AW5005DNRZ
AW5005DNRZ
    AWINIC(艾为)
    DFN6_1.5X1MM
    AW5005是一款专为全球导航卫星系统(GNSS)设计的低噪声放大器,适用于GPS、GLONASS、Galileo和Compass等系统。内置直流阻断电容器,减少了外部匹配元件的数量,降低了PCB面积...
AW5005DNRZ 数据手册
AW5005 May. 2019 V1.4 Ultra-Low Noise Amplifier for Global Navigation l Satellite Systems (GNSS) GENERAL DESCRIPTION   The AW5005 is a Low Noise Amplifier designed for Global Navigation Satellite Systems (GNSS) as GPS, GLONASS, Galileo and Compass. With on-chip DC blocking capacitors at RFIN and RFOUT, The AW5005 can be close to the antenna, requires only one external input matching inductor, and reduces assembly complexity and the PCB area, enabling a cost-effective solution.  The AW5005 with patented Smart Linearity Technology (SLT) achieves ultra-low noise figure, high linearity, high gain, over a wide range of supply voltages from 1.5V up to 3.6V. All these features make AW5005 an excellent choice for GNSS LNA as it improves sensitivity with low noise figure and high gain, provides better immunity against out-of-band jammer signals with high linearity, reduces filtering requirement of preceding stage and hence reduces the overall cost of the GNSS receiver. Reduce RF environment Interference with patented Smart-Linearity-Technology (SLT); low noise figure(NF)=0.85dB@1.575GHz; NF  n =0.79dB@1.227GHz;NF=0.80dB@1.176GHz; High power gain=18.2dB@1.575GHz;power gain=18.9dB@1.227GHz;power gain=18.7dB High linearity IIP3oob=+6.5dBm;  High input 1dB-compression point=-7.6dBm;  Requires only one input matching inductor;  RF output internally matched to 50 ohm;  Supply voltage: 1.5V to 3.6V;  Operating frequencies: GPS L1、L2/L5 band;  DFN 1.5mmX1.0mmX0.55mm-6L package;  3KV HBM ESD protection (including RFIN and RFOUT pin);  The AW5005 is available in a small lead-free, RoHS-Compliant, DFN 1.5mm X 1.0mm X 0.55mm -6L package. ic APPLICATIONS C o n  fi d @1.176 GHz; e  ti a FEATURES Smart phones, feature phones;  Tablet PCs;  Personal Navigation Devices;  Digital Still Cameras, Digital Video Cameras;  RF Front End modules; w in  Complete GPS chipset modules;  Theft protection(laptop, ATM); a  www.awinic.com.cn 1 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW5005 May. 2019 V1.4 AW5005 1 GND 6 5 RF OUTPUT EN fi d e 2 RFOUT n GND ti a l TYPICAL APPLICATION CIRCUIT LOGIC CONTROL BIAS RFIN RF INPUT (optional) VCC L2 4 3 C1 (optional) o n L1 SUPPLY VOLTAGE C1, L2 Closed to LNA C Figure 1 Typical Application Circuit of AW5005 for GNSS L1、L2/L5 a w in ic All trademarks are the property of their respective owners. www.awinic.com.cn 2 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW5005 May. 2019 V1.4 RFOUT GND 2 5 EN RFIN 3 4 VCC e 6 fi d 1 AXY GND ti a AW5005DNRZ Marking (Top View) n AW5005DNRZ (Top View) l PIN CONFIGURATION AND TOP MARK A – AW5005DNRZ XY– Production Tracing Code o PIN DEFINITION Pin Configuration and Top Mark n Figure 2 NAME 1 GND 2 GND 3 RFIN LNA input VCC DC Supply EN in 5 ic 4 C No. RFOUT Ground Ground Logic control LNA output a w 6 DESCRIPTION www.awinic.com.cn 3 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW5005 May. 2019 V1.4 GND 2 AW5005 6 RFOUT 5 EN fi d BIAS 3 4 VCC -40°C~85°C Package 1.5mmX1.0mm- Environmental Information Delivery Form A MSL3 ROHS+HF 3000 units/ Tape and Reel 6L AW5005 Z Shipping R: Tape & Reel a www.awinic.com.cn Marking Moisture Sensitivity Level DFN w in AW5005DNRZ Temperature ic Part Number C ORDERING INFORMATION