AW32801CSR
AW32801CSR
    AWINIC(艾为)
    WLCSP12_1.78X1.34MM
    停产 过压保护负载开关
AW32801CSR 数据手册
AW32801/AW32805/ AW32809/AW32812 June 2018 V1.2 Over-Voltage Protection Load Switch with Surge Protection GENERAL DESCRIPTION  The AW328XX family OVP load switch features surge protection, an internal clamp circuit protects the device from surge voltages up to 100V. IEC 61000-4-5: > 100V Integrated low Rdson nFET switch: typical 28mΩ  4.5A continuous current capability  Default Over-Voltage Protection (OVP) threshold AW32801: 5.95V  AW32805: 6.8V  AW32809: 9.98V  AW32812: 14V  OVP threshold adjustable range: 4V to 20V  Input system ESD protection The default OVP threshold is 5.95V (AW32801), 6.8V (AW32805), 9.98V (AW32809) and 14V (AW32812), the OVP threshold can be adjusted from 4V to 20V through external OVLO pin. e   IEC 61000-4-2 Contact discharge: ±8kV  IEC 61000-4-2 Air gap discharge: ±15kV  Input maximum voltage rating: 29VDC  Fast turn-off response: typical 125ns  Over-Temperature Protection (OTP)  Under-Voltage Lockout (UVLO)  1.34mm × 1.78mm WLCSP-12 package n o  Tablets  5V to 20V Charging Ports This device features over-temperature protection that prevents itself from thermal damaging. The AW328XX is available in a RoHS compliant 12-bump 1.34mm × 1.78mm WLCSP. ic Smartphones The device features an open-drain output ACOK, when VIN_UVLO < VIN < VIN_OVLO and the switch is on, ACOK will be driven low to indicate a good power input, otherwise it is high impedance. C APPLICATIONS  The AW328XX features an ultra-low 28m (typ.) Rdson nFET load switch. When input voltage exceeds the OVP threshold, the switch is turned off very fast to prevent damage to the protected downstream devices. The IN pin is capable of withstanding fault voltages up to 29VDC. n  fi d  ti a Surge protection l FEATURES a w USB Port in TYPICAL APPLICATION CIRCUIT CIN 0.1µF 50V TVS AW32801 AW32805 AW32809 AW32812 R1 OVLO R2 Optional EN Optional Figure 1 Charger OUT IN VIO COUT 1µF Battery PMIC 10kΩ ACOK Controller GND Typical Application Circuit of AW328XX Note: R1 and R2 are used for OVP threshold adjustment, to use default OVP threshold, connect OVLO to ground. All trademarks are the property of their respective owners. www.awinic.com.cn 1 Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32801/AW32805/ AW32809/AW32812 June 2018 V1.2 DEVICE COMPARISON TABLE VIN_OVLO (V) Min. Typ. Max. AW32805 VIN rising 6.66 6.80 6.94 150 AW32809 VIN rising 9.78 9.98 10.18 210 AW32812 VIN rising 13.7 14.0 14.3 AW32801 VIN rising 5.83 5.95 6.07 AW328XX Pin Configuration (TOP VIEW) 3 4 A EN OUT OUT GND B ACOK OUT IN GND C OVLO IN IN GND 2 ti a 3 4 fi d 1 e 2 28XX YYYY A o n B C C ic 100 AW328XX MARKING (TOP VIEW) 1 Figure 2 300 n PIN CONFIGURATION AND TOP MARK l Condition VIN_OVLO hysteresis (mV) Device 28XX – AW32801/AW32805/AW32809/AW32812 YYYY – Production Tracking Code Pin Configuration and Top Mark in PIN DEFINITION NAME A1 EN w PIN DESCRIPTION Enable pin, active low ACOK Power good flag, active-low, open-drain C1 OVLO OVP threshold adjustment pin C2, C3, B3 IN A2, A3, B2 OUT Switch output A4, B4, C4 GND Device ground a B1 www.awinic.com.cn Switch input and device power supply 2 Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32801/AW32805/ AW32809/AW32812 June 2018 V1.2 FUNCTIONAL BLOCK DIAGRAM OUT Clamp Detect OV