic input high level SDA,SCL IIL Low level input current SDA,SCL 5 nA IIH High level input current SDA,SCL 5 nA VOL Logic output low level SDA, IOUT=3mA 0.4 V IL Output leakage current SDA open drain 1 nA 400 kHz 0.4 ic 1.3 in I2C Interface FSCL SDA,SCL C VIL V V I2C-BUS clock frequency SCL deglitch time 200 ns SDA deglitch time 250 ns w TDEGLITCH LED Driver Current accuracy ILED=25.5mA -5% +5% % IMATCH Matching accuracy ILED=25.5mA -5% +5% % VDROP Dropout voltage ILED=25.5mA 60 100 mV FPWM PWM frequency a IACC www.awinic.com.cn Register PWM_F=0 115 122 128 Hz Register PWM_F=1 230 244 256 Hz 5 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW2026 September 2018 V1.3 I2C INTERFACE TIMING TDEGLITCH Deglitch time SCL 200 SDA 250 (Repeat-start) Start condition hold time 0.6 TLOW Low level width of SCL 1.3 THIGH High level width of SCL 0.6 TSU:STA (Repeat-start) Start condition setup time 0.6 THD:DAT Data hold time 0 TSU:DAT Data setup time 0.1 TR Rising time of SDA and SCL TF Falling time of SDA and SCL TSU:STO Stop condition setup time TBUF Time between start and stop condition kHz ns ns μs μs fi d n 400 μs μs μs μs 0.3 μs 0.3 μs 0.6 μs 1.3 μs o tBUF tLOW SCL tHD:DAT VIH VIL tSP tF VIH VIL tSU:DAT tSU:STA Start tSU:STO Stop a w in Start tHIGH tR ic tHD:STA C SDA Stop Units e THD:STA Max l Interface Clock frequency Typ. n FSCL Min ti a Parameter Name www.awinic.com.cn 6 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW2026 September 2018 V1.3 FUNCTIONAL DESCRIPTION POWER_ON RESET ti a l AW2026 provides a power-on reset feature that is controlled by VBAT supply voltage. When the VBAT supply voltage rises from 0V to 2.4V, the internal LDO starts to work. The reset signal will be generated to perform a power-on reset operation, which will reset all control circuits and configuration registers until the internal power voltage become stable. The status bit STATUS.PUIS (register: 0x02 bit4) will be set to 1 when power-on reset operation occurs, which will be cleared by a read operation of STATUS register. Usually the STATUS.PUIS bit can be used to check whether an unexpected power-on event has taken place. n OPERATING MODE fi d Shut Down e In AW2026, pin SCL provides power down control. There are three work modes available: Shut-down, Standby and Active mode. ( SCL=0 for 130ms) ( SCL=0 for 130ms) n SCL = 1 C Standby o CHIPEN=1 Active CHIPEN=0 ic Figure 1 AW2026 operating modes transition SHUT-DOWN MODE w in AW2026 enters into the shut-down mode when SCL level is pulled to low for over 130ms (prevents system against wrong resets caused by electromagnetically influences) In shut-down mode, AW2026 will reset all internal circuits and configuration register, all blocks inside AW2026 are basically switched off except the power on reset circuit and the SCL level detect circuit, and the current consumption is very low (< 1A). STANDBY MODE a AW2026 enters into standby mode when SCL level is pulled high from shut-down mode or CHIPEN is 0 from active mode. In standby mode, only part of internal circuit can work, the OSC still keep closed so that there is not internal clock, the LDO operates in low power state. The current consumption is less than 10A. In stand-by mode, the I2C interface is accessible, but only registers RSTIDR and GCR can be operated. www.awinic.com.cn 7 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW2026 September 2018 V1.3 ACTIVE MODE IACTIVE ti a IF l When bit CHIPEN of GCR register is set to 1in standby mode, AW2026 enters into active mode. In active mode, the internal OSC starts to work to provide clock signal. User can configure the device to produce the pre-defined pattern lighting effects in pattern mode or turn each LED on or off directly. When PWM level is low in fade-in and fade-out, only the OSC module works and the consumption is about 80Ua(IQ). So the average consumption of breathing is every low. When PWM level is low, only the timer module works and the consumption is IQ TON TFALL Time TOFF e TRISE n IQ Figure 2 AW2026 consumption in active mode IMAX 3mA 6.375mA IF 223μA 272μA 12.75mA 368μA 25.5mA 565μA IQ 80μA 80μA 80μA 80μA n (T + TFALL ) * 25% + TON IACTIVE = (IF - IQ ) * RISE + IQ TRISE + TON + TFALL + TOFF fi d Refer the following detailed formula (LED1/LED2/LED3 on) o SOFTWARE RESET C Writing 0x55 to register RSTIDR (register: 0x00) via I2C interface will reset the AW2026 internal circuits and all configuration registers. I2C INTERFACE in ic AW2026 supports the I²C serial bus and data transmission protocol in fast mode at 400 kHz. AW2026 operates as a slave on the I²C