o n RFIN n 1 e GND ti a l FUNCTIONAL BLOCK DIAGRAM Package Type DN: DFN 4 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW5005 May. 2019 V1.4 ABSOLUTE MAXIMUM RATINGS[1] Values Typ. Max. 5 V Unit 5 V 30 mA 10 dBm Supply Voltage at pin VCC VCC -0.3 - Voltage at pin EN [2] VEN -0.3 - Current into pin VCC ICC - - RF input power [3] PIN - Package thermal resistance θJA Junction temperature TJ n Ambient temperature range o Solder temperature(10s) ESD range C HBM [4] Latch-up ic CDM e - - 148.2 - ℃/W - - 150 ℃ TSTG -65 - 150 ℃ Tamb -40 - 85 ℃ - 260 - ℃ fi d Storage temperature range ti a Min. l Symbol n PARAMETERS ±3000 V ±1000 V +IT: +400 Standard: JEDEC STANDARD NO.78E SEPTEMBER 2016 mA in -IT: -400 Note1: Stresses beyond those listed under “absolute maximum ratings” may cause permanent damage to the device. w These are stress ratings only and functional operation of the device at these or any other conditions beyond those indicated under “recommended operating conditions” is not implied. Exposure to absolute maximum rated conditions for extended periods may affect device reliability. a Note2: Warning: due to internal ESD diode protection, the applied DC voltage should not exceed 5.0V in order to avoid excess current. Note3: The RF input and RF output are AC coupled through internal DC blocking capacitor. Note4: HBM standard: MIL-STD-883J Method 3015.9. www.awinic.com.cn 5 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW5005 May. 2019 V1.4 ELECTRICAL CHARACTERISTICS (AW5005 EVB[1]; VCC=1.5 to 3.6V, TA=-40~+85°C, f=1550MHz to 1615MHz; Typical values are at VCC=2.8V TEST CONDITION MIN TYP 1.5 - DC ELECTRICAL CHARACTERISTICS Supply Voltage ISD Shut-Down Current EN=Low ICC Supply Current EN=High VEN Digital Input-Logic High VEN Digital Input-Logic Low e 0.80 16.0 RLin Input Return Loss RLout Output Return Loss ISL Reverse Isolation NF Noise Figure[2] n Power Gain fi d AC ELECTRICAL CHARACTERISTICS Gp 8.0 25.0 o Zs=50 ohm; No jammer f=20MHz…10GHz Stability factor C Kf Noise Figure with jammer IP1dB in f1=1712.7MHz[3]; f2=1850MHz; Pin=-20dBm; f1=1712.7MHz[3]; f2=1850MHz; Pin=-30dBm; f1=824.6MHz[4]; f2=2400MHz; Pin=-20dBm f1=824.6MHz[4]; f2=2400MHz; Pin=-30dBm Out-of-band input 3rd-order intercept point w IIP3oob a IIP2oob IIP2oob Out-of-band input 3rd-order intercept point Out-of-band input 2nd-order intercept point Out-of-band input 2nd-order intercept point H2-input LTE band-13 2nd Harmonic f=787.76MHz; Pin=-25dBm; referred www.awinic.com.cn fjam=850MHz f=1575.42MHz 1dB-compression point IIP3oob Pjam=-20dBm; fjam= 1850MHz Inband input 6 V 1 μA 13.0 mA V 0.45 V 18.5 dB 5.6 dB 10 dB 28.5 dB 0.85 dB 1 Pjam=-20dBm; ic NFj 18.2 UNIT 3.6 n VCC MAX ti a PARAMETER l and TA=+25°C, f=1575.42MHz, input matched to 50 using a 9.1nH inductor, unless otherwise noted) 0.72 1.10 dB 1.14 1.50 dB -9.0 -7.6 dBm +4.0 +6.1 dBm +4.5 +6.5 dBm -2.0 -1.2 dBm -2.0 -1.2 dBm -74.4 -70.0 dBm Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW5005 May. 2019 V1.4 PARAMETER TEST CONDITION MIN TYP MAX UNIT turn-on time time from VEN ON to 90% of the final gain 2.2 2.5 μs toff turn-off time time from VEN OFF to 10% of the gain 1.7 2.0 μs ti a ton l fH2=1575.52MHz Note1: input matched to 50 ohm using a high quality‐factor 9.1nH inductor. Note2: 0.08dB PCB losses are subtracted. n Note3: IIP3=0.5*(Po_f1-IM3)+Pi_f1. a w in ic C o n fi d e Note4: IIP2=Po_f2+Pi_f2-IM2. www.awinic.com.cn 