comp ACOK UV&OT comp Oscillator fi d e Bandgap & Ibias EN GND FUNCTIONAL BLOCK DIAGRAM a w in ic C o n Figure 3 Logic Control n Gate Driver & Charge pump VIN Divider Selection OVLO ti a l IN www.awinic.com.cn 3 Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32801/AW32805/ AW32809/AW32812 June 2018 V1.2 TYPICAL APPLICATION CIRCUITS VIO AW32801 AW32805 AW32809 AW32812 OVLO Optional EN COUT 1µF Battery PMIC 10kΩ Controller ACOK l CIN 0.1µF 50V TVS Charger OUT IN ti a USB Port GND USB Port OUT IN OVLO R2 Optional VIO AW32801 AW32805 AW32809 AW32812 R1 EN COUT 1µF fi d CIN 0.1µF 50V TVS e n Figure 4 AW328XX Application Circuit (Using default OVP threshold by connecting OVLO to ground) Charger Battery PMIC 10kΩ ACOK n GND Controller C Notice for Typical Application Circuits: o Figure 5 AW328XX Application Circuit (Using external OVP threshold by connecting OVLO to R1 and R2) 1. When the default OVP threshold is used, connect OVLO pin to GND directly or through a 0Ω resistor. OVLO pin cannot be left floating. ic 2. If R1 and R2 are used to adjust the OVP threshold, in order to speed up the OVP response, R 1 + R2 < 100kΩ is recommended. It is better to use 1% precision resistors to improve the OVP threshold precision. in 3. If ACOK is not used, it can be left floating, or short to GND. 4. CIN = 0.1μF is recommended for typical application, larger CIN is also acceptable. The rated voltage of CIN should be larger than the TVS maximum clamping voltage, if no TVS is applied and only AW 328XX is used, the rated voltage of CIN should be 50V. w 5. COUT = 1μF is recommended for typical application, larger C OUT is also acceptable. The rated voltage of COUT should be larger than the OVP threshold. For example, if the OVP threshold is 6.8V, the rated voltage of COUT should be 10V or higher. a 6. If the input of AW328XX is required to pass surge voltage greater than 100V, external TVS is needed, the maximum clamping voltage of the TVS should be below 42V. www.awinic.com.cn 4 Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32801/AW32805/ AW32809/AW32812 June 2018 V1.2 Temperature Package Marking Moisture Sensitivity Level Environmental Information Delivery Form AW32801CSR -40°C~85°C WLCSP 1.34×1.78-12B 2801 MSL1 ROHS+HF 3000 units/ Tape and Reel AW32805CSR -40°C~85°C WLCSP 1.34×1.78-12B 2805 MSL1 ROHS+HF 3000 units/ Tape and Reel AW32809CSR -40°C~85°C WLCSP 1.34×1.78-12B 2809 MSL1 ROHS+HF 3000 units/ Tape and Reel AW32812CSR -40°C~85°C WLCSP 1.34×1.78-12B 2812 MSL1 ti a l Part Number n ORDERING INFORMATION 3000 units/ Tape and Reel e ROHS+HF fi d AW328XX Shipping R: Tape & Reel a w in ic C o n Package Type CS: CSP www.awinic.com.cn 5 Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32801/AW32805/ AW32809/AW32812 June 2018 V1.2 PARAMETERS RANGE Supply Voltage Range VIN -0.3V to 29V -0.3V to 29V EN -0.3V to 6V Output Voltage Range ACOK -0.3V to 6V OUT See(NOTE 2) ti a OVLO Input Voltage Range Maximum Input Peak Pulse Voltage VIN_PUL (20μs pulse width, repeat 100 times) n 42V Maximum Continuous Current From IN to OUT ISW(NOTE 3) 4.5A Operating Free-air Temperature Range Maximum Junction Temperature TJMAX 1.5A 85°C/W -40°C to 85°C 165°C -65°C to 150°C n Storage Temperature TSTG fi d Junction-to-ambient Thermal Resistance θJA(NOTE 4) 8A e Peak Current From IN to OUT IPEAK (10ms) Maximum