bus. Connections to the bus are made via the open-drain I/O pins SCL and SDA. The pullup resistor can be selected in the range of 1k~10kΩ and the typical value is 4.7kΩ. AW2026 can support different high level (1.8V~3.3V) of this I2C interface. DEVICE ADDRESS w The I2C device address (7-bit) of AW2026 is 0x64, followed by the R/W bit (Read=1/Write=0). DATA VALIDATION a When SCL is high level, SDA level must be constant. SDA can be changed only when SCL is low level. www.awinic.com.cn 8 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW2026 September 2018 V1.3 SDA SCL l Change of Data Allowed ti a Data Line Stable Data Valid Figure 3 Data Validation Diagram I2C START/STOP n I2C start: SDA changes form high level to low level when SCL is high level. fi d e I2C stop: SDA changes form low level to high level when SCL is high level. SDA SCL S/Sr P P: STOP condition o n S: START condition Sr: START Repeated condition ACK (ACKNOWLEDGEMENT) C Figure 4 I2C Start/Stop Condition Timing in ic ACK means the successful transfer of I2C bus data. After master sends 8bits data, SDA must be released; SDA is pulled to GND by slave device when slave acknowledges. When master reads, slave device sends 8bit data, releases the SDA and waits for ACK from master. If ACK is send and I2C stop is not send by master, slave device sends the next data. If ACK is not send by master, slave device stops to send data and waits for I2C stop. a w Data Output by Transmiter Not Acknowledge(NACK) Data Output by Receiver Acknowledge(ACK) 2 1 SCL From Master 8 9 Clock Pulse for Acknowledgement START condition Figure 5 I2C ACK Timing www.awinic.com.cn 9 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW2026 September 2018 V1.3 WRITE CYCLE ti a l One data bit is transferred during each clock pulse. Data is sampled during the high state of the serial clock (SCL). Consequently, throughout the clock’s high period, the data should remain stable. Any changes on the SDA line during the high state of the SCL and in the middle of a transaction, aborts the current transaction. New data should be sent during the low SCL state. This protocol allows a single data line to transfer both command/control information and data using the synchronous serial clock. Each data transaction is composed of a Start Condition, a number of byte transfers (set by the software) and a Stop Condition to terminate the transaction. Every byte written to the SDA bus must be 8 bits long and is transferred with the most significant bit first. After each byte, an Acknowledge signal must follow. In a write process, the following steps should be followed: Master device generates START condition. The “START” signal is generated by lowering the i) n SDA signal while the SCL signal is high. Master device sends slave address (7-bit) and the data direction bit (r/w = 0). c) Slave device sends acknowledge signal if the slave address is correct. d) Master sends control register address (8-bit) e) Slave sends acknowledge signal f) Master sends data byte to be written to the addressed register g) Slave sends acknowledge signal h) If master will send further data bytes the control register address will be incremented by one after acknowledge signal (repeat step 6,7) j) Master generates STOP condition to indicate write cycle end 0 1 2 3 4 5 6 7 8 0 C SCL o n fi d e b) 1 2 3 4 5 6 7 8 0 1 2 3 4 5 6 7 8 A6 A5 A4 A3 A2 A1 A0 R/WAck A7 A6 A5 A4 A3 A2 A1 A0 Ack D7 D6 D5 D4 D3 D2 D1 D0 Start Register Address Write Data Stop Figure 6 I2C Write Byte Cycle in READ CYCLE Device Address ic SDA In a read cycle, the following steps should be followed: Master device generates START condition a w a) b) Master device sends slave address (7-bit) and the data direction bit (r/w = 0). c) Slave device sends acknowledge signal if the slave address is correct. d) Master sends control register address (8-bit) e) Slave sends acknowledge signal f) Master generates STOP condition followed with START condition or REPEAT START condition g) Master device sends slave address (7-bit) and the data direction bit (r/w = 1). h) Slave device sends acknowledge signal if the slave address is correct. www.awinic.com.cn 10 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW2026 September 2018 V1.3 Slave sends data byte from addressed register. j) If the master device sends acknowledge signal, the slave device will increase the control register address by one, then send the next data from the new addressed register. k) If the master device generates STOP condition, the read cycle is ended. 