7 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW5005 May. 2019 V1.4 (AW5005 EVB[1] ; VCC=1.5 to 3.6V, TA=-40~+85°C, f=1550MHz to 1615MHz; Typical values are at VCC=1.8V and TA=+25°C, f=1575.42MHz, input matched to 50 using a 9.1nH inductor, unless otherwise noted) TEST CONDITION MIN TYP MAX UNIT 1.5 - 3.6 V 1 μA 15.0 mA VCC Supply Voltage ISD Shut-Down Current EN=Low ICC Supply Current EN=High VEN Digital Input-Logic High VEN Digital Input-Logic Low RLin Input Return Loss RLout Output Return Loss ISL Reverse Isolation NF Noise Figure[2] e 16.0 fi d Power Gain 25.0 Zs=50 ohm; n No jammer f=20MHz…10GHz Stability factor Pjam=-20dBm; Noise Figure with jammer Inband input 1dB-compression point IIP3oob in Out-of-band input w 3rd-order intercept point a IIP2oob IIP2oob H2-input Out-of-band input 2nd-order intercept point Out-of-band input 2nd-order intercept point LTE band-13 2nd Harmonic referred ton turn-on time www.awinic.com.cn 18.0 dB 5.3 dB 10 dB 28.0 dB 0.83 dB 0.76 1.10 dB 1.18 1.50 dB fjam= 1850MHz f1=1712.7MHz[3]; f2=1850MHz; Pin=-20dBm; f1=1712.7MHz[3]; f2=1850MHz; Pin=-30dBm; f1=824.6MHz[4]; f2=2400MHz; Pin=-20dBm f1=824.6MHz[4]; f2=2400MHz; Pin=-30dBm f=787.76MHz; Pin=-25dBm; fH2=1575.52MHz Out-of-band input 3rd-order intercept point IIP3oob Pjam=-20dBm; f=1575.42MHz ic IP1dB V fjam=850MHz C NFj 17.5 0.45 1 o Kf V n 0.80 AC ELECTRICAL CHARACTERISTICS Gp 6.0 ti a DC ELECTRICAL CHARACTERISTICS time from VEN ON to 90% of the final gain 8 l PARAMETER -14.0 -12.5 dBm -1.0 0.7 dBm 0 2.5 dBm -3.0 -1.9 dBm -3.0 -1.7 dBm -72.6 -70.0 dBm 2.2 2.5 μs Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW5005 May. 2019 V1.4 PARAMETER toff TEST CONDITION turn-off time MIN time from VEN OFF to 10% of the gain TYP MAX UNIT 1.7 2.0 μs l Note1: input matched to 50 ohm using a high quality‐factor 9.1nH inductor. ti a Note2: 0.08dB PCB losses are subtracted. Note3: IIP3=0.5*(Po_f1-IM3)+Pi_f1. n Note4: IIP2=Po_f2+Pi_f2-IM2. (AW5005 EVB[1]; VCC=1.5 to 3.6V, TA=-40~+85°C, f=1227.60±1.023MHz; Typical values are at VCC=2.8V TEST CONDITION DC ELECTRICAL CHARACTERISTICS MIN fi d PARAMETER e and TA=+25°C, f=1227.60MHz, input matched to 50 using a 15nH inductor, unless otherwise noted) VCC Supply Voltage ISD Shut-Down Current EN=Low ICC Supply Current EN=High VEN Digital Input-Logic High VEN Digital Input-Logic Low MAX UNIT - 3.6 V 1 μA 13.0 mA 8 0.80 V o n 1.5 TYP 0.45 V 18.5 dB C AC ELECTRICAL CHARACTERISTICS Power Gain RLin Input Return Loss RLout Output Return Loss ISL Reverse Isolation NF Noise Figure[2] a NFj IP1dB IIP3oob Zs=50 ohm; No jammer f=20MHz…10GHz Stability factor fjam=850MHz Noise Figure with jammer Pjam=-20dBm; fjam= 1850MHz Inband input f=1575.42MHz 1dB-compression point f1=1712.7MHz[3]; f2=1850MHz; Pin=-20dBm; f1=1712.7MHz[3]; f2=1850MHz; Out-of-band input Out-of-band input www.awinic.com.cn 9 18.9 5.5 dB 12.3 dB 26.2 dB 0.79 dB 1 Pjam=-20dBm; 3rd-order intercept point IIP3oob 16.0 25.0 in w Kf ic Gp 0.72 1.10 dB 1.14 1.50 dB -9.0 -7.6 dBm +4.0 +6.1 dBm +4.5 +6.5 dBm Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW5005 May. 2019 V1.4 Out-of-band input f1=824.6MHz[4]; f2=2400MHz; Pin=-20dBm f1=824.6MHz[4]; f2=2400MHz; Pin=-30dBm f=787.76MHz; Pin=-25dBm; fH2=1575.52MHz 2nd-order intercept point IIP2oob Out-of-band input 2nd-order intercept point H2-input LTE band-13 2nd Harmonic referred turn-on time time from VEN ON to 