Continuous Forward Current Through the Switch Body Diode IDIODE 260°C Contact Discharge ±8kV Air Gap Discharge ±15kV Lead Temperature (Soldering 10 Seconds) l ABSOLUTE MAXIMUM RATINGS(NOTE1) C IEC61000-4-2 System ESD on IN (NOTE 5) o ESD ±4kV Charged Device Model (All pins, per JEDEC EIA/JESD22-C101F) ±1.5kV Machine Model (All pins, per JEDEC EIA/JESD22-A115) ±400V ic Human Body Model (All pins, per MIL-STD-883J Method 3015.9) (NOTE 6) Latch-Up in Test Condition: JEDEC STANDARD No.78C SEPTEMBER 2011 +IT:800mA -IT:-800mA w NOTE1: Conditions out of those ranges listed in "absolute maximum ratings" may cause permanent damages to the device. In spite of the limits above, functional operation conditions of the device should within the ranges listed in "recommended operating conditions". Exposure to absolute-maximum-rated conditions for prolonged periods may affect device reliability. a NOTE2: -0.3V to 29V or VIN + 0.3V, whichever is smaller. NOTE3: Limited by thermal design. NOTE4: Thermal resistance from junction to ambient is highly dependent on PCB layout. NOTE5: Test is under CIN = 1μF. NOTE6: The human body model is a 100pF capacitor discharged through a 1.5kΩ resistor into each pin. www.awinic.com.cn 6 Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32801/AW32805/ AW32809/AW32812 June 2018 V1.2 ELECTRICAL CHARACTERISTICS TA = -40°C to 85°C unless otherwise noted. Typical values are guaranteed for V IN = 5V, CIN = 0.1μF, IIN≤ 4.5A and TA = 25°C. VIN_CLAMP Input Clamp Voltage VIN Input Voltage Range IIN = 10mA TYP 2.5 VIN = 5V, IOUT = 1A, TA = 25°C 28 IQ Input Quiescent Current VIN = 5V, IOUT = 0A 65 IIN_OVLO Input Current Over-voltage Condition VOVLO = 3V, VIN = 5V, VOUT = 0V 69 VOVLO_TH OVLO Set Threshold 2.5V < VIN < 20V VOVLO_RNG OVP Threshold Adjustable Range 2.5V < VIN < 20V VOVLO_SEL External OVLO Threshold VIN Rising 0.3 Hysteresis OVLO Pin Leakage Current COUT Output Load Capacitance VOVLO = VOVLO_TH n IOVLO o Protection 1.20 4 fi d Select 1.16 UNIT V 28 V 37 mΩ 100 μA 110 μA n Switch On Resistance at MAX 30.3 e Rdson MIN l TEST CONDITION ti a PARAMETER 0.42 1.24 V 20 V 0.50 V 0.1 -0.1 VIN Rising 6.66 6.80 VIN Falling 6.51 6.65 VIN Rising 9.78 9.98 VIN Falling 9.57 9.77 VIN Rising 13.7 14.0 VIN Falling 13.4 13.7 VIN Rising 5.83 5.95 VIN Falling 5.73 5.85 0.1 μA 100 μF 6.94 C AW32805 10.18 AW32809 VIN_OVLO Default OVP Trip Level V 14.3 in ic AW32812 VIN_UVLO w TSDN TSDN_HYS 6.07 AW32801 VIN Rising 2.25 2.40 VIN Falling 2.10 2.20 UVLO Trip Level V Shutdown Temperature 130 °C Shutdown Hysteresis 20 °C Temperature a Digital Logical Interface VOL ILEAK_ACOK ACOK Output Low Voltage ISINK = 1mA ACOK Leakage Current VIO = 5V, ACOK De-asserted VIH EN Input High Voltage VIL EN Input Low Voltage ILEAK_EN EN Leakage Current www.awinic.com.cn -0.5 0.4 V 0.5 μA 1.2 VEN = 5V 7 -1 V 0.5 V 10 μA Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32801/AW32805/ AW32809/AW32812 June 2018 V1.2 ELECTRICAL CHARACTERISTICS (CONTINUED) TA = -40°C to 85°C unless otherwise noted. Typical values are guaranteed for V IN = 5V, CIN = 0.1μF, IIN≤ 4.5A and TA = 25°C. TEST CONDITION MIN TYP Debounce Time From VIN > VIN_UVLO to 10% VOUT, EN Low 15 tSTAT Start-up Time From VIN > VIN_UVLO to ACOK low, EN Low 30 tON Switch Turn-on Time RL = 100Ω, CL = 22μF, VOUT from 10% VIN to 90% VIN tOFF