0 1 2 3 4 5 SDA A6 A5 A4 A3 A2 A1 7 8 0 1 2 3 4 5 6 7 A0 R/W Ack A7 A6 A5 A4 A3 A2 A1 A0 0 1 2 3 4 5 A6 A5 A4 A3 A2 A1 RS 6 7 8 0 A0 R/W Ack D7 …… S 1 ... 6 D6 …… D1 Write Data Device Address Separated Read/write transaction …… P Register Address 0 1 2 3 4 5 A6 A5 A4 A3 A2 A1 Device Address 6 7 8 0 A0 R/W Ack D7 7 8 1 ... Ack D0 Ack stop e …… Using Repeat start…… 8 n Device Address 6 7 D6 …… D1 D0 fi d start 6 ti a SCL l i) Write Data 8 Ack stop n Figure 7 I2C Read Byte Cycle o LED DRIVER C AW2026 has three LED drivers to drive one RGB LED or three single-color LEDs. Each LED is driven by common-anode mode constant current source with duty cycle controlled by PWM. Both current and PWM can be configured via I2C interface. ic LED CURRENT a w in Globally, the maximum output current for three LEDs is 4-level selectable among 3mA, 6mA, 12mA and 25.5mA via register IMAX (register: 0x03). In general, IMAX is used to set the max brightness of LED output. For each LED, there is 256 current levels configurable via 8-bit register groups ILEDx_y (x=1~3, y=1~4). So in RGB application it is possible to combine into 256x256x256 color-mixing schemes totally to achieve so-called true-color effect. Generally the current level register is used to form specified LED color for RGB application. AW2026 has 4 groups pre-defined current registers capable of forming 4 dedicated colors in true-color pattern scheme, in which up to 4 pre-defined colors can be configured to represent 4 kinds of message, more than one color can flash one by one successively in the same pattern when it’s necessary to transmit more than one messages. PWM DIMMING CONTROL In AW2026, each LED current source is gated by a 256-level, 12bit resolution PWM signal to create fine dimming effect. Each LED has an 8 bit PWM register PWMx (register: 0x1c, 0x1d, 0x1e) to control the duty cycle of constant current source. The ramp up and down are automatically implemented by PWM duty continuously adjusted to www.awinic.com.cn 11 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW2026 September 2018 V1.3 form a smooth LED current transition between ON and OFF state. The ramp slope, for rise and fall, are separately set via configuring the bit4~bit7 in pattern registers PATx_T1 and PATx_T2. The ramping can be configured as linear and logarithmic curve by setting bit0~1 (PWMLOG) in register LEDCTR (register 0x08). l LED CONTROL n fi d e n ti a Each LED of AW2026 can be independently configured to work or not via control bit LEDxEN. - LEDxEN = 0, LEDx channel is disabled and no current output. - LEDxEN = 1, LEDx channel is enabled to output lighting effect in different work mode. By register configuration, AW2026 provides two types of LED control modes: - Pattern control mode. AW2026 contains three independent pattern controller and three groups of pattern parameter register to generate user-defined breathing lighting effect. In RGB application, one pattern controller control 3 LED simultaneously to produce true-color breathing lighting, and three groups of pattern parameter can be executed successively or cyclically. For LED-independent application, three pattern controller are allocated to three different LEDs respectively, each operates with individual pattern parameter, user can start or stop each pattern independently - Manual control mode. User directly set the brightness level of each LED by configuring relative current level register and PWM level register via I2C interface. Usually it’s recommended to modify the PWM level to set on or off. For each variation of PWM level register, the smoothly ramping effect is supported by setting FADE_IN bit and/or FADE_OUT bit in register LCFGx (x=1~3). o PATTERN CONTROL MODE C BREATHING LIGHTING CONTROL ic When register bit LCFGx.LEDMD (register: 0x04, 0x05, 0x06 bit0) is set to 1, the corresponding LEDx operates in pattern mode. User should configure the related pattern parameter registers according to actual timing requirements via I2C interface before starting pattern. The repeating times of pattern is configurable also, which may be 1~ 2048 or infinite according to setting of register PATx_T5 (x=1~3). in Single Pulse mode Current a w Basically one pattern contains only one blinking, it’s called as single pulse mode. In single pulse mode, the pattern parameters includes delay time, rise time, on time, fall time, off time and repeat times can be set by corresponding configuration registers (PATx_T1~T5), The meanings of basic single-pulse pattern parameters are shown in Figure and table below. TDELAY TRISE TON TFALL TOFF Time Figure 8 Basic single-pulse pattern parameter definition