90% of the final gain toff turn-off time time from VEN OFF to 10% of the gain -1.2 -2.0 -1.2 UNIT dBm -74.4 dBm -70.0 dBm 2.2 2.5 μs 2.0 μs 1.7 fi d ton -2.0 MAX l Pin=-30dBm; TYP ti a 3rd-order intercept point MIN n IIP2oob TEST CONDITION e PARAMETER Note1: input matched to 50 ohm using a high quality‐factor 9.1nH inductor. Note2: 0.08dB PCB losses are subtracted. n Note3: IIP3=0.5*(Po_f1-IM3)+Pi_f1. o Note4: IIP2=Po_f2+Pi_f2-IM2. (AW5005 EVB[1]; VCC=1.5 to 3.6V, TA=-40~+85°C, f=1227.60±1.023MHz; Typical values are at VCC=1.8V PARAMETER C and TA=+25°C, f=1227.60MHz, input matched to 50 using a 15nH inductor, unless otherwise noted) TEST CONDITION MIN TYP MAX UNIT 1.5 - 3.6 V 1 μA 13.0 mA ic DC ELECTRICAL CHARACTERISTICS Supply Voltage ISD Shut-Down Current EN=Low ICC Supply Current EN=High VEN w VEN in VCC Digital Input-Logic High 6.0 0.80 V Digital Input-Logic Low 0.45 V 18.5 dB AC ELECTRICAL CHARACTERISTICS Power Gain RLin Input Return Loss 5.4 dB RLout Output Return Loss 12.4 dB ISL Reverse Isolation 25.6 dB NF Noise Figure[2] 0.83 dB a Gp 16.0 25.0 Zs=50 ohm; No jammer Kf f=20MHz…10GHz Stability factor www.awinic.com.cn 10 18.2 1 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW5005 May. 2019 V1.4 Pjam=-20dBm; NFj fjam=850MHz Noise Figure with jammer Pjam=-20dBm; fjam= 1850MHz Inband input f=1575.42MHz 1dB-compression point IIP3oob f1=1712.7MHz[3]; f2=1850MHz; Pin=-20dBm; f1=1712.7MHz[3]; f2=1850MHz; Pin=-30dBm; f1=824.6MHz[4]; f2=2400MHz; Pin=-20dBm f1=824.6MHz[4]; f2=2400MHz; Pin=-30dBm f=787.76MHz; Pin=-25dBm; fH2=1575.52MHz Out-of-band input 3rd-order intercept point IIP3oob Out-of-band input 3rd-order intercept point Out-of-band input 2nd-order intercept point IIP2oob Out-of-band input H2-input LTE band-13 2nd Harmonic turn-on time toff turn-off time C ton 1.10 dB 1.14 1.50 dB +4.0 +6.1 +4.5 dBm dBm +6.5 dBm -2.0 -1.2 dBm -2.0 -1.2 dBm -74.4 -70.0 dBm time from VEN ON to 90% of the final gain 2.2 2.5 μs time from VEN OFF to 10% of the gain 1.7 2.0 μs o referred 0.72 -7.6 n 2nd-order intercept point UNIT -9.0 fi d IIP2oob MAX e IP1dB TYP l MIN ti a TEST CONDITION n PARAMETER ic Note1: input matched to 50 ohm using a high quality‐factor 9.1nH inductor. Note2: 0.08dB PCB losses are subtracted. in Note3: IIP3=0.5*(Po_f1-IM3)+Pi_f1. w Note4: IIP2=Po_f2+Pi_f2-IM2. (AW5005 EVB[1]; VCC=1.5 to 3.6V, TA=-40~+85°C, f=1176.45±1.023MHz; Typical values are at VCC=2.8V a and TA=+25°C, f=1176.45MHz, input matched to 50 using a 15nH inductor, unless otherwise noted) PARAMETER TEST CONDITION MIN TYP MAX UNIT 1.5 - 3.6 V 1 μA 13.0 mA DC ELECTRICAL CHARACTERISTICS VCC Supply Voltage ISD Shut-Down Current EN=Low ICC Supply Current EN=High www.awinic.com.cn 11 8.0 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW5005 May. 2019 V1.4 PARAMETER TEST CONDITION VEN Digital Input-Logic High VEN Digital Input-Logic Low MIN TYP MAX 0.80 UNIT V 0.45 V 18.9 dB Power Gain RLin Input Return Loss RLout Output Return Loss 12.0 14.3 ISL Reverse Isolation 25.0 26.0 Noise 4.9 Figure[2] Zs=50 ohm; NFj 1 dB 1.14 1.50 dB Pjam=-20dBm; fjam= 1850MHz Inband input f=1575.42MHz n IP1dB 1dB-compression point Out-of-band input IIP3oob Out-of-band input C 3rd-order intercept point 3rd-order intercept point Out-of-band input ic IIP2oob 2nd-order intercept point IIP2oob Out-of-band input in 2nd-order intercept point H2-input LTE band-13 2nd Harmonic referred w