Switch Turn-off Time RL = 100ΩCL = 0μF, VIN > VIN_OVLO to VOUT Stop Rising n OVP trip level o C tON ms 1 ms e ns 125 fi d TIMING DIAGRAM tDEB ms n tDEB VOUT UNIT ti a Timing Characteristics (Figure 6) VIN MAX l PARAMETER tDEB tON tOFF tSTART tSTART Figure 6 AW328XX Timing Diagram a w in VACOK ic VEN www.awinic.com.cn 8 Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32801/AW32805/ AW32809/AW32812 June 2018 V1.2 TYPICAL CHARACTERISTICS TABLE OF FIGURES FIG No. Normalized Rdson vs. Output Current FIGURE 7 Normalized Rdson vs. Temp. (IOUT = 1A) FIGURE 8 Normalized Rdson vs. Input Voltage (IOUT = 1A) FIGURE 9 ti a INDEX FIGURE 10 Input Supply Current vs. Supply Voltage FIGURE 11 Normalized External OVLO Set OVP Threshold vs. Temp. FIGURE 12 Normalized Debounce Time vs. Temp. FIGURE 13 e n Normalized Internal OVP Threshold vs. Temp. FIGURE 14 fi d Over-Voltage Response (AW32805) Power-up (COUT = 1μF, 100mA load) Power-up (COUT = 100μF, 100mA load) o n 108V Surge Without Device 108V Surge With Device (AW32805) l Table 1 FIGURE 15 FIGURE 16 FIGURE 17 FIGURE 18 VIN = 5V, VEN = 0V, VOVLO = 0V, CIN = 0.1μF, COUT = 1μF, and TA = 25℃ unless otherwise specified. 2.0 1.0 ic Normalized to IOUT = 1A 1.5 in Normalized Rdson 2.5 2.0 Normalized to TA = 25° C Normalized Rdson C 3.0 1.5 1.0 0.5 0.5 0.0 0.0 w 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 Output Current (A) -40 -15 10 35 60 85 Temperature (°C) Figure 8. Normalized Rdson vs. Temp. (IOUT = 1A) a Figure 7. Normalized Rdson vs. Output Current www.awinic.com.cn 9 Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32801/AW32805/ AW32809/AW32812 June 2018 V1.2 TYPICAL CHARACTERISTICS (CONTINUED) VIN = 5V, VEN = 0V, VOVLO = 0V, CIN = 0.1μF, COUT = 1μF, and TA = 25℃ unless otherwise specified. 300 1.5 1.0 0.5 2 4 6 85° C 150 100 50 0.0 0 0 8 10 12 14 16 18 20 0 Input Voltage (V) 10 15 20 25 30 fi d 1.10 Normalized to TA = 25° C 1.05 n 1.05 Figure 10. Input Supply Current vs. Supply Voltage Normalized Threshold Voltage Normalized to TA = 25° C o 1.00 0.95 -40 -15 10 C Normalized Threshold Voltage 1.10 0.90 35 60 1.00 0.95 0.90 85 -40 -15 10 35 60 85 Temperature (°C) ic Temperature (°C) in Figure 11. Normalized Internal OVP Threshold vs. Temp. Figure 12. Normalized External OVLO Set OVP Threshold vs. Temp. 2.00 8V 5V Normalized to TA = 25° C VIN 5V / div 1.50 w Normalized Debounce Time 5 Input Voltage (V) Figure 9. Normalized Rdson vs. Input Voltage (IOUT = 1A) a l 25° C 200 ti a 2.0 –40° C 250 n Normalized to VIN = 5V e Normalized Rdson 2.5 Input Supply Current (A) 3.0 VOUT 5V / div 1.00 ACOK 2V / div 0.50 IOUT 100mA / div 0.00 -40 -15 10 35 60 85 Temperature (°C) 10µs / div Figure 13. Normalized Debounce Time vs. Temp. www.awinic.com.cn 10 Figure 14. Over-Voltage Response (AW32805) Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32801/AW32805/ AW32809/AW32812 June 2018 V1.2 TYPICAL CHARACTERISTICS (CONTINUED) VIN 5V / div ti a VIN 5V / div l VIN = 5V, VEN = 0V, VOVLO = 0V, CIN = 0.1μF, COUT = 1μF, and TA = 25℃ unless otherwise specified. VOUT 5V / div VOUT 5V / div n ACOK 2V / div e IOUT 100mA / div ACOK 2V / div IOUT 500mA / div 5ms / div fi d 5ms / div Figure 16. Power-up (COUT = 100μF, 100mA load) o n Figure 15. Power-up (COUT = 1μF, 100mA load) VIN 10V / div C VOUT 10V / div IIN 20A / div ic 20V / div 20µs / div 10µs / div Figure 18. 