www.awinic.com.cn 12 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW2026 September 2018 V1.3 Parameters Delay time until pattern start Rise time for dimming up On time Fall time for dimming down Off time Min 0 0 0.04 0 0.04 Typ. Max 8.3 8.3 8.3 8.3 8.3 Unit s s s s s l Symbol TDELAY TRISE TON TFALL TOFF ti a Multi-pulse mode fi d e n A serial fast pulse blinking can be used to transmit message different from that carried by single pulse. In multipulse mode, up to 4 pulses are allowed during one color blinking. Besides the basic timing parameter defined in single-pulse mode, there are 2 additional parameter need to be set: The number of multi-pulse is defined by setting bit4~5 (MPULSE) in register PATx_T4 (register: 0x33/0x38/ 0x3D) , the actual blinking times is MPULSE+1. The interval time between two adjacent pulses is defined by TSLOT, bit5~7 in PATx_T4 (register: 0x32/0x37/0x3C). Symbol Parameter Min Typ. Max Unit TSLOT Pause time between multiple pulses 0 1.024 s TRISE TON TFALL TSLOT TSLOT ... TOFF Time Pattern o Pattern n Current Figure 9 Multi-pulse pattern parameter definition C An example of multi-pulse pattern is shown below: ic Current in Pattern ... Pattern Pattern Time Figure 10 Multi-pulse pattern example w Multi-color mode a Blinking with multiple different colors is allowed in one pattern period in RGB LED application, if different color is expected to carry different message. In AW2026, the LED color is defined by LED current configure register ILEDx_y (x=1~3, y=1~4), there are 4 RGB current combination to generate 4 pre-defined colors for display. More than one of the 4 pre-defined colors can be chosen by setting CE1~CE4 , bit0~bit3 in PATx_T4 (register:x32/0x37/0x3C), when Cex is set to 1, the color#x is allow to be displayed in current pattern. If the color setting on CE1~CE4 is modified during current pattern is running, the updating of new color setting will not occur until present pattern period is over. If both multi-pulse and multi-color is enabled simultaneously, every selected color will blink specified times before www.awinic.com.cn 13 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW2026 September 2018 V1.3 switching to another color, and the display order of color is always from color #1 to color #4. An example of 4-color /single-pulse pattern is shown below, in which the CE1~CE4 are changed twice during pattern is running. color#2 color#3 color#4 color#1 color#3 CE=0x5 CE=0xF color#2 CE=0xA Pattern color#4 ti a color#1 l Current Time Pattern n Pattern Figure 11 Example of multi-color mode and color scheme modification e TRUE –COLOR BREATHING LIGHTING ic C o n fi d In true-color breathing lighting application, the LEDMD, bit0 in LCFGx (register: 0x04, 0x05, 0x06), and the SYNC, bit3 in LEDCTR (register: 0x08 bit3) should be set to 1, three LED output share the same pattern controller to generate PWM dimming simultaneously. Multi-pulse, multi-color and multi-pattern modes are supported fully in this mode. The RGB color is defined by LED current setting register ILEDx_y (x=1~3, y=1~4), there are 4 RGB current combination to generate 4 pre-defined color for display. In true-color mode (SYNC=1), 3 groups of pattern timer parameters could be applied to defined 3 different breathing lighting effects, which can be executed successively or keep looping forever, without external processor involved to control every pattern switching. For each pattern, if PATx_T4.SW (register: 0x33, 0x38, 0x3E) is set to 1, the next pattern parameter will be loaded and started automatically after current pattern has finished. The following table gives the current, pattern and the start/stop control source for each LED channel in truecolor pattern mode. Current Configuration Channel Pattern used Pattern Start Pattern Stop Register LED1 ILED1_y pattern #1, Write 1 to register Write 1 to register LED2 ILED2_y pattern #2, PATRUN bit0 PATRUN bit4 pattern #3 LED3 ILED3_y in Note: Y=1~4, denotes 4 pre-defined color code ( color #1, color #2, color #3 and color #4). An example of single pulse and color pattern repeating in true-color pattern mode is depicted in the figure below. a w Current Pattern Pattern Pattern Time Figure 12 Example of single-pulse/single-color true-color pattern www.awinic.com.cn 14 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW2026 September 2018 V1.3 The following figure is an example of multi pulse and multi-color pattern repeating in true-color pattern mode. Time Pattern Figure 13 Example of 2-pulse/2-color in true-color pattern ti a Pattern l Current The following figure