f1=1712.7MHz[3]; f2=1850MHz; Pin=-20dBm; f1=1712.7MHz[3]; f2=1850MHz; Pin=-30dBm; f1=824.6MHz[4]; f2=2400MHz; Pin=-20dBm f1=824.6MHz[4]; f2=2400MHz; Pin=-30dBm f=787.76MHz; Pin=-25dBm; fH2=1575.52MHz o IIP3oob dB 1.10 fjam=850MHz Noise Figure with jammer dB 0.72 fi d Pjam=-20dBm; dB e f=20MHz…10GHz Stability factor dB 0.80 No jammer Kf 18.7 n NF 16.0 ti a Gp l AC ELECTRICAL CHARACTERISTICS -9.0 -7.6 dBm +4.0 +6.1 dBm +4.5 +6.5 dBm -2.0 -1.2 dBm -2.0 -1.2 dBm -74.4 -70.0 dBm turn-on time time from VEN ON to 90% of the final gain 2.2 2.5 μs toff turn-off time time from VEN OFF to 10% of the gain 1.7 2.0 μs a ton Note1: input matched to 50 ohm using a high quality‐factor 9.1nH inductor. Note2: 0.08dB PCB losses are subtracted. Note3: IIP3=0.5*(Po_f1-IM3)+Pi_f1. Note4: IIP2=Po_f2+Pi_f2-IM2. www.awinic.com.cn 12 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW5005 May. 2019 V1.4 (AW5005 EVB[1]; VCC=1.5 to 3.6V, TA=-40~+85°C, f=1176.45±1.023MHz; Typical values are at VCC=1.8V and TA=+25°C, f=1176.45MHz, input matched to 50 using a 15nH inductor, unless otherwise noted) TEST CONDITION MIN TYP MAX UNIT 1.5 - 3.6 V 1 μA 13.0 mA VCC Supply Voltage ISD Shut-Down Current EN=Low ICC Supply Current EN=High VEN Digital Input-Logic High VEN Digital Input-Logic Low RLin Input Return Loss RLout Output Return Loss ISL Reverse Isolation NF Noise Figure[2] e 16.0 n f=20MHz…10GHz dB 25.0 25.4 dB 0.84 dB o 1 fjam=850MHz C Noise Figure with jammer Inband input 1dB-compression point IIP3oob in Out-of-band input w 3rd-order intercept point a IIP2oob IIP2oob H2-input Out-of-band input 2nd-order intercept point Out-of-band input 2nd-order intercept point LTE band-13 2nd Harmonic referred ton turn-on time www.awinic.com.cn fjam= 1850MHz f1=1712.7MHz[3]; f2=1850MHz; Pin=-20dBm; f1=1712.7MHz[3]; f2=1850MHz; Pin=-30dBm; f1=824.6MHz[4]; f2=2400MHz; Pin=-20dBm f1=824.6MHz[4]; f2=2400MHz; Pin=-30dBm f=787.76MHz; Pin=-25dBm; fH2=1575.52MHz Out-of-band input 3rd-order intercept point IIP3oob Pjam=-20dBm; f=1575.42MHz ic IP1dB time from VEN ON to 90% of the final gain 13 dB 14.2 Pjam=-20dBm; NFj 18.7 12.0 Zs=50 ohm; Stability factor V dB No jammer Kf 18.0 0.45 5.2 fi d Power Gain V n 0.80 AC ELECTRICAL CHARACTERISTICS Gp 6.0 ti a DC ELECTRICAL CHARACTERISTICS l PARAMETER 0.72 1.10 dB 1.14 1.50 dB -9.0 -7.6 dBm +4.0 +6.1 dBm +4.5 +6.5 dBm -2.0 -1.2 dBm -2.0 -1.2 dBm -74.4 -70.0 dBm 2.2 2.5 μs Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW5005 May. 2019 V1.4 PARAMETER toff TEST CONDITION turn-off time MIN time from VEN OFF to 10% of the gain TYP MAX UNIT 1.7 2.0 μs ti a l Note1: input matched to 50 ohm using a high quality‐factor 9.1nH inductor. Note2: 0.08dB PCB losses are subtracted. Note3: IIP3=0.5*(Po_f1-IM3)+Pi_f1. n Note4: IIP2=Po_f2+Pi_f2-IM2. a w in ic C o n fi d e APPLICATION BOARD Figure 3. www.awinic.com.cn Drawing of Application Board 14 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW5005 May. 2019 V1.4 Copper 35um n ti a FR4 l Vias Application Board Cross-Section a w in ic C o n fi d Figure 4. e AW5005DNRZ_application_board_sideview www.awinic.com.cn 15 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW5005 May. 2019 V1.4 TEST CIRCUITS RFOUT 5 2 EN BIAS RFIN RF INPUT RF OUTPUT n 6 e GND AW5005 1 fi d GND 3 ti a The following is the test bench for power supply, pin voltage, supply current, standby current l DC Characteristics LOGIC CONTROL SUPPLY VOLTAGE