108V Surge With Device (AW32805) a w in Figure 17. 108V Surge Without Device www.awinic.com.cn 11 Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32801/AW32805/ AW32809/AW32812 June 2018 V1.2 DETAILED FUNCTIONAL DESCRIPTION Device Operation If the AW328XX is enabled and the input voltage is between UVLO and OVP threshold, the internal charge pump begins to work after debounce time, the gate of the nFET switch will be slowly charged high till the l switch is fully on. ACOK will be driven low about 30ms after VIN valid, indicating the switch is on with a good ti a power input. If the input voltage exceeds the OVP trip level, the switch will be turned off in about 125ns. If EN is pulled high, or input voltage falls below UVLO threshold, or over-temperature happens, the switch will also be turned off. n Surge Protection fi d e The AW328XX integrates a clamp circuit to suppress input surge voltage. For surge voltages between VIN_OVLO and VIN_CLAMP, the switch will be turned off but the clamp circuit will not work. For surge voltages greater than VIN_CLAMP, the internal clamp circuit will detect surge voltage level and discharge the surge energy to ground. The device can suppress surge voltages up to 100V. Over-Voltage Protection n If the input voltage exceeds the OVP rising trip level, the switch will be turned off in about 125ns. The switch will remain off until VIN falls below the OVP falling trip level. OVP Threshold Adjustment o If OVLO pin is not grounded, and by connecting external resistor divider to OVLO pin as shown in the typical application circuit, between IN and GND, the OVP threshold can be adjusted as following: R1 +R2 VOVLO_TH R2 The adjustment range is 4V to 20V. When the OVLO pin voltage V OVLO exceeds VOVLO_SEL(0.42V typical), VOVLO is compared with the reference voltage VOVLO_TH (1.2V typical) to judge whether input supply is over-voltage. For example, if we select R1 = 51kΩ and R2 = 12.4kΩ, then the new OVP threshold calculated from the above formula is 6.14V. in ACOK Output ic C VIN_OVLO = The device features an open-drain output ACOK, it should be connected to the system I/O rail through a pull-up resistor. If the device is enabled and VIN_UVLO < VIN < VIN_OVLO, ACOK will be driven low indicating the w switch is on with a good power input. If OVP, UVLO, or OT occurs, or EN is pulled high, the switch will be turned off and ACOK will be pulled high. a USB On-The-Go (OTG) Operation If VIN = 0V and OUT is supplied by OTG voltage, the body diode of the load switch conducts current from OUT to IN and the voltage drop from OUT to IN is approximately 0.7V. When VIN > VIN_UVLO, internal charge pump begins to open the load switch after debounce time. After switch is fully on, current is supplied through switch channel and the voltage drop from OUT to IN is minimum. www.awinic.com.cn 12 Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32801/AW32805/ AW32809/AW32812 June 2018 V1.2 PCB LAYOUT CONSIDERATION To make full use of the performance of AW328XX, the guidelines below should be followed. l 1. All the peripherals should be placed as close to the device as possible. Place the input capacitor CIN on the top layer (same layer as the AW328XX) and close to IN pin, and place the output capacitor C OUT on the top layer (same layer as the AW328XX) and close to OUT pin. ti a 2. Red bold paths on figure 4 and 5 are power lines that will flow large current, please route them on PCB as straight, wide and short as possible. 