is another example of three patterns running successively in true-color pattern mode. Pattern1 fi d e n Current Pattern2 Pattern3 Time Figure 14 Example of 3 pattern running successively in true-color mode n INDIVIDUAL BREATHING LIGHTING w in ic C o In some application where three LED need blinking individually. When register bit LCFGx.LEDMD (register: 0x04, 0x05, 0x06 bit0) is set to 1, the corresponding LEDx operates in pattern mode. If register bit LEDCTR.SYNC (register: 0x08 bit3) is 0, all pattern run in individually. In this mode, the 3 internal pattern controllers and 3 groups of pattern parameters are distributed to 3 LED channel respectively. Each LED can be controlled independently to blink according to its own pattern definition. In this mode, multi-pulse pattern is supported, but multi-color is not supported, the bits CE1~CE4 in register PATx_T4 are ignored. Only registers ILEDx_1 is active for LED current setting, the other register including ILEDx_2, ILEDx_3 and ILEDx_4 are all useless. The following table gives the current, pattern parameter and the start/stop control source selection for each LED channel in individual breathing lighting mode. Pattern Channel Current Setting Register Pattern Start Pattern Stop used write 1 to PATRUN write 1 to PATRUN LED1 ILED1_1 (register: 0x10) pattern #1 bit0 bit4 write 1 to PATRUN write 1 to PATRUN LED2 ILED2_1 (register: 0x11) pattern #2 bit1 bit5 write 1 to PATRUN write 1 to PATRUN LED3 ILED3_1 (register: 0x12) pattern #3 bit2 bit6 a The following figure shows an example of 3 patterns run individually with different pattern parameters. www.awinic.com.cn 15 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW2026 September 2018 V1.3 LED1 Pattern#1: repeat times = 1 Time LED2 Time n Pattern#3: repeat times = infinite LED3 ti a l Pattern#2: repeat times = 3 Time e Figure 15 Example of Individual Pattern Mode fi d MANUAL CONTROL MODE ic C o n When control bit LCFGx.LEDMD (register: 0x04, 0x05, 0x06 bit0) is set to 0, the corresponding LEDx is work in manual control mode. In manual control mode, the LED lighting effects including color-mixed and brightness is directly configured by setting current/ PWM level register via I2C interface. When LEDCTR.SYNC (register: 0x08, bit3) is set to 0, three LED are controlled individually, the PWM level and current for each is defined by PWM1/PWM2/PWM3 (register: 0x1C/0x1D/0x1E) and ILEDx_1 (register 0x10/0x11/0x12) respectively. When LEDCTR.SYNC (register: 0x08, bit3) is set to 1, the output currents of three LED are defined by register ILEDx_1 respectively, but their PWM level are determined commonly by register PWM1. So user can change the brightness of all LED simultaneously by modifying the value of register PWM1 only. Brightness Trise and Tfall time Channel Current SYNC=0 SYNC=1 SYNC=0 SYNC=1 LED1 ILED1_1 PWM1 PAT1_T1/T2 LED2 ILED2_1 PWM2 PWM1 PAT2_T1/T2 PAT1_T1/T2 LED3 ILED3_1 PWM3 PAT3_T1/T2 a w in In manual control mode, auto dimming is supported. If LCFGx.FADE_OUT (register: 0x04, 0x05 0x06 bit2) is set to 1, automatic fade-out is enabled. If LCFGx.FADE_IN (register: 0x04, 0x05, 0x06 bit1) is set to 1, automatic fade-in is enabled. If a new value is set on PWMx register and auto dimming is enabled, the brightness of LED output ramp up/down smoothly, with its Trise and Tfall time defined by corresponding pattern configuration (PATx_T1 and PATx_T2). www.awinic.com.cn 16 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW2026 September 2018 V1.3 PWMx 0xFF 0xBF FADE_IN=0 0x7F FADE_OUT=0 0x3F 0 PWMx l Time 0xBF 0x7F FADE_OUT=1 FADE_IN=1 0x3F 0 PWMx=0xFF ti a 0xFF Time n PWMx=0 a w in ic C o n fi d e Figure 16 Manual Control Mode www.awinic.com.cn 17 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW2026 September 2018 V1.3 REGISTER DESCRIPTION REGISTER LIST RSTIDR GCR STATUS IMAX LCFG1 LCFG2 LCFG3 LEDEN LEDCTR PATRUN ILED1_1 ILED2_1 ILED3_1 ILED1_2 ILED2_2 ILED3_2 ILED1_3 ILED2_3 ILED3_3 ILED1_4 ILED2_4 ILED3_4 PWM1 PWM2 PWM3 PAT1_T1 PAT1_T2 PAT1_T3 PAT1_T4 PAT1_T5 PAT2_T1 PAT2_T2 PAT2_T3 PAT2_T4 PAT2_T5 PAT3_T1 PAT3_T2 PAT3_T3 PAT3_T4 PAT3_T5 R R/W R R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W 0 5 0 1 - - 3 2 1 0 PUIS SYNC STOP2 STOP1 ILED1_1 ILED2_1 ILED3_1 ILED1_2 ILED2_2 ILED3_2 ILED1_3 ILED2_3 ILED3_3 ILED1_4 ILED2_4 ILED3_4 PWM1 PWM2 PWM3 STOP3 1 0 PWM_F LS2 FADE_OUT FADE_OUT FADE_OUT LED3EN RUN3 0 0 1 CHIPEN LS1 LS0 IMAX FADE_IN LEDMD FADE_IN LEDMD FADE_IN LEDMD LED2EN LED1EN PWMLOG RUN2 RUN1 RESERVE o n fi d e - 4 - - TRISE TFALL TSLOT PATSW MPULSE C PATCTR ic in 6 l 7 ti a R/W n Name PATCTR