L2 VCC (optional) 4 n L1 C1 o (optional) C C1, L2 Closed to LNA S Parameter a w in ic The following is the test bench for input return loss, output return loss, reverse isolation, forward gain, and 1dB gain compression. www.awinic.com.cn RF AW5005 EVB INPUT RF OUTPUT NetWork Analyzer 16 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW5005 May. 2019 V1.4 ti a l Noise Figure The following is the test bench for noise figure, power gain. AW5015 EVB AW5005 RF OUTPUT fi d e n RF INPUT n Noise Analyzer Intermodulation distortion C o The following is the test bench for third-order intercept point and second-order intercept point. Signal Generator ic Circulator Circulator w in Signal Generator Power Combiner RF OUTPUT AW5005 EVB RF INPUT a Signal Analyzer Harmonic distortion The following is the test bench for second-order harmonic distortion. Signal Generator www.awinic.com.cn RF INPUT AW5005 EVB 17 RF OUTPUT Notch Filter Signal Analyzer Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW5005 May. 2019 V1.4 RECOMMENDED COMPONENTS LIST Table1: list of inductor for GNSS L1 Units nH LQW15A 9.1 25 250 Murata 0402 9.1 24 250 Sunlord 0402 100 20 150 Murata 0402 SDWL1005C L1 LQW15A L2 MHz Component Part Number Capacitance pF GRM155 1000 Rated Voltage Supplier Size Murata 0402 V 50 o n Units fi d Table2: list of capacitor C1 Size ti a L1 Inductance Q(min) Q Test Frequency Supplier n Part Number e Component l Table1 lists the recommended inductor types and values; Table 2 lists the recommended capacitor types and values. C PCB LAYOUT CONSIDERATION The AW5005 requires only one external inductor for input matching. If the device/phone manufacturers implement very good power supply filtering on their boards, the bypass capacitor mentioned in this application circuit may be optional. With the capacitor we can get better performance like a little higher gain etc. The value is optimized for the best gain, noise figure, return loss performance. Typical value of inductor is 9.1nH, capacitor is 1nF. For schematics see Figure1. 2. The output of AW5005 is internally matched to 50 ohm and a DC blocking capacitor is integrated on-chip, thus no external component is required at the output. 3. The AW5005 should be placed close to the GPS antenna with the input-matching inductor. Use 50 ohm micro strip lines to connect RF INPUT and RF OUTPUT. Bypass capacitor should be located close to the device. For long VCC lines, it may be necessary to add more decoupling capacitors. Proper grounding of the GND pins is very important. a w in ic 1. www.awinic.com.cn 18 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW5005 May. 2019 V1.4 TAPE AND REEL INFORMATION TAPE DIMENSIONS REEL DIMENSIONS P1 P0 P2 ti a l K0 W B0 D1 A0 e n Cavity fi d A0:Dimension designed to accommodate the component width B0:Dimension designed to accommodate the component length K0:Dimension designed to accommodate the component thickness W:Overall width of the carrier tape P0:Pitch between successive cavity centers and sprocket hole P1:Pitch between successive cavity centers P2:Pitch between sprocket hole D1:Reel Diameter D0:Reel Width o n D0 C QUADRANT ASSIGNMENTS FOR PIN 1 ORIENTATION IN TAPE Sprocket Holes Q2 Q1 Q2 Q1 Q2 Q1 Q2 Q3 Q4 Q3 Q4 Q3 Q4 Q3 Q4 User Direction of Feed Pocket Quadrants a w in ic Q1 www.awinic.com.cn 19 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW5005 May. 2019 V1.4 