3. If R1 and R2 are used, route OVLO line on PCB as short as possible to reduce parasitic capacitance. n 4. The power trace from USB connector to AW328XX may suffer from ESD event, keep other traces away from it to minimize possible EMI and ESD coupling. a w in ic C o n fi d e 5. Use rounded corners on the power trace from USB connector to AW328XX to decrease EMI coupling. www.awinic.com.cn 13 Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32801/AW32805/ AW32809/AW32812 June 2018 V1.2 TAPE AND REEL INFORMATION TAPE DIMENSIONS REEL DIMENSIONS P1 P2 P0 K0 l W ti a B0 D1 A0 Cavity e n A0:Dimension designed to accommodate the component width B0:Dimension designed to accommodate the component length K0:Dimension designed to accommodate the component thickness W:Overall width of the carrier tape P0:Pitch between successive cavity centers and sprocket hole P1:Pitch between successive cavity centers P2:Pitch between sprocket hole fi d D0 Q1 Q2 Q1 Q3 Q4 Q3 Q1 Q2 Q1 o Q2 n QUADRANT ASSIGNMENTS FOR PIN 1 ORIENTATION IN TAPE Q4 Q3 Q4 Q3 Sprocket Holes Q2 Q4 User Direction of Feed C Pocket Quadrants All Dimensions are normal Quantity Per D1:Reel Diameter Reel (mm) ic Package(mm) Pins AW328XXCSR WLCSP 1.34x1.78 12 3000 178.00 D0:Reel Width (mm) A0 (mm) B0 (mm) K0 (mm) P0 (mm) P1 (mm) P2 (mm) W (mm) Pin1 Quadrant 9.00 1.46 1.90 0.81 2.00 4.00 4.00 8.00 Q2 a w in Device www.awinic.com.cn 14 Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32801/AW32805/ AW32809/AW32812 June 2018 V1.2 PACKAGE DESCRIPTION BOTTOM VIEW e2 E Ball A1 e4 ti a e3 A l TOP VIEW B e1 D 12X Ø0.268±0.020 C Symbol A A1 A2 NOM 0.575 0.195 fi d n 2 n 1 A3 D E e1 0.340 0.040 1.340 1.780 0.400 e2 e3 e4 0.200 0.400 0.400 Tolerance ±0.055 ±0.020 ±0.025 ±0.010 ±0.025 ±0.025 NA NA NA NA Unit: mm a w in ic C o A1 A2 A3 A SIDE VIEW 3 e 4 www.awinic.com.cn 15 Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32801/AW32805/ AW32809/AW32812 June 2018 V1.2 LAND PATTERN DATA 1.200 0.200 0.400 n 0.800 ti a l 0.400 Ø0.240 Copper Pad Diameter fi d e Ø0.340 Solder Mask Opening a w in ic C o n NSMD Pad Type Unit: mm www.awinic.com.cn 16 Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32801/AW32805/ AW32809/AW32812 June 2018 V1.2 n Reflow Note Package Reflow Standard Profile o Figure 19 fi d e n ti a l REFLOW C Average ramp-up rate (217°C to peak) Spec Max. 3°C /sec 60-120sec Time to be maintained above 217°C 60-150sec Peak Temperature 250-260°C ic Time of Preheat temp. (from 150°C to 200°C) 20-40sec Ramp-down rate Max. 4°C /sec Time from 25°C to peak temp Max. 8min in Time within 5°C of actual peak temp w NOTE 1: All data are compared with the package-top temperature, measured on the package surface; a NOTE 2: AW328XX adopted the Pb-Free assembly. www.awinic.com.cn 17 Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32801/AW32805/ AW32809/AW32812 June 2018 V1.2 REVISION HISTORY Change Record V0.9 November 2016 Datasheet v0.9 released. V1.0 October 2016 Datasheet v1.0 released. l Date 1. Datasheet template changed. 2. Input voltage range modified. 3. Notice for typical application circuits added. V1.1 February 2018 ti a Version 4. VIN_PUL, IPEAK, IDIODE added in absolute maximum ratings table n 5. PCB layout consideration added. 