TRISE TFALL TSLOT PATSW MPULSE PATCTR TRISE TFALL TSLOT PATSW MPULSE TON TOFF TDELAY CE4 REPTIM CE3 CE2 CE1 CE2 CE1 CE2 CE1 TON TOFF TDELAY CE4 REPTIM CE3 TON TOFF TDELAY CE4 REPTIM CE3 a w Addr (Hex) 00 01 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 19 1A 1B 1C 1D 1E 30 31 32 33 34 35 36 37 38 39 3A 3B 3C 3D 3E DETAILED REGISTER DESCRIPTION RSTIDR, Chip ID and Software Reset Register Address: 0x00, R/W, default: 0x31 7 6 5 D7 D6 D5 www.awinic.com.cn 4 D4 3 D3 18 2 D2 1 D1 0 D0 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW2026 September 2018 V1.3 Bit 7:0 Symbol IDR Description Chip ID, 0x31 Reset: write 0x55 to RSTIDR, reset internal logic and register RESERVE CHIPEN 1 RESERVE Description PWM Modulation Frequency Select 0: 122Hz PWM modulation 1: 245Hz PWM modulation Should be set to “1” Device operating Enable 0: Disable, the device is in standby state 1: Enable, the device enters active state STATUS Register 4 PUIS 3 - 2 LS3 1 LS2 0 LS1 n Address: 0x02, R/W, default: 0x10 7 6 5 0 0 0 0 CHIPEN n 1 0 2 PWM_F e Symbol PWM_F 3 - fi d Bit 2 4 - ti a Address: 0x01, R/W, default: 0x00 7 6 5 - l GCR, Global Control Register Symbol PUIS Description Power Up Interrupt Status 0: No power-up reset has taken place 1: Power-up reset has taken place 2 LS3 operating status indication for pattern controller 3 0: stop state 1: running state 1 LS2 operating status indication for pattern controller 2 0: stop state 1: running state 0 LS1 operating status indication for pattern controller 1 0: stop state 1: running state in ic C o Bit 4 w IMAX, LED Maximum Current Register a Address: 0x03, R/W, default: 0x01 7 6 5 Bit 1:0 Symbol IMAX www.awinic.com.cn 4 - 3 - 2 - 1 0 IMAX Description Maximum LED output Current Select 00:3.1875Ma 01:6.375Ma 10:12.75Ma 11:25.5Ma 19 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW2026 September 2018 V1.3 LCFG1-3 LED Configure Register 4 - 3 - 2 FADE_OUT 1 FADE_IN Symbol FADE_OUT Description Fade-out enable control, only active in manual mode 0: PWM fade-out is disable, 1: PWM fade-out is enable, the dimming time decide by TFALL 1 FADE_IN Fade-in enable control, only active in manual mode 0: PWM fade-in is disable, 1: PWM fade-in is enable, the dimming time decide by TRISE 0 LEDMD n ti a Bit 2 0 LEDMD l LCFG1: Address: 0x04, R/W, default: 0x01 LCFG2: Address: 0x05, R/W, default: 0x00 LCFG3: Address: 0x06, R/W, default: 0x00 7 6 5 - fi d e LED Operating Mode Select. 0: Manual mode, LEDx is control directly by register ILEDx_1 and PWMx 1: Pattern mode LEDEN, LED Channel Enable Register Address: 0x07, R/W, default: 0x01 7 6 5 - 4 - 3 - 2 LED3EN Symbol LED3EN Description LED3 Enable 0: LED3 module stop work and LED3 out disable 1: LED3 output is enabled 1 LED2EN LED2 Enable 0: LED2 module stop work and LED2 out disable 1: LED2 output is enabled 0 LED1EN LED1 Enable 0: LED1 module stop work and LED1 out disable 1: LED1 output is enabled 0 LED1EN ic C o n Bit 2 1 LED2EN in LEDCTR, LED Control Register a w Address: 0x08, R/W, default: 0x00 7 6 5 Bit 3 Symbol SYNC 1:0 PWMLOG www.awinic.com.cn 4 - 3 SYNC 2 - 1 0 PWMLOG Description LED Breathing Synchronous Mode Select 0: 3 LED work in asynchronous mode with independent control 1: 3 LED work in synchronous mode for RGB application. PWM Logarithmic curve select 0x: Log60 10: Log10 11: Linearity 20 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW2026 September 2018 V1.3 PATRUN, Pattern Run/Stop Register 2 RUN3 Symbol STOP3 Description Write 1, LED3 pattern stop if independent mode; The bit clears to 0 automatically after write 1. 5 STOP2 Write 1, LED2 pattern stop if independent mode; The bit clears to 0 automatically after write 1. 4 STOP1 Write 1, LED1 pattern stop if independent mode; Write 1, pattern stop if pattern mode; The bit clears to 0 automatically after write 1. 2 RUN3 Write 1, LED3 pattern run if independent mode; The bit clears to 0 automatically after write 1. 1 RUN2 Write 1, LED2 pattern run if independent mode; The bit clears to 0 automatically after write 1. 