PACKAGE DESCRIPTION 1.00 ti a l Pin 1 Indicator fi d e n 1.50 n 0.55±0.05 0.152 0.05 0.55±0.05 C 5X(0.35±0.05) o 0.00~0.05 5X 0.15 4X 0.15 4 ic 3 0.00~0.05 0.50 6X(0.20±0.05) 1 0.10 www.awinic.com.cn M 6 0.10 0.10 0.152 0.40±0.05 a w in 0.10 Ty p. Unit:mm 20 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW5005 May. 2019 V1.4 LAND PATTERN DATA l 1.20 1 6 ℄ n SYMM 1.20 6X0.20 ti a 6X0.50 fi d 4 3 SYMM ℄ 0.05 MIN All AROUND n 0.05 MAX All AROUND o SOLDER MASK OPENING C METAL e 0.50 ic NON SOLDER MASK DEFINED SOLDER MASK OPENING METAL UNDER SOLDER MASK SOLDER MASK DEFINED a w in Unit: mm www.awinic.com.cn 21 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW5005 May. 2019 V1.4 REVISION HISTORY Release date AW5005_V1.4 2019-5  Updated S11 AND S22 OF L1 BAND AW5005_V1.3 2019-5  Updated SP AND NF OF L1/L2/L5 BAND  Updated S21 OF L1S21 BAND Added AND NF OF L2/L5 BAND  Added S21 AND NFS21 OFAND L2/L5 BAND Added NF OF L2/L5 BAND  Updated TAPE AND REEL INFORMATION  Updated PACKAGE DESCRIPTION  Updated LAND PATTERN DATA  Updated the Awinic logo 2016-12 Officially Released a w in ic C o n AW5005_V1.0 ti a 2019-2 n AW5005_V1.1 e 2019-5 fi d AW5005_V1.2 Change Record l Document ID www.awinic.com.cn 22 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW5005 May. 2019 V1.4 DISCLAIMER ti a l Information in this document is believed to be accurate and reliable. However, Shanghai AWINIC Technology Co., Ltd (AWINIC Technology) does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. n AWINIC Technology reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. Customers shall obtain the latest relevant information before placing orders and shall verify that such information is current and complete. This document supersedes and replaces all information supplied prior to the publication hereof. fi d e AWINIC Technology products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an AWINIC Technology product can reasonably be expected to result in personal injury, death or severe property or environmental damage. AWINIC Technology accepts no liability for inclusion and/or use of AWINIC Technology products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. o n Applications that are described herein for any of these products are for illustrative purposes only. AWINIC Technology makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. All products are sold subject to the general terms and conditions of commercial sale supplied at the time of order acknowledgement. C Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. ic Reproduction of AWINIC information in AWINIC data books or data sheets is permissible only if reproduction is without alteration and is accompanied by all associated warranties, conditions, limitations, and notices. AWINIC is not responsible or liable for such altered documentation. Information of third parties may be subject to additional restrictions. a w in Resale of AWINIC components or services with statements different from or beyond the parameters stated by AWINIC for that component or service voids all express and any implied warranties for the associated AWINIC component or service and is an unfair and deceptive business practice. AWINIC is not responsible or liable for any such statements. www.awinic.com.cn 23 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD
AW5005DNRZ 价格&库存
很抱歉,暂时无法提供与“AW5005DNRZ”相匹配的价格&库存,您可以联系我们找货