6. Land pattern data added. 1. Typical application circuit modified. e 7. Reflow information added. V1.2 June 2018 fi d 2. Notice for typical application circuits #6 added. 3. Package information in ordering information modified. 4. Tape and reel information modified. 5. Package description modified. a w in ic C o n 6. Reflow curve and spec modified. www.awinic.com.cn 18 Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32801/AW32805/ AW32809/AW32812 June 2018 V1.2 DISCLAIMER l Information in this document is believed to be accurate and reliable. However, Shanghai AWINIC Technology Co., Ltd (AWINIC Technology) does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. ti a AWINIC Technology reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. Customers shall obtain the latest relevant information before placing orders and shall verify that such information is current and complete. This document supersedes and replaces all information supplied prior to the publication hereof. e n AWINIC Technology products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an AWINIC Technology product can reasonably be expected to result in personal injury, death or severe property or environmental damage. AWINIC Technology accepts no liability for inclusion and/or use of AWINIC Technology products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. n fi d Applications that are described herein for any of these products are for illustrative purposes only. AWINIC Technology makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. All products are sold subject to the general terms and conditions of commercial sale supplied at the time of order acknowledgement. o Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. C Reproduction of AWINIC information in AWINIC data books or data sheets is permissible only if reproduction is without alteration and is accompanied by all associated warranties, conditions, limitations, and notices. AWINIC is not responsible or liable for such altered documentation. Information of third parties may be subject to additional restrictions. a w in ic Resale of AWINIC components or services with statements different from or beyond the parameters stated by AWINIC for that component or service voids all express and any implied warranties for the associated AWINIC component or service and is an unfair and deceptive business practice. AWINIC is not responsible or liable for any such statements. www.awinic.com.cn 19 Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD
AW32801CSR
物料型号: - AW32801 - AW32805 - AW32809 - AW32812
器件简介: AW328XX系列是过压保护负载开关,具备浪涌保护功能。内部的nFET开关具有超低导通电阻(典型值为28mΩ),能够承载高达4.5A的连续电流。该系列提供默认的过压保护(OVP)阈值,并可通过外部OVLO引脚调整OVP阈值。
引脚分配: - EN:使能引脚,低电平有效 - ACOK:电源良好标志,低电平有效,开漏 - OVLO:OVP阈值调整引脚 - IN:开关输入和设备电源输入 - OUT:开关输出 - GND:设备地
参数特性: - 浪涌保护符合IEC 61000-4-5标准,可承受大于100V的浪涌电压 - 输入系统ESD保护符合IEC 61000-4-2标准,接触放电±8kV,空气间隙放电±15kV - 输入最大电压等级为29VDC - 快速关断响应时间典型值为125ns - 过温保护(OTP)和欠压锁定(UVLO) - 封装为1.34mm × 1.78mm WLCSP-12
功能详解: - 当输入电压超过OVP阈值时,开关会快速关闭以防止下游设备损坏 - ACOK引脚提供电源良好信号,当VIN在UVLO和OVP阈值之间且开关打开时,ACOK被拉低 - 设备具有过温保护功能,防止热损伤
应用信息: 适用于智能手机、平板电脑和5V至20V的充电端口。
封装信息: - 封装类型:WLCSP 1.34x1.78-12B - 湿度敏感度等级:MSL1 - 环保信息:符合RoHS和HF要求
AW32801CSR 价格&库存
很抱歉,暂时无法提供与“AW32801CSR”相匹配的价格&库存,您可以联系我们找货