0 RUN1 Write 1, LED1 pattern run if independent mode; Write 1, pattern run if pattern mode; The bit clears to 0 automatically after write 1. fi d LED1 Current Register C o ILED1_1: Address: 0x10, R/W, default: 0Xff ILED1_2: Address: 0x13, R/W, default: 0x00 ILED1_3: Address: 0x16, R/W, default: 0x00 ILED1_4: Address: 0x19, R/W, default: 0x00 7 6 5 n ILED1_y, 0 RUN1 e Bit 6 1 RUN2 l 3 - ti a 4 STOP1 n Address: 0x09, R/W, default: 0x00 7 6 5 STOP3 STOP2 Symbol ILED1_y 3 2 1 0 Description LED1 Current Configure Register for 4 pre-defined colors, The LED1 output current value is IMAX * ILED1_y / 255. ic Bit 2:0 4 ILED1_y in ILED2_y, LED2 Current Register w ILED2_y: Address: 0x11/0x14/0x17/0x1A, R/W, default: 0x00 7 6 5 4 ILED2_y Symbol ILED2_y 2 1 0 Description LED2Current Configure Register for 4 pre-defined colors, The LED2 output current value is IMAX * ILED2_y / 255. a Bit 7:0 3 ILED3_y, LED3 Current Register ILED3_y: Address: 0x12/0x15/0x18/0x1B, R/W, default: 0x00 7 6 5 4 ILED3_y www.awinic.com.cn 21 3 2 1 0 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW2026 September 2018 V1.3 Bit 7:0 Symbol ILED3_y Description LED3 Current Configure Register, for 4 pre-defined colors The LED3 output current value is IMAX * ILED3_y / 255. PWM1/PWM2/PWM3 , PWM duty level Register 4 3 ti a l PWM1: Address: 0x1C, R/W, default:0Xff PWM2: Address: 0x1D, R/W, default:0x00 PWM3: Address: 0x1E, R/W, default:0x00 7 6 5 2 1 PWMx Symbol PWMx Description PWM level for LEDx (x=1,2,3) n Bit 7:0 PAT1_T1: Address: 0x30, R/W, default: 0x80 PAT2_T1: Address: 0x35, R/W, default: 0x00 PAT3_T1: Address: 0x3A, R/W, default: 0x00 7 6 5 TRISE 0001 a w www.awinic.com.cn TRISE Time 1000 2.1s 0.13s 1001 2.6s 0.26s 1010 3.1s 0s 0011 0.38s 1011 4.2s 0100 0.51s 1100 5.2s 0101 0.77s 1101 6.2s 0110 1.04s 1110 7.3s 0111 1.6s 1111 8.3s On Time of pattern: TON Time TON Time ic in TON 2 C 0010 n Description Rise Time of pattern: TRISE Time 0000 3:0 3 o Symbol TRISE 4 fi d e PATx_T1, Time Parameter of Pattern x Register Bit 7:4 0 0000 0.04s 1000 2.1s 0001 0.13s 1001 2.6s 0010 0.26s 1010 3.1s 0011 0.38s 1011 4.2s 0100 0.51s 1100 5.2s 0101 0.77s 1101 6.2s 0110 1.04s 1110 7.3s 0111 1.6s 1111 8.3s 22 1 0 TON Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW2026 September 2018 V1.3 PATx_T2, Time Parameter of Pattern x Register PAT1_T2: Address: 0x31, R/W, default: 0x86 PAT2_T2: Address: 0x36, R/W, default: 0x00 PAT3_T2: Address: 0x3B, R/W, default: 0x00 7 6 5 TFALL 1 l Time 1000 2.1s 0001 0.13s 1001 2.6s 0010 0.26s 1010 3.1s 0011 0.38s 1011 4.2s 0100 0.51s 1100 5.2s 0101 0.77s 1101 6.2s 0110 1.04s 1110 7.3s 0111 1.6s e 0s ti a TFALL 0000 0000 0.04s 1000 2.1s 0001 0.13s 1001 2.6s 0010 0.26s 1010 3.1s 0.38s 1011 4.2s 0.51s 1100 5.2s Off Time of pattern: TOFF Time 0011 C 0100 0 n Description Fall Time of pattern: TFALL Time fi d TOFF 2 TOFF 1111 8.3s TOFF Time n 2:0 Symbol TFALL 3 o Bit 6:4 4 0.77s 1101 6.2s 0110 1.04s 1110 7.3s 0111 1.6s 1111 8.3s ic 0101 PATx_T3, Time Parameter of Pattern x Register w in PAT1_T3: Address: 0x32, R/W, default: 0x00 PAT2_T3: Address: 0x37, R/W, default: 0x00 PAT3_T3: Address: 0x3C, R/W, default: 0x00 7 6 5 4 TSLOT a Bit 6:4 www.awinic.com.cn Symbol TSLOT 3 2 1 0 TDELAY Description Slot Time Between Pulses: TSLOT Time 000 0ms 001 130ms 010 260ms 011 380ms 23 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW2026 110 800ms 111 1024ms Startup Delay Time of Pattern: TDELAY Time TDELAY Time 0000 0s 1000 2.1s 0001 0.13s 1001 2.6s 0010 0.26s 1010 3.1s 0011 0.38s 1011 4.2s 0100 0.51s 1100 5.2s 0101 0.77s 1101 6.2s 0110 1.04s 1110 7.3s 0111 1.6s 1111 8.3s n PATx_T4, Time Parameter of Pattern x Register 4 3 CE4 2 CE3 1 CE2 Symbol PAT_CTR Description Pattern running forever control 0: pattern run forever 1: pattern stop or switch to next pattern after repeating specified times. 6 PAT_SW Pattern Switch enable, active only in true-color pattern mode. 0: Pattern switch is disabled 1: Pattern switch is enabled 5:4 MPULSE in ic C Bit 7 Multiple Pulse mode selection. 00: single pulse 01: pulse repeats 2 times 10: pulse repeats 3 times 11: pulse repeats 4 times CE4 Color #4 display enable 0: Color#4 is masked 1: Color#4 is allow to display 2 CE3 Color #3 display enable 0: Color#3 is masked 1: Color#3 is allow to display 1 CE2 Color #2 display enable 0: Color#2 is masked 1: Color#2 is allow to display a w 3 www.awinic.com.cn 0 CE1 o PAT1_T4: Address: 0x33, R/W, default: 0x00 PAT2_T4: Address: 0x38, R/W, default: 0x00 PAT3_T4: Address: 0x3D, R/W, default: 0x00 7 6 5 PAT_CTR PAT_SW MPULSE ti a 670ms n 101 e TDELAY 540ms fi d 3:0 100 l September 2018 V1.3 24 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW2026 September 2018 V1.3 0 CE1 Color #1 display enable 0: Color#1 is masked 1: Color#1 is allow to display Note: if CE1~CE4 are all set to 0, Color #1 is displayed by default 4 3 ti a PAT1_T5: Address: 0x34, R/W, default: 0x00 PAT2_T5: Address: 0x39, R/W, default: 0x00 PAT3_T5: Address: 0x3E, R/W, default: 0x00 7 6 5 l PATx_T5, Time Parameter of Pattern x Register 2 1 REPTIM Description PATTERN Repeat Times REPTIM [7] = 0: Pattern repeats REPTIM[6:0]+1 times REPTIM [7] = 1: Pattern repeats (REPTIM[6:0]+1) * 16 times n Symbol REPTIM a w in ic C o n fi d e Bit 7:0 0 www.awinic.com.cn 25 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW2026 September 2018 V1.3 TAPE AND REEL INFORMATION C o n fi d e n ti a l CARRIER TAPE ic NOTE: ALL DIMS IN mm. PIN 1 w in Pin 1 a User Direction of Feed www.awinic.com.cn 26 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW2026 September 2018 V1.3 o a w in ic C NOTE: 1、 ALL DIMS IN mm; 2、 General Tolerance ±0.25mm. n fi d e n ti a l REEL www.awinic.com.cn 27 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW2026 September 2018 V1.3 PACKAGE DESCRIPTION Dimensions in Inches Min. Max. Min. Max. A 0.400 0.500 0.016 0.200 A1 0.000 0.050 A3 0.127REF. 1.450 1.550 E 1.450 1.550 D1 0.650 E1 0.200REF. 1.150 1.250 0.050REF. fi d E2 0.750 e D2 E3 k 1.350 0.200REF. 0.150 n b e 0.250 0.400BSC. 0.150 0.250 0.002 0.005REF. 0.057 0.061 0.057 0.061 0.026 0.030 0.008REF. 0.045 0.049 0.002REF. 0.049 0.053 0.008REF. 0.006 0.010 0.016BSC. 0.006 0.010 C o L LAND PATTERN EXAMPLE 1.250 0.000 n D ti a SYMBOL l Dimensions in Millimeters 0.40 ic 0.20 1.05 0.80 1.45 a w in 0.45 NOTE: All dimensions are measured in millimeter (mm) www.awinic.com.cn 28 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW2026 September 2018 V1.3 fi d e n ti a l REFLOW n Figure 17 Package Reflow Oven Thermal Profile o Reflow Note Spec Max. 3℃ /sec Time of Preheat temp.(from 150℃ to 200℃) 60-120sec C Average ramp-up rate (217℃c to Peak) 60-150sec Peak Temperature >260℃ Time within 5℃ of actual peak temp 20-40sec. ic Time to be maintained above 217℃ Max. 6℃ /sec Time from 25℃ to peak temp Max. 8min. a w in Ramp-down rate www.awinic.com.cn 29 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW2026 September 2018 V1.3 REVISION HISTORY Date Change Record V0.9 June 2016 Datasheet V0.9 Released V0.91 July 2016 Datasheet V0.91 Released V1.0 October 2016 Datasheet V1.0 Released V1.1 November 2016 1. Added Pin 1 and Land pattern information; 2. Corrected mistake at pin configuration. December 2017 1. Added exposed pad description in Pin definition; 2. Added RoHS and MSL statements in Ordering information. September 2018 1. Refreshed Land Pattern Example (P28); 2. Refreshed Pin1 information (P26); 3. Refreshed AMR ESD and Temperature information (P4); 4. Refreshed Package Description (P28). ti a a w in ic C o n fi d V1.3 e n V1.2 l Vision www.awinic.com.cn 30 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW2026 September 2018 V1.3 DISCLAIMER l Information in this document is believed to be accurate and reliable. However, Shanghai AWINIC Technology Co., Ltd (AWINIC Technology) does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. ti a AWINIC Technology reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. Customers shall obtain the latest relevant information before placing orders and shall verify that such information is current and complete. This document supersedes and replaces all information supplied prior to the publication hereof. fi d e n AWINIC Technology products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an AWINIC Technology product can reasonably be expected to result in personal injury, death or severe property or environmental damage. AWINIC Technology accepts no liability for inclusion and/or use of AWINIC Technology products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. n Applications that are described herein for any of these products are for illustrative purposes only. AWINIC Technology makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. All products are sold subject to the general terms and conditions of commercial sale supplied at the time of order acknowledgement. o Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. C Reproduction of AWINIC information in AWINIC data books or data sheets is permissible only if reproduction is without alteration and is accompanied by all associated warranties, conditions, limitations, and notices. AWINIC is not responsible or liable for such altered documentation. Information of third parties may be subject to additional restrictions. a w in ic Resale of AWINIC components or services with statements different from or beyond the parameters stated by AWINIC for that component or service voids all express and any implied warranties for the associated AWINIC component or service and is an unfair and deceptive business practice. AWINIC is not responsible or liable for any such statements. www.awinic.com.cn 31 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD
AW2026DNR 价格&库存
很抱歉,暂时无法提供与“AW2026DNR”相匹配的价格&库存,您可以联系我们找货
